[PATCH v1 1/1] clk: nuvoton: Add support for NPCM845
Add clock controller driver for NPCM845
Signed-off-by: Stanley Chu yschu@nuvoton.com --- drivers/clk/Makefile | 1 + drivers/clk/nuvoton/Makefile | 1 + drivers/clk/nuvoton/clk_npcm8xx.c | 470 ++++++++++++++++++ .../dt-bindings/clock/nuvoton,npcm8xx-clock.h | 27 + 4 files changed, 499 insertions(+) create mode 100644 drivers/clk/nuvoton/Makefile create mode 100644 drivers/clk/nuvoton/clk_npcm8xx.c create mode 100644 include/dt-bindings/clock/nuvoton,npcm8xx-clock.h
diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 711ae5bc29..21e60bae0c 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -19,6 +19,7 @@ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ obj-$(CONFIG_ARCH_MEDIATEK) += mediatek/ obj-$(CONFIG_ARCH_MTMIPS) += mtmips/ obj-$(CONFIG_ARCH_MESON) += meson/ +obj-$(CONFIG_ARCH_NPCM) += nuvoton/ obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ obj-$(CONFIG_ARCH_SOCFPGA) += altera/ obj-$(CONFIG_CLK_AT91) += at91/ diff --git a/drivers/clk/nuvoton/Makefile b/drivers/clk/nuvoton/Makefile new file mode 100644 index 0000000000..998e5329bb --- /dev/null +++ b/drivers/clk/nuvoton/Makefile @@ -0,0 +1 @@ +obj-$(CONFIG_ARCH_NPCM8XX) += clk_npcm8xx.o diff --git a/drivers/clk/nuvoton/clk_npcm8xx.c b/drivers/clk/nuvoton/clk_npcm8xx.c new file mode 100644 index 0000000000..cdb5af5d9f --- /dev/null +++ b/drivers/clk/nuvoton/clk_npcm8xx.c @@ -0,0 +1,470 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Nuvoton Technology Corp. + */ + +#include <common.h> +#include <clk-uclass.h> +#include <div64.h> +#include <dm.h> +#include <asm/io.h> +#include <linux/bitfield.h> +#include <linux/log2.h> +#include <dt-bindings/clock/nuvoton,npcm8xx-clock.h> + +/* Register offsets */ +#define CLKSEL 0x04 /* clock source selection */ +#define CLKDIV1 0x08 /* clock divider 1 */ +#define CLKDIV2 0x2C /* clock divider 2 */ +#define CLKDIV3 0x58 /* clock divider 3 */ +#define PLLCON0 0x0C /* pll0 control */ +#define PLLCON1 0x10 /* pll1 control */ +#define PLLCON2 0x54 /* pll2 control */ + +/* PLLCON bit filed */ +#define PLLCON_INDV GENMASK(5, 0) +#define PLLCON_OTDV1 GENMASK(10, 8) +#define PLLCON_OTDV2 GENMASK(15, 13) +#define PLLCON_FBDV GENMASK(27, 16) + +/* CLKSEL bit filed */ +#define CPUCKSEL GENMASK(2, 0) +#define SDCKSEL GENMASK(7, 6) +#define UARTCKSEL GENMASK(9, 8) + +/* CLKDIV1 bit filed */ +#define SPI3CKDIV GENMASK(10, 6) +#define MMCCKDIV GENMASK(15, 11) +#define UARTDIV1 GENMASK(20, 16) +#define CLK4DIV GENMASK(27, 26) + +/* CLKDIV2 bit filed */ +#define APB5CKDIV GENMASK(23, 22) +#define APB2CKDIV GENMASK(27, 26) + +/* CLKDIV3 bit filed */ +#define SPIXCKDIV GENMASK(5, 1) +#define SPI0CKDIV GENMASK(10, 6) +#define UARTDIV2 GENMASK(15, 11) +#define SPI1CKDIV GENMASK(23, 16) + +/* Flags */ +#define DIV_TYPE1 BIT(0) /* div = clkdiv + 1 */ +#define DIV_TYPE2 BIT(1) /* div = 1 << clkdiv */ +#define PRE_DIV2 BIT(2) /* Pre divisor = 2 */ +#define POST_DIV2 BIT(3) /* Post divisor = 2 */ +#define FIXED_PARENT BIT(4) /* clock source is fixed */ + +struct npcm_clk_priv { + struct udevice *dev; + void __iomem *base; +}; + +/* Parameters of PLL configuration */ +struct npcm_clk_pll { + const int id; + const int parent_id; + u32 reg; + u32 flags; +}; + +/* Parent clock id to clksel mapping */ +struct parent_data { + int id; + int clksel; +}; + +/* Parameters of parent selection */ +struct npcm_clk_select { + const int id; + const struct parent_data *parents; + u32 reg; + u32 mask; + u8 num_parents; + u32 flags; +}; + +/* Parameters of clock divider */ +struct npcm_clk_div { + const int id; + u32 reg; + u32 mask; + u32 flags; +}; + +/* Parent clock map */ +static const struct parent_data pll_parents[] = { + {NPCM8XX_CLK_PLL0, 0}, + {NPCM8XX_CLK_PLL1, 1}, + {NPCM8XX_CLK_REFCLK, 2}, + {NPCM8XX_CLK_PLL2DIV2, 3} +}; + +static const struct parent_data cpuck_parents[] = { + {NPCM8XX_CLK_PLL0, 0}, + {NPCM8XX_CLK_PLL1, 1}, + {NPCM8XX_CLK_REFCLK, 2}, + {NPCM8XX_CLK_PLL2, 7} +}; + +static const struct parent_data apb_parent[] = {{NPCM8XX_CLK_AHB, 0}}; + +static struct npcm_clk_pll npcm8xx_clk_plls[] = { + {NPCM8XX_CLK_PLL0, NPCM8XX_CLK_REFCLK, PLLCON0, 0}, + {NPCM8XX_CLK_PLL1, NPCM8XX_CLK_REFCLK, PLLCON1, 0}, + {NPCM8XX_CLK_PLL2, NPCM8XX_CLK_REFCLK, PLLCON2, 0}, + {NPCM8XX_CLK_PLL2DIV2, NPCM8XX_CLK_REFCLK, PLLCON2, POST_DIV2} +}; + +static struct npcm_clk_select npcm8xx_clk_selectors[] = { + {NPCM8XX_CLK_AHB, cpuck_parents, CLKSEL, CPUCKSEL, 4, 0}, + {NPCM8XX_CLK_APB2, apb_parent, 0, 0, 1, FIXED_PARENT}, + {NPCM8XX_CLK_APB5, apb_parent, 0, 0, 1, FIXED_PARENT}, + {NPCM8XX_CLK_SPI0, apb_parent, 0, 0, 1, FIXED_PARENT}, + {NPCM8XX_CLK_SPI1, apb_parent, 0, 0, 1, FIXED_PARENT}, + {NPCM8XX_CLK_SPI3, apb_parent, 0, 0, 1, FIXED_PARENT}, + {NPCM8XX_CLK_SPIX, apb_parent, 0, 0, 1, FIXED_PARENT}, + {NPCM8XX_CLK_UART, pll_parents, CLKSEL, UARTCKSEL, 4, 0}, + {NPCM8XX_CLK_UART2, pll_parents, CLKSEL, UARTCKSEL, 4, 0}, + {NPCM8XX_CLK_SDHC, pll_parents, CLKSEL, SDCKSEL, 4, 0} +}; + +static struct npcm_clk_div npcm8xx_clk_dividers[] = { + {NPCM8XX_CLK_AHB, CLKDIV1, CLK4DIV, DIV_TYPE1 | PRE_DIV2}, + {NPCM8XX_CLK_APB2, CLKDIV2, APB2CKDIV, DIV_TYPE2}, + {NPCM8XX_CLK_APB5, CLKDIV2, APB5CKDIV, DIV_TYPE2}, + {NPCM8XX_CLK_SPI0, CLKDIV3, SPI0CKDIV, DIV_TYPE1}, + {NPCM8XX_CLK_SPI1, CLKDIV3, SPI1CKDIV, DIV_TYPE1}, + {NPCM8XX_CLK_SPI3, CLKDIV1, SPI3CKDIV, DIV_TYPE1}, + {NPCM8XX_CLK_SPIX, CLKDIV3, SPIXCKDIV, DIV_TYPE1}, + {NPCM8XX_CLK_UART, CLKDIV1, UARTDIV1, DIV_TYPE1}, + {NPCM8XX_CLK_UART2, CLKDIV3, UARTDIV2, DIV_TYPE1}, + {NPCM8XX_CLK_SDHC, CLKDIV1, MMCCKDIV, DIV_TYPE1} +}; + +static int clkid_to_clksel(struct npcm_clk_select *selector, int id) +{ + int