[U-Boot] [PATCH 0/6] Add support for PDM360NG board
This patch series intend to support MPC5121e based PDM360NG board. Patches preceding the actual board support patch 6 prepare needed infrastructure for the PDM360NG board.
Anatolij Gustschin (6): mpc512x: make MEM IO Control configuration a board config option mpc512x: add multi serial PSC support mpc5121: add PSC serial communication routines fsl_diu_fb.c: add support for RLE8 bitmaps fdt_support: add partitions fixup in mtd node mpc5121: add support for PDM360NG board
MAKEALL | 1 + Makefile | 3 + board/freescale/common/fsl_diu_fb.c | 107 ++++++- board/pdm360ng/Makefile | 51 +++ board/pdm360ng/config.mk | 24 ++ board/pdm360ng/pdm360ng.c | 618 +++++++++++++++++++++++++++++++++++ common/cmd_mtdparts.c | 2 +- common/fdt_support.c | 214 ++++++++++++ common/serial.c | 23 ++ cpu/mpc512x/diu.c | 14 +- cpu/mpc512x/fixed_sdram.c | 2 +- cpu/mpc512x/serial.c | 353 ++++++++++++++++++-- include/asm-ppc/immap_512x.h | 112 +++---- include/configs/aria.h | 2 + include/configs/mecp5123.h | 2 + include/configs/mpc5121ads.h | 2 + include/configs/pdm360ng.h | 525 +++++++++++++++++++++++++++++ include/fdt_support.h | 2 + include/jffs2/load_kernel.h | 1 + include/mtd_node.h | 11 + include/post.h | 1 + include/serial.h | 15 + post/tests.c | 4 + 23 files changed, 1996 insertions(+), 93 deletions(-) create mode 100644 board/pdm360ng/Makefile create mode 100644 board/pdm360ng/config.mk create mode 100644 board/pdm360ng/pdm360ng.c create mode 100644 include/configs/pdm360ng.h create mode 100644 include/mtd_node.h
Signed-off-by: Anatolij Gustschin agust@denx.de --- cpu/mpc512x/fixed_sdram.c | 2 +- include/asm-ppc/immap_512x.h | 4 ---- include/configs/aria.h | 2 ++ include/configs/mecp5123.h | 2 ++ include/configs/mpc5121ads.h | 2 ++ 5 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/cpu/mpc512x/fixed_sdram.c b/cpu/mpc512x/fixed_sdram.c index 442b5fc..72d524c 100644 --- a/cpu/mpc512x/fixed_sdram.c +++ b/cpu/mpc512x/fixed_sdram.c @@ -91,7 +91,7 @@ long int fixed_sdram(ddr512x_config_t *mddrc_config, }
/* Initialize IO Control */ - out_be32(&im->io_ctrl.io_control_mem, IOCTRL_MUX_DDR); + out_be32(&im->io_ctrl.io_control_mem, CONFIG_SYS_IOCTRL_MUX_DDR);
/* Initialize DDR Local Window */ out_be32(&im->sysconf.ddrlaw.bar, CONFIG_SYS_DDR_BASE & 0xFFFFF000); diff --git a/include/asm-ppc/immap_512x.h b/include/asm-ppc/immap_512x.h index 95350fd..1dc47e5 100644 --- a/include/asm-ppc/immap_512x.h +++ b/include/asm-ppc/immap_512x.h @@ -848,10 +848,6 @@ typedef struct ioctrl512x { u8 reserved[0x0cfc]; /* fill to 4096 bytes size */ } ioctrl512x_t;
-/* Indexes in regs array */ -/* Set for DDR */ -#define IOCTRL_MUX_DDR 0x00000036 - /* IO pin fields */ #define IO_PIN_FMUX(v) ((v) << 7) /* pin function */ #define IO_PIN_HOLD(v) ((v) << 5) /* hold time, pci only */ diff --git a/include/configs/aria.h b/include/configs/aria.h index f89fc57..a73c0c7 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -79,6 +79,8 @@ #define CONFIG_SYS_DDR_BASE 0x00000000 #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE
+#define CONFIG_SYS_IOCTRL_MUX_DDR 0x00000036 + /* DDR Controller Configuration * * SYS_CFG: diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index cccc31d..cafd6a7 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -67,6 +67,8 @@ #define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is sys memory*/ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE
+#define CONFIG_SYS_IOCTRL_MUX_DDR 0x00000036 + /* DDR Controller Configuration * * SYS_CFG: diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index fb49388..8ecc9e1 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -86,6 +86,8 @@ #define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE
Extend mpc512x serial driver to support multiple PSCs ports.
Supsequent patches for PDM360NG board support make use of this functionality by defining CONFIG_SERIAL_MULTI in the board config file. Additionally the used PSC devices are specified by defining e.g. CONFIG_SYS_PSC1, CONFIG_SYS_PSC4 and CONFIG_SYS_PSC6.
Support for PSC devices other than 1, 3, 4 and 6 is not added by this patch because these aren't used currently. In the future it can be easily added using DECLARE_PSC_SERIAL_FUNCTIONS(N) and INIT_PSC_SERIAL_STRUCTURE(N) macros in cpu/mpc512x/serial.c. Additionally you have to add code for registering added devices in serial_initialise() in common/serial.c.
Signed-off-by: Anatolij Gustschin agust@denx.de --- common/serial.c | 23 ++++ cpu/mpc512x/serial.c | 266 +++++++++++++++++++++++++++++++++++++----- include/asm-ppc/immap_512x.h | 108 +++++++++--------- include/serial.h | 8 ++ 4 files changed, 324 insertions(+), 81 deletions(-)
diff --git a/common/serial.c b/common/serial.c index 5f9ffd7..754e329 100644 --- a/common/serial.c +++ b/common/serial.c @@ -59,6 +59,14 @@ struct serial_device *__default_serial_console (void) #else return &serial0_device; #endif +#elif defined(CONFIG_MPC512X) +#if (CONFIG_PSC_CONSOLE == 3) + return &serial3_device; +#elif (CONFIG_PSC_CONSOLE == 6) + return &serial6_device; +#else +#error "Bad CONFIG_PSC_CONSOLE." +#endif #elif defined(CONFIG_S3C2410) #if defined(CONFIG_SERIAL1) return &s3c24xx_serial0_device; @@ -159,6 +167,20 @@ void serial_initialize (void) serial_register(&s5pc1xx_serial2_device); serial_register(&s5pc1xx_serial3_device); #endif +#if defined(CONFIG_MPC512X) +#if defined(CONFIG_SYS_PSC1) + serial_register(&serial1_device); +#endif +#if defined(CONFIG_SYS_PSC3) + serial_register(&serial3_device); +#endif +#if defined(CONFIG_SYS_PSC4) + serial_register(&serial4_device); +#endif +#if defined(CONFIG_SYS_PSC6) + serial_register(&serial6_device); +#endif +#endif serial_assign (default_serial_console ()->name); }
@@ -174,6 +196,7 @@ void serial_stdio_init (void) dev.flags = DEV_FLAGS_OUTPUT | DEV_FLAGS_INPUT;
dev.start = s->init; + dev.stop = s->uninit; dev.putc = s->putc; dev.puts = s->puts; dev.getc = s->getc; diff --git a/cpu/mpc512x/serial.c b/cpu/mpc512x/serial.c index ec2f41b..f421968 100644 --- a/cpu/mpc512x/serial.c +++ b/cpu/mpc512x/serial.c @@ -32,14 +32,16 @@ #include <common.h> #include <asm/io.h> #include <asm/processor.h> +#include <serial.h>
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_PSC_CONSOLE) +#if defined(CONFIG_PSC_CONSOLE) || defined(CONFIG_SERIAL_MULTI)
static void fifo_init (volatile psc512x_t *psc) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; + u32 tfsize, rfsize;
/* reset Rx & Tx fifo slice */ out_be32(&psc->rfcmd, PSC_FIFO_RESET_SLICE); @@ -49,8 +51,65 @@ static void fifo_init (volatile psc512x_t *psc) out_be32(&psc->rfintmask, 0); out_be32(&psc->tfintmask, 0);
- out_be32(&psc->tfsize, CONSOLE_FIFO_TX_SIZE | (CONSOLE_FIFO_TX_ADDR << 16)); - out_be32(&psc->rfsize, CONSOLE_FIFO_RX_SIZE | (CONSOLE_FIFO_RX_ADDR << 16)); +#if defined(CONFIG_SERIAL_MULTI) + switch (((u32)psc & 0xf00) >> 8) { + case 0: + tfsize = FIFOC_PSC0_TX_SIZE | (FIFOC_PSC0_TX_ADDR << 16); + rfsize = FIFOC_PSC0_RX_SIZE | (FIFOC_PSC0_RX_ADDR << 16); + break; + case 1: + tfsize = FIFOC_PSC1_TX_SIZE | (FIFOC_PSC1_TX_ADDR << 16); + rfsize = FIFOC_PSC1_RX_SIZE | (FIFOC_PSC1_RX_ADDR << 16); + break; + case 2: + tfsize = FIFOC_PSC2_TX_SIZE | (FIFOC_PSC2_TX_ADDR << 16); + rfsize = FIFOC_PSC2_RX_SIZE | (FIFOC_PSC2_RX_ADDR << 16); + break; + case 3: + tfsize = FIFOC_PSC3_TX_SIZE | (FIFOC_PSC3_TX_ADDR << 16); + rfsize = FIFOC_PSC3_RX_SIZE | (FIFOC_PSC3_RX_ADDR << 16); + break; + case 4: + tfsize = FIFOC_PSC4_TX_SIZE | (FIFOC_PSC4_TX_ADDR << 16); + rfsize = FIFOC_PSC4_RX_SIZE | (FIFOC_PSC4_RX_ADDR << 16); + break; + case 5: + tfsize = FIFOC_PSC5_TX_SIZE | (FIFOC_PSC5_TX_ADDR << 16); + rfsize = FIFOC_PSC5_RX_SIZE | (FIFOC_PSC5_RX_ADDR << 16); + break; + case 6: + tfsize = FIFOC_PSC6_TX_SIZE | (FIFOC_PSC6_TX_ADDR << 16); + rfsize = FIFOC_PSC6_RX_SIZE | (FIFOC_PSC6_RX_ADDR << 16); + break; + case 7: + tfsize = FIFOC_PSC7_TX_SIZE | (FIFOC_PSC7_TX_ADDR << 16); + rfsize = FIFOC_PSC7_RX_SIZE | (FIFOC_PSC7_RX_ADDR << 16); + break; + case 8: + tfsize = FIFOC_PSC8_TX_SIZE | (FIFOC_PSC8_TX_ADDR << 16); + rfsize = FIFOC_PSC8_RX_SIZE | (FIFOC_PSC8_RX_ADDR << 16); + break; + case 9: + tfsize = FIFOC_PSC9_TX_SIZE | (FIFOC_PSC9_TX_ADDR << 16); + rfsize = FIFOC_PSC9_RX_SIZE | (FIFOC_PSC9_RX_ADDR << 16); + break; + case 10: + tfsize = FIFOC_PSC10_TX_SIZE | (FIFOC_PSC10_TX_ADDR << 16); + rfsize = FIFOC_PSC10_RX_SIZE | (FIFOC_PSC10_RX_ADDR << 16); + break; + case 11: + tfsize = FIFOC_PSC11_TX_SIZE | (FIFOC_PSC11_TX_ADDR << 16); + rfsize = FIFOC_PSC11_RX_SIZE | (FIFOC_PSC11_RX_ADDR << 16); + break; + default: + return; + } +#else + tfsize = CONSOLE_FIFO_TX_SIZE | (CONSOLE_FIFO_TX_ADDR << 16); + rfsize = CONSOLE_FIFO_RX_SIZE | (CONSOLE_FIFO_RX_ADDR << 16); +#endif + out_be32(&psc->tfsize, tfsize); + out_be32(&psc->rfsize, rfsize);
/* enable Tx & Rx FIFO slice */ out_be32(&psc->rfcmd, PSC_FIFO_ENABLE_SLICE); @@ -60,24 +119,47 @@ static void fifo_init (volatile psc512x_t *psc) __asm__ volatile ("sync"); }
-void serial_setbrg(void) +void serial_setbrg_dev(unsigned int idx) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - volatile psc512x_t *psc = (psc512x_t *) &im->psc[CONFIG_PSC_CONSOLE]; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx]; unsigned long baseclk, div; + unsigned long baudrate; + char buf[16]; + char *br_env; + + baudrate = gd->baudrate; + if (idx != CONFIG_PSC_CONSOLE) { + /* Allows setting baudrate for other serial devices + * on PSCx using environment. If not specified, use + * the same baudrate as for console. + */ + sprintf(buf, "psc%d_baudrate", idx); + br_env = getenv(buf); + if (br_env) + baudrate = simple_strtoul(br_env, NULL, 10); + + debug("%s: idx %d, baudrate %d\n", __func__, idx, baudrate); + }
- /* calculate dividor for setting PSC CTUR and CTLR registers */ + /* calculate divisor for setting PSC CTUR and CTLR registers */ baseclk = (gd->ips_clk + 8) / 16; - div = (baseclk + (gd->baudrate / 2)) / gd->baudrate; + div = (baseclk + (baudrate / 2)) / baudrate;
out_8(&psc->ctur, (div >> 8) & 0xff); out_8(&psc->ctlr, div & 0xff); /* set baudrate */ }
-int serial_init(void) +int serial_init_dev(unsigned int idx) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - volatile psc512x_t *psc = (psc512x_t *) &im->psc[CONFIG_PSC_CONSOLE]; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx]; +#if defined(CONFIG_SERIAL_MULTI) + u32 reg; + + reg = in_be32(&im->clk.sccr[0]); + out_be32(&im->clk.sccr[0], reg | CLOCK_SCCR1_PSC_EN(idx)); +#endif
fifo_init (psc);
@@ -100,7 +182,7 @@ int serial_init(void) out_8(&psc->mode, PSC_MODE_1_STOPBIT);
/* set baudrate */ - serial_setbrg(); + serial_setbrg_dev(idx);
/* disable all interrupts */ out_be16(&psc->psc_imr, 0); @@ -113,13 +195,27 @@ int serial_init(void) return 0; }
