Re: [PATCH v2] board: rockchip: Add the Turing RK1 SoM
Hey Sam,
On 24-04-11 16:35:57, Sam Edwards wrote:
On Thu, Apr 11, 2024 at 1:29 AM Florian Klink flokli@flokli.de wrote:
On 23-12-14 18:46:47, Joshua Riek wrote:
The Turing RK1 is a Rockchip RK3588 based SoM from Turing Machines.
Specifications:
Rockchip RK3588 SoC 4x ARM Cortex-A76, 4x ARM Cortex-A55 8/16/32GB memory LPDDR4x Mali G610MC4 GPU 32GB eMMC HS400 2x USB 2.0, 2x USB 3.0 2x MIPI CSI 4x lanes 1x MIPI-DSI DPHY 2x lanes PCIe 2.0 x1, PCIe 3.0 x4 1x HDMI 2.1 output, 1x DP 1.4 output Gigabit Ethernet Size: 69.6mm x 45mm (260-pin SO-DIMM connector)
Kernel commit: 2806a69f3fef ("arm64: dts: rockchip: Add Turing RK1 SoM support")
diff --git a/configs/turing-rk1-rk3588_defconfig b/configs/turing-rk1-rk3588_defconfig new file mode 100644 index 0000000000..289f2da775 --- /dev/null +++ b/configs/turing-rk1-rk3588_defconfig @@ -0,0 +1,133 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_SF_DEFAULT_SPEED=24000000 +CONFIG_SF_DEFAULT_MODE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-turing-rk1" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_ROCKCHIP_SPI_IMAGE=y
Hi Florian,
Thanks for getting in touch!
Does the RK1 have an SPI chip attached, and is is possible to flash u-boot into SPI and boot from it?
The answer you want is "no." Though the RK1 does have an unpopulated pad for SPI flash, actually installing one would be a pretty involved user modification, and those users almost certainly can/will build the SPI boot image themselves.
This has sparked some confusion on whether "u-boot-rockchip-spi.bin" should be provided in a downstream build or not.
Ah yeah the CONFIG_ROCKCHIP_SPI_IMAGE=y might not be a sensible default given that 99.9% of users don't need it. Is that config entry the main thing creating the confusion? I think it should be removed here in U-Boot if so.
Yes, it caused a "u-boot-rockchip-spi.bin" to be produced, and we were wondering on whether it should be provided as a result of our build to downstream users [1].
Removing it from the `defconfig` sounds like the best way to prevent this confusion. If people solder on a SPI Flash manually, they probably know how to re-add it to the uboot config ;-)
Could you send a patch for that?
Note that the RK1 is a little different from most RK3588 boards in that UART9 at 115200 baud is the generally-accepted debug UART (due both to the popularity of pairing it with the Turing Pi 2 clusterboard, and for pin-compatibility with most NVIDIA Jetson SoMs), and setting this very early in boot requires using Rockchip's "ddrbin_tool" to change the configuration embedded in the ddrbin/TPL image. If you're already supporting other targets that require ddrbin configuration changes, please add these for RK1:
uart id=9 uart iomux=0 uart baudrate=115200
...but if this would require going significantly out of your way, don't worry about it. IIUC this is only required to get TPL+SPL output routed correctly: the U-Boot monitor + kernel will still (re)initialize UART9 appropriately.
We currently simply use `bin/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.16.bin` from https://github.com/rockchip-linux/rkbin for all RK3588 targets as `ROCKCHIP_TPL`.
There doesn't seem to be a RK1-specific blob in the repo, and so far we're not invoking the closed-source x86_64-linux-only `tools/ddrbin_tool` binary to produce an alternative version of the SPL for other targets either.
So if it also works without doing that (maybe with a little bit less debug serial output during early boot) we'd probably keep it like this ;-)
Thanks, Florian
[1]: https://github.com/NixOS/nixpkgs/pull/302138#discussion_r1560349114
Florian Klink
