[U-Boot] [PATCH 1/1] odroid-c2: increase CONFIG_SYS_BOOTM_LEN
A feature rich Kernel for Linux needs more than 8 MiB. Hence enlarge CONFIG_SYS_BOOTM_LEN to 64 MiB for the Odroid C2. As the Odroid C2 has has 2 GiB of RAM this poses no problem.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/configs/meson-gxbb-common.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/meson-gxbb-common.h b/include/configs/meson-gxbb-common.h index c3229ea..e993263 100644 --- a/include/configs/meson-gxbb-common.h +++ b/include/configs/meson-gxbb-common.h @@ -54,4 +54,6 @@ MESON_FDTFILE_SETTING \ BOOTENV
+#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64 MiB */ + #endif /* __MESON_GXBB_COMMON_CONFIG_H */
Am 14.04.2017 um 14:17 schrieb Heinrich Schuchardt:
"Linux kernel"?
Duplicate "has", and "Odroid-C2".
You are touching a generic GXBB file but reason with Odroid-C2. I have been chain-loading it on the Tronsmart Vega S95 Telos, for instance. I believe your change is generally okay, but you should fix both lines above and probably also the subject.
Regards, Andreas
A feature rich Linux kernel needs more than 8 MiB. Hence enlarge CONFIG_SYS_BOOTM_LEN to 64 MiB for the GXBB systems. As all known GXBB systems have at least 512 MiB of RAM this poses no problem.
Cc: Andreas Färber afaerber@suse.de Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: Title and commit message changed to reflect that this patch applies to all Meson GXBB systems. v1: Initial patch [PATCH 1/1] odroid-c2: increase CONFIG_SYS_BOOTM_LEN https://lists.denx.de/pipermail/u-boot/2017-April/287343.html --- include/configs/meson-gxbb-common.h | 2 ++ 1 file changed, 2 insertions(+)
Hello Tom,
could you, please, consider merging this patch.
Andreas already acknowledged the code change in version 1 (https://patchwork.ozlabs.org/patch/750826/) but requested updating the commit message which is done with version 2.
I have been booting the Odroid C2 using bootm and booti with the patch applied.
Best regards
Heinrich
Andreas Färber
