[U-Boot] [PATCH] ARM: EXYNOS: fixed the wrong function argument.
This patch is fixed the wrong function argument. And quirks should be set into s5p_sdhci.c. There are only exynos specific codes. (this patch is based on u-boot-samsung repository)
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- arch/arm/include/asm/arch-exynos/mmc.h | 4 ++-- arch/arm/include/asm/arch-s5pc1xx/mmc.h | 4 ++-- drivers/mmc/s5p_sdhci.c | 11 ++++++----- 3 files changed, 10 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 0f701c9..1ede23c 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -64,11 +64,11 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
-int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks); +int s5p_sdhci_init(u32 regbase, int index, int buswidth);
static inline unsigned int s5p_mmc_init(int index, int bus_width) { unsigned int base = samsung_get_base_mmc() + (0x10000 * index); - return s5p_sdhci_init(base, 52000000, 400000, index); + return s5p_sdhci_init(base, index, bus_width); } #endif diff --git a/arch/arm/include/asm/arch-s5pc1xx/mmc.h b/arch/arm/include/asm/arch-s5pc1xx/mmc.h index 0f701c9..1ede23c 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/mmc.h +++ b/arch/arm/include/asm/arch-s5pc1xx/mmc.h @@ -64,11 +64,11 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
static inline unsigned int s5p_mmc_init(int index, int bus_width) { unsigned int base = samsung_get_base_mmc() + (0x10000 * index); - return s5p_sdhci_init(base, 52000000, 400000, index); + return s5p_sdhci_init(base, index, bus_width); } #endif diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 1d4481b..420cbc8 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -69,7 +69,7 @@ static void s5p_sdhci_set_control_reg(struct sdhci_host *host) sdhci_writel(host, ctrl, SDHCI_CONTROL2); }
-int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks) +int s5p_sdhci_init(u32 regbase, int index, int buswidth) { struct sdhci_host *host = NULL; host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); @@ -80,11 +80,10 @@ int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks)
host->name = S5P_NAME; host->ioaddr = (void *)regbase; - host->quirks = quirks;
- host->quirks |= SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE; + host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; - if (quirks & SDHCI_QUIRK_REG32_RW) + if (host->quirks & SDHCI_QUIRK_REG32_RW) host->version = sdhci_readl(host, SDHCI_HOST_VERSION - 2) >> 16; else host->version = sdhci_readw(host, SDHCI_HOST_VERSION); @@ -92,7 +91,9 @@ int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks) host->set_control_reg = &s5p_sdhci_set_control_reg;
host->host_caps = MMC_MODE_HC; + if (buswidth == 8) + host->host_caps |= MMC_MODE_8BIT;
- add_sdhci(host, max_clk, min_clk); + add_sdhci(host, 520000000, 400000); return 0; }
if (buswidth == 8)
52000000 is right : ) please fix it.
Thanks. Minkyu Kang.
Jaehoon Chung
Minkyu Kang
