[PATCH v3] lib: Improve _parse_integer_fixup_radix base 16 detection
Base autodetection is failing for this case: if test 257 -gt 3ae; then echo first; else echo second; fi
It is because base for 3ae is recognized by _parse_integer_fixup_radix() as 10. The code detects the first char which is not between 'a'/'A' or 'f'/'F' to change base from dec to hex.
Signed-off-by: Michal Simek michal.simek@xilinx.com Signed-off-by: Shiril Tichkule shirilt@xlinx.com ---
Changes in v3: - Fix commit message to be accurate based on code. - Use tolower instead of two ranges - Use do while loop - all reported by Andy - Remove Tom's reviewed-by tag because code has changed
Changes in v2: - Fix end of string to be \0 instead of \n - Detect hex by checking chars between a-f to avoid cases like number follow by ;
lib/strto.c | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/lib/strto.c b/lib/strto.c index 55ff9f7437d5..1ac2b09c725c 100644 --- a/lib/strto.c +++ b/lib/strto.c @@ -22,9 +22,22 @@ static const char *_parse_integer_fixup_radix(const char *s, unsigned int *base) *base = 16; else *base = 8; - } else + } else { + int i = 0; + char var; + *base = 10; + + do { + var = tolower(s[i++]); + if (var >= 'a' && var <= 'f') { + *base = 16; + break; + } + } while (var); + } } + if (*base == 16 && s[0] == '0' && tolower(s[1]) == 'x') s += 2; return s;
pá 20. 3. 2020 v 8:49 odesílatel Michal Simek michal.simek@xilinx.com napsal:
Changes in v3:
Changes in v2:
} else
} else {
int i = 0;
char var;
*base = 10;
do {
*base = 16;
break;
} while (var);
-- 2.25.1
Applied. M
Michal Simek
Michal Simek
