[PATCH] board: amlogic: odroid: add runtime detection of the N2/N2+/C4/HC4 variants
Use the ADC channel 1 to check the hardware revision of the board and detect the N2 vs. N2+ and the C4 vs. HC4 variants. Each of them use different dtb file, so adjust fdtfile environment variable to the detected variant.
The ADC min/max values for each variant are taken from the vendor code, adjusted to the 12-bit ADC driver operation mode (vendor code use 10-bit mode).
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- The relevant vendor's code is here: https://github.com/hardkernel/u-boot/blob/odroidg12-v2015.01/board/hardkerne... --- arch/arm/dts/meson-g12b-odroid-n2-u-boot.dtsi | 6 ++ arch/arm/dts/meson-sm1-odroid-c4-u-boot.dtsi | 6 ++ board/amlogic/odroid-n2/odroid-n2.c | 80 +++++++++++++++++++ configs/odroid-c4_defconfig | 4 +- configs/odroid-n2_defconfig | 4 +- 5 files changed, 98 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/meson-g12b-odroid-n2-u-boot.dtsi b/arch/arm/dts/meson-g12b-odroid-n2-u-boot.dtsi index 236f2468dc..a92f9e9ff1 100644 --- a/arch/arm/dts/meson-g12b-odroid-n2-u-boot.dtsi +++ b/arch/arm/dts/meson-g12b-odroid-n2-u-boot.dtsi @@ -5,3 +5,9 @@ */
#include "meson-g12-common-u-boot.dtsi" + +/* SARADC is needed for proper board variant detection */ +&saradc { + status = "okay"; + vref-supply = <&vddao_1v8>; +}; diff --git a/arch/arm/dts/meson-sm1-odroid-c4-u-boot.dtsi b/arch/arm/dts/meson-sm1-odroid-c4-u-boot.dtsi index fbcc8287c5..963bf96b25 100644 --- a/arch/arm/dts/meson-sm1-odroid-c4-u-boot.dtsi +++ b/arch/arm/dts/meson-sm1-odroid-c4-u-boot.dtsi @@ -12,6 +12,12 @@ snps,reset-active-low; };
+/* SARADC is needed for proper board variant detection */ +&saradc { + status = "okay"; + vref-supply = <&vddao_1v8>; +}; + &tflash_vdd { gpio = <&gpio_ao GPIOAO_3 GPIO_OPEN_DRAIN>; }; diff --git a/board/amlogic/odroid-n2/odroid-n2.c b/board/amlogic/odroid-n2/odroid-n2.c index d9955433bf..2eb7fa93be 100644 --- a/board/amlogic/odroid-n2/odroid-n2.c +++ b/board/amlogic/odroid-n2/odroid-n2.c @@ -6,6 +6,7 @@
#include <common.h> #include <dm.h> +#include <adc.h> #include <env.h> #include <init.h> #include <net.h> @@ -19,6 +20,11 @@ #define EFUSE_MAC_SIZE 12 #define MAC_ADDR_LEN 6
+#define ODROID_HW_VS_ADC_CHANNEL 1 + +#define MESON_SOC_ID_G12B 0x29 +#define MESON_SOC_ID_SM1 0x2b + int mmc_get_env_dev(void) { if (meson_get_boot_device() == BOOT_DEVICE_EMMC) @@ -26,6 +32,79 @@ int mmc_get_env_dev(void) return 0; }
+/* Variant detection is based on the ADC RAW values for the channel #1 */ +static struct meson_odroid_boards { + unsigned int soc_id; + unsigned int adc_min; + unsigned int adc_max; + char *variant; +} boards[] = { + /* OdroidN2 rev 2018,7,23 */ + { MESON_SOC_ID_G12B, 80 * 4, 90 * 4, "n2" }, + /* OdroidN2 rev 2018,12,6 */ + { MESON_SOC_ID_G12B, 160 * 4, 170 * 4, "n2" }, + /* OdroidN2 rev 2019,1,17 */ + { MESON_SOC_ID_G12B, 245 * 4, 255 * 4, "n2" }, + /* OdroidN2 rev 2019,2,7 */ + { MESON_SOC_ID_G12B, 330 * 4, 350 * 4, "n2" }, + /* OdroidN2plus rev 2019,11,20 */ + { MESON_SOC_ID_G12B, 410 * 4, 430 * 4, "n2_plus" }, + /* OdroidC4 rev 2020,01,29 */ + { MESON_SOC_ID_SM1, 80 * 4, 100 * 4, "c4" }, + /* OdroidHC4 rev 2019,12,10 */ + { MESON_SOC_ID_SM1, 300 * 4, 320 * 4, "hc4" }, + /* OdroidC4 rev 2019,11,29 */ + { MESON_SOC_ID_SM1, 335 * 4, 345 * 4, "c4" }, + /* OdroidHC4 rev 2020,8,7 */ + { MESON_SOC_ID_SM1, 590 * 4, 610 * 4, "hc4" }, +}; + +static void odroid_set_fdtfile(char *soc, char *variant) +{ + char s[128]; + + snprintf(s, sizeof(s), "amlogic/meson-%s-odroid-%s.dtb", soc, variant); + env_set("fdtfile", s); +} + +static int odroid_detect_variant(void) +{ + char *variant = "", *soc = ""; + unsigned int adcval = 0; + int ret, i, soc_id = 0; + + if (of_machine_is_compatible("amlogic,sm1")) { + soc_id = MESON_SOC_ID_SM1; + soc = "sm1"; + } else if (of_machine_is_compatible("amlogic,g12b")) { + soc_id = MESON_SOC_ID_G12B; + soc = "g12b"; + } else { + return -1; + } + + ret = adc_channel_single_shot("adc@9000", ODROID_HW_VS_ADC_CHANNEL, + &adcval); + if (ret) + return ret; + + for (i = 0 ; i < ARRAY_SIZE(boards) ; ++i) { + if (soc_id == boards[i].soc_id && + adcval >= boards[i].adc_min && + adcval < boards[i].adc_max) { + variant = boards[i].variant; + break; + } + } + + printf("Board variant: %s\n", variant); + env_set("variant", variant); + + odroid_set_fdtfile(soc, variant); + + return 0; +} + int misc_init_r(void) { u8 mac_addr[MAC_ADDR_LEN]; @@ -58,5 +137,6 @@ int misc_init_r(void) meson_generate_serial_ethaddr(); }
