Problem on imx: add rom api support on imx8mn
Hi all
I have some problems that I have understood and fixed but I can not explain. Right now I have on imx8mn that can boot from boot0 or boot1 partition after remove a condition in the is_boot_from_stream_device
This is a boot from mmcblk0boot0 with some debug
U-Boot SPL 2020.04-5.4.70-2.3.2+gf3bcbdfc62 (Jul 03 2021 - 17:00:27 +0000) power_bd71837_init DDRINFO: start DRAM init DDRINFO: DRAM rate 1600MTS DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done Normal Boot Trying to boot from BOOTROM ROM API interface 2 from boot 131073
Interface is 2 MMC and boot is 131073 and according to this
static int is_boot_from_stream_device(u32 boot) +{ + u32 interface; + + interface = boot >> 16; + if (interface >= BT_DEV_TYPE_USB) + return 1; + + if (interface == BT_DEV_TYPE_MMC && (boot & 1)) + return 1; + + return 0; +}
means a stream interface but it does not boot.
Boot from boot1 give 131072 that is boot1 this let device boot because is_boot_from_stream_device is 0 and romapi use spl_romapi_load_image_seekable
Remove boot & 1 condition let me boot from mmcblk0boot0 and mmcblk0boot1 without any problem
mmc partconf 0 EXT_CSD[179], PARTITION_CONFIG: BOOT_ACK: 0x0 BOOT_PARTITION_ENABLE: 0x1 PARTITION_ACCESS: 0x0
and the board was fused already.
Any idea why?
Michael
On 2021/7/4 1:24, Michael Nazzareno Trimarchi wrote:
Hi all
u32 interface;
return 1;
return 1;
Who gives 131073? Boot from boot1, you mean emmc boot partition0?
Have you enabled emmc fastboot in fuse?
boot & 1 is checking emmc fastboot. emmc fastboot mode is actually stream device. If fastboot mode enabled, you need burn your flash.bin into offset 0. Not 32KB offset.
Regards, Peng.
Any idea why?
Michael
Hi Peng
Hi all
u32 interface;
return 1;
return 1;
The offset is correct and the spl is starting on boot0 but then it should load the rest from boot0 block and not from usb. And why in case of boot1 the 1 is not present. I flash both on offset 0. Anyway I sent a patch
Michael
Regards, Peng.
Any idea why?
Michael
On 2021/7/8 17:15, Michael Nazzareno Trimarchi wrote:
Hi Peng
Hi all
u32 interface;
return 1;
return 1;
I suspect you have eMMC fastboot enabled for boot0, but not for boot1.
Regards, Peng.
Michael
Regards, Peng.
Any idea why?
Michael
Hi
Hi Peng
Hi all
u32 interface;
return 1;
return 1;
I think that was fuse this way
# Alternative Boot ("Fast boot") # =>[BT_FUSE_SEL | eMMC boot | USDHC1 EMMC] FB: ucmd fuse prog -y 1 3 0x10002A00 # =>[Fast boot | 8-bit DDR | MMC High speed | 1.8V | eMMC reset enable] FB: ucmd fuse prog -y 2 1 0x000000E7 # =>[Fast Boot Ack enable] FB: ucmd fuse prog -y 2 2 0x00000001 # boot_bus_width: 2 (8-bit), reset_boot_bus_width: 0, boot_mode: 2 (use dual data rate (DDR)) FB: ucmd mmc bootbus 0 2 0 2 # boot_ack: 1, boot_partition: 1 (Boot partition 1), 7 (User area), partition_access: No access to boot partition (default) FB: ucmd mmc partconf 0 1 1 0
How is it supposed to work in this case?
Michael
Regards, Peng.
Michael
Regards, Peng.
Any idea why?
