[U-Boot] [PATCH] mmc: rmobile: Add SDHC support for Renesas rmobile ARM SoC
This adds Renesas rmobile ARM SoC's SD/MMC host support. This drivers tested with Gose board and Koelsch board.
Signed-off-by: Yoshiyuki Ito yoshiyuki.ito.ub@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/arch-rmobile/r8a7790.h | 6 + arch/arm/include/asm/arch-rmobile/r8a7791.h | 5 + arch/arm/include/asm/arch-rmobile/r8a7793.h | 5 + arch/arm/include/asm/arch-rmobile/r8a7794.h | 5 + arch/arm/include/asm/arch-rmobile/rcar-base.h | 3 + arch/arm/include/asm/arch-rmobile/sh_sdhi.h | 166 +++++++ drivers/mmc/Kconfig | 9 + drivers/mmc/Makefile | 1 + drivers/mmc/sh_sdhi.c | 688 ++++++++++++++++++++++++++ 9 files changed, 888 insertions(+) create mode 100644 arch/arm/include/asm/arch-rmobile/sh_sdhi.h create mode 100644 drivers/mmc/sh_sdhi.c
diff --git a/arch/arm/include/asm/arch-rmobile/r8a7790.h b/arch/arm/include/asm/arch-rmobile/r8a7790.h index de14869..a70adc6 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7790.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7790.h @@ -15,6 +15,12 @@ #define CONFIG_SYS_I2C_SH_BASE2 0xE6520000 #define CONFIG_SYS_I2C_SH_BASE3 0xE60B0000
+/* SDHI */ +#define CONFIG_SYS_SH_SDHI1_BASE 0xEE120000 +#define CONFIG_SYS_SH_SDHI2_BASE 0xEE140000 +#define CONFIG_SYS_SH_SDHI3_BASE 0xEE160000 +#define CONFIG_SYS_SH_SDHI_NR_CHANNEL 4 + #define R8A7790_CUT_ES2X 2 #define IS_R8A7790_ES2() \ (rmobile_get_cpu_rev_integer() == R8A7790_CUT_ES2X) diff --git a/arch/arm/include/asm/arch-rmobile/r8a7791.h b/arch/arm/include/asm/arch-rmobile/r8a7791.h index 26a0bd5..658d435 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7791.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7791.h @@ -17,6 +17,11 @@ /* SH-I2C */ #define CONFIG_SYS_I2C_SH_BASE2 0xE60B0000
+/* SDHI */ +#define CONFIG_SYS_SH_SDHI1_BASE 0xEE140000 +#define CONFIG_SYS_SH_SDHI2_BASE 0xEE160000 +#define CONFIG_SYS_SH_SDHI_NR_CHANNEL 3 + #define DBSC3_1_QOS_R0_BASE 0xE67A1000 #define DBSC3_1_QOS_R1_BASE 0xE67A1100 #define DBSC3_1_QOS_R2_BASE 0xE67A1200 diff --git a/arch/arm/include/asm/arch-rmobile/r8a7793.h b/arch/arm/include/asm/arch-rmobile/r8a7793.h index 778812e..505c812 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7793.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7793.h @@ -18,6 +18,11 @@ /* SH-I2C */ #define CONFIG_SYS_I2C_SH_BASE2 0xE60B0000
+/* SDHI */ +#define CONFIG_SYS_SH_SDHI1_BASE 0xEE140000 +#define CONFIG_SYS_SH_SDHI2_BASE 0xEE160000 +#define CONFIG_SYS_SH_SDHI_NR_CHANNEL 3 + #define DBSC3_1_QOS_R0_BASE 0xE67A1000 #define DBSC3_1_QOS_R1_BASE 0xE67A1100 #define DBSC3_1_QOS_R2_BASE 0xE67A1200 diff --git a/arch/arm/include/asm/arch-rmobile/r8a7794.h b/arch/arm/include/asm/arch-rmobile/r8a7794.h index 66d5a29..e8f1d1d 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7794.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7794.h @@ -14,4 +14,9 @@ /* SH-I2C */ #define CONFIG_SYS_I2C_SH_BASE2 0xE60B0000
