[U-Boot] [PATCH] bedbug_860.c: Fix return type to silence compile warnings.
commit 47e26b1b "cmd_usage(): simplify return code handling" caused the following compile warnings:
bedbug_860.c: In function 'bedbug860_do_break': bedbug_860.c:73: warning: 'return' with a value, in function returning void bedbug_860.c:121: warning: 'return' with a value, in function returning void
Fix the return type.
Actually the while file could need some cleanup - commands should return proper error codes, and there are coding style issues. => To be fixed later.
Signed-off-by: Wolfgang Denk wd@denx.de --- arch/powerpc/cpu/mpc8xx/bedbug_860.c | 6 ++++-- 1 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xx/bedbug_860.c b/arch/powerpc/cpu/mpc8xx/bedbug_860.c index 83db035..1a9c0ba 100644 --- a/arch/powerpc/cpu/mpc8xx/bedbug_860.c +++ b/arch/powerpc/cpu/mpc8xx/bedbug_860.c @@ -69,8 +69,10 @@ void bedbug860_do_break (cmd_tbl_t *cmdtp, int flag, int argc, int which_bp; /* Breakpoint number */ /* -------------------------------------------------- */
- if (argc < 2) - return cmd_usage(cmdtp); + if (argc < 2) { + cmd_usage(cmdtp); + return; + }
/* Turn off a breakpoint */
Actually these files could need some cleanup - commands should return proper error codes, and there are coding style issues. => To be fixed later.
Signed-off-by: Wolfgang Denk wd@denx.de --- Changes since V1: fix other occurrences of the same issue, too.
arch/powerpc/cpu/mpc8260/bedbug_603e.c | 12 ++++++++---- arch/powerpc/cpu/mpc8xx/bedbug_860.c | 12 ++++++++---- 2 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8260/bedbug_603e.c b/arch/powerpc/cpu/mpc8260/bedbug_603e.c index 89193a3..92f8957 100644 --- a/arch/powerpc/cpu/mpc8260/bedbug_603e.c +++ b/arch/powerpc/cpu/mpc8260/bedbug_603e.c @@ -70,8 +70,10 @@ void bedbug603e_do_break (cmd_tbl_t *cmdtp, int flag, int argc, int which_bp; /* Breakpoint number */ /* -------------------------------------------------- */
@@ -114,8 +116,10 @@ void bedbug603e_do_break (cmd_tbl_t *cmdtp, int flag, int argc,
if(!(( isdigit( argv[ 1 ][ 0 ] )) || (( argv[ 1 ][ 0 ] >= 'a' ) && ( argv[ 1 ][ 0 ] <= 'f' )) || - (( argv[ 1 ][ 0 ] >= 'A' ) && ( argv[ 1 ][ 0 ] <= 'F' )))) - return cmd_usage(cmdtp); + (( argv[ 1 ][ 0 ] >= 'A' ) && ( argv[ 1 ][ 0 ] <= 'F' )))) { + cmd_usage(cmdtp); + return; + }
addr = simple_strtoul( argv[ 1 ], NULL, 16 );
diff --git a/arch/powerpc/cpu/mpc8xx/bedbug_860.c b/arch/powerpc/cpu/mpc8xx/bedbug_860.c index 83db035..c0016f7 100644 --- a/arch/powerpc/cpu/mpc8xx/bedbug_860.c +++ b/arch/powerpc/cpu/mpc8xx/bedbug_860.c @@ -69,8 +69,10 @@ void bedbug860_do_break (cmd_tbl_t *cmdtp, int flag, int argc, int which_bp; /* Breakpoint number */ /* -------------------------------------------------- */
@@ -117,8 +119,10 @@ void bedbug860_do_break (cmd_tbl_t *cmdtp, int flag, int argc,
/* Set a breakpoint at the address */
- if( !isdigit( argv[ 1 ][ 0 ])) - return cmd_usage(cmdtp); + if( !isdigit( argv[ 1 ][ 0 ])) { + cmd_usage(cmdtp); + return; + }
addr = simple_strtoul( argv[ 1 ], NULL, 16 ) & 0xfffffffc;
Aplied.
