[PATCH 1/2] board: solidrun lx2160a-cex7: new board
Add board level support code for the SolidRun LX2160A based COM-Express 7 system.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- arch/arm/Kconfig | 13 + arch/arm/cpu/armv8/Kconfig | 2 +- board/solidrun/lx2160acex7/Kconfig | 15 ++ board/solidrun/lx2160acex7/MAINTAINERS | 7 + board/solidrun/lx2160acex7/Makefile | 7 + board/solidrun/lx2160acex7/README | 43 ++++ board/solidrun/lx2160acex7/lx2160acex7.c | 287 +++++++++++++++++++++++ configs/lx2160acex7_tfa_defconfig | 59 +++++ include/configs/lx2160acex7.h | 47 ++++ 9 files changed, 479 insertions(+), 1 deletion(-) create mode 100644 board/solidrun/lx2160acex7/Kconfig create mode 100644 board/solidrun/lx2160acex7/MAINTAINERS create mode 100644 board/solidrun/lx2160acex7/Makefile create mode 100644 board/solidrun/lx2160acex7/README create mode 100644 board/solidrun/lx2160acex7/lx2160acex7.c create mode 100644 configs/lx2160acex7_tfa_defconfig create mode 100644 include/configs/lx2160acex7.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f96841c77717..008af453987f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1201,6 +1201,18 @@ config TARGET_LX2160ARDB is a high-performance development platform that supports the QorIQ LX2160A/LX2120A/LX2080A Layerscape Architecture processor.
+config TARGET_LX2160ACEX7 + bool "Support lx2160acex7" + select ARCH_LX2160A + select ARM64 + select ARMV8_MULTIENTRY + select ARCH_SUPPORT_TFABOOT + select BOARD_LATE_INIT + help + Support for SolidRun LX2160A based com express type 7 module and + platform. The lx2160acex7 high-performance platform that supports the + QorIQ LX2160A/LX2120A/LX2080A Layerscape Architecture processor. + config TARGET_LX2160AQDS bool "Support lx2160aqds" select ARCH_LX2160A @@ -1821,6 +1833,7 @@ source "board/hisilicon/poplar/Kconfig" source "board/isee/igep003x/Kconfig" source "board/phytec/pcm051/Kconfig" source "board/silica/pengwyn/Kconfig" +source "board/solidrun/lx2160acex7/Kconfig" source "board/spear/spear300/Kconfig" source "board/spear/spear310/Kconfig" source "board/spear/spear320/Kconfig" diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 92a2b58ed46d..9df6ebdc1bb4 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -109,7 +109,7 @@ config PSCI_RESET !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ !TARGET_LS1046AFRWY && \ !TARGET_LS2081ARDB && !TARGET_LX2160ARDB && \ - !TARGET_LX2160AQDS && \ + !TARGET_LX2160AQDS && !TARGET_LX2160ACEX7 && \ !ARCH_UNIPHIER && !TARGET_S32V234EVB help Most armv8 systems have PSCI support enabled in EL3, either through diff --git a/board/solidrun/lx2160acex7/Kconfig b/board/solidrun/lx2160acex7/Kconfig new file mode 100644 index 000000000000..85673846a4a5 --- /dev/null +++ b/board/solidrun/lx2160acex7/Kconfig @@ -0,0 +1,15 @@ +if TARGET_LX2160ACEX7 + +config SYS_BOARD + default "lx2160acex7" + +config SYS_VENDOR + default "solidrun" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "lx2160acex7" + +endif diff --git a/board/solidrun/lx2160acex7/MAINTAINERS b/board/solidrun/lx2160acex7/MAINTAINERS new file mode 100644 index 000000000000..6fcc3dcc938c --- /dev/null +++ b/board/solidrun/lx2160acex7/MAINTAINERS @@ -0,0 +1,7 @@ +LX2160ACEX7 BOARD +M: Baruch Siach baruch@tkos.co.il +S: Maintained +F: board/solidrun/lx2160acex7/ +F: include/configs/lx2160acex7.h +F: configs/lx2160acex7_tfa_defconfig +F: arch/arm/dts/fsl-lx2160a-cex7.dts