i; + + for (i = 0; i < selector->num_parents; i++) { + if (selector->parents[i].id == id) + return selector->parents[i].clksel; + } + + return -EINVAL; +} + +static int clksel_to_clkid(struct npcm_clk_select *selector, int clksel) +{ + int i; + + for (i = 0; i < selector->num_parents; i++) { + if (selector->parents[i].clksel == clksel) + return selector->parents[i].id; + } + + return -EINVAL; +} + +static struct npcm_clk_pll *npcm_clk_pll_get(int clk_id) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(npcm8xx_clk_plls); i++) { + if (npcm8xx_clk_plls[i].id == clk_id) + return &npcm8xx_clk_plls[i]; + } + + return NULL; +} + +static struct npcm_clk_select *npcm_clk_selector_get(int clk_id) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(npcm8xx_clk_selectors); i++) { + if (npcm8xx_clk_selectors[i].id == clk_id) + return &npcm8xx_clk_selectors[i]; + } + + return NULL; +} + +static struct npcm_clk_div *npcm_clk_divider_get(int clk_id) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(npcm8xx_clk_dividers); i++) { + if (npcm8xx_clk_dividers[i].id == clk_id) + return &npcm8xx_clk_dividers[i]; + } + + return NULL; +} + +static ulong npcm_clk_get_fin(struct npcm_clk_priv *priv, int id) +{ + struct npcm_clk_select *selector; + struct clk parent; + ulong parent_rate; + u32 val, clksel; + int ret; + + selector = npcm_clk_selector_get(id); + if (!selector) + return 0; + + if (selector->flags & FIXED_PARENT) { + clksel = 0; + } else { + val = readl(priv->base + selector->reg); + clksel = (val & selector->mask) >> (ffs(selector->mask) - 1); + } + parent.id = clksel_to_clkid(selector, clksel); + + ret = clk_request(priv->dev, &parent); + if (ret) + return 0; + + parent_rate = clk_get_rate(&parent); + + debug("fin of clk%d = %lu\n", id, parent_rate); + return parent_rate; +} + +static u32 npcm_clk_get_div(struct npcm_clk_priv *priv, int id) +{ + struct npcm_clk_div *divider; + u32 val, div; + + divider = npcm_clk_divider_get(id); + if (!divider) + return 0; + + val = readl(priv->base + divider->reg); + div = (val & divider->mask) >> (ffs(divider->mask) - 1); + if (divider->flags & DIV_TYPE1) + div = div + 1; + else + div = 1 << div; + + if (divider->flags & PRE_DIV2) + div = div << 1; + + return div; +} + +static u32 npcm_clk_set_div(struct npcm_clk_priv *priv, int id, u32 div) +{ + struct npcm_clk_div *divider; + u32 val, clkdiv; + + divider = npcm_clk_divider_get(id); + if (!divider) + return -EINVAL; + + if (divider->flags & PRE_DIV2) + div = div >> 1; + + if (divider->flags & DIV_TYPE1) + clkdiv = div - 1; + else + clkdiv = ilog2(div); + + val = readl(priv->base + divider->reg); + val &= ~divider->mask; + val |= (clkdiv << (ffs(divider->mask) - 1)) & divider->mask; + writel(val, priv->base + divider->reg); + + return 0; +} + +static ulong npcm_clk_get_fout(struct npcm_clk_priv *priv, int