[PATCH] net: guard call to tftp_start() with IS_ENABLED(CONFIG_CMD_TFTPBOOT)
net_auto_load() cannot call tftp_start() if CONFIG_CMD_TFTPBOOT is disabled.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- net/net.c | 23 ++++++++++++++--------- 1 file changed, 14 insertions(+), 9 deletions(-)
diff --git a/net/net.c b/net/net.c index d9bc9df643f..1e0b7c85624 100644 --- a/net/net.c +++ b/net/net.c @@ -334,17 +334,22 @@ void net_auto_load(void) net_set_state(NETLOOP_SUCCESS); return; } - if (net_check_prereq(TFTPGET)) { -/* We aren't expecting to get a serverip, so just accept the assigned IP */ - if (IS_ENABLED(CONFIG_BOOTP_SERVERIP)) { - net_set_state(NETLOOP_SUCCESS); - } else { - printf("Cannot autoload with TFTPGET\n"); - net_set_state(NETLOOP_FAIL); + if (IS_ENABLED(CONFIG_CMD_TFTPBOOT)) { + if (net_check_prereq(TFTPGET)) { + /* + * We aren't expecting to get a serverip, so just + * accept the assigned IP + */ + if (IS_ENABLED(CONFIG_BOOTP_SERVERIP)) { + net_set_state(NETLOOP_SUCCESS); + } else { + printf("Cannot autoload with TFTPGET\n"); + net_set_state(NETLOOP_FAIL); + } + return; } - return; + tftp_start(TFTPGET); } - tftp_start(TFTPGET); }
static int net_init_loop(void)
Jerome Forissier
