[U-Boot] [PATCH u-boot] boards: amlogic: Fix boards README
Fix typos and update the supported devices for all Amlogic boards.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/mach-meson/Kconfig | 2 +- board/amlogic/khadas-vim/README | 8 +++++++- board/amlogic/libretech-cc/README | 12 +++++++++--- board/amlogic/odroid-c2/README | 5 +++++ board/amlogic/p212/README | 7 +++++++ 5 files changed, 29 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index 9a06ccc..5364e9d 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -17,7 +17,7 @@ config MESON_GXL select DM select DM_SERIAL help - The Amlogic Meson GXL (S905X and S905X) is an ARM SoC with a + The Amlogic Meson GXL (S905X and S905D) is an ARM SoC with a quad-core Cortex-A53 CPU and a Mali-450 GPU.
if MESON_GXBB diff --git a/board/amlogic/khadas-vim/README b/board/amlogic/khadas-vim/README index 7eaca72..0ccd8f5 100644 --- a/board/amlogic/khadas-vim/README +++ b/board/amlogic/khadas-vim/README @@ -4,7 +4,7 @@ U-Boot for Khadas VIM Khadas VIM is an Open Source DIY Box manufactured by Shenzhen Wesion Technology Co., Ltd with the following specifications:
- - Amlogic S905x ARM Cortex-A53 quad-core SoC @ 2GHz + - Amlogic S905X ARM Cortex-A53 quad-core SoC @ 1.5GHz - ARM Mali 450 GPU - 2GB DDR3 SDRAM - 10/100 Ethernet @@ -20,6 +20,12 @@ Currently the u-boot port supports the following devices: - serial - eMMC, microSD - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - USB Host + - ADC
U-Boot compilation ================== diff --git a/board/amlogic/libretech-cc/README b/board/amlogic/libretech-cc/README index c06a392..d007f58 100644 --- a/board/amlogic/libretech-cc/README +++ b/board/amlogic/libretech-cc/README @@ -4,13 +4,13 @@ U-Boot for LibreTech CC LibreTech CC is a single board computer manufactured by Libre Technology with the following specifications:
- - Amlogic S905X ARM Cortex-A53 quad-core SoC @ 2GHz + - Amlogic S905X ARM Cortex-A53 quad-core SoC @ 1.5GHz - ARM Mali 450 GPU - 2GB DDR3 SDRAM - - Gigabit Ethernet + - 10/100 Ethernet - HDMI 2.0 4K/60Hz display - 40-pin GPIO header - - 4 x USB 2.0 Host, 1 x USB OTG + - 4 x USB 2.0 Host - eMMC, microSD - Infrared receiver
@@ -20,6 +20,12 @@ Currently the U-Boot port supports the following devices: - serial - eMMC, microSD - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - USB Host + - ADC
U-Boot compilation ================== diff --git a/board/amlogic/odroid-c2/README b/board/amlogic/odroid-c2/README index b407c04..bed48c5 100644 --- a/board/amlogic/odroid-c2/README +++ b/board/amlogic/odroid-c2/README @@ -20,6 +20,11 @@ Currently the u-boot port supports the following devices: - serial - eMMC, microSD - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - ADC
u-boot compilation ================== diff --git a/board/amlogic/p212/README b/board/amlogic/p212/README index 979502d..ef5370c 100644 --- a/board/amlogic/p212/README +++ b/board/amlogic/p212/README @@ -20,6 +20,13 @@ Schematics are available from Amlogic on demand. Currently the u-boot port supports the following devices: - serial - eMMC, microSD + - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - USB Host + - ADC
Neil Armstrong
