[PATCH 0/9] spi: dm-convert and cleanups
We still have few drivers left over, drivers/spi/fsl_espi.c drivers/spi/fsl_dspi.c drivers/spi/kirkwood_spi.c drivers/spi/mxc_spi.c drivers/spi/omap3_spi.c drivers/spi/sh_qspi.c
Yes, most of them have SPL foot-print issues but will figure out the proper solutions and do necessary cleanup in coming days.
Travis-CI: https://travis-ci.org/github/openedev/u-boot-amarula/builds/691159310
Note: - fsl_espi.c will completely removed along with SPI config items on their boards, since there is no response on dm-conversion over years even though we made couple of zap patches. - We are planning to push this soon.
Any inputs? Jagan.
Jagan Teki (9): spi Drop spi_init() spi: Kconfig: Drop redundant CF_SPI definition spi: Kconfig: Move MSCC_BB_SPI, FSL_QSPI into DM_SPI ks2_evm: Switch to DM_SPL, SPL_OF_CONTROL spi: davinci: Drop non-dm code spi: mxs: Drop nondm code spi: mxs: Code cleanup spi: Zap SOFT_SPI (non-dm) doc: driver-model: Update SPI migration status
configs/k2e_evm_defconfig | 2 + configs/k2g_evm_defconfig | 2 + configs/k2hk_evm_defconfig | 2 + configs/k2l_evm_defconfig | 2 + doc/driver-model/migration.rst | 5 - drivers/spi/Kconfig | 73 ++++++------ drivers/spi/Makefile | 1 - drivers/spi/cf_spi.c | 4 - drivers/spi/davinci_spi.c | 157 ------------------------- drivers/spi/kirkwood_spi.c | 4 - drivers/spi/mxs_spi.c | 158 +++---------------------- drivers/spi/soft_spi_legacy.c | 168 --------------------------- include/configs/ti_armv7_keystone2.h | 17 --- 13 files changed, 58 insertions(+), 537 deletions(-) delete mode 100644 drivers/spi/soft_spi_legacy.c
spi_init doesn't exist anywhere in the code.
Drop it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/cf_spi.c | 4 ---- drivers/spi/kirkwood_spi.c | 4 ---- 2 files changed, 8 deletions(-)
diff --git a/drivers/spi/cf_spi.c b/drivers/spi/cf_spi.c index dd9c77281f..dec92df69b 100644 --- a/drivers/spi/cf_spi.c +++ b/drivers/spi/cf_spi.c @@ -383,10 +383,6 @@ static int coldfire_spi_probe(struct udevice *bus) return 0; }
-void spi_init(void) -{ -} - #if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) static int coldfire_dspi_ofdata_to_platdata(struct udevice *bus) { diff --git a/drivers/spi/kirkwood_spi.c b/drivers/spi/kirkwood_spi.c index 01fcf6bef5..3986b06b25 100644 --- a/drivers/spi/kirkwood_spi.c +++ b/drivers/spi/kirkwood_spi.c @@ -183,10 +183,6 @@ int spi_cs_is_valid(unsigned int bus, unsigned int cs) } #endif
-void spi_init(void) -{ -} - void spi_cs_activate(struct spi_slave *slave) { _spi_cs_activate(spireg);
Drop it.
Applied to u-boot-spi/master
CF_SPI kconfig option defined twice with DM_SPI and non DM_SPI.
Drop the non DM_SPI side kconfig definition.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/Kconfig | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index fc759e71e2..658a48e57a 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -384,12 +384,6 @@ config MSCC_BB_SPI Enable MSCC bitbang SPI driver. This driver can be used on MSCC SOCs.
-config CF_SPI - bool "ColdFire SPI driver" - help - Enable the ColdFire SPI driver. This driver can be used on - some m68k SoCs. - config FSL_ESPI bool "Freescale eSPI driver" imply SPI_FLASH_BAR
- MSCC_BB_SPI - FSL_QSPI
Both are fully dm-driven, let's move them into DM_SPI side definition.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/Kconfig | 30 +++++++++++++++--------------- 1 file changed, 15 insertions(+), 15 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 658a48e57a..59415209ee 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -141,6 +141,14 @@ config FSL_DSPI this Freescale DSPI IP core. LS102xA and Colibri VF50/VF61 platforms use this driver.