+/* SDHI */ +#define CONFIG_SYS_SH_SDHI1_BASE 0xEE140000 +#define CONFIG_SYS_SH_SDHI2_BASE 0xEE160000 +#define CONFIG_SYS_SH_SDHI_NR_CHANNEL 3 + #endif /* __ASM_ARCH_R8A7794_H */ diff --git a/arch/arm/include/asm/arch-rmobile/rcar-base.h b/arch/arm/include/asm/arch-rmobile/rcar-base.h index dbbebcf..0bae173 100644 --- a/arch/arm/include/asm/arch-rmobile/rcar-base.h +++ b/arch/arm/include/asm/arch-rmobile/rcar-base.h @@ -43,6 +43,9 @@ #define CONFIG_SYS_RCAR_I2C2_BASE 0xE6530000 #define CONFIG_SYS_RCAR_I2C3_BASE 0xE6540000
+/* SDHI */ +#define CONFIG_SYS_SH_SDHI0_BASE 0xEE100000 + #define S3C_BASE 0xE6784000 #define S3C_INT_BASE 0xE6784A00 #define S3C_MEDIA_BASE 0xE6784B00 diff --git a/arch/arm/include/asm/arch-rmobile/sh_sdhi.h b/arch/arm/include/asm/arch-rmobile/sh_sdhi.h new file mode 100644 index 0000000..bd9df09 --- /dev/null +++ b/arch/arm/include/asm/arch-rmobile/sh_sdhi.h @@ -0,0 +1,166 @@ +/* + * drivers/mmc/sh-sdhi.h + * + * SD/MMC driver for Reneas rmobile ARM SoCs + * + * Copyright (C) 2013-2014 Renesas Electronics Corporation + * Copyright (C) 2008-2009 Renesas Solutions Corp. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _SH_SDHI_H +#define _SH_SDHI_H + +#define SDHI_CMD (0x0000 >> 1) +#define SDHI_PORTSEL (0x0004 >> 1) +#define SDHI_ARG0 (0x0008 >> 1) +#define SDHI_ARG1 (0x000C >> 1) +#define SDHI_STOP (0x0010 >> 1) +#define SDHI_SECCNT (0x0014 >> 1) +#define SDHI_RSP00 (0x0018 >> 1) +#define SDHI_RSP01 (0x001C >> 1) +#define SDHI_RSP02 (0x0020 >> 1) +#define SDHI_RSP03 (0x0024 >> 1) +#define SDHI_RSP04 (0x0028 >> 1) +#define SDHI_RSP05 (0x002C >> 1) +#define SDHI_RSP06 (0x0030 >> 1) +#define SDHI_RSP07 (0x0034 >> 1) +#define SDHI_INFO1 (0x0038 >> 1) +#define SDHI_INFO2 (0x003C >> 1) +#define SDHI_INFO1_MASK (0x0040 >> 1) +#define SDHI_INFO2_MASK (0x0044 >> 1) +#define SDHI_CLK_CTRL (0x0048 >> 1) +#define SDHI_SIZE (0x004C >> 1) +#define SDHI_OPTION (0x0050 >> 1) +#define SDHI_ERR_STS1 (0x0058 >> 1) +#define SDHI_ERR_STS2 (0x005C >> 1) +#define SDHI_BUF0 (0x0060 >> 1) +#define SDHI_SDIO_MODE (0x0068 >> 1) +#define SDHI_SDIO_INFO1 (0x006C >> 1) +#define SDHI_SDIO_INFO1_MASK (0x0070 >> 1) +#define SDHI_CC_EXT_MODE (0x01B0 >> 1) +#define SDHI_SOFT_RST (0x01C0 >> 1) +#define SDHI_VERSION (0x01C4 >> 1) +#define SDHI_HOST_MODE (0x01C8 >> 1) +#define SDHI_SDIF_MODE (0x01CC >> 1) +#define SDHI_EXT_SWAP (0x01E0 >> 1) +#define SDHI_SD_DMACR (0x0324 >> 1) + +/* SDHI CMD VALUE */ +#define CMD_MASK 0x0000ffff +#define SDHI_APP 0x0040 +#define SDHI_SD_APP_SEND_SCR 0x0073 +#define SDHI_SD_SWITCH 0x1C06 + +/* SDHI_PORTSEL */ +#define USE_1PORT (1 << 8) /* 1 port */ + +/* SDHI_ARG */ +#define ARG0_MASK 0x0000ffff +#define ARG1_MASK 0x0000ffff + +/* SDHI_STOP */ +#define STOP_SEC_ENABLE (1 << 8) + +/* SDHI_INFO1 */ +#define INFO1_RESP_END (1 << 0) +#define