id) +{ + ulong parent_rate; + u32 div; + + parent_rate = npcm_clk_get_fin(priv, id); + if (!parent_rate) + return -EINVAL; + + div = npcm_clk_get_div(priv, id); + if (!div) + return -EINVAL; + + debug("fout of clk%d = (%lu / %u)\n", id, parent_rate, div); + return (parent_rate / div); +} + +static ulong npcm_clk_set_fout(struct npcm_clk_priv *priv, int id, ulong rate) +{ + u32 div; + ulong parent_rate; + int ret; + + parent_rate = npcm_clk_get_fin(priv, id); + if (!parent_rate) + return -EINVAL; + + div = DIV_ROUND_UP(parent_rate, rate); + ret = npcm_clk_set_div(priv, id, div); + if (ret) + return ret; + + debug("%s: rate %lu, new rate (%lu / %u)\n", __func__, rate, parent_rate, div); + return (parent_rate / div); +} + +static ulong npcm_clk_get_pll_fout(struct npcm_clk_priv *priv, int id) +{ + struct npcm_clk_pll *pll; + struct clk parent; + ulong parent_rate; + ulong fbdv, indv, otdv1, otdv2; + u32 val; + u64 ret; + + pll = npcm_clk_pll_get(id); + if (!pll) + return -ENODEV; + + parent.id = pll->parent_id; + ret = clk_request(priv->dev, &parent); + if (ret) + return ret; + + parent_rate = clk_get_rate(&parent); + + val = readl(priv->base + pll->reg); + indv = FIELD_GET(PLLCON_INDV, val); + fbdv = FIELD_GET(PLLCON_FBDV, val); + otdv1 = FIELD_GET(PLLCON_OTDV1, val); + otdv2 = FIELD_GET(PLLCON_OTDV2, val); + + ret = (u64)parent_rate * fbdv; + do_div(ret, indv * otdv1 * otdv2); + if (pll->flags & POST_DIV2) + do_div(ret, 2); + + debug("fout of pll(id %d) = %llu\n", id, ret); + return ret; +} + +static ulong npcm_clk_get_rate(struct clk *clk) +{ + struct npcm_clk_priv *priv = dev_get_priv(clk->dev); + struct clk refclk; + int ret; + + debug("%s: id %lu\n", __func__, clk->id); + switch (clk->id) { + case NPCM8XX_CLK_REFCLK: + ret = clk_get_by_name(priv->dev, "refclk", &refclk); + if (!ret) + return clk_get_rate(&refclk); + else + return ret; + case NPCM8XX_CLK_PLL0: + case NPCM8XX_CLK_PLL1: + case NPCM8XX_CLK_PLL2: + case NPCM8XX_CLK_PLL2DIV2: + return npcm_clk_get_pll_fout(priv, clk->id); + case NPCM8XX_CLK_AHB: + case NPCM8XX_CLK_APB2: + case NPCM8XX_CLK_APB5: + case NPCM8XX_CLK_SDHC: + case NPCM8XX_CLK_UART: + case NPCM8XX_CLK_UART2: + case NPCM8XX_CLK_SPI0: + case NPCM8XX_CLK_SPI1: + case NPCM8XX_CLK_SPI3: + case NPCM8XX_CLK_SPIX: + return npcm_clk_get_fout(priv, clk->id); + default: + return -ENOSYS; + } +} + +static ulong npcm_clk_set_rate(struct clk *clk, ulong rate) +{ + struct npcm_clk_priv *priv = dev_get_priv(clk->dev); + + debug("%s: id %lu, rate %lu\n", __func__, clk->id, rate); + switch (clk->id) { + case NPCM8XX_CLK_UART: + case NPCM8XX_CLK_UART2: + case NPCM8XX_CLK_SPI0: + case NPCM8XX_CLK_SPI1: + case NPCM8XX_CLK_SPI3: + case NPCM8XX_CLK_SPIX: + return npcm_clk_set_fout(priv, clk->id, rate); + default: + return -ENOSYS; + } +} + +static int npcm_clk_set_parent(struct