-void serial_putc (const char c) +int serial_uninit_dev(unsigned int idx) +{ + volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx]; + u32 reg; + + out_8(&psc->command, PSC_RX_DISABLE | PSC_TX_DISABLE); + reg = in_be32(&im->clk.sccr[0]); + reg &= ~CLOCK_SCCR1_PSC_EN(idx); + out_be32(&im->clk.sccr[0], reg); + + return 0; +} + +void serial_putc_dev(unsigned int idx, const char c) { volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; - volatile psc512x_t *psc = (psc512x_t *) &im->psc[CONFIG_PSC_CONSOLE]; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx];
if (c == '\n') - serial_putc ('\r'); + serial_putc_dev(idx, '\r');
/* Wait for last character to go. */ while (!(in_be16(&psc->psc_status) & PSC_SR_TXEMP)) @@ -128,10 +224,10 @@ void serial_putc (const char c) out_8(&psc->tfdata_8, c); }
-void serial_putc_raw (const char c) +void serial_putc_raw_dev(unsigned int idx, const char c) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - volatile psc512x_t *psc = (psc512x_t *) &im->psc[CONFIG_PSC_CONSOLE]; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx];
/* Wait for last character to go. */ while (!(in_be16(&psc->psc_status) & PSC_SR_TXEMP)) @@ -140,18 +236,16 @@ void serial_putc_raw (const char c) out_8(&psc->tfdata_8, c); }
- -void serial_puts (const char *s) +void serial_puts_dev(unsigned int idx, const char *s) { - while (*s) { - serial_putc (*s++); - } + while (*s) + serial_putc_dev(idx, *s++); }
-int serial_getc (void) +int serial_getc_dev(unsigned int idx) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - volatile psc512x_t *psc = (psc512x_t *) &im->psc[CONFIG_PSC_CONSOLE]; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx];
/* Wait for a character to arrive. */ while (in_be32(&psc->rfstat) & PSC_FIFO_EMPTY) @@ -160,18 +254,18 @@ int serial_getc (void) return in_8(&psc->rfdata_8); }
-int serial_tstc (void) +int serial_tstc_dev(unsigned int idx) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - volatile psc512x_t *psc = (psc512x_t *) &im->psc[CONFIG_PSC_CONSOLE]; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx];
return !(in_be32(&psc->rfstat) & PSC_FIFO_EMPTY); }
-void serial_setrts(int s) +void serial_setrts_dev(unsigned int idx, int s) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - volatile psc512x_t *psc = (psc512x_t *) &im->psc[CONFIG_PSC_CONSOLE]; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx];
if (s) { /* Assert RTS (become LOW) */ @@ -183,11 +277,127 @@ void serial_setrts(int s) } }
-int serial_getcts(void) +int serial_getcts_dev(unsigned int idx) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - volatile psc512x_t *psc = (psc512x_t *) &im->psc[CONFIG_PSC_CONSOLE]; + volatile psc512x_t *psc = (psc512x_t *) &im->psc[idx];
return (in_8(&psc->ip) & 0x1) ? 0 : 1; } +#endif /* CONFIG_PSC_CONSOLE || CONFIG_SERIAL_MULTI */ + +#if defined(CONFIG_SERIAL_MULTI) + +#define DECLARE_PSC_SERIAL_FUNCTIONS(port) \ + int serial##port##_init(void) \ + { \ + return serial_init_dev(port); \ + } \ + int serial##port##_uninit(void) \ + { \ + return serial_uninit_dev(port); \ + } \ + void serial##port##_setbrg(void) \ + { \ + serial_setbrg_dev(port); \ + } \ + int serial##port##_getc(void) \ + { \ + return serial_getc_dev(port); \ + } \ + int serial##port##_tstc(void) \ + { \ + return serial_tstc_dev(port); \ + } \ + void serial##port##_putc(const char c) \ + { \ + serial_putc_dev(port, c); \ + } \ + void serial##port##_puts(const char *s) \ + { \ + serial_puts_dev(port, s); \ + } + +#define INIT_PSC_SERIAL_STRUCTURE(port, name, bus) { \ + name, \ + bus, \ + serial##port##_init, \ + serial##port##_uninit, \ + serial##port##_setbrg, \ + serial##port##_getc, \ + serial##port##_tstc, \ + serial##port##_putc, \ + serial##port##_puts, \ +} + +#if defined(CONFIG_SYS_PSC1) +DECLARE_PSC_SERIAL_FUNCTIONS(1); +struct serial_device serial1_device = +INIT_PSC_SERIAL_STRUCTURE(1, "psc1", "UART1"); +#endif + +#if defined(CONFIG_SYS_PSC3) +DECLARE_PSC_SERIAL_FUNCTIONS(3); +struct serial_device serial3_device = +INIT_PSC_SERIAL_STRUCTURE(3, "psc3", "UART3"); +#endif + +#if defined(CONFIG_SYS_PSC4) +DECLARE_PSC_SERIAL_FUNCTIONS(4); +struct serial_device serial4_device = +INIT_PSC_SERIAL_STRUCTURE(4, "psc4", "UART4"); +#endif + +#if defined(CONFIG_SYS_PSC6) +DECLARE_PSC_SERIAL_FUNCTIONS(6); +struct serial_device serial6_device = +INIT_PSC_SERIAL_STRUCTURE(6, "psc6", "UART6"); +#endif + +#else + +void serial_setbrg(void) +{ + serial_setbrg_dev(CONFIG_PSC_CONSOLE); +} + +int serial_init(void) +{ + return serial_init_dev(CONFIG_PSC_CONSOLE); +} + +void serial_putc(const char c) +{ + serial_putc_dev(CONFIG_PSC_CONSOLE, c); +} + +void serial_putc_raw(const char c) +{ + serial_putc_raw_dev(CONFIG_PSC_CONSOLE, c); +} + +void serial_puts(const char *s) +{ + serial_puts_dev(CONFIG_PSC_CONSOLE, s); +} + +int serial_getc(void) +{ + return serial_getc_dev(CONFIG_PSC_CONSOLE); +} + +int serial_tstc(void) +{ + return serial_tstc_dev(CONFIG_PSC_CONSOLE); +} + +void serial_setrts(int s) +{ + return serial_setrts_dev(CONFIG_PSC_CONSOLE, s); +} + +int serial_getcts(void) +{ + return serial_getcts_dev(CONFIG_PSC_CONSOLE); +} #endif /* CONFIG_PSC_CONSOLE */ diff --git a/include/asm-ppc/immap_512x.h b/include/asm-ppc/immap_512x.h index 1dc47e5..c430cb6 100644 --- a/include/asm-ppc/immap_512x.h +++ b/include/asm-ppc/immap_512x.h @@ -1112,66 +1112,68 @@ typedef struct fifoc512x { * * Overall size of FIFOC memory is not documented in the MPC5121e RM, but * tests indicate that it is 1024 words total. + * + * *_TX_SIZE and *_RX_SIZE is the number of 4-byte words for FIFO slice. */ -#define FIFOC_PSC0_TX_SIZE 0x0 /* number of 4-byte words for FIFO slice */ +#define FIFOC_PSC0_TX_SIZE 0x04 #define FIFOC_PSC0_TX_ADDR 0x0 -#define FIFOC_PSC0_RX_SIZE 0x0 -#define FIFOC_PSC0_RX_ADDR 0x0 +#define FIFOC_PSC0_RX_SIZE 0x04 +#define FIFOC_PSC0_RX_ADDR 0x10
-#define FIFOC_PSC1_TX_SIZE 0x0 -#define FIFOC_PSC1_TX_ADDR 0x0 -#define FIFOC_PSC1_RX_SIZE 0x0 -#define FIFOC_PSC1_RX_ADDR 0x0 +#define FIFOC_PSC1_TX_SIZE 0x04 +#define FIFOC_PSC1_TX_ADDR 0x20 +#define FIFOC_PSC1_RX_SIZE 0x04 +#define FIFOC_PSC1_RX_ADDR 0x30
-#define FIFOC_PSC2_TX_SIZE 0x0 -#define FIFOC_PSC2_TX_ADDR 0x0 -#define FIFOC_PSC2_RX_SIZE 0x0 -#define FIFOC_PSC2_RX_ADDR 0x0 +#define FIFOC_PSC2_TX_SIZE 0x04 +#define FIFOC_PSC2_TX_ADDR 0x40 +#define FIFOC_PSC2_RX_SIZE 0x04 +#define FIFOC_PSC2_RX_ADDR 0x50
#define FIFOC_PSC3_TX_SIZE 0x04 -#define FIFOC_PSC3_TX_ADDR 0x0 +#define FIFOC_PSC3_TX_ADDR 0x60 #define FIFOC_PSC3_RX_SIZE 0x04 -#define FIFOC_PSC3_RX_ADDR 0x10 - -#define FIFOC_PSC4_TX_SIZE 0x0 -#define FIFOC_PSC4_TX_ADDR 0x0 -#define FIFOC_PSC4_RX_SIZE 0x0 -#define FIFOC_PSC4_RX_ADDR 0x0 - -#define FIFOC_PSC5_TX_SIZE 0x0 -#define FIFOC_PSC5_TX_ADDR 0x0 -#define FIFOC_PSC5_RX_SIZE 0x0 -#define FIFOC_PSC5_RX_ADDR 0x0 - -#define FIFOC_PSC6_TX_SIZE 0x0 -#define FIFOC_PSC6_TX_ADDR 0x0 -#define FIFOC_PSC6_RX_SIZE 0x0 -#define FIFOC_PSC6_RX_ADDR 0x0 - -#define FIFOC_PSC7_TX_SIZE 0x0 -#define FIFOC_PSC7_TX_ADDR 0x0 -#define FIFOC_PSC7_RX_SIZE 0x0 -#define FIFOC_PSC7_RX_ADDR 0x0 - -#define FIFOC_PSC8_TX_SIZE 0x0 -#define FIFOC_PSC8_TX_ADDR 0x0 -#define FIFOC_PSC8_RX_SIZE 0x0 -#define FIFOC_PSC8_RX_ADDR 0x0 - -#define FIFOC_PSC9_TX_SIZE 0x0 -#define FIFOC_PSC9_TX_ADDR 0x0 -#define FIFOC_PSC9_RX_SIZE 0x0 -#define FIFOC_PSC9_RX_ADDR 0x0 - -#define FIFOC_PSC10_TX_SIZE 0x0 -#define FIFOC_PSC10_TX_ADDR 0x0 -#define FIFOC_PSC10_RX_SIZE 0x0 -#define FIFOC_PSC10_RX_ADDR 0x0 - -#define FIFOC_PSC11_TX_SIZE 0x0 -#define FIFOC_PSC11_TX_ADDR 0x0 -#define FIFOC_PSC11_RX_SIZE 0x0 -#define FIFOC_PSC11_RX_ADDR 0x0 +#define FIFOC_PSC3_RX_ADDR 0x70 + +#define FIFOC_PSC4_TX_SIZE 0x04 +#define FIFOC_PSC4_TX_ADDR 0x80 +#define FIFOC_PSC4_RX_SIZE 0x04 +#define FIFOC_PSC4_RX_ADDR 0x90 + +#define FIFOC_PSC5_TX_SIZE 0x04 +#define FIFOC_PSC5_TX_ADDR 0xa0 +#define FIFOC_PSC5_RX_SIZE 0x04 +#define FIFOC_PSC5_RX_ADDR 0xb0 + +#define FIFOC_PSC6_TX_SIZE 0x04 +#define FIFOC_PSC6_TX_ADDR 0xc0 +#define FIFOC_PSC6_RX_SIZE 0x04 +#define FIFOC_PSC6_RX_ADDR 0xd0 + +#define FIFOC_PSC7_TX_SIZE 0x04 +#define FIFOC_PSC7_TX_ADDR 0xe0 +#define FIFOC_PSC7_RX_SIZE 0x04 +#define FIFOC_PSC7_RX_ADDR 0xf0 + +#define FIFOC_PSC8_TX_SIZE 0x04 +#define FIFOC_PSC8_TX_ADDR 0x100 +#define FIFOC_PSC8_RX_SIZE 0x04 +#define FIFOC_PSC8_RX_ADDR 0x110 + +#define FIFOC_PSC9_TX_SIZE 0x04 +#define FIFOC_PSC9_TX_ADDR 0x120 +#define FIFOC_PSC9_RX_SIZE 0x04 +#define FIFOC_PSC9_RX_ADDR 0x130 + +#define FIFOC_PSC10_TX_SIZE 0x04 +#define FIFOC_PSC10_TX_ADDR 0x140 +#define FIFOC_PSC10_RX_SIZE 0x04 +#define FIFOC_PSC10_RX_ADDR 0x150 + +#define FIFOC_PSC11_TX_SIZE 0x04 +#define FIFOC_PSC11_TX_ADDR 0x160 +#define FIFOC_PSC11_RX_SIZE 0x04 +#define FIFOC_PSC11_RX_ADDR 0x170
/* * SATA diff --git a/include/serial.h b/include/serial.h index f2638ec..3f3edbc 100644 --- a/include/serial.h +++ b/include/serial.h @@ -9,6 +9,7 @@ struct serial_device { char ctlr[CTLRSIZE];
int (*init) (void); + int (*uninit) (void); void (*setbrg) (void); int (*getc) (void); int (*tstc) (void); @@ -37,6 +38,13 @@ extern struct serial_device eserial4_device;
#endif
+#if defined(CONFIG_MPC512X) +extern struct serial_device serial1_device; +extern struct serial_device serial3_device; +extern struct serial_device serial4_device; +extern struct serial_device serial6_device; +#endif + #if defined(CONFIG_S3C2410) extern struct serial_device s3c24xx_serial0_device; extern struct serial_device s3c24xx_serial1_device;
Signed-off-by: Anatolij Gustschin agust@denx.de --- cpu/mpc512x/serial.c | 87 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/serial.h | 7 ++++ 2 files changed, 94 insertions(+), 0 deletions(-)
diff --git a/cpu/mpc512x/serial.c b/cpu/mpc512x/serial.c index f421968..cb5bbf0 100644 --- a/cpu/mpc512x/serial.c +++ b/cpu/mpc512x/serial.c @@ -401,3 +401,90 @@ int serial_getcts(void) return serial_getcts_dev(CONFIG_PSC_CONSOLE); } #endif /* CONFIG_PSC_CONSOLE */ + +#if defined(CONFIG_SERIAL_MULTI) +#include <stdio_dev.h> +/* + * Routines for communication with serial devices over PSC + */ +/* Bitfield for initialized PSCs */ +static unsigned int initialized; + +struct stdio_dev *open_port(int num, int baudrate) +{ + struct stdio_dev *port; + char env_var[16]; + char env_val[10]; + char name[7]; + + if (num < 0 || num > 11) + return NULL; + + sprintf(name, "psc%d", num); + port = stdio_get_by_name(name); + if (!port) + return NULL; + + if (!test_bit(num, &initialized)) { + sprintf(env_var, "psc%d_baudrate", num); + sprintf(env_val, "%d", baudrate); + setenv(env_var, env_val); + + if (port->start()) + return NULL; + + set_bit(num, &initialized); + } + + return port; +} + +int close_port(int num) +{ + struct stdio_dev *port; + int ret; + char name[7]; + + if (num < 0 || num > 11) + return -1; + + sprintf(name, "psc%d", num); + port = stdio_get_by_name(name); + if (!port) + return -1; + + ret = port->stop(); + clear_bit(num, &initialized); + + return ret; +} + +int write_port(struct stdio_dev *port, char *buf) +{ + if (!port || !buf) + return -1; + + port->puts(buf); + + return 0; +} + +int read_port(struct stdio_dev *port, char *buf, int size) +{ + int cnt = 0; + + if (!port || !buf) + return -1; + + if (!size) + return 0; + + while (port->tstc()) { + buf[cnt++] = port->getc(); + if (cnt > size) + break; + } + + return cnt; +} +#endif /* CONFIG_SERIAL_MULTI */ diff --git a/include/serial.h b/include/serial.h index 3f3edbc..6423fba 100644 --- a/include/serial.h +++ b/include/serial.h @@ -92,4 +92,11 @@ extern int usbtty_tstc(void);
