[U-Boot] [PATCH] powerpc/mpc85xx:NAND_SPL:Avoid IFC/eLBC Base address setting
During NAND_SPL boot, base address and different register are programmed default by corresponding NAND controllers(eLBC/IFC). These settings are sufficient enough for NAND SPL.
Avoid updating these register.They will be programmed during NAND RAMBOOT.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init_nand.c | 26 -------------------------- 1 files changed, 0 insertions(+), 26 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c b/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c index f33db02..bf7a6f6 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init_nand.c @@ -26,32 +26,6 @@
void cpu_init_f(void) { -#ifdef CONFIG_FSL_LBC - fsl_lbc_t *lbc = LBC_BASE_ADDR; - - /* - * LCRR - Clock Ratio Register - set up local bus timing - * when needed - */ - out_be32(&lbc->lcrr, LCRR_DBYP | LCRR_CLKDIV_8); - -#if defined(CONFIG_SYS_NAND_BR_PRELIM) && defined(CONFIG_SYS_NAND_OR_PRELIM) - set_lbc_br(0, CONFIG_SYS_NAND_BR_PRELIM); - set_lbc_or(0, CONFIG_SYS_NAND_OR_PRELIM); -#else -#error CONFIG_SYS_NAND_BR_PRELIM, CONFIG_SYS_NAND_OR_PRELIM must be defined -#endif -#endif -#ifdef CONFIG_FSL_IFC -#ifndef CONFIG_SYS_FSL_ERRATUM_IFC_A003399 -#if defined(CONFIG_SYS_CSPR0) && defined(CONFIG_SYS_CSOR0) - set_ifc_cspr(IFC_CS0, CONFIG_SYS_CSPR0); - set_ifc_amask(IFC_CS0, CONFIG_SYS_AMASK0); - set_ifc_csor(IFC_CS0, CONFIG_SYS_CSOR0); -#endif -#endif -#endif - #if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L2_ADDR) ccsr_l2cache_t *l2cache = (void *)CONFIG_SYS_MPC85xx_L2_ADDR;
Prabhakar Kushwaha
