[U-Boot] [PATCH 0/1] fdt: Fix handling of paths with options in them
Hi all,
Here is a small but important fdt parsing fix. See the patch / commit message for details.
I'm wondering how to best take this upstream. This is a dependency for the sunxi dm work I'm doing so I will happily take this upstream (once reviewed) through the sunxi tree.
Regards,
Hans
After syncing the sunxi dts files with the upstream kernel dm/fdt sunxi builds would no longer boot.
The problem is that stdout-path is now set like this in the upstream dts files: stdout-path = "serial0:115200n8". The use of options in of-paths, either after an alias name, or after a full path, e.g. stdout-path = "/soc@01c00000/serial@01c28000:115200", is standard of usage, but something which the u-boot dts code so far did not handle.
This commit fixes this, adding support for both path formats.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/dts/sun7i-a20-pcduino3.dts | 2 +- lib/libfdt/fdt_ro.c | 25 ++++++++++++++++++++++--- 2 files changed, 23 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/sun7i-a20-pcduino3.dts b/arch/arm/dts/sun7i-a20-pcduino3.dts index cd05267..624abf2 100644 --- a/arch/arm/dts/sun7i-a20-pcduino3.dts +++ b/arch/arm/dts/sun7i-a20-pcduino3.dts @@ -64,7 +64,7 @@ };
chosen { - stdout-path = "serial0:115200n8"; + stdout-path = "/soc@01c00000/serial@01c28000:115200"; };
leds { diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index 03733e5..44fc0aa 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -113,6 +113,25 @@ int fdt_subnode_offset(const void *fdt, int parentoffset, return fdt_subnode_offset_namelen(fdt, parentoffset, name, strlen(name)); }
+/* + * Find the next of path seperator, note we need to search for both '/' and ':' + * and then take the first one so that we do the rigth thing for e.g. + * "foo/bar:option" and "bar:option/otheroption", both of which happen, so + * first searching for either ':' or '/' does not work. + */ +static const char *fdt_path_next_seperator(const char *path) +{ + const char *sep1 = strchr(path, '/'); + const char *sep2 = strchr(path, ':'); + + if (sep1 && sep2) + return (sep1 < sep2) ? sep1 : sep2; + else if (sep1) + return sep1; + else + return sep2; +} + int fdt_path_offset(const void *fdt, const char *path) { const char *end = path + strlen(path); @@ -123,7 +142,7 @@ int fdt_path_offset(const void *fdt, const char *path)
/* see if we have an alias */ if (*path != '/') { - const char *q = strchr(path, '/'); + const char *q = fdt_path_next_seperator(path);
if (!q) q = end; @@ -141,9 +160,9 @@ int fdt_path_offset(const void *fdt, const char *path)
while (*p == '/') p++; - if (! *p) + if (*p == '\0' || *p == ':') return offset; - q = strchr(p, '/'); + q = fdt_path_next_seperator(p); if (! q) q = end;
chosen {
leds {
Ugh, this does not belong in here, this was just here to test the second code path of fdt_path_offset handles paths with options correctly.
Will drop from my personal tree.
Regards,
Hans
- Find the next of path seperator, note we need to search for both '/' and ':'
- and then take the first one so that we do the rigth thing for e.g.
- "foo/bar:option" and "bar:option/otheroption", both of which happen, so
- first searching for either ':' or '/' does not work.
