Broken P2020 board since commit be7dbb60c5bf ("Convert CONFIG_SYS_IMMR to Kconfig")
Hello!
In current master branch is U-Boot for P2020 board (powerpc mpc85xx based) built by P2020RDB-PC_SDCARD_defconfig completely broken. U-Boot does not work at all and on UART is nothing printed.
I run git bisect and it found commit which broke this P2020 board:
be7dbb60c5bfa38ea444fe7de1dca8bd35f83f5b is the first bad commit commit be7dbb60c5bfa38ea444fe7de1dca8bd35f83f5b Author: Tom Rini trini@konsulko.com Date: Sun Dec 12 22:12:30 2021 -0500
This converts the following to Kconfig: CONFIG_SYS_IMMR
We do this by consolidating the SYS_IMMR options we have and providing defaults.
We also, in the few places where M68K was also sharing code with these platforms, define it within the file to CONFIG_SYS_MBAR to match usage. This should be cleaned up longer term.
Signed-off-by: Tom Rini trini@konsulko.com
:040000 040000 12f819284e85d64b7df5da65476038a542e587f5 ea3da4aefeee93f1566be6b7f85a43846f29aa8b M arch :040000 040000 afe083b1f22b57470532d2a2c3c37b6a5d4a68d4 302d04810c9449622ce43982f562d2e8400086ec M configs :040000 040000 411b7912fc83c8aaf25adf5647400625793cee38 0eff4a6f6e7b5f21bc3d533e1c5bc1cd2a5ed86b M drivers :040000 040000 b7d8b45f803b3619f76be355193d5c5645e76782 be2ac1c8506e99d1f9c615ad09477884f5ce1231 M include
So it is relatively new change (Dec 2021).
Tom, any idea how this commit could broke P2020 board which is mpc85xx platform? I do not see nothing suspicious in this commit. Before this commit BootROM can successfully boot SPL without any issues and SPL prints info on UART. This board use include/configs/p1_p2_rdb_pc.h config file and it was not touched at all.
Priyanka, Wolfgang, you are marked as maintainers, do you know how to debug this issue? Or do you have some P2020 board or other mpc85xx based, so you could test if U-Boot is working on this platform?
For reference I built U-Boot SPL by these commands:
make CROSS_COMPILE=powerpc-linux-gnuspe- P2020RDB-PC_SDCARD_defconfig spl/u-boot-spl.bin boot_format config_sram_p2020rdb.dat spl/u-boot-spl.bin -spi u-boot.sdcard.bin
boot_format and config_sram_p2020rdb.dat are taken from the upstream git repo from the latest branch nxp/sdk-v2.0.x: https://source.codeaurora.org/external/qoriq/qoriq-yocto-sdk/boot-format
u-boot.sdcard.bin is then copied to SD card (starting from sector zero).
On Wed, Mar 30, 2022 at 02:20:28PM +0200, Pali Rohár wrote:
Hello!
Convert CONFIG_SYS_IMMR to Kconfig This converts the following to Kconfig: CONFIG_SYS_IMMR We do this by consolidating the SYS_IMMR options we have and providing defaults. We also, in the few places where M68K was also sharing code with these platforms, define it within the file to CONFIG_SYS_MBAR to match usage. This should be cleaned up longer term. Signed-off-by: Tom Rini <trini@konsulko.com>
The likely answer is that one of the sets of games PowerPC platforms play so that "SPL", "TPL" and regular U-Boot to do redefine some symbols / base addresses didn't get migrated correctly. Or, re-reading that commit, maybe what I had worked out wasn't right, and CONFIG_SYS_IMMR=0xff700000 is wrong?
Hello!
In include/mpc85xx.h you removed code:
-#ifndef CONFIG_SYS_IMMR -#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR -#endif
And in include/configs/p1_p2_rdb_pc.h is:
#define CONFIG_SYS_CCSRBAR 0xffe00000
So it looks like that CONFIG_SYS_IMMR needs to be set to 0xffe00000 value. I'm going to test this change.
Hello!
Yes, changing it to 0xffe00000 fixed this issue and SPL started printing on UART again.
Here are config files which sets custom CONFIG_SYS_CCSRBAR value:
$ git grep '#define\s*CONFIG_SYS_CCSRBAR\s' include/ include/configs/MPC8540ADS.h:#define CONFIG_SYS_CCSRBAR 0xe0000000 include/configs/MPC8548CDS.h:#define CONFIG_SYS_CCSRBAR 0xe0000000 include/configs/MPC8560ADS.h:#define CONFIG_SYS_CCSRBAR 0xe0000000 include/configs/P1010RDB.h:#define CONFIG_SYS_CCSRBAR 0xffe00000 include/configs/p1_p2_rdb_pc.h:#define CONFIG_SYS_CCSRBAR 0xffe00000 include/configs/qemu-ppce500.h:#define CONFIG_SYS_CCSRBAR 0xe0000000 include/configs/socrates.h:#define CONFIG_SYS_CCSRBAR 0xE0000000 include/mpc85xx.h:#define CONFIG_SYS_CCSRBAR CONFIG_SYS_CCSRBAR_DEFAULT
And this should be reflected into CONFIG_SYS_IMMR as it looks like that all above config files are MPC85xx platforms.
Hello!
Ah, OK, so what happened was that what I had been doing to check for unmigrated symbols missed this one as we have SYS_CCSRBAR_DEFAULT in Kconfig but not SYS_CCSRBAR. I'll post something to fix these platforms shortly, thanks!
Pali Rohár
