[U-Boot] [u-boot] [PATCH] [1/2] [v1.2] mxc_fec: fix some erroneous PHY accesses.
This patch fixes erroneous access to the ethernet PHY which broke the driver. 1. Selector field in the auto-negotiation register must be 0x00001 for using 802.3, not 0x00000 which is reseved. 2. Access to the PHY address specified by CONFIG_FEC_MXC_PHYADDR, not 0x0 fixed address.
This has been tested in i.MX27 Litekit board and eldk-4.2 toolchains.
Now using proper defines for auto-negotiation register.
Signed-off-by: Javier Martin javier.martin@vista-silicon.com -- drivers/net/fec_mxc.c | 8 +++++--- 1 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index bd83a24..9764e12 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -157,7 +157,9 @@ static int miiphy_restart_aneg(struct eth_device *dev) /* * Set the auto-negotiation advertisement register bits */ - miiphy_write(dev->name, CONFIG_FEC_MXC_PHYADDR, PHY_ANAR, 0x1e0); + miiphy_write(dev->name, CONFIG_FEC_MXC_PHYADDR, PHY_ANAR, + PHY_ANLPAR_TXFD | PHY_ANLPAR_TX | PHY_ANLPAR_10FD | + PHY_ANLPAR_10 | PHY_ANLPAR_PSB_802_3); miiphy_write(dev->name, CONFIG_FEC_MXC_PHYADDR, PHY_BMCR, PHY_BMCR_AUTON | PHY_BMCR_RST_NEG);
@@ -341,8 +343,8 @@ static int fec_open(struct eth_device *edev) writel(FEC_ECNTRL_ETHER_EN, &fec->eth->ecntrl);
miiphy_wait_aneg(edev); - miiphy_speed(edev->name, 0); - miiphy_duplex(edev->name, 0); + miiphy_speed(edev->name, CONFIG_FEC_MXC_PHYADDR); + miiphy_duplex(edev->name, CONFIG_FEC_MXC_PHYADDR);
/* * Enable SmartDMA receive task
Dear Ben Warren, do these patches look OK for you?
Thanks.
Javier,
- Selector field in the auto-negotiation register must be 0x00001 for
Applied to net repo.
thanks, Ben
Ben Warren
javier Martin