#endif /* CONFIG_USB_TTY */
+#if defined(CONFIG_MPC512X) && defined(CONFIG_SERIAL_MULTI) +extern struct stdio_dev *open_port(int num, int baudrate); +extern int close_port(int num); +extern int write_port(struct stdio_dev *port, char *buf); +extern int read_port(struct stdio_dev *port, char *buf, int size); +#endif + #endif
Allow displaying run length encoded bitmaps.
Signed-off-by: Anatolij Gustschin agust@denx.de --- board/freescale/common/fsl_diu_fb.c | 78 +++++++++++++++++++++++++++++++++++ 1 files changed, 78 insertions(+), 0 deletions(-)
diff --git a/board/freescale/common/fsl_diu_fb.c b/board/freescale/common/fsl_diu_fb.c index 2fc878b..d7c55b5 100644 --- a/board/freescale/common/fsl_diu_fb.c +++ b/board/freescale/common/fsl_diu_fb.c @@ -26,6 +26,7 @@ #include <common.h> #include <i2c.h> #include <malloc.h> +#include <bmp_layout.h>
#include "fsl_diu_fb.h"
@@ -464,6 +465,78 @@ static int allocate_buf(struct diu_addr *buf, u32 size, u32 bytes_align) return 0; }
+int display_rle8_bitmap(unsigned char *bmp, unsigned int *palette, + int yoff, int xoff) +{ + struct fb_info *info = &fsl_fb_info; + bmp_header_t *im = (bmp_header_t *)bmp; + unsigned char *bm; + unsigned int *fbp; + unsigned int cnt; + int decode = 1; + int x, y, bpp, i; + + x = 0; + y = __le32_to_cpu(im->height) - 1; + bpp = info->var.bits_per_pixel / 8; + fbp = (unsigned int *) ((unsigned int)info->screen_base + + (((y + yoff) * info->var.xres) + xoff) * bpp); + bm = bmp + __le32_to_cpu(im->data_offset); + + while (decode) { + switch (bm[0]) { + case 0: + switch (bm[1]) { + case 0: + /* scan line end marker */ + bm += 2; + x = 0; + y--; + fbp = (unsigned int *) + ((unsigned int)info->screen_base + + (((y + yoff) * info->var.xres) + + xoff) * bpp); + continue; + case 1: + /* end of bitmap data marker */ + decode = 0; + break; + case 2: + /* run offset marker */ + x += bm[2]; + y -= bm[3]; + fbp = (unsigned int *) + ((unsigned int)info->screen_base + + (((y + yoff) * info->var.xres) + + x + xoff) * bpp); + bm += 4; + break; + default: + /* unencoded run */ + cnt = bm[1]; + bm += 2; + for (i = 0; i < cnt; i++) { + *fbp++ = palette[bm[0]]; + bm++; + x++; + } + if (cnt & 1) + bm++; + } + break; + default: + /* encoded run */ + for (i = 0; i < bm[0]; i++) { + *fbp++ = palette[bm[1]]; + x++; + } + bm += 2; + break; + } + } + return __le32_to_cpu(im->height); +} + int fsl_diu_display_bmp(unsigned char *bmp, int xoffset, int yoffset, @@ -544,6 +617,11 @@ int fsl_diu_display_bmp(unsigned char *bmp, } break; case 8: + if (bmp[30] == BMP_BI_RLE8) { + return display_rle8_bitmap(bmp, palette, yoffset, + xoffset); + } + for (y = height - 1; y >= 0; y--) { fb_t = (unsigned int *) ((unsigned int)info->screen_base + (((y+yoffset) * info->var.xres) + xoffset)*cpp); for (x = 0; x < width; x++) {
Allow overriding defined partitions in the device tree blob using partition info defined in the 'mtdparts' environment variable.
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Gerald Van Baren vanbaren@cideas.com --- common/cmd_mtdparts.c | 2 +- common/fdt_support.c | 214 +++++++++++++++++++++++++++++++++++++++++++ include/fdt_support.h | 2 + include/jffs2/load_kernel.h | 1 + include/mtd_node.h | 11 ++ 5 files changed, 229 insertions(+), 1 deletions(-) create mode 100644 include/mtd_node.h
diff --git a/common/cmd_mtdparts.c b/common/cmd_mtdparts.c index b375fea..80c548b 100644 --- a/common/cmd_mtdparts.c +++ b/common/cmd_mtdparts.c @@ -776,7 +776,7 @@ static int device_del(struct mtd_device *dev) * @param num device number * @return NULL if requested device does not exist */ -static struct mtd_device* device_find(u8 type, u8 num) +struct mtd_device *device_find(u8 type, u8 num) { struct list_head *entry; struct mtd_device *dev_tmp; diff --git a/common/fdt_support.c b/common/fdt_support.c index f89a3ee..b6abf38 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -757,3 +757,217 @@ int fdt_fixup_nor_flash_size(void *blob, int cs, u32 size) return -1; } #endif + +#ifdef CONFIG_FDT_FIXUP_PARTITIONS +#include <jffs2/load_kernel.h> +#include <mtd_node.h> + +struct reg_cell { + unsigned int r0; + unsigned int r1; +}; + +int fdt_del_subnodes(const void *blob, int parent_offset) +{ + int off, ndepth; + int ret; + + for (ndepth = 0, off = fdt_next_node(blob, parent_offset, &ndepth); + (off >= 0) && (ndepth > 0); + off = fdt_next_node(blob, off, &ndepth)) { + if (ndepth == 1) { + debug("delete %s: offset: %x\n", + fdt_get_name(blob, off, 0), off); + ret = fdt_del_node((void *)blob, off); + if (ret < 0) { + printf("Can't delete node: %s\n", + fdt_strerror(ret)); + return ret; + } else { + ndepth = 0; + off = parent_offset; + } + } + } + return 0; +} + +int fdt_increase_size(void *fdt, int add_len) +{ + int newlen; + + newlen = fdt_totalsize(fdt) + add_len; + + /* Open in place with a new len */ + return fdt_open_into(fdt, fdt, newlen); +} + +int fdt_del_partitions(void *blob, int parent_offset) +{ + const void *prop; + int ndepth = 0; + int off; + int ret; + + off = fdt_next_node(blob, parent_offset, &ndepth); + if (off > 0 && ndepth == 1) { + prop = fdt_getprop(blob, off, "label", NULL); + if (prop == NULL) { + /* + * Could not find label property, nand {}; node? + * Check subnode, delete partitions there if any. + */ + return fdt_del_partitions(blob, off); + } else { + ret = fdt_del_subnodes(blob, parent_offset); + if (ret < 0) { + printf("Can't remove subnodes: %s\n", + fdt_strerror(ret)); + return ret; + } + } + } + return 0; +} + +int fdt_node_set_part_info(void *blob, int parent_offset, + struct mtd_device *dev) +{ + struct list_head *pentry; + struct part_info *part; + struct reg_cell cell; + int off, ndepth = 0; + int part_num, ret; + char buf[64]; + + ret = fdt_del_partitions(blob, parent_offset); + if (ret < 0) + return ret; + + /* + * Check if it is nand {}; subnode, adjust + * the offset in this case + */ + off = fdt_next_node(blob, parent_offset, &ndepth); + if (off > 0 && ndepth == 1) + parent_offset = off; + + part_num = 0; + list_for_each_prev(pentry, &dev->parts) { + int newoff; + + part = list_entry(pentry, struct part_info, link); + + debug("%2d: %-20s0x%08x\t0x%08x\t%d\n", + part_num, part->name, part->size, + part->offset, part->mask_flags); + + sprintf(buf, "partition@%x", part->offset); +add_sub: + ret = fdt_add_subnode(blob, parent_offset, buf); + if (ret == -FDT_ERR_NOSPACE) { + ret = fdt_increase_size(blob, 512); + if (!ret) + goto add_sub; + else + goto err_size; + } else if (ret < 0) { + printf("Can't add partition node: %s\n", + fdt_strerror(ret)); + return ret; + } + newoff = ret; + + /* Check MTD_WRITEABLE_CMD flag */ + if (part->mask_flags & 1) { +add_ro: + ret = fdt_setprop(blob, newoff, "read_only", NULL, 0); + if (ret == -FDT_ERR_NOSPACE) { + ret = fdt_increase_size(blob, 512); + if (!ret) + goto add_ro; + else + goto err_size; + } else if (ret < 0) + goto err_prop; + } + + cell.r0 = cpu_to_fdt32(part->offset); + cell.r1 = cpu_to_fdt32(part->size); +add_reg: + ret = fdt_setprop(blob, newoff, "reg", &cell, sizeof(cell)); + if (ret == -FDT_ERR_NOSPACE) { + ret = fdt_increase_size(blob, 512); + if (!ret) + goto add_reg; + else + goto err_size; + } else if (ret < 0) + goto err_prop; + +add_label: + ret = fdt_setprop_string(blob, newoff, "label", part->name); + if (ret == -FDT_ERR_NOSPACE) { + ret = fdt_increase_size(blob, 512); + if (!ret) + goto add_label; + else + goto err_size; + } else if (ret < 0) + goto err_prop; + + part_num++; + } + return 0; +err_size: + printf("Can't increase blob size: %s\n", fdt_strerror(ret)); + return ret; +err_prop: + printf("Can't add property: %s\n", fdt_strerror(ret)); + return ret; +} + +/* + * Update partitions in nor/nand nodes using info from + * mtdparts environment variable. The nodes to update are + * specified by node_info structure which contains mtd device + * type and compatible string: E. g. the board code in + * ft_board_setup() could use: + * + * struct node_info nodes[] = { + * { "fsl,mpc5121-nfc", MTD_DEV_TYPE_NAND, }, + * { "cfi-flash", MTD_DEV_TYPE_NOR, }, + * }; + * + * fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); + */ +void fdt_fixup_mtdparts(void *blob, void *node_info, int node_info_size) +{ + struct node_info *ni = node_info; + struct mtd_device *dev; + int i, idx; + int noff; + + if (mtdparts_init() != 0) + return; + + for (i = 0; i < node_info_size; i++) { + idx = 0; + noff = fdt_node_offset_by_compatible(blob, -1, ni[i].compat); + while (noff != -FDT_ERR_NOTFOUND) { + debug("%s: %s, mtd dev type %d\n", + fdt_get_name(blob, noff, 0), + ni[i].compat, ni[i].type); + dev = device_find(ni[i].type, idx++); + if (dev) { + if (fdt_node_set_part_info(blob, noff, dev)) + return; /* return on error */ + } + + /* Jump to next flash node */ + noff = fdt_node_offset_by_compatible(blob, noff, + ni[i].compat); + } + } +} +#endif diff --git a/include/fdt_support.h b/include/fdt_support.h index 0a9dd0d..a3d5f8c 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -81,5 +81,7 @@ int fdt_resize(void *blob);
int fdt_fixup_nor_flash_size(void *blob, int cs, u32 size);
+void fdt_fixup_mtdparts(void *fdt, void *node_info, int node_info_size); + #endif /* ifdef CONFIG_OF_LIBFDT */ #endif /* ifndef __FDT_SUPPORT_H */ diff --git a/include/jffs2/load_kernel.h b/include/jffs2/load_kernel.h index 8b2720e..906eb3d 100644 --- a/include/jffs2/load_kernel.h +++ b/include/jffs2/load_kernel.h @@ -78,5 +78,6 @@ struct mtdids { extern int mtdparts_init(void); extern int find_dev_and_part(const char *id, struct mtd_device **dev, u8 *part_num, struct part_info **part); +extern struct mtd_device *device_find(u8 type, u8 num);
#endif /* load_kernel_h */ diff --git a/include/mtd_node.h b/include/mtd_node.h new file mode 100644 index 0000000..5aae085 --- /dev/null +++ b/include/mtd_node.h @@ -0,0 +1,11 @@ +#ifndef _NODE_INFO +#define _NODE_INFO + +/* + * Info we use to search for a flash node in DTB. + */ +struct node_info { + const char *compat; /* compatible string */ + int type; /* mtd flash type */ +}; +#endif
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh.