Michael
Hi Michael,
-----Original Message----- From: Michael Nazzareno Trimarchi michael@amarulasolutions.com Sent: Thursday, July 15, 2021 2:52 PM To: Peng Fan (OSS) peng.fan@oss.nxp.com Cc: Peng Fan peng.fan@nxp.com; U-Boot-Denx u-boot@lists.denx.de; Stefano Babic sbabic@denx.de; Ye Li ye.li@nxp.com; Fabio Estevam festevam@gmail.com; Jagan Teki jagan@amarulasolutions.com Subject: [EXT] Re: Problem on imx: add rom api support on imx8mn
Caution: EXT Email
Hi
Hi Peng
Hi all
u32 interface;
return 1;
return 1;
Above settings use the boot0 for fastboot. When you switch to boot1 for fastboot, did you change the partconf setting to "mmc partconf 0 1 2 0"?
If the ROM boots from emmc fastboot, it will set the bit0 to 1 to indicate the fastboot. Since at this time, ROM does not leave fastboot (just stop the clock), we should continue the stream mode read in SPL for FIT image load. So below checking is correct. If you continue the stream mode read, what is the failure do you meet? The codes will read max 640KB data from ROM to search to FIT header. Can it get the header or not?
if (interface == BT_DEV_TYPE_MMC && (boot & 1)) return 1;
Best regards, Ye Li
Michael
Regards, Peng.
Michael
Regards, Peng.
Any idea why?
Michael
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.ama rulasolutions.com%2F&data=04%7C01%7Cye.li%40nxp.com%7C1e6a78bc a6d441c39f8608d9475d2495%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0% 7C0%7C637619287640324977%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wL jAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&s data=xIsVMyj9Qp1vciZnjJJK1wAT7A8fLdNRAs9pp4tll%2F0%3D&reserved= 0
Hi
On Thu, Jul 15, 2021 at 9:56 AM Ye Li ye.li@nxp.com wrote:
Hi Michael,
Caution: EXT Email
Hi
Hi Peng
Hi all
u32 interface;
return 1;
return 1;
I don't need to use fastboot. I mean the idea is if I boot from block0 I want to continue there. BOOTROM fill the mode but then it should be able to not fail. Am I right?
It does not find the header, in this case and it's not problem of size of 640Kb (I have extend it). My impression is that is loading from mmcblk0 and not boot partition
Michael
Best regards, Ye Li
Michael
Regards, Peng.
Michael
Regards, Peng.
Any idea why?
Michael
Hi Ye
On Thu, Jul 15, 2021 at 10:19 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi
Hi Michael,
Caution: EXT Email
Hi
Hi Peng
wrote:
On 2021/7/4 1:24, Michael Nazzareno Trimarchi wrote: > Hi all > > I have some problems that I have understood and fixed but I can > not explain. Right now I have on imx8mn that can boot from boot0 > or boot1 partition after remove a condition in the > is_boot_from_stream_device > > This is a boot from mmcblk0boot0 with some debug > > U-Boot SPL 2020.04-5.4.70-2.3.2+gf3bcbdfc62 (Jul 03 2021 - > 17:00:27 +0000) power_bd71837_init > DDRINFO: start DRAM init > DDRINFO: DRAM rate 1600MTS > DDRINFO:ddrphy calibration done > DDRINFO: ddrmix config done > Normal Boot > Trying to boot from BOOTROM > ROM API interface 2 from boot 131073 > > Interface is 2 MMC and boot is 131073 and according to this > > static int is_boot_from_stream_device(u32 boot) > +{ > + u32 interface; > + > + interface = boot >> 16; > + if (interface >= BT_DEV_TYPE_USB) > + return 1; > + > + if (interface == BT_DEV_TYPE_MMC && (boot & 1)) > + return 1; > + > + return 0; > +} > > means a stream interface but it does not boot. > > Boot from boot1 give 131072 that is boot1 this let device boot > because
> is_boot_from_stream_device is 0 and romapi use > spl_romapi_load_image_seekable > > Remove boot & 1 condition let me boot from mmcblk0boot0 and > mmcblk0boot1 without any problem
U-Boot SPL 2020.04-00190-g4bad07fb61-dirty (Aug 06 2021 - 11:38:18 +0200) spl_init power_bd71837_init DDRINFO: start DRAM init DDRINFO: DRAM rate 1600MTS DDRINFO:ddrphy calibration done DDRINFO: ddrmix config done
SPL: board_init_r()
Normal Boot Trying to boot from BOOTROM ROM API interface 2 from boot 131073 Can't found uboot FIT image in 640K range SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
This is my error but if I continue stream mode but it works in seakble mode. 2 is the MMC and boot mode is 131073
Michael
Michael
Best regards, Ye Li
Michael
Regards, Peng.