clk *clk, struct clk *parent) +{ + struct npcm_clk_priv *priv = dev_get_priv(clk->dev); + struct npcm_clk_select *selector; + int clksel; + u32 val; + + debug("%s: id %lu, parent %lu\n", __func__, clk->id, parent->id); + selector = npcm_clk_selector_get(clk->id); + if (!selector) + return -EINVAL; + + clksel = clkid_to_clksel(selector, parent->id); + if (clksel < 0) + return -EINVAL; + + val = readl(priv->base + selector->reg); + val &= ~selector->mask; + val |= clksel << (ffs(selector->mask) - 1); + writel(val, priv->base + selector->reg); + + return 0; +} + +static int npcm_clk_request(struct clk *clk) +{ + if (clk->id >= NPCM8XX_NUM_CLOCKS) + return -EINVAL; + + return 0; +} + +static struct clk_ops npcm_clk_ops = { + .get_rate = npcm_clk_get_rate, + .set_rate = npcm_clk_set_rate, + .set_parent = npcm_clk_set_parent, + .request = npcm_clk_request, +}; + +static int npcm_clk_probe(struct udevice *dev) +{ + struct npcm_clk_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -EINVAL; + priv->dev = dev; + + return 0; +} + +static const struct udevice_id npcm_clk_ids[] = { + { .compatible = "nuvoton,npcm845-clk" }, + { } +}; + +U_BOOT_DRIVER(clk_npcm) = { + .name = "clk_npcm", + .id = UCLASS_CLK, + .of_match = npcm_clk_ids, + .ops = &npcm_clk_ops, + .priv_auto = sizeof(struct npcm_clk_priv), + .probe = npcm_clk_probe, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/dt-bindings/clock/nuvoton,npcm8xx-clock.h b/include/dt-bindings/clock/nuvoton,npcm8xx-clock.h new file mode 100644 index 0000000000..7da8b422e5 --- /dev/null +++ b/include/dt-bindings/clock/nuvoton,npcm8xx-clock.h @@ -0,0 +1,27 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2022 Nuvoton Technology Corp. + */ + +#ifndef __DT_BINDINGS_CLOCK_NPCM8XX_H +#define __DT_BINDINGS_CLOCK_NPCM8XX_H + +#define NPCM8XX_CLK_REFCLK 0 +#define NPCM8XX_CLK_PLL0 1 +#define NPCM8XX_CLK_PLL1 2 +#define NPCM8XX_CLK_PLL2 3 +#define NPCM8XX_CLK_PLL2DIV2 4 +#define NPCM8XX_CLK_AHB 5 +#define NPCM8XX_CLK_APB2 6 +#define NPCM8XX_CLK_APB5 7 +#define NPCM8XX_CLK_UART 8 +#define NPCM8XX_CLK_UART2 9 +#define NPCM8XX_CLK_SPI0 10 +#define NPCM8XX_CLK_SPI1 11 +#define NPCM8XX_CLK_SPI3 12 +#define NPCM8XX_CLK_SPIX 13 +#define NPCM8XX_CLK_SDHC 14 + +#define NPCM8XX_NUM_CLOCKS (NPCM8XX_CLK_SDHC + 1) + +#endif
- Copyright (c) 2022 Nuvoton Technology Corp.
- struct udevice *dev;
- void __iomem *base;
- const int id;
- const int parent_id;
- u32 reg;
- u32 flags;
- int id;
- int clksel;
- const int id;
- const struct parent_data *parents;
- u32 reg;
- u32 mask;
- u8 num_parents;
- u32 flags;
- const int id;
- u32 reg;
- u32 mask;
- u32 flags;
- {NPCM8XX_CLK_PLL0, 0},
- {NPCM8XX_CLK_PLL1, 1},
- {NPCM8XX_CLK_REFCLK, 2},
- {NPCM8XX_CLK_PLL2DIV2, 3}
- {NPCM8XX_CLK_PLL2, 7}
- {NPCM8XX_CLK_PLL0, NPCM8XX_CLK_REFCLK, PLLCON0, 0},
- {NPCM8XX_CLK_PLL1, NPCM8XX_CLK_REFCLK, PLLCON1, 0},
