[U-Boot] [PATCH 1/2]Refactored common cpu specific code for 85xx/86xx into one file.
Removed same code pieces from cpu/mpc85xx/cpu.c and cpu/mpc86xx/cpu.c and moved to cpu/mpc8xxx/cpu.c(new file)
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com --- based on u-boot version 2009.06 Makefile | 2 + cpu/mpc85xx/cpu.c | 70 +--------------------------------- cpu/mpc86xx/cpu.c | 32 +--------------- cpu/mpc8xxx/Makefile | 25 ++++++++++++ cpu/mpc8xxx/cpu.c | 105 ++++++++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 134 insertions(+), 100 deletions(-) create mode 100644 cpu/mpc8xxx/Makefile create mode 100644 cpu/mpc8xxx/cpu.c
diff --git a/Makefile b/Makefile index 2a06440..35dd6b2 100644 --- a/Makefile +++ b/Makefile @@ -262,10 +262,12 @@ endif ifeq ($(CPU),mpc85xx) LIBS += drivers/qe/qe.a LIBS += cpu/mpc8xxx/ddr/libddr.a +LIBS += cpu/mpc8xxx/lib8xxx.a TAG_SUBDIRS += cpu/mpc8xxx endif ifeq ($(CPU),mpc86xx) LIBS += cpu/mpc8xxx/ddr/libddr.a +LIBS += cpu/mpc8xxx/lib8xxx.a TAG_SUBDIRS += cpu/mpc8xxx endif LIBS += drivers/rtc/librtc.a diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index 28c6119..4724f27 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -1,5 +1,5 @@ /* - * Copyright 2004,2007,2008 Freescale Semiconductor, Inc. + * Copyright 2004,2007-2009 Freescale Semiconductor, Inc. * (C) Copyright 2002, 2003 Motorola Inc. * Xianghua Xiao (X.Xiao@motorola.com) * @@ -29,58 +29,12 @@ #include <common.h> #include <watchdog.h> #include <command.h> -#include <tsec.h> -#include <netdev.h> #include <fsl_esdhc.h> #include <asm/cache.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
-struct cpu_type cpu_type_list [] = { - CPU_TYPE_ENTRY(8533, 8533), - CPU_TYPE_ENTRY(8533, 8533_E), - CPU_TYPE_ENTRY(8535, 8535), - CPU_TYPE_ENTRY(8535, 8535_E), - CPU_TYPE_ENTRY(8536, 8536), - CPU_TYPE_ENTRY(8536, 8536_E), - CPU_TYPE_ENTRY(8540, 8540), - CPU_TYPE_ENTRY(8541, 8541), - CPU_TYPE_ENTRY(8541, 8541_E), - CPU_TYPE_ENTRY(8543, 8543), - CPU_TYPE_ENTRY(8543, 8543_E), - CPU_TYPE_ENTRY(8544, 8544), - CPU_TYPE_ENTRY(8544, 8544_E), - CPU_TYPE_ENTRY(8545, 8545), - CPU_TYPE_ENTRY(8545, 8545_E), - CPU_TYPE_ENTRY(8547, 8547_E), - CPU_TYPE_ENTRY(8548, 8548), - CPU_TYPE_ENTRY(8548, 8548_E), - CPU_TYPE_ENTRY(8555, 8555), - CPU_TYPE_ENTRY(8555, 8555_E), - CPU_TYPE_ENTRY(8560, 8560), - CPU_TYPE_ENTRY(8567, 8567), - CPU_TYPE_ENTRY(8567, 8567_E), - CPU_TYPE_ENTRY(8568, 8568), - CPU_TYPE_ENTRY(8568, 8568_E), - CPU_TYPE_ENTRY(8569, 8569), - CPU_TYPE_ENTRY(8569, 8569_E), - CPU_TYPE_ENTRY(8572, 8572), - CPU_TYPE_ENTRY(8572, 8572_E), - CPU_TYPE_ENTRY(P2020, P2020), - CPU_TYPE_ENTRY(P2020, P2020_E), -}; - -struct cpu_type *identify_cpu(u32 ver) -{ - int i; - for (i = 0; i < ARRAY_SIZE(cpu_type_list); i++) - if (cpu_type_list[i].soc_ver == ver) - return &cpu_type_list[i]; - - return NULL; -} - int checkcpu (void) { sys_info_t sysinfo; @@ -329,28 +283,6 @@ void upmconfig (uint upm, uint * table, uint size) out_be32(mxmr, (in_be32(mxmr) & 0x4fffffc0) | MxMR_OP_NORM); }