Michael
Regards, Peng.
> > mmc partconf 0 > EXT_CSD[179], PARTITION_CONFIG: > BOOT_ACK: 0x0 > BOOT_PARTITION_ENABLE: 0x1 > PARTITION_ACCESS: 0x0 > > and the board was fused already. > > Any idea why? > > Michael >
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
On 2021/8/6 17:56, Michael Nazzareno Trimarchi wrote:
Hi Ye
Hi
Hi Michael,
Caution: EXT Email
Hi
Hi Peng
wrote:
> > On 2021/7/4 1:24, Michael Nazzareno Trimarchi wrote: >> Hi all >> >> I have some problems that I have understood and fixed but I can >> not explain. Right now I have on imx8mn that can boot from boot0 >> or boot1 partition after remove a condition in the >> is_boot_from_stream_device >> >> This is a boot from mmcblk0boot0 with some debug >> >> U-Boot SPL 2020.04-5.4.70-2.3.2+gf3bcbdfc62 (Jul 03 2021 - >> 17:00:27 +0000) power_bd71837_init >> DDRINFO: start DRAM init >> DDRINFO: DRAM rate 1600MTS >> DDRINFO:ddrphy calibration done >> DDRINFO: ddrmix config done >> Normal Boot >> Trying to boot from BOOTROM >> ROM API interface 2 from boot 131073 >> >> Interface is 2 MMC and boot is 131073 and according to this >> >> static int is_boot_from_stream_device(u32 boot) >> +{ >> + u32 interface; >> + >> + interface = boot >> 16; >> + if (interface >= BT_DEV_TYPE_USB) >> + return 1; >> + >> + if (interface == BT_DEV_TYPE_MMC && (boot & 1)) >> + return 1; >> + >> + return 0; >> +} >> >> means a stream interface but it does not boot. >> >> Boot from boot1 give 131072 that is boot1 this let device boot >> because > > Who gives 131073? Boot from boot1, you mean emmc boot partition0? > >> is_boot_from_stream_device is 0 and romapi use >> spl_romapi_load_image_seekable >> >> Remove boot & 1 condition let me boot from mmcblk0boot0 and >> mmcblk0boot1 without any problem > > Have you enabled emmc fastboot in fuse? > > boot & 1 is checking emmc fastboot. emmc fastboot mode is actually > stream device. If fastboot mode enabled, you need burn your > flash.bin into offset 0. Not 32KB offset.
SPL: board_init_r()
stream mode is only effective when usb download and eMMC fastboot.
Note eMMC fastboot, needs both set eMMC chip and SoC fuse(or boot switch)
Otherwise, there is bug somewhere.
Regards, Peng.
Michael
Michael
Best regards, Ye Li
Michael
Regards, Peng.
Michael
> > Regards, > Peng. > >> >> mmc partconf 0 >> EXT_CSD[179], PARTITION_CONFIG: >> BOOT_ACK: 0x0 >> BOOT_PARTITION_ENABLE: 0x1 >> PARTITION_ACCESS: 0x0 >> >> and the board was fused already. >> >> Any idea why? >> >> Michael >>
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.ama%2F&... rulasolutions.com%2F&data=04%7C01%7Cye.li%40nxp.com%7C1e6a78bc a6d441c39f8608d9475d2495%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0% 7C0%7C637619287640324977%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wL jAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&s data=xIsVMyj9Qp1vciZnjJJK1wAT7A8fLdNRAs9pp4tll%2F0%3D&reserved= 0
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.amarula...
Peng Fan (OSS)
Ye Li
