[PATCH] mx6: peripheral clock from oscillator
In order to be able to run the I2C bus at 400Khz, the chip errata[1] recommends that the peripheral clock runs out of the 24MHz oscillator.
[1] Rev 2, 10/2019, ERR007805
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io --- arch/arm/mach-imx/mx6/soc.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/mx6/soc.c b/arch/arm/mach-imx/mx6/soc.c index e129286065..f498c93b00 100644 --- a/arch/arm/mach-imx/mx6/soc.c +++ b/arch/arm/mach-imx/mx6/soc.c @@ -26,6 +26,8 @@ #include <imx_thermal.h> #include <mmc.h>
+#define ERRATA_ERR007805 (is_mx6dl() || is_mx6solo() || is_mx6ull()) + struct scu_regs { u32 ctrl; u32 config; @@ -469,7 +471,7 @@ int arch_cpu_init(void) }
/* Set perclk to source from OSC 24MHz */ - if (is_mx6sl()) + if (is_mx6sl() || ERRATA_ERR007805) setbits_le32(&ccm->cscmr1, MXC_CCM_CSCMR1_PER_CLK_SEL_MASK);
imx_wdog_disable_powerdown(); /* Disable PDE bit of WMCR register */
- if (is_mx6sl())
all ok with this ?
2.17.1
On Mon, Oct 19, 2020 at 11:23 AM Jorge Ramirez-Ortiz jorge@foundries.io wrote:
I would suggest adding the optee related motivation that you explained earlier here in the commit log too.
Not clear what document this refers to.
if (is_mx6sl())
This gives the impression that imx6sl is not affected by the erratum, but in fact it is: https://www.nxp.com/docs/en/errata/IMX6SLCE.pdf
You could define it like this:
#define has_err007805() (is_mx6sl() || is_mx6dl() || is_mx6solo() || is_mx6ull())
sure, will do.
um, weird, I just googled "imx Rev 2, 10/2019, ERR007805" and it showed the document and a link to the errata.
how do you tipically do this otherwise? I didnt want to depend on links that migh break in the future.
if (is_mx6sl())
sounds good. will do (I didnt know the reason for the mx6sl configuring the clock was that same errata)
On Thu, Oct 22, 2020 at 6:24 PM Jorge Ramirez-Ortiz, Foundries jorge@foundries.io wrote:
The errata document is specific for a SoC.
It does not help to add "Rev 2, 10/2019, ERR007805" in the commit log as we cannot know which SoC it refers to.
Just mention the SoC errata document. For example: IMX6SLCE Rev. 5, 02/2019
perfect. now you understand my point and why I was being generic.
um, weird....the patch indicates imx6 in the name. this should be enough no?
so you need the names and versions of the errata document for each SoC being affected? that being the case, should it be a patch per family or a patch per SoC?
On Fri, Oct 23, 2020 at 3:35 AM Jorge Ramirez-Ortiz, Foundries jorge@foundries.io wrote:
imx6 is too generic. Which imx6? imx6sx, imx6sl, imx6solo, imx6dl, imx6qp, imx6q, imx6ul, imx6ull, imx6ulz?
It is OK to keep mx6 in the Subject though.
No, my point was just to replace:
[1] Rev 2, 10/2019, ERR007805 (this is not a doc reference)
by a real errata document reference. It can be imx6ull, imx6sl or any other SoC errata document like, for example:
Fabio Estevam
Jorge Ramirez-Ortiz