+config FSL_QSPI + bool "Freescale QSPI driver" + imply SPI_FLASH_BAR + help + Enable the Freescale Quad-SPI (QSPI) driver. This driver can be + used to access the SPI NOR flash on platforms embedding this + Freescale IP core. + config ICH_SPI bool "Intel ICH SPI driver" help @@ -167,6 +175,13 @@ config MPC8XXX_SPI help Enable support for SPI on the MPC8XXX PowerPC SoCs.
+config MSCC_BB_SPI + bool "MSCC bitbang SPI driver" + depends on SOC_VCOREIII + help + Enable MSCC bitbang SPI driver. This driver can be used on + MSCC SOCs. + config MT7621_SPI bool "MediaTek MT7621 SPI driver" depends on SOC_MT7628 @@ -377,13 +392,6 @@ config SOFT_SPI Enable Soft SPI driver. This driver is to use GPIO simulate the SPI protocol.
-config MSCC_BB_SPI - bool "MSCC bitbang SPI driver" - depends on SOC_VCOREIII - help - Enable MSCC bitbang SPI driver. This driver can be used on - MSCC SOCs. - config FSL_ESPI bool "Freescale eSPI driver" imply SPI_FLASH_BAR @@ -392,14 +400,6 @@ config FSL_ESPI access the SPI interface and SPI NOR flash on platforms embedding this Freescale eSPI IP core.
-config FSL_QSPI - bool "Freescale QSPI driver" - imply SPI_FLASH_BAR - help - Enable the Freescale Quad-SPI (QSPI) driver. This driver can be - used to access the SPI NOR flash on platforms embedding this - Freescale IP core. - config DAVINCI_SPI bool "Davinci & Keystone SPI driver" depends on ARCH_DAVINCI || ARCH_KEYSTONE
- MSCC_BB_SPI
- FSL_QSPI
This would make SPL build to DM_SPL, SPL_OF_CONTROL.
Build fine with but not tested.
Cc: Vitaly Andrianov vitalya@ti.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/k2e_evm_defconfig | 2 ++ configs/k2g_evm_defconfig | 2 ++ configs/k2hk_evm_defconfig | 2 ++ configs/k2l_evm_defconfig | 2 ++ include/configs/ti_armv7_keystone2.h | 8 -------- 5 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 644b6e5464..9f91fb9598 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -36,11 +36,13 @@ CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SPL_DM=y CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 5bc7f7f865..fb8fb250da 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="keystone-k2g-evm" CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" CONFIG_DTB_RESELECT=y @@ -41,6 +42,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y +CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_SYS_I2C_DAVINCI=y CONFIG_MISC=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index eb5916c2c6..1cd7331653 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -36,11 +36,13 @@ CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SPL_DM=y CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 71a35e3496..ae4b26b7a9 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -36,11 +36,13 @@ CONFIG_MTDIDS_DEFAULT="nand0=davinci_nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SPL_DM=y CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y CONFIG_MISC=y diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 1b014c1022..37210b2605 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -53,10 +53,6 @@
/* UART Configuration */ #define CONFIG_SYS_NS16550_MEM32 -#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_DM_SERIAL) -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE -4 -#endif #define CONFIG_SYS_NS16550_COM1 KS2_UART0_BASE #define CONFIG_SYS_NS16550_COM2 KS2_UART1_BASE
@@ -77,10 +73,6 @@ #define CONFIG_SYS_SPI2 #define CONFIG_SYS_SPI2_BASE KS2_SPI2_BASE #define CONFIG_SYS_SPI2_NUM_CS 4 -#ifdef CONFIG_SPL_BUILD -#undef CONFIG_DM_SPI -#undef CONFIG_DM_SPI_FLASH -#endif
/* Network Configuration */ #define CONFIG_BOOTP_DEFAULT
Now all boards which are using davinci SPI driver have moved to SPL_DM so drop the unneeded non-dm code.
Cc: Adam Ford aford173@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/Kconfig | 12 +- drivers/spi/davinci_spi.c | 157 --------------------------- include/configs/ti_armv7_keystone2.h | 9 -- 3 files changed, 6 insertions(+), 172 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 59415209ee..1a1f195232 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -119,6 +119,12 @@ config CF_SPI Enable the ColdFire SPI driver. This driver can be used on some m68k SoCs.