- {NPCM8XX_CLK_PLL2, NPCM8XX_CLK_REFCLK, PLLCON2, 0},
- {NPCM8XX_CLK_PLL2DIV2, NPCM8XX_CLK_REFCLK, PLLCON2, POST_DIV2}
- {NPCM8XX_CLK_AHB, cpuck_parents, CLKSEL, CPUCKSEL, 4, 0},
- {NPCM8XX_CLK_APB2, apb_parent, 0, 0, 1, FIXED_PARENT},
- {NPCM8XX_CLK_APB5, apb_parent, 0, 0, 1, FIXED_PARENT},
- {NPCM8XX_CLK_SPI0, apb_parent, 0, 0, 1, FIXED_PARENT},
- {NPCM8XX_CLK_SPI1, apb_parent, 0, 0, 1, FIXED_PARENT},
- {NPCM8XX_CLK_SPI3, apb_parent, 0, 0, 1, FIXED_PARENT},
- {NPCM8XX_CLK_SPIX, apb_parent, 0, 0, 1, FIXED_PARENT},
- {NPCM8XX_CLK_UART, pll_parents, CLKSEL, UARTCKSEL, 4, 0},
- {NPCM8XX_CLK_UART2, pll_parents, CLKSEL, UARTCKSEL, 4, 0},
- {NPCM8XX_CLK_SDHC, pll_parents, CLKSEL, SDCKSEL, 4, 0}
- {NPCM8XX_CLK_AHB, CLKDIV1, CLK4DIV, DIV_TYPE1 | PRE_DIV2},
- {NPCM8XX_CLK_APB2, CLKDIV2, APB2CKDIV, DIV_TYPE2},
- {NPCM8XX_CLK_APB5, CLKDIV2, APB5CKDIV, DIV_TYPE2},
- {NPCM8XX_CLK_SPI0, CLKDIV3, SPI0CKDIV, DIV_TYPE1},
- {NPCM8XX_CLK_SPI1, CLKDIV3, SPI1CKDIV, DIV_TYPE1},
- {NPCM8XX_CLK_SPI3, CLKDIV1, SPI3CKDIV, DIV_TYPE1},
- {NPCM8XX_CLK_SPIX, CLKDIV3, SPIXCKDIV, DIV_TYPE1},
- {NPCM8XX_CLK_UART, CLKDIV1, UARTDIV1, DIV_TYPE1},
- {NPCM8XX_CLK_UART2, CLKDIV3, UARTDIV2, DIV_TYPE1},
- {NPCM8XX_CLK_SDHC, CLKDIV1, MMCCKDIV, DIV_TYPE1}
- int i;
- for (i = 0; i < selector->num_parents; i++) {
- return -EINVAL;
- int i;
- return -EINVAL;
- int i;
- for (i = 0; i < ARRAY_SIZE(npcm8xx_clk_plls); i++) {
- return NULL;
- int i;
- for (i = 0; i < ARRAY_SIZE(npcm8xx_clk_selectors); i++) {
- return NULL;
- int i;
- for (i = 0; i < ARRAY_SIZE(npcm8xx_clk_dividers); i++) {
- return NULL;
Here, I would just pass in the clock directly. You call this like
so you could rework it to just be
npcm_clk_get_pll_fout(clk)
and then use clk->dev and clk->id as needed. Same goes for the other clocks.
- struct npcm_clk_select *selector;
- struct clk parent;
- ulong parent_rate;
- u32 val, clksel;
- int ret;
- selector = npcm_clk_selector_get(id);
- if (!selector)
- if (selector->flags & FIXED_PARENT) {
clksel = 0;
- } else {
- parent.id = clksel_to_clkid(selector, clksel);
- ret = clk_request(priv->dev, &parent);
- if (ret)
- parent_rate = clk_get_rate(&parent);
- debug("fin of clk%d = %lu\n", id, parent_rate);
- return parent_rate;
- struct npcm_clk_div *divider;
- u32 val, div;
- divider = npcm_clk_divider_get(id);
- if (!divider)
- val = readl(priv->base + divider->reg);
- div = (val & divider->mask) >> (ffs(divider->mask) - 1);
- if (divider->flags & DIV_TYPE1)
div = div + 1;
- else
div = 1 << div;
- if (divider->flags & PRE_DIV2)
div = div << 1;
- return div;
- u32 val, clkdiv;
- if (!divider)
return -EINVAL;
div = div >> 1;
clkdiv = div - 1;
- else
- val &= ~divider->mask;
- val |= (clkdiv << (ffs(divider->mask) - 1)) & divider->mask;
- writel(val, priv->base + divider->reg);
- u32 div;
