[PATCH] spl: spl_fit.c: enable check of signature for config node in spl/tpl
This commit add the support of signature check for config node in spl/tpl when the function spl_load_simple_fit is used.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- common/spl/spl_fit.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index fd6086a65c..7d10a4352c 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -551,6 +551,16 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, if (spl_load_simple_fit_skip_processing()) return 0;
+ if (IS_ENABLED(CONFIG_SPL_FIT_SIGNATURE)) { + int conf_offset = fit_find_config_node(fit); + + printf("## Checking hash(es) for config %s ... ", + fit_get_name(fit, conf_offset, NULL)); + if (fit_config_verify(fit, conf_offset)) + return -EPERM; + puts("OK\n"); + } + /* find the node holding the images information */ images = fdt_path_offset(fit, FIT_IMAGES_PATH); if (images < 0) {
On Thu, 29 Oct 2020 at 11:50, Philippe Reynes philippe.reynes@softathome.com wrote:
We have sandbox SPL tests available now so it should be possible to write a test of FIT loading in SPL.
return -EPERM;
puts("OK\n");
-- 2.17.1
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org
Philippe Reynes
