[U-Boot] [PATCH v2] board/BuR/kwb: use bootvx(...) (with bootline feature) instead go(...)
Since we don't have for sure a valid IP-setup during board_late_init(...) because it maybe allready stored in environment or not, we cannot form a proper vxWorks bootline at this place.
So we move to the way, forming the bootline just before executing/launching vxWorks. To do this we use the bootvx command instead go.
We only have to form the "othbootargs" environment variable, the rest is done pretty good by the "bootvx" commannd.
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at -- ---
Changes in v2: - form only othbootargs instead whole bootline within board-code - depends now on Bin Mengs changes belong CMD_ELF http://patchwork.ozlabs.org/patch/523289/ - adapt kwb_defconfig to the new Kconfig defaults - use bootvx ... instead go ... to launch vxWorks kernel
board/BuR/kwb/board.c | 27 +++++++++------------------ configs/kwb_defconfig | 3 +++ include/configs/kwb.h | 8 +++++--- 3 files changed, 17 insertions(+), 21 deletions(-)
diff --git a/board/BuR/kwb/board.c b/board/BuR/kwb/board.c index 039ec20..ad74ff2 100644 --- a/board/BuR/kwb/board.c +++ b/board/BuR/kwb/board.c @@ -47,10 +47,6 @@ #define RSTCTRL_FORCE_PWR_NEN 0x0404 #define RSTCTRL_CAN_STB 0x4040
-#define VXWORKS_BOOTLINE 0x80001100 -#define DEFAULT_BOOTLINE "cpsw(0,0):pme/vxWorks" -#define VXWORKS_USER "u=vxWorksFTP pw=vxWorks tn=vxtarget" - DECLARE_GLOBAL_DATA_PTR;
#if defined(CONFIG_SPL_BUILD) @@ -281,20 +277,15 @@ int board_late_init(void) } else { puts("ERROR: i2c_set_bus_speed failed! (scratchregister)\n"); } - /* setup vxworks bootline */ - char *vxworksbootline = (char *)VXWORKS_BOOTLINE; - sprintf(vxworksbootline, - "%s h=%s e=%s:%s g=%s %s o=0x%08x;0x%08x;0x%08x;0x%08x", - DEFAULT_BOOTLINE, - getenv("serverip"), - getenv("ipaddr"), getenv("netmask"), - getenv("gatewayip"), - VXWORKS_USER, - (unsigned int) gd->fb_base-0x20, - (u32)getenv_ulong("vx_memtop", 16, gd->fb_base-0x20), - (u32)getenv_ulong("vx_romfsbase", 16, 0), - (u32)getenv_ulong("vx_romfssize", 16, 0)); - + /* setup othbootargs for bootvx-command (vxWorks bootline) */ + char othbootargs[128]; + snprintf(othbootargs, sizeof(othbootargs), + "u=vxWorksFTP pw=vxWorks o=0x%08x;0x%08x;0x%08x;0x%08x", + (unsigned int) gd->fb_base-0x20, + (u32)getenv_ulong("vx_memtop", 16, gd->fb_base-0x20), + (u32)getenv_ulong("vx_romfsbase", 16, 0), + (u32)getenv_ulong("vx_romfssize", 16, 0)); + setenv("othbootargs", othbootargs); /* * reset VBAR registers to its reset location, VxWorks 6.9.3.2 does * expect that vectors are there, original u-boot moves them to _start diff --git a/configs/kwb_defconfig b/configs/kwb_defconfig index f82fcf3..0bbe0a7 100644 --- a/configs/kwb_defconfig +++ b/configs/kwb_defconfig @@ -3,6 +3,9 @@ CONFIG_TARGET_KWB=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_SYS_PROMPT="U-Boot (BuR V2.0)# " +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_GO is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/include/configs/kwb.h b/include/configs/kwb.h index 96f2e9d..45253b8 100644 --- a/include/configs/kwb.h +++ b/include/configs/kwb.h @@ -57,6 +57,8 @@ #ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ BUR_COMMON_ENV \ +"bootaddr=0x80001100\0" \ +"bootdev=cpsw(0,0)\0" \ "vx_romfsbase=0x800E0000\0" \ "vx_romfssize=0x20000\0" \ "vx_memtop=0x8FBEF000\0" \ @@ -66,7 +68,7 @@ BUR_COMMON_ENV \ "logoaddr=0x82000000\0" \ "defaultARlen=0x8000\0" \ "loaddefaultAR=mmc read ${loadaddr} 800 ${defaultARlen}\0" \ -"defaultAR=run loadromfs; run loaddefaultAR; go ${loadaddr}\0" \ +"defaultAR=run loadromfs; run loaddefaultAR; bootvx ${loadaddr}\0" \ "logo0=fatload mmc 0:1 ${logoaddr} SYSTEM/ADDON/Bootlogo/Bootlogo.bmp.gz && " \ "bmp display ${logoaddr} 0 0\0" \ "logo1=fatload mmc 0:1 ${logoaddr} SYSTEM/BASE/Bootlogo/Bootlogo.bmp.gz && " \ @@ -74,11 +76,11 @@ BUR_COMMON_ENV \ "mmcboot=echo booting AR from eMMC-flash ...; "\ "run logo0 || run logo1; " \ "run loadromfs; " \ - "fatload mmc 0:1 ${loadaddr} arimg && go ${loadaddr}; " \ + "fatload mmc 0:1 ${loadaddr} arimg && bootvx ${loadaddr}; " \ "run defaultAR;\0" \ "netboot=echo booting AR from network ...; " \ "run loadromfs; " \ - "tftp ${loadaddr} arimg && go ${loadaddr}; " \ + "tftp ${loadaddr} arimg && bootvx ${loadaddr}; " \ "puts 'networkboot failed!';\0" \ "netscript=echo running script from network (tftp) ...; " \ "tftp 0x80000000 netscript.img && source; " \
Changes in v2:
DEFAULT_BOOTLINE,
getenv("serverip"),
VXWORKS_USER,
"netscript=echo running script from network (tftp) ...; " \ "tftp 0x80000000 netscript.img && source; " \ --
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at Reviewed-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
Hannes Schmelzer