- -/* - * Initializes on-chip ethernet controllers. - * to override, implement board_eth_init() - */ -int cpu_eth_init(bd_t *bis) -{ -#if defined(CONFIG_ETHER_ON_FCC) - fec_initialize(bis); -#endif - -#if defined(CONFIG_UEC_ETH) - uec_standard_init(bis); -#endif - -#if defined(CONFIG_TSEC_ENET) || defined(CONFIG_MPC85XX_FEC) - tsec_standard_init(bis); -#endif - - return 0; -} - /* * Initializes on-chip MMC controllers. * to override, implement board_mmc_init() diff --git a/cpu/mpc86xx/cpu.c b/cpu/mpc86xx/cpu.c index bc64286..32d06d2 100644 --- a/cpu/mpc86xx/cpu.c +++ b/cpu/mpc86xx/cpu.c @@ -1,5 +1,5 @@ /* - * Copyright 2006 Freescale Semiconductor + * Copyright 2006,2009 Freescale Semiconductor, Inc. * Jeff Brown * Srikanth Srinivasan (srikanth.srinivasan@freescale.com) * @@ -28,25 +28,8 @@ #include <asm/cache.h> #include <asm/mmu.h> #include <mpc86xx.h> -#include <tsec.h> #include <asm/fsl_law.h>
-struct cpu_type cpu_type_list [] = { - CPU_TYPE_ENTRY(8610, 8610), - CPU_TYPE_ENTRY(8641, 8641), - CPU_TYPE_ENTRY(8641D, 8641D), -}; - -struct cpu_type *identify_cpu(u32 ver) -{ - int i; - for (i = 0; i < ARRAY_SIZE(cpu_type_list); i++) - if (cpu_type_list[i].soc_ver == ver) - return &cpu_type_list[i]; - - return NULL; -} - /* * Default board reset function */ @@ -209,16 +192,3 @@ void mpc86xx_reginfo(void) printf("\tBR7\t0x%08X\tOR7\t0x%08X \n", in_be32(&lbc->br7), in_be32(&lbc->or7));
} - -/* - * Initializes on-chip ethernet controllers. - * to override, implement board_eth_init() - */ -int cpu_eth_init(bd_t *bis) -{ -#if defined(CONFIG_TSEC_ENET) - tsec_standard_init(bis); -#endif - - return 0; -} diff --git a/cpu/mpc8xxx/Makefile b/cpu/mpc8xxx/Makefile new file mode 100644 index 0000000..430a75f --- /dev/null +++ b/cpu/mpc8xxx/Makefile @@ -0,0 +1,25 @@ +# +# Copyright 2009 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License +# Version 2 as published by the Free Software Foundation. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib8xxx.a + +COBJS-y += cpu.o + +SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend diff --git a/cpu/mpc8xxx/cpu.c b/cpu/mpc8xxx/cpu.c new file mode 100644 index 0000000..3de3bda --- /dev/null +++ b/cpu/mpc8xxx/cpu.c @@ -0,0 +1,105 @@ +/* + * Copyright 2009 Freescale Semiconductor, Inc. + * + * This file is derived from cpu/mpc85xx/cpu.c and cpu/mpc86xx/cpu.c. + * Basically this file contains cpu specific common code for 85xx/86xx + * processors. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <command.h> +#include <tsec.h> +#include <netdev.h> +#include <asm/cache.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct cpu_type cpu_type_list [] = { +#if defined(CONFIG_MPC85xx) + CPU_TYPE_ENTRY(8533, 8533), + CPU_TYPE_ENTRY(8533, 8533_E), + CPU_TYPE_ENTRY(8535, 8535), + CPU_TYPE_ENTRY(8535, 8535_E), + CPU_TYPE_ENTRY(8536, 8536), + CPU_TYPE_ENTRY(8536, 8536_E), + CPU_TYPE_ENTRY(8540, 8540), + CPU_TYPE_ENTRY(8541, 8541), + CPU_TYPE_ENTRY(8541, 8541_E), + CPU_TYPE_ENTRY(8543, 8543), + CPU_TYPE_ENTRY(8543, 8543_E), + CPU_TYPE_ENTRY(8544, 8544), + CPU_TYPE_ENTRY(8544, 8544_E), + CPU_TYPE_ENTRY(8545, 8545), + CPU_TYPE_ENTRY(8545, 8545_E), + CPU_TYPE_ENTRY(8547, 8547_E), + CPU_TYPE_ENTRY(8548, 8548), + CPU_TYPE_ENTRY(8548, 8548_E), + CPU_TYPE_ENTRY(8555, 8555), + CPU_TYPE_ENTRY(8555, 8555_E), + CPU_TYPE_ENTRY(8560, 8560), + CPU_TYPE_ENTRY(8567, 8567), + CPU_TYPE_ENTRY(8567, 8567_E), + CPU_TYPE_ENTRY(8568, 8568), + CPU_TYPE_ENTRY(8568, 8568_E), + CPU_TYPE_ENTRY(8569, 8569), + CPU_TYPE_ENTRY(8569, 