+config DAVINCI_SPI + bool "Davinci & Keystone SPI driver" + depends on ARCH_DAVINCI || ARCH_KEYSTONE + help + Enable the Davinci SPI driver + config DESIGNWARE_SPI bool "Designware SPI driver" help @@ -400,12 +406,6 @@ config FSL_ESPI access the SPI interface and SPI NOR flash on platforms embedding this Freescale eSPI IP core.
-config DAVINCI_SPI - bool "Davinci & Keystone SPI driver" - depends on ARCH_DAVINCI || ARCH_KEYSTONE - help - Enable the Davinci SPI driver - config SH_QSPI bool "Renesas Quad SPI driver" help diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index 97ac97b1a5..e1e9b45cc9 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -55,41 +55,6 @@ /* SPIDEF */ #define SPIDEF_CSDEF0_MASK BIT(0)
-#ifndef CONFIG_DM_SPI -#define SPI0_BUS 0 -#define SPI0_BASE CONFIG_SYS_SPI_BASE -/* - * Define default SPI0_NUM_CS as 1 for existing platforms that uses this - * driver. Platform can configure number of CS using CONFIG_SYS_SPI0_NUM_CS - * if more than one CS is supported and by defining CONFIG_SYS_SPI0. - */ -#ifndef CONFIG_SYS_SPI0 -#define SPI0_NUM_CS 1 -#else -#define SPI0_NUM_CS CONFIG_SYS_SPI0_NUM_CS -#endif - -/* - * define CONFIG_SYS_SPI1 when platform has spi-1 device (bus #1) and - * CONFIG_SYS_SPI1_NUM_CS defines number of CS on this bus - */ -#ifdef CONFIG_SYS_SPI1 -#define SPI1_BUS 1 -#define SPI1_NUM_CS CONFIG_SYS_SPI1_NUM_CS -#define SPI1_BASE CONFIG_SYS_SPI1_BASE -#endif - -/* - * define CONFIG_SYS_SPI2 when platform has spi-2 device (bus #2) and - * CONFIG_SYS_SPI2_NUM_CS defines number of CS on this bus - */ -#ifdef CONFIG_SYS_SPI2 -#define SPI2_BUS 2 -#define SPI2_NUM_CS CONFIG_SYS_SPI2_NUM_CS -#define SPI2_BASE CONFIG_SYS_SPI2_BASE -#endif -#endif - DECLARE_GLOBAL_DATA_PTR;
/* davinci spi register set */ @@ -122,9 +87,6 @@ struct davinci_spi_regs {
/* davinci spi slave */ struct davinci_spi_slave { -#ifndef CONFIG_DM_SPI - struct spi_slave slave; -#endif struct davinci_spi_regs *regs; unsigned int freq; /* current SPI bus frequency */ unsigned int mode; /* current SPI mode used */ @@ -346,124 +308,6 @@ out: return 0; }
-#ifndef CONFIG_DM_SPI - -static inline struct davinci_spi_slave *to_davinci_spi(struct spi_slave *slave) -{ - return container_of(slave, struct davinci_spi_slave, slave); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - int ret = 0; - - switch (bus) { - case SPI0_BUS: - if (cs < SPI0_NUM_CS) - ret = 1; - break; -#ifdef CONFIG_SYS_SPI1 - case SPI1_BUS: - if (cs < SPI1_NUM_CS) - ret = 1; - break; -#endif -#ifdef CONFIG_SYS_SPI2 - case SPI2_BUS: - if (cs < SPI2_NUM_CS) - ret = 1; - break; -#endif - default: - /* Invalid bus number. Do nothing */ - break; - } - return ret; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - /* do nothing */ -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - /* do nothing */ -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct davinci_spi_slave *ds; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - ds = spi_alloc_slave(struct davinci_spi_slave, bus, cs); - if (!ds) - return NULL; - - switch (bus) { - case SPI0_BUS: - ds->regs = (struct davinci_spi_regs *)SPI0_BASE; - break; -#ifdef CONFIG_SYS_SPI1 - case SPI1_BUS: - ds->regs = (struct davinci_spi_regs *)SPI1_BASE; - break; -#endif -#ifdef CONFIG_SYS_SPI2 - case SPI2_BUS: - ds->regs = (struct davinci_spi_regs *)SPI2_BASE; - break; -#endif - default: /* Invalid bus number */ - return NULL; - } - - ds->freq = max_hz; - ds->mode = mode; - - return &ds->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - - free(ds); -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - - ds->cur_cs = slave->cs; - - return __davinci_spi_xfer(ds, bitlen, dout, din, flags); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - -#ifdef CONFIG_SPI_HALF_DUPLEX - ds->half_duplex = true; -#else - ds->half_duplex = false; -#endif - return __davinci_spi_claim_bus(ds, ds->slave.cs); -} - -void spi_release_bus(struct spi_slave *slave) -{ - struct davinci_spi_slave *ds = to_davinci_spi(slave); - - __davinci_spi_release_bus(ds); -} - -#else static int davinci_spi_set_speed(struct udevice *bus, uint max_hz) { struct davinci_spi_slave *ds = dev_get_priv(bus); @@ -582,4 +426,3 @@ U_BOOT_DRIVER(davinci_spi) = { .ops = &davinci_spi_ops, .priv_auto_alloc_size = sizeof(struct davinci_spi_slave), }; -#endif diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 37210b2605..b632ae010d 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -64,15 +64,6 @@
/* SPI Configuration */ #define CONFIG_SYS_SPI_CLK ks_clk_get_rate(KS2_CLK1_6) -#define CONFIG_SYS_SPI0 -#define CONFIG_SYS_SPI_BASE KS2_SPI0_BASE -#define CONFIG_SYS_SPI0_NUM_CS 4 -#define CONFIG_SYS_SPI1 -#define CONFIG_SYS_SPI1_BASE KS2_SPI1_BASE -#define CONFIG_SYS_SPI1_NUM_CS 4 -#define CONFIG_SYS_SPI2 -#define CONFIG_SYS_SPI2_BASE KS2_SPI2_BASE -#define CONFIG_SYS_SPI2_NUM_CS 4
Thanks for doing that.
Tested-by: Adam Ford aford173@gmail.com #da850-evm
+config DAVINCI_SPI
help
-config DAVINCI_SPI
help
- Define default SPI0_NUM_CS as 1 for existing platforms that uses this
- driver. Platform can configure number of CS using CONFIG_SYS_SPI0_NUM_CS
- if more than one CS is supported and by defining CONFIG_SYS_SPI0.
- define CONFIG_SYS_SPI1 when platform has spi-1 device (bus #1) and
- CONFIG_SYS_SPI1_NUM_CS defines number of CS on this bus
- define CONFIG_SYS_SPI2 when platform has spi-2 device (bus #2) and
- CONFIG_SYS_SPI2_NUM_CS defines number of CS on this bus
int ret = 0;
switch (bus) {
case SPI0_BUS:
ret = 1;
break;
case SPI1_BUS:
ret = 1;
break;
case SPI2_BUS:
ret = 1;
break;
-#endif
default:
break;
return ret;
/* do nothing */
/* do nothing */
return NULL;
if (!ds)
return NULL;
switch (bus) {
case SPI0_BUS:
break;
case SPI1_BUS:
break;
case SPI2_BUS:
break;
-#endif
return NULL;
ds->freq = max_hz;
ds->mode = mode;
return &ds->slave;
free(ds);
-#else
-#endif
2.25.1
Deadline for DM migration already passed by months and no response on full dm conversation hence removed the nondm code.
Note: Look like there is no user for nondm code for this driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/Kconfig | 12 ++--- drivers/spi/mxs_spi.c | 123 ------------------------------------------ 2 files changed, 6 insertions(+), 129 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 1a1f195232..46a7b9e9d3 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -213,6 +213,12 @@ config MVEBU_A3700_SPI used to access the SPI NOR flash on platforms embedding this Marvell IP core.