- const char *sep1 = strchr(path, '/');
- const char *sep2 = strchr(path, ':');
- if (sep1 && sep2)
- else if (sep1)
return sep1;
- else
return sep2;
- int fdt_path_offset(const void *fdt, const char *path) { const char *end = path + strlen(path);
if (!q) q = end;
if (! *p)
q = strchr(p, '/');
if (! q) q = end;q = fdt_path_next_seperator(p);
Hi Hans,
I haven't looked. but is this change in dtc upstream or just in the kernel?
chosen {
stdout-path = "/soc@01c00000/serial@01c28000:115200"; }; leds {
if (sep1 && sep2)
else if (sep1)
return sep1;
else
return sep2;
const char *q = fdt_path_next_seperator(path); if (!q) q = end;
if (! *p)
q = strchr(p, '/');
-- 2.3.5
On 20-04-15 17:39, Simon Glass wrote:
Hi Hans,
This is just a change in the dts files shipped with the kernel not in dtc, the dts files for sunxi used to not set stdout-path, and you patched in a stdout-path setting for u-boot:
http://git.denx.de/?p=u-boot.git;a=commitdiff;h=1a81cf8399675056beef5e76be8a...
+ chosen { + stdout-path = &uart0; + };
But now the upstream dts contains a stdout-path itself, but like this;
alias { serial0 = &uart0; };
chosen { stdout-path = "serial0:115200n8"; };
And the current u-boot dts parsing does not grok this due to it not recognizing the : in there.
Where as the kernel has:
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/drivers...
static struct device_node *__of_find_node_by_path(struct device_node *parent, const char *path) { struct device_node *child; int len;
len = strcspn(path, "/:"); if (!len) return NULL;
__for_each_child_of_node(parent, child) { const char *name = strrchr(child->full_name, '/'); if (WARN(!name, "malformed device_node %s\n", child->full_name)) continue; name++; if (strncmp(path, name, len) == 0 && (strlen(name) == len)) return child; } return NULL; }
Where the strcspn surves the same purpose as the fdt_path_next_seperator my patch introduces find the basename to match for stopping at the first occurence of either a '/' or a ':' char.
Regards,
Hans
chosen {
if (sep1 && sep2)
else if (sep1)
return sep1;
else
return sep2;
if (! *p)
q = strchr(p, '/');
-- 2.3.5
Hi Hans,
Hi Hans,
In that case, can we change this in the fdt support /fdtdec code, instead of making a change to libfdt that will never go upstream?
If that doesn't work or is too painful, then we should take this patch.
chosen {
alias { serial0 = &uart0; }; chosen { stdout-path = "serial0:115200n8"; };
len = strcspn(path, "/:"); if (!len) return NULL; __for_each_child_of_node(parent, child) { const char *name = strrchr(child->full_name, '/'); if (WARN(!name, "malformed device_node %s\n",
Regards,
Hans
chosen {
and ':'
so
if (sep1 && sep2)
else if (sep1)
return sep1;
else
return sep2;
if (! *p)
q = strchr(p, '/');
-- 2.3.5
On 22-04-15 19:20, Simon Glass wrote:
Hi Hans,
Hi Hans,
Actually I started with fixing this the fdtdev level, but then I noticed that the kernel does this at the of_find_node_by_path level, so if we fix this for stdout-path only (which a fdtdec patch would do) then we may get bit by this again later.
Also fixing it at the fdtdec level means adding a strdup + error checking since then we need to pass a truncated (options removed) copy of the path to fdt_path_offset(), while with the current patch we can keep using read only access to the fdt.
So I've a slight preference for going this way. Why would libfdt upstream not take this patch ?
Regards,
Hans
chosen {
Regards,
Hans
chosen {
and ':'
so
if (sep1 && sep2)
else if (sep1)
return sep1;
else
return sep2;
if (! *p)
q = strchr(p, '/');
-- 2.3.5
Hi Hans,
Hi Hans,
Hi Hans,
I'm not sure, but please go ahead and send it upstream. Thanks for the explanation, I'll pick this up.
Regards,
Hans
chosen {
Regards,
Hans
chosen {
'/' and ':'
happen, so
if (sep1 && sep2)
else if (sep1)
return sep1;
else
return sep2;
if (! *p)
q = strchr(p, '/');
-- 2.3.5
Hi Hans,
On 23 April 2015 at 10:15, Simon Glass sjg@chromium.org wrote:
Hi Hans,
Hi Hans,
Hi Hans,
Can I just check if you are OK to send this upstream? We don't need to wait for it to be accepted, just want to know it will be sent.