INFO1_ACCESS_END (1 << 2) +#define INFO1_CARD_RE (1 << 3) +#define INFO1_CARD_IN (1 << 4) +#define INFO1_ISD0CD (1 << 5) +#define INFO1_WRITE_PRO (1 << 7) +#define INFO1_DATA3_CARD_RE (1 << 8) +#define INFO1_DATA3_CARD_IN (1 << 9) +#define INFO1_DATA3 (1 << 10) + +/* SDHI_INFO2 */ +#define INFO2_CMD_ERROR (1 << 0) +#define INFO2_CRC_ERROR (1 << 1) +#define INFO2_END_ERROR (1 << 2) +#define INFO2_TIMEOUT (1 << 3) +#define INFO2_BUF_ILL_WRITE (1 << 4) +#define INFO2_BUF_ILL_READ (1 << 5) +#define INFO2_RESP_TIMEOUT (1 << 6) +#define INFO2_SDDAT0 (1 << 7) +#define INFO2_BRE_ENABLE (1 << 8) +#define INFO2_BWE_ENABLE (1 << 9) +#define INFO2_CBUSY (1 << 14) +#define INFO2_ILA (1 << 15) +#define INFO2_ALL_ERR (0x807f) + +/* SDHI_INFO1_MASK */ +#define INFO1M_RESP_END (1 << 0) +#define INFO1M_ACCESS_END (1 << 2) +#define INFO1M_CARD_RE (1 << 3) +#define INFO1M_CARD_IN (1 << 4) +#define INFO1M_DATA3_CARD_RE (1 << 8) +#define INFO1M_DATA3_CARD_IN (1 << 9) +#define INFO1M_ALL (0xffff) +#define INFO1M_SET (INFO1M_RESP_END | \ + INFO1M_ACCESS_END | \ + INFO1M_DATA3_CARD_RE | \ + INFO1M_DATA3_CARD_IN) + +/* SDHI_INFO2_MASK */ +#define INFO2M_CMD_ERROR (1 << 0) +#define INFO2M_CRC_ERROR (1 << 1) +#define INFO2M_END_ERROR (1 << 2) +#define INFO2M_TIMEOUT (1 << 3) +#define INFO2M_BUF_ILL_WRITE (1 << 4) +#define INFO2M_BUF_ILL_READ (1 << 5) +#define INFO2M_RESP_TIMEOUT (1 << 6) +#define INFO2M_BRE_ENABLE (1 << 8) +#define INFO2M_BWE_ENABLE (1 << 9) +#define INFO2M_ILA (1 << 15) +#define INFO2M_ALL (0xffff) +#define INFO2M_ALL_ERR (0x807f) + +/* SDHI_CLK_CTRL */ +#define CLK_ENABLE (1 << 8) + +/* SDHI_OPTION */ +#define OPT_BUS_WIDTH_1 (1 << 15) /* bus width = 1 bit */ + +/* SDHI_ERR_STS1 */ +#define ERR_STS1_CRC_ERROR ((1 << 11) | (1 << 10) | (1 << 9) | \ + (1 << 8) | (1 << 5)) +#define ERR_STS1_CMD_ERROR ((1 << 4) | (1 << 3) | (1 << 2) | \ + (1 << 1) | (1 << 0)) + +/* SDHI_ERR_STS2 */ +#define ERR_STS2_RES_TIMEOUT (1 << 0) +#define ERR_STS2_RES_STOP_TIMEOUT ((1 << 0) | (1 << 1)) +#define ERR_STS2_SYS_ERROR ((1 << 6) | (1 << 5) | (1 << 4) | \ + (1 << 3) | (1 << 2) | (1 << 1) | \ + (1 << 0)) + +/* SDHI_SDIO_MODE */ +#define SDIO_MODE_ON (1 << 0) +#define SDIO_MODE_OFF (0 << 0) + +/* SDHI_SDIO_INFO1 */ +#define SDIO_INFO1_IOIRQ (1 << 0) +#define SDIO_INFO1_EXPUB52 (1 << 14) +#define SDIO_INFO1_EXWT (1 << 15) + +/* SDHI_SDIO_INFO1_MASK */ +#define SDIO_INFO1M_CLEAR ((1 << 1) | (1 << 2)) +#define SDIO_INFO1M_ON ((1 << 15) | (1 << 14) | (1 << 2) | \ + (1 << 1) | (1 << 0)) + +/* SDHI_EXT_SWAP */ +#define SET_SWAP ((1 << 6) | (1 << 7)) /* SWAP */ + +/* SDHI_SOFT_RST */ +#define SOFT_RST_ON (0 << 0) +#define SOFT_RST_OFF (1 << 0) + +#define CLKDEV_SD_DATA 25000000 /* 25 MHz */ +#define CLKDEV_HS_DATA 50000000 /* 50 MHz */ +#define CLKDEV_MMC_DATA 20000000 /* 20MHz */ +#define CLKDEV_INIT 400000 /* 100 - 400 KHz */ + +int sh_sdhi_init(unsigned long addr, int