8569_E), + CPU_TYPE_ENTRY(8572, 8572), + CPU_TYPE_ENTRY(8572, 8572_E), + CPU_TYPE_ENTRY(P2020, P2020), + CPU_TYPE_ENTRY(P2020, P2020_E), +#elif defined(CONFIG_MPC86xx) + CPU_TYPE_ENTRY(8610, 8610), + CPU_TYPE_ENTRY(8641, 8641), + CPU_TYPE_ENTRY(8641D, 8641D), +#endif +}; + +struct cpu_type *identify_cpu(u32 ver) +{ + int i; + for (i = 0; i < ARRAY_SIZE(cpu_type_list); i++) + if (cpu_type_list[i].soc_ver == ver) + return &cpu_type_list[i]; + + return NULL; +} + +/* + * Initializes on-chip ethernet controllers. + * to override, implement board_eth_init() + */ +int cpu_eth_init(bd_t *bis) +{ +#if defined(CONFIG_ETHER_ON_FCC) + fec_initialize(bis); +#endif + +#if defined(CONFIG_UEC_ETH) + uec_standard_init(bis); +#endif + +#if defined(CONFIG_TSEC_ENET) || defined(CONFIG_MPC85XX_FEC) + tsec_standard_init(bis); +#endif + + return 0; +}
Hello Kumar
If the patch is fine, could you please pick it up.
Many Thanks Poonam
-----Original Message----- From: Aggrwal Poonam-B10812 Sent: Wednesday, July 29, 2009 7:33 AM To: u-boot@lists.denx.de Cc: Aggrwal Poonam-B10812 Subject: [PATCH 1/2]Refactored common cpu specific code for 85xx/86xx into one file.
- Copyright 2004,2007,2008 Freescale Semiconductor, Inc.
- Copyright 2004,2007-2009 Freescale Semiconductor, Inc.
- (C) Copyright 2002, 2003 Motorola Inc.
- Xianghua Xiao (X.Xiao@motorola.com)
- int i;
- return NULL;
- Initializes on-chip ethernet controllers.
- to override, implement board_eth_init()
-#endif
-#endif
-#endif
- Initializes on-chip MMC controllers.
- to override, implement board_mmc_init() diff --git
- Copyright 2006 Freescale Semiconductor
- Copyright 2006,2009 Freescale Semiconductor, Inc.
- Jeff Brown
- Srikanth Srinivasan (srikanth.srinivasan@freescale.com)
- int i;
- return NULL;
- Default board reset function
-#endif
-} diff --git a/cpu/mpc8xxx/Makefile b/cpu/mpc8xxx/Makefile new file mode 100644 index 0000000..430a75f --- /dev/null +++ b/cpu/mpc8xxx/Makefile @@ -0,0 +1,25 @@ +# +# Copyright 2009 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or # +modify it under the terms of the GNU General Public License # Version 2 +as published by the Free Software Foundation. +#
+COBJS-y += cpu.o
+$(LIB): $(OBJS)
- $(AR) $(ARFLAGS) $@ $(OBJS)
- Copyright 2009 Freescale Semiconductor, Inc.
- This file is derived from cpu/mpc85xx/cpu.c and cpu/mpc86xx/cpu.c.
- Basically this file contains cpu specific common code for
85xx/86xx
- processors.
- project.
- MA 02111-1307 USA
+#endif +};
- int i;
- return NULL;
- to override, implement board_eth_init() */ int cpu_eth_init(bd_t
+*bis) { #if defined(CONFIG_ETHER_ON_FCC)
1.5.6.5
Dear Poonam Aggrwal,
In message 1248832972-515-1-git-send-email-poonam.aggrwal@freescale.com you wrote:
- Basically this file contains cpu specific common code for 85xx/86xx
- processors.
- project.
- MA 02111-1307 USA
Please sort the Pxxxx entries after the 8xxxx ones.
- int i;
Please use braces for multiline statements like here.
Pxxxx are really 85xx class parts (we use the cpu/mpc85xx) directory for them. We can swap 86xx and (85xx/Pxxxx) if we want the Pxxxx's at the end.
- k
Dear Kumar Gala,
In message 6ACE562A-DEB9-4E6C-B357-1A0D208B0E42@kernel.crashing.org you wrote:
I see - ok. Thanks.
Kumar Gala
Poonam Aggrwal
