[U-Boot] [UBOOT PATCH 0/2] spi: Moved spi u-bbot headers to Kconfig
This seris of patch moved spi headers to Kconfig. These are the configs: -CONFIG_SYS_ZYNQ_SPI_WAIT -CONFIG_XILINX_SPI_IDLE_VAL -CONFIG_SYS_ZYNQ_QSPI_WAIT
Vipul Kumar (2): qspi: Added Kconfig support for CONFIG_SYS_ZYNQ_QSPI_WAIT spi: Added Kconfig support for SYS_ZYNQ_SPI_WAIT and XILINX_SPI_IDLE_VAL
drivers/spi/Kconfig | 18 ++++++++++++++++++ drivers/spi/xilinx_spi.c | 4 ---- drivers/spi/zynq_qspi.c | 3 --- drivers/spi/zynq_spi.c | 3 --- 4 files changed, 18 insertions(+), 10 deletions(-)
-- 2.7.4
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
This patch added Kconfig support for CONFIG_SYS_ZYNQ_QSPI_WAIT and set it to default value 10 milliseconds.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/spi/Kconfig | 6 ++++++ drivers/spi/zynq_qspi.c | 3 --- 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 235a8c7..436e9ad 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -204,6 +204,12 @@ config ZYNQ_QSPI Zynq QSPI IP core. This IP is used to connect the flash in 4-bit qspi, 8-bit dual stacked and shared 4-bit dual parallel.
+config SYS_ZYNQ_QSPI_WAIT + int "Define Zynq QSPI wait time in ms" + default 10 + help + Define default Zynq QSPI wait time in milliseconds. + endif # if DM_SPI
config SOFT_SPI diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index 255e02f..c9241aa 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -46,9 +46,6 @@ DECLARE_GLOBAL_DATA_PTR; #define ZYNQ_QSPI_CR_SS_SHIFT 10 /* Slave select shift */
#define ZYNQ_QSPI_FIFO_DEPTH 63 -#ifndef CONFIG_SYS_ZYNQ_QSPI_WAIT -#define CONFIG_SYS_ZYNQ_QSPI_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ -#endif
/* zynq qspi register set */ struct zynq_qspi_regs { -- 2.7.4
- int "Define Zynq QSPI wait time in ms"
here I am missing depends on ZYNQ_QSPI.
M
- default 10
- help
endif # if DM_SPI
This patch added Kconfig support for CONFIG_SYS_ZYNQ_SPI_WAIT and CONFIG_XILINX_SPI_IDLE_VAL and set default value.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/spi/Kconfig | 12 ++++++++++++ drivers/spi/xilinx_spi.c | 4 ---- drivers/spi/zynq_spi.c | 3 --- 3 files changed, 12 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 436e9ad..bcb28cf 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -210,6 +210,18 @@ config SYS_ZYNQ_QSPI_WAIT help Define default Zynq QSPI wait time in milliseconds.
+config SYS_ZYNQ_SPI_WAIT + int "Define Zynq SPI wait time in ms" + default 10 + help + Define default Zynq SPI wait time in milliseconds. + +config XILINX_SPI_IDLE_VAL + hex "Define the default SPI idle value" + default 0xFFFFFFFF + help + Set the default SPI idle value. + endif # if DM_SPI
config SOFT_SPI diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index a951a77..9781ea9 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -74,10 +74,6 @@ SPICR_SPE) #define XILSPI_SPICR_DFLT_OFF (SPICR_MASTER_INHIBIT | SPICR_MANUAL_SS)
-#ifndef CONFIG_XILINX_SPI_IDLE_VAL -#define CONFIG_XILINX_SPI_IDLE_VAL GENMASK(7, 0) -#endif - #ifndef CONFIG_SYS_XILINX_SPI_LIST #define CONFIG_SYS_XILINX_SPI_LIST { CONFIG_SYS_SPI_BASE } #endif diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index ed2b8cb..be8f525 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -33,9 +33,6 @@ DECLARE_GLOBAL_DATA_PTR; #define ZYNQ_SPI_CR_SS_SHIFT 10 /* Slave select shift */
#define ZYNQ_SPI_FIFO_DEPTH 128 -#ifndef CONFIG_SYS_ZYNQ_SPI_WAIT -#define CONFIG_SYS_ZYNQ_SPI_WAIT (CONFIG_SYS_HZ/100) /* 10 ms */ -#endif
/* zynq spi register set */ struct zynq_spi_regs { -- 2.7.4
- int "Define Zynq SPI wait time in ms"
The same here - add depends on XILINX_SPI.
M
- default 10
- help
- hex "Define the default SPI idle value"
- default 0xFFFFFFFF
- help
endif # if DM_SPI
Michal Simek
Vipul Kumar
