[U-Boot] [PATCH] Do not call board_early_init_f() twice
Apparently due to a missed rebase conflict resolution board_early_init_f() is included twice in the list of initialization functions.
Leave only the first occurrence. . built and boot an Exynos 5250 target
Signed-off-by: Vadim Bendebury vbendeb@chromium.org --- common/board_f.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 29b49c3..7698891 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -788,9 +788,6 @@ static init_fnc_t init_sequence_f[] = { /* TODO: can we rename this to timer_init()? */ init_timebase, #endif -#if defined(CONFIG_BOARD_EARLY_INIT_F) - board_early_init_f, -#endif #ifdef CONFIG_ARM timer_init, /* initialize timer */ #endif
Vadim Bendebury