+config MXS_SPI + bool "MXS SPI Driver" + help + Enable the MXS SPI controller driver. This driver can be used + on the i.MX23 and i.MX28 SoCs. + config NXP_FSPI bool "NXP FlexSPI driver" depends on SPI_MEM @@ -424,12 +430,6 @@ config MXC_SPI Enable the MXC SPI controller driver. This driver can be used on various i.MX SoCs such as i.MX31/35/51/6/7.
-config MXS_SPI - bool "MXS SPI Driver" - help - Enable the MXS SPI controller driver. This driver can be used - on the i.MX23 and i.MX28 SoCs. - config OMAP3_SPI bool "McSPI driver for OMAP" help diff --git a/drivers/spi/mxs_spi.c b/drivers/spi/mxs_spi.c index 0da4a80d71..a21419a15a 100644 --- a/drivers/spi/mxs_spi.c +++ b/drivers/spi/mxs_spi.c @@ -46,19 +46,6 @@ static void mxs_spi_end_xfer(struct mxs_ssp_regs *ssp_regs) writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_set); }
-#if !CONFIG_IS_ENABLED(DM_SPI) -struct mxs_spi_slave { - struct spi_slave slave; - uint32_t max_khz; - uint32_t mode; - struct mxs_ssp_regs *regs; -}; - -static inline struct mxs_spi_slave *to_mxs_slave(struct spi_slave *slave) -{ - return container_of(slave, struct mxs_spi_slave, slave); -} -#else #include <dm.h> #include <errno.h> #include <dt-structs.h> @@ -87,20 +74,12 @@ struct mxs_spi_priv { unsigned int clk_id; unsigned int mode; }; -#endif
-#if !CONFIG_IS_ENABLED(DM_SPI) -static int mxs_spi_xfer_pio(struct mxs_spi_slave *slave, - char *data, int length, int write, unsigned long flags) -{ - struct mxs_ssp_regs *ssp_regs = slave->regs; -#else static int mxs_spi_xfer_pio(struct mxs_spi_priv *priv, char *data, int length, int write, unsigned long flags) { struct mxs_ssp_regs *ssp_regs = priv->regs; -#endif
if (flags & SPI_XFER_BEGIN) mxs_spi_start_xfer(ssp_regs); @@ -156,17 +135,10 @@ static int mxs_spi_xfer_pio(struct mxs_spi_priv *priv, return 0; }
-#if !CONFIG_IS_ENABLED(DM_SPI) -static int mxs_spi_xfer_dma(struct mxs_spi_slave *slave, - char *data, int length, int write, unsigned long flags) -{ - struct mxs_ssp_regs *ssp_regs = slave->regs; -#else static int mxs_spi_xfer_dma(struct mxs_spi_priv *priv, char *data, int length, int write, unsigned long flags) { struct mxs_ssp_regs *ssp_regs = priv->regs; -#endif const int xfer_max_sz = 0xff00; const int desc_count = DIV_ROUND_UP(length, xfer_max_sz) + 1; struct mxs_dma_desc *dp; @@ -207,11 +179,7 @@ static int mxs_spi_xfer_dma(struct mxs_spi_priv *priv, /* Invalidate the area, so no writeback into the RAM races with DMA */ invalidate_dcache_range(dstart, dstart + cache_data_count);
-#if !CONFIG_IS_ENABLED(DM_SPI) - dmach = MXS_DMA_CHANNEL_AHB_APBH_SSP0 + slave->slave.bus; -#else dmach = priv->dma_channel; -#endif
dp = desc; while (length) { @@ -288,20 +256,12 @@ static int mxs_spi_xfer_dma(struct mxs_spi_priv *priv, return ret; }