Signed-off-by: Michael Weiss michael.weiss@ifm.com Signed-off-by: Anatolij Gustschin agust@denx.de --- MAKEALL | 1 + Makefile | 3 + board/freescale/common/fsl_diu_fb.c | 29 ++- board/pdm360ng/Makefile | 51 +++ board/pdm360ng/config.mk | 24 ++ board/pdm360ng/pdm360ng.c | 618 +++++++++++++++++++++++++++++++++++ cpu/mpc512x/diu.c | 14 +- include/configs/pdm360ng.h | 525 +++++++++++++++++++++++++++++ include/post.h | 1 + post/tests.c | 4 + 10 files changed, 1264 insertions(+), 6 deletions(-) create mode 100644 board/pdm360ng/Makefile create mode 100644 board/pdm360ng/config.mk create mode 100644 board/pdm360ng/pdm360ng.c create mode 100644 include/configs/pdm360ng.h
diff --git a/MAKEALL b/MAKEALL index 1e660b6..06ac650 100755 --- a/MAKEALL +++ b/MAKEALL @@ -93,6 +93,7 @@ LIST_512x=" \ aria \ mecp5123 \ mpc5121ads \ + pdm360ng \ "
######################################################################### diff --git a/Makefile b/Makefile index 524b9da..9003ef9 100644 --- a/Makefile +++ b/Makefile @@ -820,6 +820,9 @@ aria_config: unconfig mecp5123_config: unconfig @$(MKCONFIG) -a mecp5123 ppc mpc512x mecp5123 esd
+pdm360ng_config: unconfig + @$(MKCONFIG) -a pdm360ng ppc mpc512x pdm360ng + mpc5121ads_config \ mpc5121ads_rev2_config \ : unconfig diff --git a/board/freescale/common/fsl_diu_fb.c b/board/freescale/common/fsl_diu_fb.c index d7c55b5..5512bb2 100644 --- a/board/freescale/common/fsl_diu_fb.c +++ b/board/freescale/common/fsl_diu_fb.c @@ -51,6 +51,22 @@ struct fb_videomode { #define FB_SYNC_COMP_HIGH_ACT 8 /* composite sync high active */ #define FB_VMODE_NONINTERLACED 0 /* non interlaced */
+/* This setting is used for the ifm pdm360ng with PRIMEVIEW PM070WL3 */ +static struct fb_videomode fsl_diu_mode_800 = { + .refresh = 60, + .xres = 800, + .yres = 480, + .pixclock = 31250, + .left_margin = 86, + .right_margin = 42, + .upper_margin = 33, + .lower_margin = 10, + .hsync_len = 128, + .vsync_len = 2, + .sync = FB_SYNC_COMP_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT, + .vmode = FB_VMODE_NONINTERLACED +}; + /* * These parameters give default parameters * for video output 1024x768, @@ -211,9 +227,14 @@ int fsl_diu_init(int xres,
disable_lcdc();
- if (xres == 1280) { + switch (xres) { + case 800: + fsl_diu_mode_db = &fsl_diu_mode_800; + break; + case 1280: fsl_diu_mode_db = &fsl_diu_mode_1280; - } else { + break; + default: fsl_diu_mode_db = &fsl_diu_mode_1024; }
@@ -592,9 +613,9 @@ int fsl_diu_display_bmp(unsigned char *bmp, b = *bitmap++; for (k = 0; k < 8; k++) { if (b & 0x80) - *fb_t = palette[1]; + *fb_t++ = palette[1]; else - *fb_t = palette[0]; + *fb_t++ = palette[0]; b = b << 1; } } diff --git a/board/pdm360ng/Makefile b/board/pdm360ng/Makefile new file mode 100644 index 0000000..8513242 --- /dev/null +++ b/board/pdm360ng/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2007 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y := $(BOARD).o + +COBJS := $(COBJS-y) +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/pdm360ng/config.mk b/board/pdm360ng/config.mk new file mode 100644 index 0000000..56337e4 --- /dev/null +++ b/board/pdm360ng/config.mk @@ -0,0 +1,24 @@ +# +# (C) Copyright 2009 +# Michael Weiß, ifm ecomatic gmbh, michael.weiss@ifm.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +TEXT_BASE = 0xF0000000 diff --git a/board/pdm360ng/pdm360ng.c b/board/pdm360ng/pdm360ng.c new file mode 100644 index 0000000..f6e601d --- /dev/null +++ b/board/pdm360ng/pdm360ng.c @@ -0,0 +1,618 @@ +/* + * (C) Copyright 2009 Wolfgang Denk wd@denx.de + * + * (C) Copyright 2009 + * Michael Weiß, ifm ecomatic gmbh, michael.weiss@ifm.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <asm/bitops.h> +#include <command.h> +#include <asm/io.h> +#include <asm/processor.h> +#include <asm/mpc512x.h> +#include <fdt_support.h> +#ifdef CONFIG_MISC_INIT_R +#include <i2c.h> +#endif +#include <serial.h> +#include <post.h> +#include <jffs2/load_kernel.h> +#include <mtd_node.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Clocks in use */ +#define SCCR1_CLOCKS_EN (CLOCK_SCCR1_CFG_EN | \ + CLOCK_SCCR1_LPC_EN | \ + CLOCK_SCCR1_NFC_EN | \ + CLOCK_SCCR1_PSC_EN(CONFIG_PSC_CONSOLE) | \ + CLOCK_SCCR1_PSCFIFO_EN | \ + CLOCK_SCCR1_DDR_EN | \ + CLOCK_SCCR1_FEC_EN | \ + CLOCK_SCCR1_TPR_EN) + +#define SCCR2_CLOCKS_EN (CLOCK_SCCR2_MEM_EN | \ + CLOCK_SCCR2_SPDIF_EN | \ + CLOCK_SCCR2_DIU_EN | \ + CLOCK_SCCR2_I2C_EN) + +int board_early_init_f(void) +{ + volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; + + /* + * Initialize Local Window for FLASH-Bank1 access (CS1) + */ + out_be32(&im->sysconf.lpcs1aw, + CSAW_START(CONFIG_SYS_FLASH1_BASE) | + CSAW_STOP(CONFIG_SYS_FLASH1_BASE, CONFIG_SYS_FLASH1_SIZE) + ); + out_be32(&im->lpc.cs_cfg[1], CONFIG_SYS_CS1_CFG); + + /* + * Local Window for MRAM access (CS2) + */ + out_be32(&im->sysconf.lpcs2aw, + CSAW_START(CONFIG_SYS_MRAM_BASE) | + CSAW_STOP(CONFIG_SYS_MRAM_BASE, CONFIG_SYS_MRAM_SIZE) + ); + out_be32(&im->lpc.cs_cfg[2], CONFIG_SYS_CS2_CFG); + + sync_law(&im->sysconf.lpcs2aw); + + /* + * Configure Flash Speed + */ + out_be32(&im->lpc.cs_cfg[0], CONFIG_SYS_CS0_CFG); + out_be32(&im->lpc.altr, CONFIG_SYS_CS_ALETIMING); + + /* + * Enable clocks + */ + out_be32(&im->clk.sccr[0], SCCR1_CLOCKS_EN); + out_be32(&im->clk.sccr[1], SCCR2_CLOCKS_EN); +#if defined(CONFIG_IIM) || defined(CONFIG_CMD_FUSE) + setbits_be32(&im->clk.sccr[1], CLOCK_SCCR2_IIM_EN); +#endif + + return 0; +} + +phys_size_t initdram (int board_type) +{ + u32 pdm360ng_init_seq[] = { + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_PCHG_ALL, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_RFSH, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_RFSH, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_MICRON_INIT_DEV_OP, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_EM2, + CONFIG_SYS_DDRCMD_NOP, + CONFIG_SYS_DDRCMD_PCHG_ALL, + CONFIG_SYS_DDRCMD_EM2, + CONFIG_SYS_DDRCMD_EM3, + CONFIG_SYS_DDRCMD_EN_DLL, + CONFIG_SYS_DDRCMD_RES_DLL, + CONFIG_SYS_DDRCMD_PCHG_ALL, + CONFIG_SYS_DDRCMD_RFSH, + CONFIG_SYS_DDRCMD_RFSH, + CONFIG_SYS_MICRON_INIT_DEV_OP, + CONFIG_SYS_DDRCMD_OCD_DEFAULT, + CONFIG_SYS_DDRCMD_OCD_EXIT, + CONFIG_SYS_DDRCMD_PCHG_ALL, + CONFIG_SYS_DDRCMD_NOP + }; + + return fixed_sdram(NULL, pdm360ng_init_seq, + ARRAY_SIZE(pdm360ng_init_seq)); +} + +#if defined(CONFIG_SERIAL_MULTI) +static int set_lcd_brightness(char *); +#endif + +int misc_init_r(void) +{ + volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; + +#ifdef CONFIG_FSL_DIU_FB +# if !(defined(CONFIG_VIDEO) || defined(CONFIG_CFB_CONSOLE)) + mpc5121_diu_init(); +#endif +#if defined(CONFIG_SERIAL_MULTI) + set_lcd_brightness(0); +#endif + /* Switch LCD-Backlight and LVDS-Interface on */ + setbits_be32(&im->gpio.gpdir, 0x01040000); + clrsetbits_be32(&im->gpio.gpdat, 0x01000000, 0x00040000); +#endif + +#if defined(CONFIG_HARD_I2C) + if (!getenv("ethaddr")) { + uchar buf[6]; + char mac[18]; + int ret; + + /* I2C-0 for on-board eeprom */ + i2c_set_bus_num(CONFIG_SYS_I2C_EEPROM_BUS_NUM); + + /* Read ethaddr from EEPROM */ + ret = i2c_read(CONFIG_SYS_I2C_EEPROM, + CONFIG_SYS_I2C_EEPROM_MAC_OFFSET, 1, buf, 6); + if (!ret) { + sprintf(mac, "%02X:%02X:%02X:%02X:%02X:%02X", + buf[0], buf[1], buf[2], buf[3], buf[4], buf[5]); + /* Owned by IFM ? */ + if (strstr(mac, "00:02:01") != mac) { + printf("Illegal MAC address in EEPROM: %s\n", + mac); + } else { + debug("Using MAC from I2C EEPROM: %s\n", mac); + setenv("ethaddr", mac); + } + } else { + printf("Error: Unable to read MAC from I2C" + " EEPROM at address %02X:%02X\n", + CONFIG_SYS_I2C_EEPROM, + CONFIG_SYS_I2C_EEPROM_MAC_OFFSET); + } + } +#endif /* defined(CONFIG_HARD_I2C) */ + + return 0; +} + +static iopin_t ioregs_init[] = { + /* FUNC1=LPC_CS4 */ + { + offsetof(struct ioctrl512x, io_control_pata_ce1), 1, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(1) | + IO_PIN_PUE(1) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC1=CAN3_TX */ + { + offsetof(struct ioctrl512x, io_control_pata_isolate), 1, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC3=GPIO12 Sets Next 5 to GPIO pads */ + /* GPIO12-GPIO16 */ + { + offsetof(struct ioctrl512x, io_control_pata_ior), 5, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC2=DIU_LD22 Sets Next 2 to DIU_LD pads */ + /* DIU_LD22-DIU_LD23 */ + { + offsetof(struct ioctrl512x, io_control_pci_ad31), 2, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(1) + }, + /* FUNC2=USB1_DATA7 Sets Next 12 to USB1 pads */ + /* USB1_DATA7-USB1_DATA0, USB1_STOP, USB1_NEXT, USB1_CLK, USB1_DIR */ + { + offsetof(struct ioctrl512x, io_control_pci_ad29), 12, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(1) + }, + /* FUNC1=VIU_DATA0 Sets Next 3 to VIU_DATA pads */ + /* VIU_DATA0-VIU_DATA2 */ + { + offsetof(struct ioctrl512x, io_control_pci_ad17), 3, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(1) + }, + /* FUNC2=FEC_TXD_0 */ + { + offsetof(struct ioctrl512x, io_control_pci_ad14), 1, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(1) + }, + /* FUNC1=VIU_DATA3 Sets Next 2 to VIU_DATA pads */ + /* VIU_DATA3, VIU_DATA4 */ + { + offsetof(struct ioctrl512x, io_control_pci_ad13), 2, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(1) + }, + /* FUNC2=FEC_RXD_1 Sets Next 12 to FEC pads */ + /* FEC_RXD_1, FEC_RXD_0, FEC_RX_CLK, FEC_TX_CLK, FEC_RX_ER, FEC_RX_DV */ + /* FEC_TX_EN, FEC_TX_ER, FEC_CRS, FEC_MDC, FEC_MDIO, FEC_COL */ + { + offsetof(struct ioctrl512x, io_control_pci_ad11), 12, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(1) + }, + /* FUNC2=DIU_LD03 Sets Next 25 to DIU pads */ + /* DIU_LD00-DIU_LD21 */ + { + offsetof(struct ioctrl512x, io_control_pci_cbe0), 22, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(1) + }, + /* FUNC2=DIU_CLK Sets Next 3 to DIU pads */ + /* DIU_CLK, DIU_VSYNC, DIU_HSYNC */ + { + offsetof(struct