[U-Boot] Please pull u-boot-x86
Hi Tom,
Here are some more PCI driver model improvements and better interrupt support on x86.
The following changes since commit 66d10c18bf2c34698362b6fe1891bcc6e8755243:
Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblaze (2015-07-28 11:31:21 -0400)
git://git.denx.de/u-boot-x86.git
for you to fetch changes up to 488d19cbcace0b87a2d08881eab7356088198903:
patman: add distutils based installer (2015-07-28 10:36:25 -0600)
---------------------------------------------------------------- Bin Meng (20): x86: Display correct CS/EIP/EFLAGS when there is an error code x86: Simplify architecture defined exception handling in irq_llsr() x86: Change pci option rom area MTRR setting to cacheable x86: Enable DM RTC support for all x86 boards x86: pci: Assign pci irqs to all functions x86: pci: Do not assign irq 0 to pci device buildman: Correct '--fetch-arch' command documentation Fix incorrect comments in linker_lists.h dm: pci: Correct primary/secondary/subordinate bus number assignment dm: pci: Use complete bdf in all pci config read/write routines dm: pci: Pass only device/function to pci_bus_find_devfn() dm: pci: Support bridge device configuration correctly x86: Convert to use driver model pci on queensbay/crownbay x86: mpspec: Allow platform to determine how PIRQ is connected to I/O APIC x86: mpspec: Move writing ISA interrupt entry after PCI x86: qemu: Enable I/O APIC chip select on PIIX3 x86: Allow cpu-x86 driver to be probed for UP x86: qemu: Enable writing MP table x86: qemu: Turn on PCIe ECAM address range decoding on Q35 x86: Reserve PCIe ECAM address range in the E820 table
Chris Packham (1): patman: add distutils based installer
arch/x86/Kconfig | 10 ++++ arch/x86/cpu/cpu.c | 36 ++++++++++++--- arch/x86/cpu/interrupts.c | 180 ++++++++++++++++++++++++++++++------------------------------------------ arch/x86/cpu/ivybridge/lpc.c | 1 - arch/x86/cpu/ivybridge/sdram.c | 32 +++++++++---- arch/x86/cpu/pci.c | 29 ++++++++---- arch/x86/cpu/qemu/pci.c | 45 ++++++++++++++++-- arch/x86/cpu/queensbay/Makefile | 1 - arch/x86/cpu/queensbay/tnc.c | 5 -- arch/x86/cpu/queensbay/tnc_pci.c | 46 ------------------- arch/x86/dts/chromebook_link.dts | 1 + arch/x86/dts/chromebox_panther.dts | 1 + arch/x86/dts/crownbay.dts | 6 ++- arch/x86/dts/galileo.dts | 1 + arch/x86/dts/minnowmax.dts | 1 + arch/x86/dts/qemu-x86_i440fx.dts | 13 ++++++ arch/x86/dts/qemu-x86_q35.dts | 13 ++++++ arch/x86/dts/rtc.dtsi | 1 + arch/x86/include/asm/arch-qemu/qemu.h | 10 +++- arch/x86/include/asm/interrupt.h | 24 ++++++++++ arch/x86/include/asm/mpspec.h | 17 +++++++ arch/x86/include/asm/mtrr.h | 2 + arch/x86/include/asm/pci.h | 3 +- arch/x86/include/asm/ptrace.h | 16 +++++-- arch/x86/lib/fsp/fsp_dram.c | 6 +++ arch/x86/lib/mpspec.c | 50 +++++++++++++++----- arch/x86/lib/pirq_routing.c | 3 +- arch/x86/lib/zimage.c | 5 +- configs/chromebook_link_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/galileo_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/qemu-x86_defconfig | 4 ++ drivers/pci/pci-uclass.c | 62 ++++++++++++------------- drivers/pci/pci_auto.c | 75 +++++++++++++++++++++++++----- drivers/pci/pci_common.c | 7 ++- include/linker_lists.h | 20 ++++---- tools/buildman/README | 4 +- tools/patman/README | 11 +++++ tools/patman/__init__.py | 3 ++ tools/patman/patman.py | 20 ++++---- tools/patman/setup.py | 13 ++++++ 43 files changed, 506 insertions(+), 276 deletions(-) delete mode 100644 arch/x86/cpu/queensbay/tnc_pci.c create mode 100644 tools/patman/__init__.py create mode 100644 tools/patman/setup.py
On Tue, Jul 28, 2015 at 11:42:22AM -0600, Simon Glass wrote:
Hi Tom,