-#if !CONFIG_IS_ENABLED(DM_SPI) -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); - struct mxs_ssp_regs *ssp_regs = mxs_slave->regs; -#else int mxs_spi_xfer(struct udevice *dev, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { struct udevice *bus = dev_get_parent(dev); struct mxs_spi_priv *priv = dev_get_priv(bus); struct mxs_ssp_regs *ssp_regs = priv->regs; -#endif int len = bitlen / 8; char dummy; int write = 0; @@ -345,95 +305,13 @@ int mxs_spi_xfer(struct udevice *dev, unsigned int bitlen,
if (!dma || (len < MXSSSP_SMALL_TRANSFER)) { writel(SSP_CTRL1_DMA_ENABLE, &ssp_regs->hw_ssp_ctrl1_clr); -#if !CONFIG_IS_ENABLED(DM_SPI) - return mxs_spi_xfer_pio(mxs_slave, data, len, write, flags); -#else return mxs_spi_xfer_pio(priv, data, len, write, flags); -#endif } else { writel(SSP_CTRL1_DMA_ENABLE, &ssp_regs->hw_ssp_ctrl1_set); -#if !CONFIG_IS_ENABLED(DM_SPI) - return mxs_spi_xfer_dma(mxs_slave, data, len, write, flags); -#else return mxs_spi_xfer_dma(priv, data, len, write, flags); -#endif - } -} - -#if !CONFIG_IS_ENABLED(DM_SPI) -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - /* MXS SPI: 4 ports and 3 chip selects maximum */ - if (!mxs_ssp_bus_id_valid(bus) || cs > 2) - return 0; - else - return 1; -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct mxs_spi_slave *mxs_slave; - - if (!spi_cs_is_valid(bus, cs)) { - printf("mxs_spi: invalid bus %d / chip select %d\n", bus, cs); - return NULL; } - - mxs_slave = spi_alloc_slave(struct mxs_spi_slave, bus, cs); - if (!mxs_slave) - return NULL; - - if (mxs_dma_init_channel(MXS_DMA_CHANNEL_AHB_APBH_SSP0 + bus)) - goto err_init; - - mxs_slave->max_khz = max_hz / 1000; - mxs_slave->mode = mode; - mxs_slave->regs = mxs_ssp_regs_by_bus(bus); - - return &mxs_slave->slave; - -err_init: - free(mxs_slave); - return NULL; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); - - free(mxs_slave); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); - struct mxs_ssp_regs *ssp_regs = mxs_slave->regs; - u32 reg = 0; - - mxs_reset_block(&ssp_regs->hw_ssp_ctrl0_reg); - - writel((slave->cs << MXS_SSP_CHIPSELECT_SHIFT) | - SSP_CTRL0_BUS_WIDTH_ONE_BIT, - &ssp_regs->hw_ssp_ctrl0); - - reg = SSP_CTRL1_SSP_MODE_SPI | SSP_CTRL1_WORD_LENGTH_EIGHT_BITS; - reg |= (mxs_slave->mode & SPI_CPOL) ? SSP_CTRL1_POLARITY : 0; - reg |= (mxs_slave->mode & SPI_CPHA) ? SSP_CTRL1_PHASE : 0; - writel(reg, &ssp_regs->hw_ssp_ctrl1); - - writel(0, &ssp_regs->hw_ssp_cmd0); - - mxs_set_ssp_busclock(slave->bus, mxs_slave->max_khz); - - return 0; }
-void spi_release_bus(struct spi_slave *slave) -{ -} - -#else /* CONFIG_DM_SPI */ /* Base numbers of i.MX2[38] clk for ssp0 IP block */ #define MXS_SSP_IMX23_CLKID_SSP0 33 #define MXS_SSP_IMX28_CLKID_SSP0 46 @@ -625,4 +503,3 @@ U_BOOT_DRIVER(mxs_spi) = { .priv_auto_alloc_size = sizeof(struct mxs_spi_priv), .probe = mxs_spi_probe, }; -#endif
Order the macros, private structures and simple functions in a proper way to have more code readability.