ioctrl512x, io_control_spdif_txclk), 3, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC2=CAN3_RX */ + { + offsetof(struct ioctrl512x, io_control_irq1), 1, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* Sets lowest slew on 2 CAN_TX Pins*/ + { + offsetof(struct ioctrl512x, io_control_can1_tx), 2, 0, + IO_PIN_FMUX(0) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC3=CAN4_TX Sets Next 2 to CAN4 pads */ + /* CAN4_TX, CAN4_RX */ + { + offsetof(struct ioctrl512x, io_control_j1850_tx), 2, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC3=GPIO8 Sets Next 2 to GPIO pads */ + /* GPIO8, GPIO9 */ + { + offsetof(struct ioctrl512x, io_control_psc0_0), 2, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC1=FEC_TXD_1 Sets Next 3 to FEC pads */ + /* FEC_TXD_1, FEC_TXD_2, FEC_TXD_3 */ + { + offsetof(struct ioctrl512x, io_control_psc0_4), 3, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC1=FEC_RXD_3 Sets Next 2 to FEC pads */ + /* FEC_RXD_3, FEC_RXD_2 */ + { + offsetof(struct ioctrl512x, io_control_psc1_4), 2, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC3=GPIO17 */ + { + offsetof(struct ioctrl512x, io_control_psc2_1), 1, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC3=GPIO2/GPT2 Sets Next 3 to GPIO pads */ + /* GPIO2, GPIO20, GPIO21 */ + { + offsetof(struct ioctrl512x, io_control_psc2_4), 3, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC2=VIU_PIX_CLK */ + { + offsetof(struct ioctrl512x, io_control_psc3_4), 1, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC3=GPIO24 Sets Next 2 to GPIO pads */ + /* GPIO24, GPIO25 */ + { + offsetof(struct ioctrl512x, io_control_psc4_0), 2, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC1=NFC_CE2 */ + { + offsetof(struct ioctrl512x, io_control_psc4_4), 1, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(1) | + IO_PIN_PUE(1) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC2=VIU_DATA5 Sets Next 5 to VIU_DATA pads */ + /* VIU_DATA5-VIU_DATA9 */ + { + offsetof(struct ioctrl512x, io_control_psc5_0), 5, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC1=LPC_TSIZ1 Sets Next 2 to LPC_TSIZ pads */ + /* LPC_TSIZ1-LPC_TSIZ2 */ + { + offsetof(struct ioctrl512x, io_control_psc6_0), 2, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC1=LPC_TS */ + { + offsetof(struct ioctrl512x, io_control_psc6_4), 1, 0, + IO_PIN_FMUX(1) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + }, + /* FUNC3=GPIO16 Sets Next 5 to GPIO pads */ + /* GPIO16-GPIO19, GPT7/GPIO7 */ + { + offsetof(struct ioctrl512x, io_control_psc7_0), 5, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC3=GPIO20 Sets Next 2 to GPIO pads */ + /* GPIO20, GPIO21 */ + { + offsetof(struct ioctrl512x, io_control_psc8_0), 2, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC3=GPIO0/GPT0 */ + { + offsetof(struct ioctrl512x, io_control_psc8_4), 1, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC3=GPIO8 Sets Next 2 to GPIO pads */ + /* GPIO8, GPIO9 */ + { + offsetof(struct ioctrl512x, io_control_psc10_0), 2, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC3=GPIO2/GPT2 Sets Next 3 to GPIO pads */ + /* GPIO2, GPIO12, GPIO13 */ + { + offsetof(struct ioctrl512x, io_control_psc10_4), 3, 0, + IO_PIN_FMUX(3) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(0) + }, + /* FUNC2=DIU_DE */ + { + offsetof(struct ioctrl512x, io_control_psc11_4), 1, 0, + IO_PIN_FMUX(2) | IO_PIN_HOLD(0) | IO_PIN_PUD(0) | + IO_PIN_PUE(0) | IO_PIN_ST(0) | IO_PIN_DS(3) + } +}; + +int checkboard (void) +{ + volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; + + puts("Board: PDM360NG\n"); + + /* initialize function mux & slew rate IO inter alia on IO Pins */ + + iopin_initialize(ioregs_init, ARRAY_SIZE(ioregs_init)); + + /* initialize IO_CONTROL_GP (GPIO/GPT-mux-register) */ + setbits_be32(&im->io_ctrl.io_control_gp, (1 << 0)); /* GP_MUX7->GPIO7 */ + + /* configure GPIO24 (VIU_CE), output/high */ + setbits_be32(&im->gpio.gpdir, 0x80); + setbits_be32(&im->gpio.gpdat, 0x80); + + return 0; +} + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +#ifdef CONFIG_FDT_FIXUP_PARTITIONS +struct node_info nodes[] = { + { "fsl,mpc5121-nfc", MTD_DEV_TYPE_NAND, }, + { "cfi-flash", MTD_DEV_TYPE_NOR, }, +}; +#endif + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize); +#ifdef CONFIG_FDT_FIXUP_PARTITIONS + fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); +#endif +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ + +/* + * Co-Processor communication POST + */ +#if defined(CONFIG_POST) && defined(CONFIG_SERIAL_MULTI) + +#if defined(CONFIG_SYS_POST_WORD_ADDR) +# define _POST_ADDR (CONFIG_SYS_POST_WORD_ADDR) +#else +#error echo "No POST word address defined" +#endif + +void post_word_store(ulong a) +{ + volatile void *save_addr = (volatile void *)(_POST_ADDR); + + out_be32(save_addr, a); +} + +ulong post_word_load(void) +{ + volatile void *save_addr = (volatile void *)(_POST_ADDR); + + return in_be32(save_addr); +} + +/* + * Actually the termination sequence of the coprocessor + * commands is "\r\n" (CR LF), but here we use a side effect of + * the putc() routine of the serial driver which checks for LF + * and sends CR before sending LF. Therefore the termination + * sequence in the command below is only "\n". + * "alive" string is the coprocessor response for ping command + * and not a command, therefore it is terminated with "\r\n". + */ +char ping[] = "$PI;2C\n"; +char alive[] = "$AL;38\r\n"; + +#define PDM360NG_COPROC_READ_DELAY 5000 + +int pdm360ng_coprocessor_post_test(int flags) +{ + struct stdio_dev *cop_port; + int ret; + char buf[10]; + + /* Test IO Coprocessor communication */ + cop_port = open_port(4, 38400); + if (!cop_port) + return -1; + + write_port(cop_port, ping); + udelay(PDM360NG_COPROC_READ_DELAY); + + memset(buf, 0, sizeof(buf)); + ret = read_port(cop_port, buf, sizeof(buf)); + close_port(4); + if (ret <= 0) { + post_log("Error: Can't read IO Coprocessor port.\n"); + return -1; + } + + if (strcmp(buf, alive)) { + post_log("Error: IO-Cop. resp.: %s\n", buf); + return -1; + } + + /* Test WD Coprocessor communication */ + cop_port = open_port(1, 38400); + if (!cop_port) { + post_log("Error: Can't open WD Coprocessor port.\n"); + return -1; + } + + write_port(cop_port, ping); + udelay(PDM360NG_COPROC_READ_DELAY); + + memset(buf, 0, sizeof(buf)); + ret = read_port(cop_port, buf, sizeof(buf)); + close_port(1); + if (ret <= 0) { + post_log("Error: Can't read WD Coprocessor port.\n"); + return -1; + } + + if (strcmp(buf, alive)) { + post_log("Error: WD-Cop. resp.: %s\n", buf); + return -1; + } + + return 0; +} +#endif /* CONFIG_POST */ + +#if defined(CONFIG_SERIAL_MULTI) +/* + * If argument is NULL, set the LCD brightness to the + * value from "brightness" environment variable. Set + * the LCD brightness to the value specified by the + * argument otherwise. Default brightness is zero. + */ +#define MAX_BRIGHTNESS 99 +static int set_lcd_brightness(char *brightness) +{ + struct stdio_dev *cop_port; + char *env; + char cmd_buf[20]; + int val = 0; + int cs = 0; + int len, i; + + if (brightness) { + val = simple_strtol(brightness, NULL, 10); + } else { + env = getenv("brightness"); + if (env) + val = simple_strtol(env, NULL, 10); + } + + if (val < 0) + val = 0; + + if (val > MAX_BRIGHTNESS) + val = MAX_BRIGHTNESS; + + sprintf(cmd_buf, "$SB;%04d;", val); + + len = strlen(cmd_buf); + for (i = 1; i <= len; i++) + cs += cmd_buf[i]; + + cs = (~cs + 1) & 0xff; + sprintf(cmd_buf + len, "%02X\n", cs); + + /* IO Coprocessor communication */ + cop_port = open_port(4, 38400); + if (!cop_port) { + printf("Error: Can't open IO Coprocessor port.\n"); + return -1; + } + + debug("%s: cmd: %s", __func__, cmd_buf); + write_port(cop_port, cmd_buf); + /* + * Wait for transmission and maybe response data + * before closing the port. + */ + udelay(PDM360NG_COPROC_READ_DELAY); + memset(cmd_buf, 0, sizeof(cmd_buf)); + len = read_port(cop_port, cmd_buf, sizeof(cmd_buf)); + if (len) + printf("Error: %s\n", cmd_buf); + + close_port(4); + + return 0; +} + +static int cmd_lcd_brightness(cmd_tbl_t *cmdtp, int flag, + int argc, char *argv[]) +{ + if (argc < 2) { + cmd_usage(cmdtp); + return 1; + } + + return set_lcd_brightness(argv[1]); +} + +U_BOOT_CMD(lcdbr, 2, 1, cmd_lcd_brightness, + "set LCD brightness", + "<brightness> - set LCD backlight level to <brightness>.\n" +); +#endif /* CONFIG_SERIAL_MULTI */ diff --git a/cpu/mpc512x/diu.c b/cpu/mpc512x/diu.c index a24f395..fc43a9d 100644 --- a/cpu/mpc512x/diu.c +++ b/cpu/mpc512x/diu.c @@ -68,8 +68,13 @@ char *valid_bmp(char *addr) unsigned long h_addr;
h_addr = simple_strtoul(addr, NULL, 16); - if (h_addr < CONFIG_SYS_FLASH_BASE || - h_addr >= (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_FLASH_SIZE - 1)) { + if ((h_addr < CONFIG_SYS_FLASH_BASE || + h_addr >= (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_FLASH_SIZE - 1)) +#if defined(CONFIG_SYS_FLASH1_BASE) && defined(CONFIG_SYS_FLASH1_SIZE) + && (h_addr < CONFIG_SYS_FLASH1_BASE || + h_addr >= (CONFIG_SYS_FLASH1_BASE + CONFIG_SYS_FLASH1_SIZE - 1)) +#endif + ) { printf("bmp addr %lx is not a valid flash address\n", h_addr); return 0; } else if ((*(char *)(h_addr) != 'B') || (*(char *)(h_addr+1) != 'M')) { @@ -85,8 +90,13 @@ int mpc5121_diu_init(void) char *bmp = NULL; char *bmp_env;
+#ifdef CONFIG_PDM360NG + xres = 800; + yres = 480; +#else xres = 1024; yres = 768; +#endif pixel_format = 0x88883316;