ch); + +#endif /* _SH_SDHI_H */ diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index e69de29..7ba85a2 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -0,0 +1,9 @@ +menu "MMC Host controller Support" + +config SH_SDHI + bool "SuperH/Renesas ARM SoCs on-chip SDHI host controller support" + depends on RMOBILE + help + Support for the on-chip SDHI host controller on SuperH/Renesas ARM SoCs platform + +endmenu diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 464cee1..0b645cc 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -25,6 +25,7 @@ obj-$(CONFIG_KONA_SDHCI) += kona_sdhci.o obj-$(CONFIG_S3C_SDI) += s3c_sdi.o obj-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o obj-$(CONFIG_SH_MMCIF) += sh_mmcif.o +obj-$(CONFIG_SH_SDHI) += sh_sdhi.o obj-$(CONFIG_SPEAR_SDHCI) += spear_sdhci.o obj-$(CONFIG_TEGRA_MMC) += tegra_mmc.o obj-$(CONFIG_DWMMC) += dw_mmc.o diff --git a/drivers/mmc/sh_sdhi.c b/drivers/mmc/sh_sdhi.c new file mode 100644 index 0000000..7db3f4e --- /dev/null +++ b/drivers/mmc/sh_sdhi.c @@ -0,0 +1,688 @@ +/* + * drivers/mmc/sh_sdhi.c + * + * SD/MMC driver for Renesas rmobile ARM SoCs. + * + * Copyright (C) 2011,2013-2014 Renesas Electronics Corporation + * Copyright (C) 2014 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * Copyright (C) 2008-2009 Renesas Solutions Corp. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <mmc.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/arch/rmobile.h> +#include <asm/arch/sh_sdhi.h> + +#define DRIVER_NAME "sh-sdhi" + +struct sh_sdhi_host { + unsigned long addr; + int ch; + int bus_shift; +}; + +static unsigned short g_wait_int[CONFIG_SYS_SH_SDHI_NR_CHANNEL]; +static unsigned short g_sd_error[CONFIG_SYS_SH_SDHI_NR_CHANNEL]; + +static inline void sh_sdhi_writew(struct sh_sdhi_host *host, int reg, u16 val) +{ + writew(val, host->addr + (reg << host->bus_shift)); +} + +static inline u16 sh_sdhi_readw(struct sh_sdhi_host *host, int reg) +{ + return readw(host->addr + (reg << host->bus_shift)); +} + +static void *mmc_priv(struct mmc *mmc) +{ + return (void *)mmc->priv; +} + +static int detect_waiting; +static void sh_sdhi_detect(struct sh_sdhi_host *host) +{ + sh_sdhi_writew(host, SDHI_OPTION, + OPT_BUS_WIDTH_1 | sh_sdhi_readw(host, SDHI_OPTION)); + + detect_waiting = 0; +} + +static int sh_sdhi_intr(void *dev_id) +{ + struct sh_sdhi_host *host = dev_id; + int state1 = 0, state2 = 0; + + state1 = sh_sdhi_readw(host, SDHI_INFO1); + state2 = sh_sdhi_readw(host, SDHI_INFO2); + + debug("%s: state1 = %x, state2 = %x\n", __func__, state1, state2); + + /* CARD Insert */ + if (state1 & INFO1_CARD_IN) { + sh_sdhi_writew(host, SDHI_INFO1, ~INFO1_CARD_IN); + if (!detect_waiting) { + detect_waiting = 1; + sh_sdhi_detect(host); + } + sh_sdhi_writew(host, SDHI_INFO1_MASK, INFO1M_RESP_END | + INFO1M_ACCESS_END | INFO1M_CARD_IN | + INFO1M_DATA3_CARD_RE | INFO1M_DATA3_CARD_IN); + return -EAGAIN; + } + /* CARD Removal */ + if (state1 & INFO1_CARD_RE) { + sh_sdhi_writew(host, SDHI_INFO1, ~INFO1_CARD_RE); + if (!detect_waiting) { + detect_waiting = 1; + sh_sdhi_detect(host); + } + sh_sdhi_writew(host, SDHI_INFO1_MASK, INFO1M_RESP_END | + INFO1M_ACCESS_END | INFO1M_CARD_RE | + INFO1M_DATA3_CARD_RE | INFO1M_DATA3_CARD_IN); + sh_sdhi_writew(host, SDHI_SDIO_INFO1_MASK, SDIO_INFO1M_ON); + sh_sdhi_writew(host, SDHI_SDIO_MODE, SDIO_MODE_OFF); + return -EAGAIN; + } + + if (state2 & INFO2_ALL_ERR) { + sh_sdhi_writew(host, SDHI_INFO2, + (unsigned short)~(INFO2_ALL_ERR)); + sh_sdhi_writew(host, SDHI_INFO2_MASK, + INFO2M_ALL_ERR | + sh_sdhi_readw(host, SDHI_INFO2_MASK)); + g_sd_error[host->ch] = 1; + g_wait_int[host->ch] = 1; + return 0; + } + /* Respons End */ + if (state1 & INFO1_RESP_END) { + sh_sdhi_writew(host, SDHI_INFO1, ~INFO1_RESP_END); + sh_sdhi_writew(host, SDHI_INFO1_MASK, + INFO1M_RESP_END | + sh_sdhi_readw(host, SDHI_INFO1_MASK)); + g_wait_int[host->ch] = 1; + return 0; + } + /* SD_BUF Read Enable */ + if (state2 & INFO2_BRE_ENABLE) { + sh_sdhi_writew(host, SDHI_INFO2, ~INFO2_BRE_ENABLE); + sh_sdhi_writew(host, SDHI_INFO2_MASK, + INFO2M_BRE_ENABLE | INFO2M_BUF_ILL_READ | + sh_sdhi_readw(host, SDHI_INFO2_MASK)); + g_wait_int[host->ch] = 1; + return 0; + } + /* SD_BUF Write Enable */ + if (state2 & INFO2_BWE_ENABLE) { + sh_sdhi_writew(host, SDHI_INFO2, ~INFO2_BWE_ENABLE); + sh_sdhi_writew(host, SDHI_INFO2_MASK, + INFO2_BWE_ENABLE | INFO2M_BUF_ILL_WRITE | + sh_sdhi_readw(host, SDHI_INFO2_MASK)); + g_wait_int[host->ch] = 1; + return 0; + } + /* Access End */ + if (state1 & INFO1_ACCESS_END) { + sh_sdhi_writew(host, SDHI_INFO1, ~INFO1_ACCESS_END); + sh_sdhi_writew(host, SDHI_INFO1_MASK, + INFO1_ACCESS_END | + sh_sdhi_readw(host, SDHI_INFO1_MASK)); + g_wait_int[host->ch] = 1; + return 0; + } + return -EAGAIN; +} + +static int sh_sdhi_wait_interrupt_flag(struct sh_sdhi_host *host) +{ + int timeout = 10000000; + + while (1) { + timeout--; + if (timeout < 0) { + puts("timeout\n"); + return 0; + } + + if (!sh_sdhi_intr(host)) + break; + + udelay(1); /* 1 usec */ + } + + return 1; /* Return value: NOT 0 = complete waiting */ +} + +static void sh_sdhi_clock_control(struct sh_sdhi_host *host, unsigned long clk) +{ + u32 clkdiv, i; + + if (sh_sdhi_readw(host, SDHI_INFO2) & (1 << 14)) { + printf(DRIVER_NAME": Busy state ! Cannot change the clock\n"); + return; + } + + sh_sdhi_writew(host, SDHI_CLK_CTRL, + ~CLK_ENABLE & sh_sdhi_readw(host, SDHI_CLK_CTRL)); + + if (clk == 0) + return; + + clkdiv = 0x80; + i = CONFIG_SH_SDHI_FREQ >> (0x8 + 1); + for (; clkdiv && clk >= (i << 1); (clkdiv >>= 1)) + i <<= 1; + + sh_sdhi_writew(host, SDHI_CLK_CTRL, clkdiv); + + /* Waiting for SD Bus busy to be cleared */ + while ((sh_sdhi_readw(host, SDHI_INFO2) & 0x2000) == 0) + ; + + sh_sdhi_writew(host, SDHI_CLK_CTRL, + CLK_ENABLE | sh_sdhi_readw(host, SDHI_CLK_CTRL)); +} + +static void sh_sdhi_sync_reset(struct sh_sdhi_host *host) +{ + sh_sdhi_writew(host, SDHI_SOFT_RST, SOFT_RST_ON); + sh_sdhi_writew(host, SDHI_SOFT_RST, SOFT_RST_OFF); + sh_sdhi_writew(host, SDHI_CLK_CTRL, + CLK_ENABLE | sh_sdhi_readw(host, SDHI_CLK_CTRL)); + + while (sh_sdhi_readw(host, SDHI_INFO2) & INFO2_CBUSY) + udelay(100); + +#if defined(CONFIG_R8A7790) + if (host->ch < 2) + sh_sdhi_writew(host, SDHI_HOST_MODE, 1); /* 16bit access */ +#elif defined(CONFIG_R8A7791) || defined(CONFIG_R8A7793) || \ + defined(CONFIG_R8A7790) + if (host->ch == 0) + sh_sdhi_writew(host, SDHI_HOST_MODE, 1); /* 16bit access */ +#endif +} + +static int sh_sdhi_error_manage(struct sh_sdhi_host *host) +{ + unsigned short e_state1, e_state2; + int ret; + + g_sd_error[host->ch] = 0; + g_wait_int[host->ch] = 0; + + e_state1 = sh_sdhi_readw(host, SDHI_ERR_STS1); + e_state2 = sh_sdhi_readw(host, SDHI_ERR_STS2); + if (e_state2 & ERR_STS2_SYS_ERROR) { + if (e_state2 & ERR_STS2_RES_STOP_TIMEOUT) + ret = TIMEOUT; + else + ret = -EILSEQ; + debug("%s: ERR_STS2 = %04x\n", + DRIVER_NAME, sh_sdhi_readw(host, SDHI_ERR_STS2)); + sh_sdhi_sync_reset(host); + sh_sdhi_writew(host, SDHI_INFO1_MASK, + INFO1M_DATA3_CARD_RE | INFO1M_DATA3_CARD_IN); + return ret; + } + if (e_state1 & ERR_STS1_CRC_ERROR || e_state1 & ERR_STS1_CMD_ERROR) + ret = -EILSEQ; + else + ret = TIMEOUT; + + debug("%s: ERR_STS1 = %04x\n", + DRIVER_NAME, sh_sdhi_readw(host, SDHI_ERR_STS1)); + sh_sdhi_sync_reset(host); + sh_sdhi_writew(host, SDHI_INFO1_MASK, + INFO1M_DATA3_CARD_RE | INFO1M_DATA3_CARD_IN); + return ret; +} + +static int sh_sdhi_single_read(struct sh_sdhi_host *host, struct mmc_data *data) +{ + int ch = host->ch; + long time; + unsigned short blocksize, i; + unsigned short *p = (unsigned short *)data->dest; + + if ((unsigned long)p & 0x00000001) { + printf(DRIVER_NAME": %s: The data pointer is unaligned.", + __func__); + return -EIO; + } + + g_wait_int[ch] = 0; + sh_sdhi_writew(host, SDHI_INFO2_MASK, + ~(INFO2M_BRE_ENABLE | INFO2M_BUF_ILL_READ) & + sh_sdhi_readw(host, SDHI_INFO2_MASK)); + sh_sdhi_writew(host, SDHI_INFO1_MASK, + ~INFO1M_ACCESS_END & + sh_sdhi_readw(host, SDHI_INFO1_MASK)); + time = sh_sdhi_wait_interrupt_flag(host); + if (time == 0 || g_sd_error[ch] != 0) + return sh_sdhi_error_manage(host); + + g_wait_int[ch] = 0; + blocksize = sh_sdhi_readw(host, SDHI_SIZE); + for (i = 0; i < blocksize / 2; i++) + *p++ = sh_sdhi_readw(host, SDHI_BUF0); + + time = sh_sdhi_wait_interrupt_flag(host); + if (time == 0 || g_sd_error[ch] != 0) + return sh_sdhi_error_manage(host); + + g_wait_int[ch] = 0; + return 0; +} + +static int sh_sdhi_multi_read(struct sh_sdhi_host *host, struct mmc_data *data) +{ + int ch = host->ch; + long time; + unsigned short blocksize, i, sec; + unsigned short *p = (unsigned short *)data->dest; + + if ((unsigned long)p & 