[PATCH v4] apalis/colibri_imx6: move setting bootcmd to defconfig
Move setting the default boot command to the apalis/colibri_imx6_defconfig. It allows replacing the command without code modification.
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Igor Opaniuk igor.opaniuk@foundries.io Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
Changes in v4: - add an acked-by record.
Changes in v3: - fix Peng Fan's e-mail address.
Changes in v2: - fix spaces after semicolon. - add reviewed-by records.
configs/apalis_imx6_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + include/configs/apalis_imx6.h | 4 ---- include/configs/colibri_imx6.h | 4 ---- 4 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index a0e85ba23a4..f64b1ca4378 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -23,6 +23,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=1 +CONFIG_BOOTCOMMAND="run distro_bootcmd; usb start; setenv stdout serial,vidconsole; setenv stdin serial,usbkbd" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 47b1cfb1917..373d6476ddc 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -22,6 +22,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=1 +CONFIG_BOOTCOMMAND="run distro_bootcmd; usb start; setenv stdout serial,vidconsole; setenv stdin serial,usbkbd" # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 12de0105c6c..ade479cb943 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -133,10 +133,6 @@ #endif #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ - "bootcmd=run distro_bootcmd ; " \ - "usb start ; " \ - "setenv stdout serial,vidconsole; " \ - "setenv stdin serial,usbkbd\0" \ "boot_file=zImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off vmalloc=400M\0" \ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 804a144a03e..f91d6b49ea8 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -115,10 +115,6 @@ #define FDT_FILE "imx6dl-colibri-eval-v3.dtb" #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ - "bootcmd=run distro_bootcmd; " \ - "usb start ; " \ - "setenv stdout serial,vidconsole; " \ - "setenv stdin serial,usbkbd\0" \ "boot_file=zImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off galcore.contiguousSize=50331648\0" \
Hi everybody,
I have not applied this, not because I see issue, but because the patch requires to be rebased and I did not want to do this and merge without test. Could you just rebase it and repost, I will then merge soon.
Regards, Stefano
Changes in v4:
Changes in v3:
Changes in v2:
"usb start ; " \
"boot_file=zImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off vmalloc=400M\0" \"setenv stdin serial,usbkbd\0" \
"usb start ; " \
"boot_file=zImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off galcore.contiguousSize=50331648\0" \"setenv stdin serial,usbkbd\0" \
Hi Stefano,
On Mon, Feb 7, 2022 at 1:01 PM Stefano Babic sbabic@denx.de wrote:
Hi everybody,
Sure, no problem. I'll repost the rebased patch soon.
Regards, Stefano
Changes in v4:
Changes in v3:
Changes in v2:
"usb start ; " \
"usb start ; " \
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Oleksandr Suvorov
Oleksandr Suvorov
Stefano Babic