diff --git a/board/solidrun/lx2160acex7/Makefile b/board/solidrun/lx2160acex7/Makefile new file mode 100644 index 000000000000..a2ee6fd8fde8 --- /dev/null +++ b/board/solidrun/lx2160acex7/Makefile @@ -0,0 +1,7 @@ +# +# Copyright 2019 SolidRun ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += lx2160acex7.o diff --git a/board/solidrun/lx2160acex7/README b/board/solidrun/lx2160acex7/README new file mode 100644 index 000000000000..33421073ad30 --- /dev/null +++ b/board/solidrun/lx2160acex7/README @@ -0,0 +1,43 @@ +Overview +-------- + +The SolidRun CEx7 LX2160A has COM-Express Type 7 form factor, based on NXP +LX2160A SoC. SolidRun provides two carriers, Clearfog CX, and HoneyComb. + +https://developer.solid-run.com/products/cex7-lx2160a/ + +U-Boot currentl supports boot from SD/eMMC. + +SD Boot Memory Map +------------------ + +Offsets are relative to the beginning of the SD card. + +0x001000 bl2_sd.pbl (RCW+PBI+bl2.pbl) +0x100000 fip.bin (BL31 + BL33(U-Boot)) +0x500000 U-Boot Environment +0x800000 DDR PHY Firmware (fip_ddr.bin) + +ATF (ARM Trusted Firmware) generates bl2_sd.pbl and fip.bin. + +fip_ddr.bin is available from https://github.com/NXP/ddr-phy-binary. + +DPAA2 Management Complex (MC) Firmware +-------------------------------------- + +U-Boot loads DPAA2 MC firmware and configuration files from the first SD/eMMC +partition. The following environment variables define firmware files location. + +mc_firmware_dir : directory of firmware files +mc_fw_file : MC firmware file name +dpc_file : DPC file name +dpl_file : DPL file name + +Default values for these variables are defined in +include/configs/lx2160acex7.h. + +MC firmware is available from the linux-firmware repository at dpaa2/mc/. + +mc-utils generates DPL and DPC: + + https://source.codeaurora.org/external/qoriq/qoriq-components/mc-utils diff --git a/board/solidrun/lx2160acex7/lx2160acex7.c b/board/solidrun/lx2160acex7/lx2160acex7.c new file mode 100644 index 000000000000..57dd7605b7ee --- /dev/null +++ b/board/solidrun/lx2160acex7/lx2160acex7.c @@ -0,0 +1,287 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 SolidRun ltd. + */ + +#include <common.h> +#include <dm.h> +#include <dm/platform_data/serial_pl01x.h> +#include <netdev.h> +#include <fsl_ddr.h> +#include <fsl_sec.h> +#include <asm/io.h> +#include <fdt_support.h> +#include <fsl-mc/fsl_mc.h> +#include <asm/arch/soc.h> +#include <fm_eth.h> +#include <fsl-mc/ldpaa_wriop.h> +#include <miiphy.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct pl01x_serial_platdata serial0 = { +#if CONFIG_CONS_INDEX == 0 + .base = CONFIG_SYS_SERIAL0, +#elif CONFIG_CONS_INDEX == 1 + .base = CONFIG_SYS_SERIAL1, +#else +#error "Unsupported console index value." +#endif + .type = TYPE_PL011, +}; + +U_BOOT_DEVICE(nxp_serial0) = { + .name = "serial_pl01x", + .platdata = &serial0, +}; + +static struct pl01x_serial_platdata serial1 = { + .base = CONFIG_SYS_SERIAL1, + .type = TYPE_PL011, +}; + +U_BOOT_DEVICE(nxp_serial1) = { + .name = "serial_pl01x", + .platdata = &serial1, +}; + +static void uart_get_clock(void) +{ + serial0.clock = get_serial_clock(); + serial1.clock = get_serial_clock(); +} + +int board_early_init_f(void) +{ + /* get required clock for UART IP */ + uart_get_clock(); + fsl_lsch3_early_init_f(); + + return 0; +} + +int checkboard(void) +{ + enum boot_src src = get_boot_src(); + char buf[64]; + cpu_name(buf); + printf("Board: %s-CEX7, ", buf); + + if (src == BOOT_SOURCE_SD_MMC) { + puts("SD\n"); + } + puts("SERDES1 Reference: Clock1 = 161.13MHz Clock2 = 100MHz\n"); + puts("SERDES2 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); + puts("SERDES3 Reference: Clock1 = 100MHz Clock2 = 100MHz\n"); + return 0; +} + +unsigned long get_board_sys_clk(void) +{ + return 100000000; +} + +unsigned long get_board_ddr_clk(void) +{ + return 100000000; +} + +int board_init(void) +{ +#ifdef CONFIG_FSL_CAAM + sec_init(); +#endif + + return 0; +} + +void detail_board_ddr_info(void) +{ + int i; + u64 ddr_size = 0; + + puts("\nDDR "); + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + ddr_size += gd->bd->bi_dram[i].size; + print_size(ddr_size, ""); + print_ddr_info(0); +} + +#ifdef CONFIG_FSL_MC_ENET +void fdt_fixup_board_enet(void *fdt) +{ + int offset; + + offset = fdt_path_offset(fdt, "/soc/fsl-mc"); + + if (offset < 0) + offset = fdt_path_offset(fdt, "/fsl-mc"); + + if (offset < 0) { + printf("%s: fsl-mc node not found in device tree (error %d)\n", + __func__, offset); + return; + } + + if (get_mc_boot_status() == 0 && + (is_lazy_dpl_addr_valid() || get_dpl_apply_status() == 0)) { + fdt_status_okay(fdt, offset); + } else { + fdt_status_fail(fdt, offset); + } +} + +void board_quiesce_devices(void) +{ + fsl_mc_ldpaa_exit(gd->bd); +} +#endif + +#ifdef CONFIG_OF_BOARD_SETUP + +int ft_board_setup(void *blob, bd_t *bd) +{ + int i; + bool mc_memory_bank = false; + + u64 *base; + u64 *size; + u64 mc_memory_base = 0; + u64 mc_memory_size = 0; + u16 total_memory_banks; + + ft_cpu_setup(blob, bd); + + fdt_fixup_mc_ddr(&mc_memory_base, &mc_memory_size); + + if (mc_memory_base != 0) + mc_memory_bank = true; + + total_memory_banks = CONFIG_NR_DRAM_BANKS + mc_memory_bank; + + base = calloc(total_memory_banks, sizeof(u64)); + size = calloc(total_memory_banks, sizeof(u64)); + + /* fixup DT for the three GPP DDR banks */ + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + base[i] = gd->bd->bi_dram[i].start; + size[i] = gd->bd->bi_dram[i].size; + } + +#ifdef CONFIG_RESV_RAM + /* reduce size if reserved memory is within this bank */ + if (gd->arch.resv_ram >= base[0] && + gd->arch.resv_ram < base[0] + size[0]) + size[0] = gd->arch.resv_ram - base[0]; + else if (gd->arch.resv_ram >= base[1] && + gd->arch.resv_ram < base[1] + size[1]) + size[1] = gd->arch.resv_ram - base[1]; + else if (gd->arch.resv_ram >= base[2] && + gd->arch.resv_ram < base[2] + size[2]) + size[2] = gd->arch.resv_ram - base[2]; +#endif + + if (mc_memory_base != 0) { + for (i = 0; i <= total_memory_banks; i++) { + if (base[i] == 0 && size[i] == 0) { + base[i] = mc_memory_base; + size[i] = mc_memory_size; + break; + } + } + } + + fdt_fixup_memory_banks(blob, base, size, total_memory_banks); + +#ifdef CONFIG_USB + fsl_fdt_fixup_dr_usb(blob, bd); +#endif + +#ifdef CONFIG_FSL_MC_ENET + fdt_fsl_mc_fixup_iommu_map_entry(blob); + fdt_fixup_board_enet(blob); +#endif + + return 0; +} +#endif + +int fsl_initdram(void) +{ + gd->ram_size = tfa_get_dram_size(); + + if (!gd->ram_size) + gd->ram_size = fsl_ddr_sdram_size(); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ +#if defined(CONFIG_FSL_MC_ENET) + struct memac_mdio_info mdio_info; + struct memac_mdio_controller *reg; + int i, interface; + struct mii_dev *dev; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 srds_s1; + + srds_s1 = in_le32(&gur->rcwsr[28]) & + FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS3_RCWSR28_SRDS1_PRTCL_SHIFT; + + reg = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO1; + mdio_info.regs = reg; + mdio_info.name = DEFAULT_WRIOP_MDIO1_NAME; + + /* Register the EMI 1 */ + fm_memac_mdio_init(bis, &mdio_info); + + wriop_set_phy_address(WRIOP1_DPMAC17, 0, + RGMII_PHY_ADDR1); + reg = (struct memac_mdio_controller *)CONFIG_SYS_FSL_WRIOP1_MDIO2; + switch (srds_s1) { + case 3: + case 5: + case 8: + case 13: + case 14: + case 15: + case 17: + case 20: + case 23: + wriop_set_phy_address(WRIOP1_DPMAC17, 0, + RGMII_PHY_ADDR1); + break; + + default: + printf("SerDes1 protocol 0x%x is not supported on LX2160ACEX7\n", + srds_s1); + goto next; + } + for (i = WRIOP1_DPMAC17; i <= WRIOP1_DPMAC17; i++) { + interface = wriop_get_enet_if(i); + switch (interface) { + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_RGMII_ID: + dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO1_NAME); + wriop_set_mdio(i, dev); + break; + default: + break; + } + } + +next: + cpu_eth_init(bis); +#endif /* CONFIG_FSL_MC_ENET */ + + return pci_eth_init(bis); +} + +void reset_phy(void) +{ +#if defined(CONFIG_FSL_MC_ENET) + mc_env_boot(); +#endif +} diff --git a/configs/lx2160acex7_tfa_defconfig b/configs/lx2160acex7_tfa_defconfig new file mode 100644 index 000000000000..ee44d0693ac2 --- /dev/null +++ b/configs/lx2160acex7_tfa_defconfig @@ -0,0 +1,59 @@ +CONFIG_ARM=y +CONFIG_TARGET_LX2160ACEX7=y +CONFIG_TFABOOT=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SYS_MALLOC_F_LEN=0x6000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0x500000 +CONFIG_NR_DRAM_BANKS=3 +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_AHCI=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-cex7" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SATA_CEVA=y +CONFIG_FSL_CAAM=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_GIGE=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE_GEN4=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/include/configs/lx2160acex7.h b/include/configs/lx2160acex7.h new file mode 100644 index 000000000000..5c1bd55aea3f --- /dev/null +++ b/include/configs/lx2160acex7.h @@ -0,0 +1,47 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 SolidRun ltd. + */ + +#ifndef __LX2_CEX7_H +#define __LX2_CEX7_H + +#include "lx2160a_common.h" + +/* MAC/PHY configuration */ +#if defined(CONFIG_FSL_MC_ENET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "DPMAC17@rgmii-id" + +#define RGMII_PHY_ADDR1 0x01 + +#endif + +#undef CONFIG_ID_EEPROM + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXTRA_ENV_SETTINGS \ + "mc_firmware_dir=boot\0" \ + "mc_fw_file=mc_lx2160a.itb\0" \ + "mc_fw_addr=0x80a00000\0" \ + "dpc_file=dpc-8_x_usxgmii.dtb\0" \ + "dpc_addr=0x80e00000\0" \ + "dpl_file=dpl-eth.8x10g.19.dtb\0" \ + "dpl_addr=0x80d00000\0" + +#undef SD_MC_INIT_CMD +#define SD_MC_INIT_CMD \ + "load mmc 0:1 ${mc_fw_addr} ${mc_firmware_dir}/${mc_fw_file}; " \ + "load mmc 0:1 ${dpc_addr} ${mc_firmware_dir}/${dpc_file}; " \ + "fsl_mc start mc ${mc_fw_addr} ${dpc_addr}\0" + +#undef SD_BOOTCOMMAND +#define SD_BOOTCOMMAND \ + "load mmc 0:1 ${dpl_addr} ${mc_firmware_dir}/${dpl_file}; " \ + "fsl_mc lazyapply dpl ${dpl_addr}; " \ + "run distro_bootcmd" + +#include <asm/fsl_secure_boot.h> + +#endif /* __LX2_CEX7_H */
Add DT description of the SolidRun LX2160A COM-Express system.