0x00000001) { + printf(DRIVER_NAME": %s: The data pointer is unaligned.", + __func__); + return -EIO; + } + + debug("%s: blocks = %d, blocksize = %d\n", + __func__, data->blocks, data->blocksize); + + g_wait_int[ch] = 0; + for (sec = 0; sec < data->blocks; sec++) { + sh_sdhi_writew(host, SDHI_INFO2_MASK, + ~(INFO2M_BRE_ENABLE | INFO2M_BUF_ILL_READ) & + sh_sdhi_readw(host, SDHI_INFO2_MASK)); + + time = sh_sdhi_wait_interrupt_flag(host); + if (time == 0 || g_sd_error[ch] != 0) + return sh_sdhi_error_manage(host); + + g_wait_int[ch] = 0; + blocksize = sh_sdhi_readw(host, SDHI_SIZE); + for (i = 0; i < blocksize / 2; i++) + *p++ = sh_sdhi_readw(host, SDHI_BUF0); + } + + return 0; +} + +static int sh_sdhi_single_write(struct sh_sdhi_host *host, + struct mmc_data *data) +{ + int ch = host->ch; + long time; + unsigned short blocksize, i; + const unsigned short *p = (const unsigned short *)data->src; + + if ((unsigned long)p & 0x00000001) { + printf(DRIVER_NAME": %s: The data pointer is unaligned.", + __func__); + return -EIO; + } + + debug("%s: blocks = %d, blocksize = %d\n", + __func__, data->blocks, data->blocksize); + + g_wait_int[ch] = 0; + sh_sdhi_writew(host, SDHI_INFO2_MASK, + ~(INFO2M_BWE_ENABLE | INFO2M_BUF_ILL_WRITE) & + sh_sdhi_readw(host, SDHI_INFO2_MASK)); + sh_sdhi_writew(host, SDHI_INFO1_MASK, + ~INFO1M_ACCESS_END & + sh_sdhi_readw(host, SDHI_INFO1_MASK)); + + time = sh_sdhi_wait_interrupt_flag(host); + if (time == 0 || g_sd_error[ch] != 0) + return sh_sdhi_error_manage(host); + + g_wait_int[ch] = 0; + blocksize = sh_sdhi_readw(host, SDHI_SIZE); + for (i = 0; i < blocksize / 2; i++) + sh_sdhi_writew(host, SDHI_BUF0, *p++); + + time = sh_sdhi_wait_interrupt_flag(host); + if (time == 0 || g_sd_error[ch] != 0) + return sh_sdhi_error_manage(host); + + g_wait_int[ch] = 0; + return 0; +} + +static int sh_sdhi_multi_write(struct sh_sdhi_host *host, struct mmc_data *data) +{ + int ch = host->ch; + long time; + unsigned short i, sec, blocksize; + const unsigned short *p = (const unsigned short *)data->src; + + debug("%s: blocks = %d, blocksize = %d\n", + __func__, data->blocks, data->blocksize); + + g_wait_int[ch] = 0; + for (sec = 0; sec < data->blocks; sec++) { + sh_sdhi_writew(host, SDHI_INFO2_MASK, + ~(INFO2M_BWE_ENABLE | INFO2M_BUF_ILL_WRITE) & + sh_sdhi_readw(host, SDHI_INFO2_MASK)); + + time = sh_sdhi_wait_interrupt_flag(host); + if (time == 0 || g_sd_error[ch] != 0) + return sh_sdhi_error_manage(host); + + g_wait_int[ch] = 0; + blocksize = sh_sdhi_readw(host, SDHI_SIZE); + for (i = 0; i < blocksize / 2; i++) + sh_sdhi_writew(host, SDHI_BUF0, *p++); + } + + return 0; +} + +static void sh_sdhi_get_response(struct sh_sdhi_host *host, struct mmc_cmd *cmd) +{ + unsigned short i, j, cnt = 1; + volatile unsigned short resp[8]; + volatile unsigned long *p1, *p2; + + if (cmd->resp_type & MMC_RSP_136) { + cnt = 