debug("mpc5121_diu_init\n"); diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h new file mode 100644 index 0000000..5e59dd1 --- /dev/null +++ b/include/configs/pdm360ng.h @@ -0,0 +1,525 @@ +/* + * (C) Copyright 2009 + * Michael Weiß, ifm ecomatic gmbh, michael.weiss@ifm.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * pdm360ng board configuration file + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#undef DEBUG + +#define CONFIG_PDM360NG 1 +#define CONFIG_PDM360NG_BIG /* PDM360NG with big memory */ +#undef CONFIG_PDM360NG_SMALL /* PDM360NG with small memory */ + +/* + * Memory map for the PDM360NG board: + * + * 0x0000_0000 - 0x1FFF_FFFF DDR RAM (512 MB) + * 0x2000_0000 - 0x3FFF_FFFF reserved (DDR RAM (512 MB) + * 0x5000_0000 - 0x5001_FFFF SRAM (128 KB) + * 0x5004_0000 - 0x5005_FFFF MRAM (CS2) (128 KB) + * 0x8000_0000 - 0x803F_FFFF IMMR (4 MB) + * 0xF000_0000 - 0xF7FF_FFFF NOR FLASH (CS0) (128 MB) + * 0xF800_0000 - 0xFFFF_FFFF NOR FLASH (CS1) (128 MB) + */ + +/* + * High Level Configuration Options + */ +#define CONFIG_E300 1 /* E300 Family */ +#define CONFIG_MPC512X 1 /* MPC512X family */ +#define CONFIG_FSL_DIU_FB 1 /* FSL DIU */ +#undef CONFIG_FSL_DIU_LOGO_BMP /* Don't include FSL DIU binary bmp */ + +/* Used for silent command in environment */ +#define CONFIG_SYS_DEVICE_NULLDEV +#define CONFIG_SILENT_CONSOLE + +/* Video */ +#undef CONFIG_VIDEO + +#if defined(CONFIG_VIDEO) +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#endif + +#define CONFIG_SYS_MPC512X_CLKIN 33333333 /* in Hz */ + +#define CONFIG_BOARD_EARLY_INIT_F /* call board_early_init_f() */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_SYS_IMMR 0x80000000 +#define CONFIG_SYS_DIU_ADDR ((CONFIG_SYS_IMMR) + 0x2100) + +#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest region */ +#define CONFIG_SYS_MEMTEST_END 0x00400000 + +/* + * DDR Setup - manually set all parameters as there's no SPD etc. + */ +#ifdef CONFIG_PDM360NG_BIG +#define CONFIG_SYS_DDR_SIZE 512 /* MB */ +#elif defined CONFIG_PDM360NG_SMALL +#define CONFIG_SYS_DDR_SIZE 128 /* MB */ +#else +#error No memory configuration level defined! +#endif +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE + +#define CONFIG_SYS_IOCTRL_MUX_DDR 0x00000012 /* DDR pin mux and slew rate */ + +/* DDR Controller Configuration for Micron DDR2 SDRAM MT47H128M8-3 + * + * SYS_CFG: + * [31:31] MDDRC Soft Reset: Diabled + * [30:30] DRAM CKE pin: Enabled + * [29:29] DRAM CLK: Enabled + * [28:28] Command Mode: Enabled (For initialization only) + * [27:25] DRAM Row Select: dram_row[15:0] = magenta_address[25:10] + * [24:21] DRAM Bank Select: dram_bank[1:0] = magenta_address[11:10] + * [20:19] Read Test: DON'T USE + * [18:18] Self Refresh: Enabled + * [17:17] 16bit Mode: Disabled + * [16:13] Read Delay: 3 + * [12:12] Half DQS Delay: Disabled + * [11:11] Quarter DQS Delay: Disabled + * [10:08] Write Delay: 2 + * [07:07] Early ODT: Disabled + * [06:06] On DIE Termination: Enabled + * [05:05] FIFO Overflow Clear: DON'T USE here + * [04:04] FIFO Underflow Clear: DON'T USE here + * [03:03] FIFO Overflow Pending: DON'T USE here + * [02:02] FIFO Underlfow Pending: DON'T USE here + * [01:01] FIFO Overlfow Enabled: Enabled + * [00:00] FIFO Underflow Enabled: Enabled + * TIME_CFG0 + * [31:16] DRAM Refresh Time: 0 CSB clocks + * [15:8] DRAM Command Time: 0 CSB clocks + * [07:00] DRAM Precharge Time: 0 CSB clocks + * TIME_CFG1 + * [31:26] DRAM tRFC: + * [25:21] DRAM tWR1: + * [20:17] DRAM tWRT1: + * [16:11] DRAM tDRR: + * [10:05] DRAM tRC: + * [04:00] DRAM tRAS: + * TIME_CFG2 + * [31:28] DRAM tRCD: + * [27:23] DRAM tFAW: + * [22:19] DRAM tRTW1: + * [18:15] DRAM tCCD: + * [14:10] DRAM tRTP: + * [09:05] DRAM tRP: + * [04:00] DRAM tRPA + */ + +#ifdef CONFIG_PDM360NG_BIG +#define CONFIG_SYS_MDDRC_SYS_CFG 0xEA804A40 +#define CONFIG_SYS_MDDRC_TIME_CFG0 0x030C3D2E +#define CONFIG_SYS_MDDRC_TIME_CFG1 0x68EC1168 +#define CONFIG_SYS_MDDRC_TIME_CFG2 0x34310864 + +#elif defined CONFIG_PDM360NG_SMALL +#define CONFIG_SYS_MDDRC_SYS_CFG 0xE8604A40 +#define CONFIG_SYS_MDDRC_TIME_CFG0 0x030C3D2E +#define CONFIG_SYS_MDDRC_TIME_CFG1 0x3CEC1168 +#define CONFIG_SYS_MDDRC_TIME_CFG2 0x33310863 +#else +#error No memory configuration level defined! +#endif + +#define CONFIG_SYS_MDDRC_SYS_CFG_EN 0xF0000000 + +#define CONFIG_SYS_DDRCMD_NOP 0x01380000 +#define CONFIG_SYS_DDRCMD_PCHG_ALL 0x01100400 +#define CONFIG_SYS_DDRCMD_EM2 0x01020000 /* EMR2 */ +#define CONFIG_SYS_DDRCMD_EM3 0x01030000 /* EMR3 */ +#define CONFIG_SYS_DDRCMD_EN_DLL 0x01010040 /* EMR with 150 ohm ODT todo: verify*/ +#define CONFIG_SYS_DDRCMD_RES_DLL 0x01000100 +#define CONFIG_SYS_DDRCMD_RFSH 0x01080000 +#define CONFIG_SYS_MICRON_INIT_DEV_OP 0x01000432 +#define CONFIG_SYS_DDRCMD_OCD_DEFAULT 0x010107C0 /* EMR with 150 ohm ODT todo: verify*/ +#define CONFIG_SYS_DDRCMD_OCD_EXIT 0x01010440 /* EMR new command with 150 ohm ODT todo: verify*/ + +/* DDR Priority Manager Configuration */ +#define CONFIG_SYS_MDDRCGRP_PM_CFG1 0x00077777 +#define CONFIG_SYS_MDDRCGRP_PM_CFG2 0x00000000 +#define CONFIG_SYS_MDDRCGRP_HIPRIO_CFG 0x00000001 +#define CONFIG_SYS_MDDRCGRP_LUT0_MU 0xFFEEDDCC +#define CONFIG_SYS_MDDRCGRP_LUT0_ML 0xBBAAAAAA +#define CONFIG_SYS_MDDRCGRP_LUT1_MU 0x66666666 +#define CONFIG_SYS_MDDRCGRP_LUT1_ML 0x55555555 +#define CONFIG_SYS_MDDRCGRP_LUT2_MU 0x44444444 +#define CONFIG_SYS_MDDRCGRP_LUT2_ML 0x44444444 +#define CONFIG_SYS_MDDRCGRP_LUT3_MU 0x55555555 +#define CONFIG_SYS_MDDRCGRP_LUT3_ML 0x55555558 +#define CONFIG_SYS_MDDRCGRP_LUT4_MU 0x11111111 +#define CONFIG_SYS_MDDRCGRP_LUT4_ML 0x11111122 +#define CONFIG_SYS_MDDRCGRP_LUT0_AU 0xaaaaaaaa +#define CONFIG_SYS_MDDRCGRP_LUT0_AL 0xaaaaaaaa +#define CONFIG_SYS_MDDRCGRP_LUT1_AU 0x66666666 +#define CONFIG_SYS_MDDRCGRP_LUT1_AL 0x66666666 +#define CONFIG_SYS_MDDRCGRP_LUT2_AU 0x11111111 +#define CONFIG_SYS_MDDRCGRP_LUT2_AL 0x11111111 +#define CONFIG_SYS_MDDRCGRP_LUT3_AU 0x11111111 +#define CONFIG_SYS_MDDRCGRP_LUT3_AL 0x11111111 +#define CONFIG_SYS_MDDRCGRP_LUT4_AU 0x11111111 +#define CONFIG_SYS_MDDRCGRP_LUT4_AL 0x11111111 + +/* + * NOR FLASH on the Local Bus + */ +#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ + +#ifdef CONFIG_PDM360NG_BIG +#define CONFIG_SYS_FLASH_BASE 0xF0000000 /* start of FLASH-Bank0 */ +#define CONFIG_SYS_FLASH1_BASE 0xF8000000 /* start of FLASH-Bank1 */ +#define CONFIG_SYS_FLASH_SIZE 0x08000000 /* max flash size of FLASH-Bank0 in bytes */ +#define CONFIG_SYS_FLASH1_SIZE 0x08000000 /* max flash size of FLASH-Bank1 in bytes */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max sectors per device */ + /* 512 sectors with size 0x40000 for 128MB*/ +#elif defined CONFIG_PDM360NG_SMALL +#define CONFIG_SYS_FLASH_BASE 0xF0000000 /* start of FLASH-Bank0 */ +#define CONFIG_SYS_FLASH1_BASE 0xF4000000 /* start of FLASH-Bank1 */ +#define CONFIG_SYS_FLASH_SIZE 0x04000000 /* max flash size of FLASH-Bank0 in bytes */ +#define CONFIG_SYS_FLASH1_SIZE 0x04000000 /* max flash size of FLASH-Bank1 in bytes */ +#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ + /* 256 sectors with size 0x40000 for 64MB*/ +#else +#error No memory configuration level defined! +#endif + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH1_BASE} + +#undef CONFIG_SYS_FLASH_CHECKSUM + +#define CONFIG_SYS_SRAM_BASE 0x50000000 +#define CONFIG_SYS_SRAM_SIZE 0x00020000 /* 128 KB */ + +#define CONFIG_SYS_CS0_CFG 0x05059350 /* ALE active low, data size 4bytes */ +#define CONFIG_SYS_CS1_CFG 0x05059350 /* ALE active low, data size 4bytes */ + +#define CONFIG_SYS_MRAM_BASE 0x50040000 +#define CONFIG_SYS_MRAM_SIZE 0x00020000 +#define CONFIG_SYS_CS2_CFG 0x05059150 /* ALE active low, data size 4bytes */ + +#define CONFIG_SYS_CS_ALETIMING 0x00000007 /* alt. CS timing for CS0, CS1, CS2 */ + +/* + * NAND FLASH + */ +#define CONFIG_CMD_NAND /* enable NAND support */ +#define CONFIG_NAND_MPC5121_NFC +#define CONFIG_SYS_NAND_BASE 0x40000000 + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE +#define CONFIG_SYS_NAND_SELECT_DEVICE /* driver supports mutipl. chips */ + +/* + * Configuration parameters for MPC5121 NAND driver + */ +#define CONFIG_FSL_NFC_WIDTH 1 +#define CONFIG_FSL_NFC_WRITE_SIZE 2048 +#define CONFIG_FSL_NFC_SPARE_SIZE 64 +#define CONFIG_FSL_NFC_CHIPS CONFIG_SYS_MAX_NAND_DEVICE + +/* + * Dynamic MTD partition support + */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_FLASH_CFI_MTD +#define MTDIDS_DEFAULT "nor0=f0000000.flash,nor1=f8000000.flash," \ + "nand0=MPC5121 NAND" + +/* + * Flash layout + */ +#define MTDPARTS_DEFAULT "mtdparts=f0000000.flash:512k(u-boot)," \ + "256k(environment1)," \ + "256k(environment2)," \ + "256k(splash-factory)," \ + "2m(FIT: recovery)," \ + "4608k(fs-recovery)," \ + "256k(splash-customer),"\ + "5m(FIT: kernel+dtb)," \ + "64m(rootfs squash)ro," \ + "51m(userfs ubi);" \ + "f8000000.flash:-(unused);" \ + "MPC5121 NAND:1024m(extended-userfs)" + +/* + * Override partitions in device tree using info + * in mtdparts env. variable. + */ +#ifdef CONFIG_CMD_MTDPARTS +#define CONFIG_FDT_FIXUP_PARTITIONS +#endif + +/* Use SRAM for initial stack */ +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_SRAM_SIZE /* End of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_SIZE 0x100 /* num bytes initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_POST_WORD_ADDR (CONFIG_SYS_GBL_DATA_OFFSET - 0x4) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_POST_WORD_ADDR + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE /* Start of monitor */ +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) /* Reserve 512 kB for Mon */ +#ifdef CONFIG_FSL_DIU_FB +#define CONFIG_SYS_MALLOC_LEN (6 * 1024 * 1024) /* Reserved for malloc */ +#else +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) +#endif + +/* + * Serial Port + */ +#define CONFIG_CONS_INDEX 1 +#undef CONFIG_SERIAL_SOFTWARE_FIFO + +/* + * Serial console configuration + */ +#define CONFIG_PSC_CONSOLE 6 /* console is on PSC6 */ +#if CONFIG_PSC_CONSOLE != 6 +#error CONFIG_PSC_CONSOLE must be 6 +#endif +#define CONFIG_BAUDRATE 115200 /* ... at 115200 bps */ +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + +#define CONSOLE_FIFO_TX_SIZE FIFOC_PSC6_TX_SIZE +#define CONSOLE_FIFO_TX_ADDR