No functionality changed.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/mxs_spi.c | 37 ++++++++++++++++++------------------- 1 file changed, 18 insertions(+), 19 deletions(-)
diff --git a/drivers/spi/mxs_spi.c b/drivers/spi/mxs_spi.c index a21419a15a..e231e96e58 100644 --- a/drivers/spi/mxs_spi.c +++ b/drivers/spi/mxs_spi.c @@ -13,7 +13,10 @@ */
#include <common.h> +#include <dm.h> +#include <dt-structs.h> #include <cpu_func.h> +#include <errno.h> #include <log.h> #include <malloc.h> #include <memalign.h> @@ -34,21 +37,9 @@
#define MXSSSP_SMALL_TRANSFER 512
-static void mxs_spi_start_xfer(struct mxs_ssp_regs *ssp_regs) -{ - writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_set); - writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_clr); -} - -static void mxs_spi_end_xfer(struct mxs_ssp_regs *ssp_regs) -{ - writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_clr); - writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_set); -} - -#include <dm.h> -#include <errno.h> -#include <dt-structs.h> +/* Base numbers of i.MX2[38] clk for ssp0 IP block */ +#define MXS_SSP_IMX23_CLKID_SSP0 33 +#define MXS_SSP_IMX28_CLKID_SSP0 46
#ifdef CONFIG_MX28 #define dtd_fsl_imx_spi dtd_fsl_imx28_spi @@ -75,6 +66,18 @@ struct mxs_spi_priv { unsigned int mode; };
+static void mxs_spi_start_xfer(struct mxs_ssp_regs *ssp_regs) +{ + writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_set); + writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_clr); +} + +static void mxs_spi_end_xfer(struct mxs_ssp_regs *ssp_regs) +{ + writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_clr); + writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_set); +} + static int mxs_spi_xfer_pio(struct mxs_spi_priv *priv, char *data, int length, int write, unsigned long flags) @@ -312,10 +315,6 @@ int mxs_spi_xfer(struct udevice *dev, unsigned int bitlen, } }
-/* Base numbers of i.MX2[38] clk for ssp0 IP block */ -#define MXS_SSP_IMX23_CLKID_SSP0 33 -#define MXS_SSP_IMX28_CLKID_SSP0 46 - static int mxs_spi_probe(struct udevice *bus) { struct mxs_spi_platdata *plat = dev_get_platdata(bus);
- Deadline for DM migration already passed by months. - Sent couple of zap patches and - No response on dm conversation hence removed the driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/spi/Kconfig | 13 ++- drivers/spi/Makefile | 1 - drivers/spi/soft_spi_legacy.c | 168 ---------------------------------- 3 files changed, 6 insertions(+), 176 deletions(-) delete mode 100644 drivers/spi/soft_spi_legacy.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 46a7b9e9d3..09b9cb17d8 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -292,6 +292,12 @@ config SPI_SIFIVE
The SiFive SPI controller driver is found on various SiFive SoCs.
+config SOFT_SPI + bool "Soft SPI driver" + help + Enable Soft SPI driver. This driver is to use GPIO simulate + the SPI protocol. + config SPI_SUNXI bool "Allwinner SoC SPI controllers" default ARCH_SUNXI @@ -397,13 +403,6 @@ config ZYNQMP_GQSPI
endif # if DM_SPI
-config SOFT_SPI - bool "Soft SPI driver" - depends on DM_SPI || (DEPRECATED && !DM_SPI) - help - Enable Soft SPI driver. This driver is to use GPIO simulate - the SPI protocol. - config FSL_ESPI bool "Freescale eSPI driver" imply SPI_FLASH_BAR diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 342776404a..54881a7412 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -13,7 +13,6 @@ obj-$(CONFIG_TI_QSPI) += ti_qspi.o else obj-y += spi.o obj-$(CONFIG_SPI_MEM) += spi-mem-nodm.o -obj-$(CONFIG_SOFT_SPI) += soft_spi_legacy.o endif