- parent_rate = npcm_clk_get_fin(priv, id);
- if (!parent_rate)
return -EINVAL;
- div = npcm_clk_get_div(priv, id);
- if (!div)
return -EINVAL;
- debug("fout of clk%d = (%lu / %u)\n", id, parent_rate, div);
- return (parent_rate / div);
- u32 div;
- int ret;
- if (!parent_rate)
return -EINVAL;
- div = DIV_ROUND_UP(parent_rate, rate);
- ret = npcm_clk_set_div(priv, id, div);
- if (ret)
return ret;
- debug("%s: rate %lu, new rate (%lu / %u)\n", __func__, rate, parent_rate, div);
- struct npcm_clk_pll *pll;
- ulong fbdv, indv, otdv1, otdv2;
- u32 val;
- u64 ret;
- pll = npcm_clk_pll_get(id);
- if (!pll)
return -ENODEV;
- parent.id = pll->parent_id;
- if (ret)
return ret;
- val = readl(priv->base + pll->reg);
- indv = FIELD_GET(PLLCON_INDV, val);
- fbdv = FIELD_GET(PLLCON_FBDV, val);
- otdv1 = FIELD_GET(PLLCON_OTDV1, val);
- otdv2 = FIELD_GET(PLLCON_OTDV2, val);
- ret = (u64)parent_rate * fbdv;
- do_div(ret, indv * otdv1 * otdv2);
- if (pll->flags & POST_DIV2)
do_div(ret, 2);
- debug("fout of pll(id %d) = %llu\n", id, ret);
- return ret;
- struct npcm_clk_priv *priv = dev_get_priv(clk->dev);
- struct clk refclk;
- int ret;
- debug("%s: id %lu\n", __func__, clk->id);
- switch (clk->id) {
- case NPCM8XX_CLK_REFCLK:
if (!ret)
else
return ret;
- case NPCM8XX_CLK_PLL0:
- case NPCM8XX_CLK_PLL1:
- case NPCM8XX_CLK_PLL2:
- case NPCM8XX_CLK_PLL2DIV2:
- case NPCM8XX_CLK_AHB:
- case NPCM8XX_CLK_APB2:
- case NPCM8XX_CLK_APB5:
- case NPCM8XX_CLK_SDHC:
- case NPCM8XX_CLK_UART:
- case NPCM8XX_CLK_UART2:
- case NPCM8XX_CLK_SPI0:
- case NPCM8XX_CLK_SPI1:
- case NPCM8XX_CLK_SPI3:
- case NPCM8XX_CLK_SPIX:
- default:
return -ENOSYS;
- debug("%s: id %lu, rate %lu\n", __func__, clk->id, rate);
- default:
return -ENOSYS;
- int clksel;
- u32 val;
- debug("%s: id %lu, parent %lu\n", __func__, clk->id, parent->id);
- selector = npcm_clk_selector_get(clk->id);
- if (!selector)
return -EINVAL;
- clksel = clkid_to_clksel(selector, parent->id);
- if (clksel < 0)
return -EINVAL;
- val = readl(priv->base + selector->reg);
- val &= ~selector->mask;
- val |= clksel << (ffs(selector->mask) - 1);
- writel(val, priv->base + selector->reg);
- if (clk->id >= NPCM8XX_NUM_CLOCKS)
return -EINVAL;
- .get_rate = npcm_clk_get_rate,
- .set_rate = npcm_clk_set_rate,
- .set_parent = npcm_clk_set_parent,
- .request = npcm_clk_request,
- struct npcm_clk_priv *priv = dev_get_priv(dev);
- priv->base = dev_read_addr_ptr(dev);
- if (!priv->base)
return -EINVAL;
- priv->dev = dev;
- { .compatible = "nuvoton,npcm845-clk" },
- .name = "clk_npcm",
- .id = UCLASS_CLK,
- .of_match = npcm_clk_ids,
- .ops = &npcm_clk_ops,
- .priv_auto = sizeof(struct npcm_clk_priv),
- .probe = npcm_clk_probe,
- .flags = DM_FLAG_PRE_RELOC,
This looks good. With the above comment addressed (or otherwise):
Reviewed-by: Sean Anderson seanga2@gmail.com
Sean Anderson
Stanley Chu
