[PATCH] spi: mxc_spi: fix warnings if CLK_ENABLED not set
Following warnings (unused variables) are raised:
drivers/spi/mxc_spi.c: In function 'mxc_spi_probe': drivers/spi/mxc_spi.c:595:14: error: unused variable 'blob' [-Werror=unused-variable] 595 | const void *blob = gd->fdt_blob; | ^~~~ drivers/spi/mxc_spi.c:594:6: error: unused variable 'node' [-Werror=unused-variable] 594 | int node = dev_of_offset(bus);
Move the variable declaration inside the code where they are used.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/spi/mxc_spi.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index f3dddbdbd7..a80c3e737d 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -591,8 +591,6 @@ void spi_release_bus(struct spi_slave *slave) static int mxc_spi_probe(struct udevice *bus) { struct mxc_spi_slave *mxcs = dev_get_plat(bus); - int node = dev_of_offset(bus); - const void *blob = gd->fdt_blob; int ret; int i;
@@ -629,6 +627,8 @@ static int mxc_spi_probe(struct udevice *bus)
mxcs->max_hz = clk_get_rate(&clk); #else + int node = dev_of_offset(bus); + const void *blob = gd->fdt_blob; mxcs->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", 20000000); #endif
Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de Tested-by: Frieder Schrempf frieder.schrempf@kontron.de
- const void *blob = gd->fdt_blob; mxcs->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", 20000000);
#endif
Frieder Schrempf
Stefano Babic