On 24-04-15 14:42, Simon Glass wrote:
Hi Hans,
Hi Hans,
Hi Hans,
Hi Hans,
On 20 April 2015 at 03:13, Hans de Goede hdegoede@redhat.com wrote: > > > After syncing the sunxi dts files with the upstream kernel dm/fdt sunxi > builds would no longer boot. > > The problem is that stdout-path is now set like this in the upstream > dts > files: stdout-path = "serial0:115200n8". The use of options in > of-paths, > either after an alias name, or after a full path, e.g. stdout-path = > "/soc@01c00000/serial@01c28000:115200", is standard of usage, but > something > which the u-boot dts code so far did not handle. > > This commit fixes this, adding support for both path formats. > > Signed-off-by: Hans de Goede hdegoede@redhat.com > --- > arch/arm/dts/sun7i-a20-pcduino3.dts | 2 +- > lib/libfdt/fdt_ro.c | 25 ++++++++++++++++++++++---
Yes I will submit this upstream.
Regards,
Hans
Hi Hans,
Hi Hans,
Hi Hans,
On 20-04-15 17:39, Simon Glass wrote: > > > > Hi Hans, > > On 20 April 2015 at 03:13, Hans de Goede hdegoede@redhat.com wrote: >> >> >> >> After syncing the sunxi dts files with the upstream kernel dm/fdt >> sunxi >> builds would no longer boot. >> >> The problem is that stdout-path is now set like this in the upstream >> dts >> files: stdout-path = "serial0:115200n8". The use of options in >> of-paths, >> either after an alias name, or after a full path, e.g. stdout-path = >> "/soc@01c00000/serial@01c28000:115200", is standard of usage, but >> something >> which the u-boot dts code so far did not handle. >> >> This commit fixes this, adding support for both path formats. >> >> Signed-off-by: Hans de Goede hdegoede@redhat.com >> --- >> arch/arm/dts/sun7i-a20-pcduino3.dts | 2 +- >> lib/libfdt/fdt_ro.c | 25 >> ++++++++++++++++++++++--- > > > > > I haven't looked. but is this change in dtc upstream or just in the > kernel?
Applied to u-boot-fdt, thanks!
- Simon
+Scott
Hi Hans,
Hi Hans,
Hi Hans,
Hi Hans,
On 20 April 2015 at 12:10, Hans de Goede hdegoede@redhat.com wrote: > > > Hi, > > On 20-04-15 17:39, Simon Glass wrote: >> >> >> >> Hi Hans, >> >> On 20 April 2015 at 03:13, Hans de Goede hdegoede@redhat.com wrote: >>> >>> >>> >>> After syncing the sunxi dts files with the upstream kernel dm/fdt >>> sunxi >>> builds would no longer boot. >>> >>> The problem is that stdout-path is now set like this in the upstream >>> dts >>> files: stdout-path = "serial0:115200n8". The use of options in >>> of-paths, >>> either after an alias name, or after a full path, e.g. stdout-path = >>> "/soc@01c00000/serial@01c28000:115200", is standard of usage, but >>> something >>> which the u-boot dts code so far did not handle. >>> >>> This commit fixes this, adding support for both path formats. >>> >>> Signed-off-by: Hans de Goede hdegoede@redhat.com >>> --- >>> arch/arm/dts/sun7i-a20-pcduino3.dts | 2 +- >>> lib/libfdt/fdt_ro.c | 25 >>> ++++++++++++++++++++++--- >> >> >> >> >> I haven't looked. but is this change in dtc upstream or just in the >> kernel? > > > > > This is just a change in the dts files shipped with the kernel not in > dtc, > the dts files for sunxi used to not set stdout-path, and you patched > in > a stdout-path setting for u-boot:
It looks like this was rejected upstream. If so can you please create a patch for fdtdec.c (I assume) to move your code into there?
Hans de Goede