Signed-off-by: Baruch Siach baruch@tkos.co.il --- arch/arm/dts/Makefile | 3 ++- arch/arm/dts/fsl-lx2160a-cex7.dts | 42 +++++++++++++++++++++++++++++++ 2 files changed, 44 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/fsl-lx2160a-cex7.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d8846df1bdd9..9f25cf14e244 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -366,7 +366,8 @@ dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls1028a-rdb.dtb \ fsl-ls1028a-qds.dtb \ fsl-lx2160a-rdb.dtb \ - fsl-lx2160a-qds.dtb + fsl-lx2160a-qds.dtb \ + fsl-lx2160a-cex7.dtb dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1043a-qds-lpuart.dtb \ fsl-ls1043a-rdb.dtb \ diff --git a/arch/arm/dts/fsl-lx2160a-cex7.dts b/arch/arm/dts/fsl-lx2160a-cex7.dts new file mode 100644 index 000000000000..95dab55dbea2 --- /dev/null +++ b/arch/arm/dts/fsl-lx2160a-cex7.dts @@ -0,0 +1,42 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * SolidRun LX2160ACEX7 device tree source + * + * Author: Rabeeh Khoury rabeeh@solid-run.com + * + * Copyright 2019 SolidRun ltd. + * + */ + +/dts-v1/; + +#include "fsl-lx2160a.dtsi" + +/ { + model = "SolidRun LX2160ACEX7 COM express type 7 based board"; + compatible = "fsl,lx2160acex7", "fsl,lx2160a"; +}; + +&esdhc0 { + status = "okay"; +}; + +&esdhc1 { + status = "okay"; +}; + +&sata0 { + status = "okay"; +}; + +&sata1 { + status = "okay"; +}; + +&sata2 { + status = "okay"; +}; + +&sata3 { + status = "okay"; +};
-----Original Message----- From: Baruch Siach baruch@tkos.co.il Sent: Wednesday, December 4, 2019 6:59 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Rabeeh Khoury rabeeh@solid-run.com; Jon Nettleton jon@solid-run.com; Baruch Siach baruch@tkos.co.il Subject: [PATCH 1/2] board: solidrun lx2160a-cex7: new board
This patch has below compilation warning. Kindly fix. aarch64: + lx2160acex7_tfa +board/solidrun/lx2160acex7/lx2160acex7.c: In function 'uart_get_clock': +board/solidrun/lx2160acex7/lx2160acex7.c:50:18: error: implicit declaration of function 'get_serial_clock'; did you mean 'uart_get_clock'? [-Werror=implicit-function-declaration] + serial0.clock = get_serial_clock(); + ^~~~~~~~~~~~~~~~ + uart_get_clock +cc1: all warnings being treated as errors +make[2]: *** [board/solidrun/lx2160acex7/lx2160acex7.o] Error 1 +make[1]: *** [board/solidrun/lx2160acex7] Error 2 +make: *** [sub-make] Error 2
-Priyanka
Hi Priyanka,
- serial0.clock = get_serial_clock();
uart_get_clock
Thanks for your review.
This build error is because of commit d96c26040e901 ("common: Move clock functions into a new file"). clock_legacy.h include in now missing. I'll rebase the patches on current master and post an update.
baruch
Hi Priyanka,
uart_get_clock
It turns out that adding clock_legacy.h is not enough. The board does not boot current U-Boot master with nothing shown on the console. Do you have any idea what LX2160A related code change might have caused that?
Thanks, baruch
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Baruch Siach Sent: Thursday, February 6, 2020 5:16 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Rabeeh Khoury rabeeh@solid-run.com Subject: Re: [PATCH 1/2] board: solidrun lx2160a-cex7: new board
Hi Priyanka,
This patch has below compilation warning. Kindly fix. aarch64: + lx2160acex7_tfa +board/solidrun/lx2160acex7/lx2160acex7.c: In function 'uart_get_clock': +board/solidrun/lx2160acex7/lx2160acex7.c:50:18: error: implicit +declaration of function 'get_serial_clock'; did you mean +'uart_get_clock'? [-Werror=implicit-function-declaration]
uart_get_clock
Thanks, baruch
These might be related to UART related changes done by Vabhav for lx2160ardb. Adding Vabhav to provide the details. Meanwhile, you can also check changes via git log.
Regards Priyanka
Baruch Siach
Priyanka Jain
Priyanka Jain (OSS)
