[PATCH] mips: mtmips: Kconfig: select options used in SPL
debug_uart_init SPL_SERIAL_SUPPORT __udelay SPL_LIBGENERIC_SUPPORT puts SPL_LIBCOMMON_SUPPORT default_serial_console SPL_DM / SPL_DM_SERIAL
after disable SPL, and re-enable SPL, options above and some more options will be un-set. then cause a compile error. add minmal options needed by compile.
Signed-off-by: Du Huanpeng dhu@hodcarrier.org --- arch/mips/mach-mtmips/Kconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 8756cadb..d6ae3a0 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -44,8 +44,12 @@ config SOC_MT7620 select PINCTRL_MT7620 select MT7620_SERIAL select MISC + select SPL_SERIAL_SUPPORT if SPL + select SPL_LIBGENERIC_SUPPORT if SPL + select SPL_LIBCOMMON_SUPPORT if SPL select SPL_SEPARATE_BSS if SPL select SPL_LOADER_SUPPORT if SPL + imply SPL_DM if SPL select SPL_OF_CONTROL if SPL_DM select SPL_OF_PLATDATA if SPL_DM select SPL_DM_SERIAL if SPL_DM
Du Huanpeng