FIFOC_PSC6_TX_ADDR +#define CONSOLE_FIFO_RX_SIZE FIFOC_PSC6_RX_SIZE +#define CONSOLE_FIFO_RX_ADDR FIFOC_PSC6_RX_ADDR + +/* + * Used PSC UART devices + */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_SYS_PSC1 +#define CONFIG_SYS_PSC4 +#define CONFIG_SYS_PSC6 + +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +/* I2C */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* so disable bit-banged I2C */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE +#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F + +/* + * MAC addr in EEPROM + */ +#define CONFIG_SYS_I2C_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM 0x50 +#define CONFIG_SYS_I2C_EEPROM_MAC_OFFSET 0x10 + +/* + * Enabled only to delete ethaddr before testing + * ethaddr setting from EEPROM + */ +#define CONFIG_ENV_OVERWRITE + +/* + * IIM - IC Identification Module + */ +#undef CONFIG_IIM + +/* + * EEPROM configuration + */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* 16-bit EEPROM address */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Atmel: AT24C32A-10TQ-2.7 */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* 10ms of delay */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* 32-Byte Page Write Mode */ + +/* + * Ethernet configuration + */ +#define CONFIG_MPC512x_FEC 1 +#define CONFIG_NET_MULTI +#define CONFIG_PHY_ADDR 0x1F +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_FEC_AN_TIMEOUT 1 +#define CONFIG_HAS_ETH0 + +/* + * Configure on-board RTC + */ +#define CONFIG_RTC_M41T62 /* use M41T62 rtc via i2 */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* at address 0x68 */ + +/* + * Environment + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +/* This has to be a multiple of the Flash sector size */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x40000 /* one sector (256K) for env */ + +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_DATE +#undef CONFIG_CMD_FUSE + +/* + * Watchdog timeout = CONFIG_SYS_WATCHDOG_VALUE * 65536 / IPS clock. + * For example, when IPS is set to 66MHz and CONFIG_SYS_WATCHDOG_VALUE is set + * to 0xFFFF, watchdog timeouts after about 64s. For details refer + * to chapter 36 of the MPC5121e Reference Manual. + */ +#undef CONFIG_WATCHDOG /* disable watchdog */ +#define CONFIG_SYS_WATCHDOG_VALUE 0xFFFF + + /* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ + +#ifdef CONFIG_CMD_KGDB + #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else + #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 8 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/ + +/* Cache Configuration */ +#define CONFIG_SYS_DCACHE_SIZE 32768 +#define CONFIG_SYS_CACHELINE_SIZE 32 +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ +#endif + +#define CONFIG_SYS_HID0_INIT 0x000000000 +#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK | HID0_ICE) +#define CONFIG_SYS_HID2 HID2_HBE + +#define CONFIG_HIGH_BATS 1 /* High BATs supported */ + +/* + * Internal Definitions + * + * Boot Flags + */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed of kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +#ifdef CONFIG_SERIAL_MULTI +/* POST support */ +#define CONFIG_POST (CONFIG_SYS_POST_COPROC) + +#define CONFIG_POST_COPROC {\ + "Coprocessors communication test", \ + "coproc_com", \ + "This test checks communication with coprocessors.", \ + POST_RAM | POST_ALWAYS | POST_CRITICAL, \ + &pdm360ng_coprocessor_post_test, \ + NULL, \ + NULL, \ + CONFIG_SYS_POST_COPROC \ + } +#endif + +/* + * Environment Configuration + */ +#define CONFIG_TIMESTAMP + +#define CONFIG_HOSTNAME pdm360ng +#define CONFIG_LOADADDR 400000 /* default location for tftp and bootm */ + +#define CONFIG_BOOTDELAY 5 /* -1 disables auto-boot */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs */ + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_PREBOOT "echo;" \ + "echo PDM360NG SAMPLE;" \ + "echo" + +#define CONFIG_BOOTCOMMAND "run env_cont" + +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_SUPPORT_OLD_DEVICE_TREES 1 + +#define OF_CPU "PowerPC,5121@0" +#define OF_SOC_COMPAT "fsl,mpc5121-immr" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc@80000000/serial@11600" + +#endif /* __CONFIG_H */ diff --git a/include/post.h b/include/post.h index 9fcd3ce..d147103 100644 --- a/include/post.h +++ b/include/post.h @@ -119,6 +119,7 @@ extern int post_hotkeys_pressed(void); #define CONFIG_SYS_POST_BSPEC4 0x00080000 #define CONFIG_SYS_POST_BSPEC5 0x00100000 #define CONFIG_SYS_POST_CODEC 0x00200000 +#define CONFIG_SYS_POST_COPROC 0x00400000
diff --git a/post/tests.c b/post/tests.c index 3224f00..06e9dc0 100644 --- a/post/tests.c +++ b/post/tests.c @@ -53,6 +53,7 @@ extern int gdc_post_test (int flags); extern int fpga_post_test (int flags); extern int lwmon5_watchdog_post_test(int flags); extern int sysmon1_post_test(int flags); +extern int pdm360ng_coprocessor_post_test(int flags);
extern int sysmon_init_f (void);
@@ -286,6 +287,9 @@ struct post_test post_list[] = #if CONFIG_POST & CONFIG_SYS_POST_BSPEC5 CONFIG_POST_BSPEC5, #endif +#if CONFIG_POST & CONFIG_SYS_POST_COPROC + CONFIG_POST_COPROC, +#endif };
unsigned int post_list_size = sizeof (post_list) / sizeof (struct post_test);
Hi Anatolij,
this looks pretty good - only a few remarks below.
Please fix the e-mail format.
- pdm360ng \
- @$(MKCONFIG) -a pdm360ng ppc mpc512x pdm360ng
Keep the list of targets sorted in the Makefile please.
- .refresh = 60,
- .xres = 800,
- .yres = 480,
- .pixclock = 31250,
- .left_margin = 86,
- .right_margin = 42,
- .upper_margin = 33,
- .lower_margin = 10,
- .hsync_len = 128,
- .vsync_len = 2,
- .sync = FB_SYNC_COMP_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT,
- .vmode = FB_VMODE_NONINTERLACED
- These parameters give default parameters
- for video output 1024x768,
disable_lcdc();
- switch (xres) {
- case 800:
break;
- case 1280: fsl_diu_mode_db = &fsl_diu_mode_1280;
- } else {
break;
- default: fsl_diu_mode_db = &fsl_diu_mode_1024; }
*fb_t = palette[1];
*fb_t = palette[0];
- $(AR) $(ARFLAGS) $@ $(OBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
- (C) Copyright 2009 Wolfgang Denk wd@denx.de
- Michael Weiß, ifm ecomatic gmbh, michael.weiss@ifm.com
- project.
- MA 02111-1307 USA
CLOCK_SCCR1_TPR_EN)
CLOCK_SCCR2_I2C_EN)
- volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR;
- out_be32(&im->sysconf.lpcs1aw,
- out_be32(&im->lpc.cs_cfg[1], CONFIG_SYS_CS1_CFG);
- out_be32(&im->sysconf.lpcs2aw,
- out_be32(&im->lpc.cs_cfg[2], CONFIG_SYS_CS2_CFG);
- sync_law(&im->sysconf.lpcs2aw);
- out_be32(&im->lpc.cs_cfg[0], CONFIG_SYS_CS0_CFG);
- out_be32(&im->lpc.altr, CONFIG_SYS_CS_ALETIMING);
* Enable clocks
- out_be32(&im->clk.sccr[0], SCCR1_CLOCKS_EN);
- out_be32(&im->clk.sccr[1], SCCR2_CLOCKS_EN);
- setbits_be32(&im->clk.sccr[1], CLOCK_SCCR2_IIM_EN);
- u32 pdm360ng_init_seq[] = {
- return fixed_sdram(NULL, pdm360ng_init_seq,
- mpc5121_diu_init();
- set_lcd_brightness(0);
- /* Switch LCD-Backlight and LVDS-Interface on */
- setbits_be32(&im->gpio.gpdir, 0x01040000);
- clrsetbits_be32(&im->gpio.gpdat, 0x01000000, 0x00040000);
- if (!getenv("ethaddr")) {
uchar buf[6];
char mac[18];
int ret;
if (!ret) {
mac);
} else {
} else {
- /* FUNC1=LPC_CS4 */
- /* FUNC1=CAN3_TX */
- /* FUNC3=GPIO12 Sets Next 5 to GPIO pads */
- /* GPIO12-GPIO16 */
- /* FUNC2=DIU_LD22 Sets Next 2 to DIU_LD pads */
- /* DIU_LD22-DIU_LD23 */
- /* FUNC2=USB1_DATA7 Sets Next 12 to USB1 pads */
- /* USB1_DATA7-USB1_DATA0, USB1_STOP, USB1_NEXT, USB1_CLK, USB1_DIR */
- /* FUNC1=VIU_DATA0 Sets Next 3 to VIU_DATA pads */
- /* VIU_DATA0-VIU_DATA2 */
- /* FUNC2=FEC_TXD_0 */
- /* FUNC1=VIU_DATA3 Sets Next 2 to VIU_DATA pads */
- /* VIU_DATA3, VIU_DATA4 */
- /* FUNC2=FEC_RXD_1 Sets Next 12 to FEC pads */
- /* FEC_RXD_1, FEC_RXD_0, FEC_RX_CLK, FEC_TX_CLK, FEC_RX_ER, FEC_RX_DV */
- /* FEC_TX_EN, FEC_TX_ER, FEC_CRS, FEC_MDC, FEC_MDIO, FEC_COL */
- /* FUNC2=DIU_LD03 Sets Next 25 to DIU pads */
- /* DIU_LD00-DIU_LD21 */
- /* FUNC2=DIU_CLK Sets Next 3 to DIU pads */
- /* DIU_CLK, DIU_VSYNC, DIU_HSYNC */
- /* FUNC2=CAN3_RX */
- /* Sets lowest slew on 2 CAN_TX Pins*/
- /* FUNC3=CAN4_TX Sets Next 2 to CAN4 pads */
- /* CAN4_TX, CAN4_RX */
- /* FUNC3=GPIO8 Sets Next 2 to GPIO pads */
- /* GPIO8, GPIO9 */
- /* FUNC1=FEC_TXD_1 Sets Next 3 to FEC pads */
- /* FEC_TXD_1, FEC_TXD_2, FEC_TXD_3 */
- /* FUNC1=FEC_RXD_3 Sets Next 2 to FEC pads */
- /* FEC_RXD_3, FEC_RXD_2 */
- /* FUNC3=GPIO17 */
- /* FUNC3=GPIO2/GPT2 Sets Next 3 to GPIO pads */
- /* GPIO2, GPIO20, GPIO21 */
- /* FUNC2=VIU_PIX_CLK */
- /* FUNC3=GPIO24 Sets Next 2 to GPIO pads */
- /* GPIO24, GPIO25 */
- /* FUNC1=NFC_CE2 */
- /* FUNC2=VIU_DATA5 Sets Next 5 to VIU_DATA pads */
- /* VIU_DATA5-VIU_DATA9 */
- /* FUNC1=LPC_TSIZ1 Sets Next 2 to LPC_TSIZ pads */
- /* LPC_TSIZ1-LPC_TSIZ2 */
- /* FUNC1=LPC_TS */
- /* FUNC3=GPIO16 Sets Next 5 to GPIO pads */
- /* GPIO16-GPIO19, GPT7/GPIO7 */
- /* FUNC3=GPIO20 Sets Next 2 to GPIO pads */
- /* GPIO20, GPIO21 */
- /* FUNC3=GPIO0/GPT0 */
- /* GPIO2, GPIO12, GPIO13 */
- /* FUNC2=DIU_DE */
- puts("Board: PDM360NG\n");
- /* initialize function mux & slew rate IO inter alia on IO Pins */
- iopin_initialize(ioregs_init, ARRAY_SIZE(ioregs_init));
- /* initialize IO_CONTROL_GP (GPIO/GPT-mux-register) */
- setbits_be32(&im->io_ctrl.io_control_gp, (1 << 0)); /* GP_MUX7->GPIO7 */
- /* configure GPIO24 (VIU_CE), output/high */
- setbits_be32(&im->gpio.gpdir, 0x80);
- setbits_be32(&im->gpio.gpdat, 0x80);
- { "fsl,mpc5121-nfc", MTD_DEV_TYPE_NAND, },
- { "cfi-flash", MTD_DEV_TYPE_NOR, },
+}; +#endif
- ft_cpu_setup(blob, bd);
- fdt_fixup_memory(blob, (u64)bd->bi_memstart, (u64)bd->bi_memsize);
- fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));
- Co-Processor communication POST
Why is this depending on SERIAL_MULTI? The POST system as such is orthogonal, no?