obj-$(CONFIG_ALTERA_SPI) += altera_spi.o diff --git a/drivers/spi/soft_spi_legacy.c b/drivers/spi/soft_spi_legacy.c deleted file mode 100644 index cc5ab5f991..0000000000 --- a/drivers/spi/soft_spi_legacy.c +++ /dev/null @@ -1,168 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2002 - * Gerald Van Baren, Custom IDEAS, vanbaren@cideas.com. - * - * Influenced by code from: - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - */ - -#include <common.h> -#include <spi.h> - -#include <malloc.h> - -/*----------------------------------------------------------------------- - * Definitions - */ - -#ifdef DEBUG_SPI -#define PRINTD(fmt,args...) printf (fmt ,##args) -#else -#define PRINTD(fmt,args...) -#endif - -struct soft_spi_slave { - struct spi_slave slave; - unsigned int mode; -}; - -static inline struct soft_spi_slave *to_soft_spi(struct spi_slave *slave) -{ - return container_of(slave, struct soft_spi_slave, slave); -} - -/*=====================================================================*/ -/* Public Functions */ -/*=====================================================================*/ - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct soft_spi_slave *ss; - - if (!spi_cs_is_valid(bus, cs)) - return NULL; - - ss = spi_alloc_slave(struct soft_spi_slave, bus, cs); - if (!ss) - return NULL; - - ss->mode = mode; - - /* TODO: Use max_hz to limit the SCK rate */ - - return &ss->slave; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct soft_spi_slave *ss = to_soft_spi(slave); - - free(ss); -} - -int spi_claim_bus(struct spi_slave *slave) -{ -#ifdef CONFIG_SYS_IMMR - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; -#endif - struct soft_spi_slave *ss = to_soft_spi(slave); - - /* - * Make sure the SPI clock is in idle state as defined for - * this slave. - */ - if (ss->mode & SPI_CPOL) - SPI_SCL(1); - else - SPI_SCL(0); - - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ - /* Nothing to do */ -} - -/*----------------------------------------------------------------------- - * SPI transfer - * - * This writes "bitlen" bits out the SPI MOSI port and simultaneously clocks - * "bitlen" bits in the SPI MISO port. That's just the way SPI works. - * - * The source of the outgoing bits is the "dout" parameter and the - * destination of the input bits is the "din" parameter. Note that "dout" - * and "din" can point to the same memory location, in which case the - * input data overwrites the output data (since both are buffered by - * temporary variables, this is OK). - */ -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ -#ifdef CONFIG_SYS_IMMR - volatile immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; -#endif - struct soft_spi_slave *ss = to_soft_spi(slave); - uchar tmpdin = 0; - uchar tmpdout = 0; - const u8 *txd = dout; - u8 *rxd = din; - int cpol = ss->mode & SPI_CPOL; - int cpha = ss->mode & SPI_CPHA; - unsigned int j; - - PRINTD("spi_xfer: slave %u:%u dout %08X din %08X bitlen %u\n", - slave->bus, slave->cs, *(uint *)txd, *(uint *)rxd, bitlen); - - if (flags & SPI_XFER_BEGIN) - spi_cs_activate(slave); - - for(j = 0; j < bitlen; j++) { - /* - * Check if it is time to work on a new byte. - */ - if ((j % 8) == 0) { - if (txd) - tmpdout = *txd++; - else - tmpdout = 0; - if(j != 0) { - if (rxd) - *rxd++ = tmpdin; - } - tmpdin = 0; - } - - if (!cpha) - SPI_SCL(!cpol); - SPI_SDA(tmpdout & 0x80); - SPI_DELAY; - if (cpha) - SPI_SCL(!cpol); - else - SPI_SCL(cpol); - tmpdin <<= 1; - tmpdin |= SPI_READ; - tmpdout <<= 1; - SPI_DELAY; - if (cpha) - SPI_SCL(cpol); - } - /* - * If the number of bits isn't a multiple of 8, shift the last - * bits over to left-justify them. Then store the last byte - * read in. - */ - if (rxd) { - if ((bitlen % 8) != 0) - tmpdin <<= 8 - (bitlen % 8); - *rxd++ = tmpdin; - } - - if (flags & SPI_XFER_END) - spi_cs_deactivate(slave); - - return(0); -}
Update SPI drivers, driver model conversion status as per latest conversion and dropping nondm code.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- doc/driver-model/migration.rst | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/doc/driver-model/migration.rst b/doc/driver-model/migration.rst index d1fc0e6a78..2c0e2c7f06 100644 --- a/doc/driver-model/migration.rst +++ b/doc/driver-model/migration.rst @@ -69,20 +69,15 @@ to move the migration with in the deadline. No dm conversion yet::
drivers/spi/fsl_espi.c - drivers/spi/lpc32xx_ssp.c - drivers/spi/sh_spi.c - drivers/spi/soft_spi_legacy.c
* Status: In progress * Deadline: 2019.04
Partially converted::
- drivers/spi/davinci_spi.c drivers/spi/fsl_dspi.c drivers/spi/kirkwood_spi.c drivers/spi/mxc_spi.c - drivers/spi/mxs_spi.c drivers/spi/omap3_spi.c drivers/spi/sh_qspi.c
Adam Ford
Jagan Teki