+ odroid_detect_variant(); return 0; } diff --git a/configs/odroid-c4_defconfig b/configs/odroid-c4_defconfig index 367d22db0b..8a9b8b0c02 100644 --- a/configs/odroid-c4_defconfig +++ b/configs/odroid-c4_defconfig @@ -8,7 +8,7 @@ CONFIG_DM_GPIO=y CONFIG_MESON_G12A=y CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_IDENT_STRING=" odroid-c4" +CONFIG_IDENT_STRING=" odroid-c4/hc4" CONFIG_DEFAULT_DEVICE_TREE="meson-sm1-odroid-c4" CONFIG_DEBUG_UART=y CONFIG_OF_BOARD_SETUP=y @@ -26,6 +26,8 @@ CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_ADC=y +CONFIG_SARADC_MESON=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y CONFIG_PHY_REALTEK=y diff --git a/configs/odroid-n2_defconfig b/configs/odroid-n2_defconfig index 76c60ab032..b82bd78f2d 100644 --- a/configs/odroid-n2_defconfig +++ b/configs/odroid-n2_defconfig @@ -8,7 +8,7 @@ CONFIG_DM_GPIO=y CONFIG_MESON_G12A=y CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_IDENT_STRING=" odroid-n2" +CONFIG_IDENT_STRING=" odroid-n2/n2_plus" CONFIG_DEFAULT_DEVICE_TREE="meson-g12b-odroid-n2" CONFIG_DEBUG_UART=y CONFIG_OF_BOARD_SETUP=y @@ -26,6 +26,8 @@ CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_ADC=y +CONFIG_SARADC_MESON=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y CONFIG_PHY_REALTEK=y
- status = "okay";
- vref-supply = <&vddao_1v8>;
- status = "okay";
- unsigned int soc_id;
- unsigned int adc_min;
- unsigned int adc_max;
- char *variant;
+} boards[] = {
- /* OdroidN2 rev 2018,7,23 */
- { MESON_SOC_ID_G12B, 80 * 4, 90 * 4, "n2" },
- /* OdroidN2 rev 2018,12,6 */
- { MESON_SOC_ID_G12B, 160 * 4, 170 * 4, "n2" },
- /* OdroidN2 rev 2019,1,17 */
- { MESON_SOC_ID_G12B, 245 * 4, 255 * 4, "n2" },
- /* OdroidN2 rev 2019,2,7 */
- { MESON_SOC_ID_G12B, 330 * 4, 350 * 4, "n2" },
- /* OdroidN2plus rev 2019,11,20 */
- { MESON_SOC_ID_G12B, 410 * 4, 430 * 4, "n2_plus" },
- /* OdroidC4 rev 2020,01,29 */
- { MESON_SOC_ID_SM1, 80 * 4, 100 * 4, "c4" },
- /* OdroidHC4 rev 2019,12,10 */
- { MESON_SOC_ID_SM1, 300 * 4, 320 * 4, "hc4" },
- /* OdroidC4 rev 2019,11,29 */
- { MESON_SOC_ID_SM1, 335 * 4, 345 * 4, "c4" },
- /* OdroidHC4 rev 2020,8,7 */
- { MESON_SOC_ID_SM1, 590 * 4, 610 * 4, "hc4" },
- char s[128];
- snprintf(s, sizeof(s), "amlogic/meson-%s-odroid-%s.dtb", soc, variant);
- env_set("fdtfile", s);
- char *variant = "", *soc = "";
- unsigned int adcval = 0;
- int ret, i, soc_id = 0;
- if (of_machine_is_compatible("amlogic,sm1")) {
soc = "sm1";
- } else if (of_machine_is_compatible("amlogic,g12b")) {
soc = "g12b";
- } else {
return -1;
- ret = adc_channel_single_shot("adc@9000", ODROID_HW_VS_ADC_CHANNEL,
&adcval);
- if (ret)
return ret;
- for (i = 0 ; i < ARRAY_SIZE(boards) ; ++i) {
break;
- printf("Board variant: %s\n", variant);
- env_set("variant", variant);
- odroid_set_fdtfile(soc, variant);
- odroid_detect_variant(); return 0;
Nice code ! It' super clean, for me it's ok
I let other people review it and I'll push it in a few days if everyone is happy.
Neil
The relevant vendor's code is here: https://protect2.fireeye.com/v1/url?k=482d7422-17b64cfb-482cff6d-0cc47a3356b...
- status = "okay";
- status = "okay";
- char *variant;
+} boards[] = {
- char s[128];
soc = "sm1";
soc = "g12b";
- } else {
return -1;
&adcval);
- if (ret)
return ret;
break;
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Neil
- status = "okay";
- status = "okay";
- char *variant;
+} boards[] = {
- char s[128];
soc = "sm1";
soc = "g12b";
- } else {
return -1;
&adcval);
- if (ret)
return ret;
break;
Applied to u-boot-amlogic
Jaehoon Chung
Marek Szyprowski
Neil Armstrong