- volatile void *save_addr = (volatile void *)(_POST_ADDR);
- out_be32(save_addr, a);
- return in_be32(save_addr);
Can't we put this into 512x shared code? I really dislike putting this into board code. I know that 5200 set a precedent here, but they all have identical code. One should rather fix 5200 also.
- Actually the termination sequence of the coprocessor
- commands is "\r\n" (CR LF), but here we use a side effect of
- the putc() routine of the serial driver which checks for LF
- and sends CR before sending LF. Therefore the termination
- sequence in the command below is only "\n".
- "alive" string is the coprocessor response for ping command
- and not a command, therefore it is terminated with "\r\n".
- struct stdio_dev *cop_port;
- int ret;
- char buf[10];
- /* Test IO Coprocessor communication */
- cop_port = open_port(4, 38400);
- if (!cop_port)
return -1;
- write_port(cop_port, ping);
- udelay(PDM360NG_COPROC_READ_DELAY);
- memset(buf, 0, sizeof(buf));
- ret = read_port(cop_port, buf, sizeof(buf));
- close_port(4);
- if (ret <= 0) {
return -1;
- if (strcmp(buf, alive)) {
return -1;
- /* Test WD Coprocessor communication */
- cop_port = open_port(1, 38400);
- if (!cop_port) {
return -1;
- close_port(1);
- if (ret <= 0) {
return -1;
return -1;
Wouldn't it be a good idea to split the POST stuff into a separate file?
- If argument is NULL, set the LCD brightness to the
- value from "brightness" environment variable. Set
- the LCD brightness to the value specified by the
- argument otherwise. Default brightness is zero.
- char *env;
- char cmd_buf[20];
- int val = 0;
- int cs = 0;
- int len, i;
- if (brightness) {
- } else {
if (env)
- if (val < 0)
val = 0;
- if (val > MAX_BRIGHTNESS)
- sprintf(cmd_buf, "$SB;%04d;", val);
- len = strlen(cmd_buf);
- for (i = 1; i <= len; i++)
cs += cmd_buf[i];
- cs = (~cs + 1) & 0xff;
- sprintf(cmd_buf + len, "%02X\n", cs);
- /* IO Coprocessor communication */
- if (!cop_port) {
return -1;
- debug("%s: cmd: %s", __func__, cmd_buf);
- write_port(cop_port, cmd_buf);
- memset(cmd_buf, 0, sizeof(cmd_buf));
- len = read_port(cop_port, cmd_buf, sizeof(cmd_buf));
- if (len)
- close_port(4);
- if (argc < 2) {
cmd_usage(cmdtp);
return 1;
- return set_lcd_brightness(argv[1]);
- "set LCD brightness",
- "<brightness> - set LCD backlight level to <brightness>.\n"
- if ((h_addr < CONFIG_SYS_FLASH_BASE ||
- ) { printf("bmp addr %lx is not a valid flash address\n", h_addr); return 0; } else if ((*(char *)(h_addr) != 'B') || (*(char *)(h_addr+1) != 'M')) {
- xres = 800;
- yres = 480;
- project.
- MA 02111-1307 USA
- pdm360ng board configuration file
+#undef DEBUG
- Memory map for the PDM360NG board:
- 0x0000_0000 - 0x1FFF_FFFF DDR RAM (512 MB)
- 0x2000_0000 - 0x3FFF_FFFF reserved (DDR RAM (512 MB)
- 0x5000_0000 - 0x5001_FFFF SRAM (128 KB)
- 0x5004_0000 - 0x5005_FFFF MRAM (CS2) (128 KB)
- 0x8000_0000 - 0x803F_FFFF IMMR (4 MB)
- 0xF000_0000 - 0xF7FF_FFFF NOR FLASH (CS0) (128 MB)
- 0xF800_0000 - 0xFFFF_FFFF NOR FLASH (CS1) (128 MB)
- High Level Configuration Options
- DDR Setup - manually set all parameters as there's no SPD etc.
- SYS_CFG:
- [31:31] MDDRC Soft Reset: Diabled
- [30:30] DRAM CKE pin: Enabled
- [29:29] DRAM CLK: Enabled
- [28:28] Command Mode: Enabled (For initialization only)
- [27:25] DRAM Row Select: dram_row[15:0] = magenta_address[25:10]
- [24:21] DRAM Bank Select: dram_bank[1:0] = magenta_address[11:10]
- [20:19] Read Test: DON'T USE
- [18:18] Self Refresh: Enabled
- [17:17] 16bit Mode: Disabled
- [16:13] Read Delay: 3
- [12:12] Half DQS Delay: Disabled
- [11:11] Quarter DQS Delay: Disabled
- [10:08] Write Delay: 2
- [07:07] Early ODT: Disabled
- [06:06] On DIE Termination: Enabled
- [05:05] FIFO Overflow Clear: DON'T USE here
- [04:04] FIFO Underflow Clear: DON'T USE here
- [03:03] FIFO Overflow Pending: DON'T USE here
- [02:02] FIFO Underlfow Pending: DON'T USE here
- [01:01] FIFO Overlfow Enabled: Enabled
- [00:00] FIFO Underflow Enabled: Enabled
- TIME_CFG0
- [31:16] DRAM Refresh Time: 0 CSB clocks
- [15:8] DRAM Command Time: 0 CSB clocks
- [07:00] DRAM Precharge Time: 0 CSB clocks
- TIME_CFG1
- [31:26] DRAM tRFC:
- [25:21] DRAM tWR1:
- [20:17] DRAM tWRT1:
- [16:11] DRAM tDRR:
- [10:05] DRAM tRC:
- [04:00] DRAM tRAS:
- TIME_CFG2
- [31:28] DRAM tRCD:
- [27:23] DRAM tFAW:
- [22:19] DRAM tRTW1:
- [18:15] DRAM tCCD:
- [14:10] DRAM tRTP:
- [09:05] DRAM tRP:
- [04:00] DRAM tRPA
- NOR FLASH on the Local Bus
- NAND FLASH
- Configuration parameters for MPC5121 NAND driver
- Dynamic MTD partition support
- Flash layout
- Override partitions in device tree using info
- in mtdparts env. variable.
Isn't this shared among the 512x implementations so we can put it in a common file?
- Serial Port
- Serial console configuration
- {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
- Used PSC UART devices
- MAC addr in EEPROM
- Enabled only to delete ethaddr before testing
- ethaddr setting from EEPROM
- IIM - IC Identification Module
+#undef CONFIG_IIM
- EEPROM configuration
- Ethernet configuration
- Configure on-board RTC
- Environment
- Watchdog timeout = CONFIG_SYS_WATCHDOG_VALUE * 65536 / IPS clock.
- For example, when IPS is set to 66MHz and CONFIG_SYS_WATCHDOG_VALUE is set
- to 0xFFFF, watchdog timeouts after about 64s. For details refer
- to chapter 36 of the MPC5121e Reference Manual.
- Miscellaneous configurable options
- #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */
+#else
- #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
- For booting Linux, the board info and command line data
- have to be in the first 8 MB of memory, since this is
- the maximum mapped by the Linux kernel during initialization.
- Internal Definitions
- Boot Flags
- "Coprocessors communication test", \
- "coproc_com", \
- "This test checks communication with coprocessors.", \
- POST_RAM | POST_ALWAYS | POST_CRITICAL, \
- &pdm360ng_coprocessor_post_test, \
- NULL, \
- NULL, \
- CONFIG_SYS_POST_COPROC \
- Environment Configuration
- "echo PDM360NG SAMPLE;" \
- "echo"
- CONFIG_POST_COPROC,
+#endif };
Cheers Detlev
Hi Detlev,
Ok.
Ok!
Currently there is only Coprocessor POST only which depends on SERIAL_MULTI. I think I should better do something like:
#if defined(CONFIG_POST) #if defined(CONFIG_SERIAL_MULTI) /* Co-Processor POST code */ ... #endif #endif
Even better would be to move POST code to separate file, it seems.
I'll move it to cpu/mpc512x/commproc.c.
- close_port(1);
- if (ret <= 0) {
return -1;
return -1;
I'll move it to a separate file.
Yes, we should put it in a common file.
Thanks, Anatolij
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Dear Anatolij Gustschin,
In message 1266964630-7754-7-git-send-email-agust@denx.de you wrote:
--===============1816892533==
Incorrect mail address format.
Entry to MAINTAINERS file is missing.
uchar buf[6];
char mac[18];
int ret;
if (!ret) {
If you really want to do this, then please use
sprintf(mac, "%pM", buf);
instead.
mac);
Why not simply a memcmp() or a strncmp() ?
} else {
} else {
All this seems overly complicated to me. All these string conversions are not really needed. Why not like this:
uchar ifm_oui[3] = { 0, 2, 1, };
ret = i2c_read(...); if (ret != 0) { printf("Error: Unable to read MAC from I2C" " EEPROM at address %02X:%02X\n", CONFIG_SYS_I2C_EEPROM, CONFIG_SYS_I2C_EEPROM_MAC_OFFSET); return 0; /* or rather return 1; ??? */ }
if (memcmp(buf, ifm_oui, sizeof(ifm_oui)) { printf("Illegal MAC address in EEPROM: %pM\n", buf): }
eth_setenv_enetaddr("ethaddr", buf);
This seems wrong to me. Why does LCD related code depend on CONFIG_SERIAL_MULTI ???
I don't like this. Why do we see hardcoded values here and not the data from the CFI driver's auto-sizing? I assume both flash banks are maped into one big contiguous array of NOR flash, right? Then there should be just a single test for "< base || >(base+size)" here, using the total size of the combined flash banks.
And why would it be necessary that the BMP resides in NOR flash in the first place?
Why cannot - for example - a "preboot" command be used to read it from SDCard into RAM?
- xres = 800;
- yres = 480;
Please avoid the board specific #define here. check for a feature instead (resolution = 800x400).
+#undef DEBUG
Please remove dead code.
This makes no sense. If you want to toggle between "small" and "big" configurations, then please use a single #define which is either set or not set.
I don't see why this is needed at all. Does not U-Boot auto-detect the RAM size, so you can auto-adjust all code where needed?
Please use auto-sizing with get_ram_size() instead, so a single U-Bootimage can be used with both configurations.
Do comment and code match?
Lines way too long. Please fix globally.
- Serial Port
Please do not #undef what is not defined anyway. Remove dead code.
You may want to sort that list.
- "coproc_com", \
- NULL, \
- NULL, \
This does not belong into the board config file.
Please split the POST specific code out into a separate commit.
In message 1266964630-7754-6-git-send-email-agust@denx.de you wrote:
Allow overriding defined partitions in the device tree blob using partition info defined in the 'mtdparts' environment variable.
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Gerald Van Baren vanbaren@cideas.com
common/cmd_mtdparts.c | 2 +- common/fdt_support.c | 214 +++++++++++++++++++++++++++++++++++++++++++ include/fdt_support.h | 2 + include/jffs2/load_kernel.h | 1 + include/mtd_node.h | 11 ++ 5 files changed, 229 insertions(+), 1 deletions(-) create mode 100644 include/mtd_node.h
Applied to "next" branch, thanks.
Thanks for applying this, gvb
In message 1266964630-7754-5-git-send-email-agust@denx.de you wrote:
Allow displaying run length encoded bitmaps.
board/freescale/common/fsl_diu_fb.c | 78 +++++++++++++++++++++++++++++++++++ 1 files changed, 78 insertions(+), 0 deletions(-)
Isn't there a way to implement this feature in common code, so all boards with bitmap support can benefit from this?
Hello Wolfgang,
There is a way to do it, sure. The problem is, diu driver doesn't use this common code. I'll rework the diu driver to do so.
Best regards, Anatolij -- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Can you be more specific? What does the DIU driver do wrong?
Applied to u-boot-mpc5xxx repo, thanks.
cpu/mpc512x/serial.c | 87 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/serial.h | 7 ++++ 2 files changed, 94 insertions(+), 0 deletions(-)
In message 1266964630-7754-3-git-send-email-agust@denx.de you wrote:
Extend mpc512x serial driver to support multiple PSCs ports.
Supsequent patches for PDM360NG board support make use of this functionality by defining CONFIG_SERIAL_MULTI in the board config file. Additionally the used PSC devices are specified by defining e.g. CONFIG_SYS_PSC1, CONFIG_SYS_PSC4 and CONFIG_SYS_PSC6.
Support for PSC devices other than 1, 3, 4 and 6 is not added by this patch because these aren't used currently. In the future it can be easily added using DECLARE_PSC_SERIAL_FUNCTIONS(N) and INIT_PSC_SERIAL_STRUCTURE(N) macros in cpu/mpc512x/serial.c. Additionally you have to add code for registering added devices in serial_initialise() in common/serial.c.
common/serial.c | 23 ++++ cpu/mpc512x/serial.c | 266 +++++++++++++++++++++++++++++++++++++----- include/asm-ppc/immap_512x.h | 108 +++++++++--------- include/serial.h | 8 ++ 4 files changed, 324 insertions(+), 81 deletions(-)
cpu/mpc512x/fixed_sdram.c | 2 +- include/asm-ppc/immap_512x.h | 4 ---- include/configs/aria.h | 2 ++ include/configs/mecp5123.h | 2 ++ include/configs/mpc5121ads.h | 2 ++ 5 files changed, 7 insertions(+), 5 deletions(-)
participants (5)
Anatolij Gustschin
Detlev Zundel
Gerald Van Baren
Timur Tabi