4; + resp[0] = sh_sdhi_readw(host, SDHI_RSP00); + resp[1] = sh_sdhi_readw(host, SDHI_RSP01); + resp[2] = sh_sdhi_readw(host, SDHI_RSP02); + resp[3] = sh_sdhi_readw(host, SDHI_RSP03); + resp[4] = sh_sdhi_readw(host, SDHI_RSP04); + resp[5] = sh_sdhi_readw(host, SDHI_RSP05); + resp[6] = sh_sdhi_readw(host, SDHI_RSP06); + resp[7] = sh_sdhi_readw(host, SDHI_RSP07); + + /* SDHI REGISTER SPECIFICATION */ + for (i = 7, j = 6; i > 0; i--) { + resp[i] = (resp[i] << 8) & 0xff00; + resp[i] |= (resp[j--] >> 8) & 0x00ff; + } + resp[0] = (resp[0] << 8) & 0xff00; + + /* SDHI REGISTER SPECIFICATION */ + p1 = ((unsigned long *)resp) + 3; + + } else { + resp[0] = sh_sdhi_readw(host, SDHI_RSP00); + resp[1] = sh_sdhi_readw(host, SDHI_RSP01); + + p1 = ((unsigned long *)resp); + } + + p2 = (unsigned long *)cmd->response; +#if defined(__BIG_ENDIAN_BITFIELD) + for (i = 0; i < cnt; i++) { + *p2++ = ((*p1 >> 16) & 0x0000ffff) | + ((*p1 << 16) & 0xffff0000); + p1--; + } +#else + for (i = 0; i < cnt; i++) + *p2++ = *p1--; +#endif /* __BIG_ENDIAN_BITFIELD */ +} + +static unsigned short sh_sdhi_set_cmd(struct sh_sdhi_host *host, + struct mmc_data *data, unsigned short opc) +{ + switch (opc) { + case SD_CMD_APP_SEND_OP_COND: + case SD_CMD_APP_SEND_SCR: + opc |= SDHI_APP; + break; + case SD_CMD_APP_SET_BUS_WIDTH: + /* SD_APP_SET_BUS_WIDTH*/ + if (!data) + opc |= SDHI_APP; + else /* SD_SWITCH */ + opc = SDHI_SD_SWITCH; + break; + default: + break; + } + return opc; +} + +static unsigned short sh_sdhi_data_trans(struct sh_sdhi_host *host, + struct mmc_data *data, unsigned short opc) +{ + unsigned short ret; + + switch (opc) { + case MMC_CMD_READ_MULTIPLE_BLOCK: + ret = sh_sdhi_multi_read(host, data); + break; + case MMC_CMD_WRITE_MULTIPLE_BLOCK: + ret = sh_sdhi_multi_write(host, data); + break; + case MMC_CMD_WRITE_SINGLE_BLOCK: + ret = sh_sdhi_single_write(host, data); + break; + case MMC_CMD_READ_SINGLE_BLOCK: + case SDHI_SD_APP_SEND_SCR: + case SDHI_SD_SWITCH: /* SD_SWITCH */ + ret = sh_sdhi_single_read(host, data); + break; + default: + printf(DRIVER_NAME": SD: NOT SUPPORT CMD = d'%04d\n", opc); + ret = -EINVAL; + break; + } + return ret; +} + +static int sh_sdhi_start_cmd(struct sh_sdhi_host *host, + struct mmc_data *data, struct mmc_cmd *cmd) +{ + long time; + unsigned short opc = cmd->cmdidx; + int ret = 0; + + debug("opc = %d, arg = %x, resp_type = %x\n", + opc, cmd->cmdarg, cmd->resp_type); + + if (opc == MMC_CMD_STOP_TRANSMISSION) { + /* SDHI sends the STOP command automatically by STOP reg */ + sh_sdhi_writew(host, SDHI_INFO1_MASK, ~INFO1M_ACCESS_END & + sh_sdhi_readw(host, SDHI_INFO1_MASK)); + + time = sh_sdhi_wait_interrupt_flag(host); + if (time == 0 || g_sd_error[host->ch] != 0) + return sh_sdhi_error_manage(host); + + sh_sdhi_get_response(host, cmd); + return 0; + } + + if (data) { + if ((opc == MMC_CMD_READ_MULTIPLE_BLOCK) || + opc == MMC_CMD_WRITE_MULTIPLE_BLOCK) { + sh_sdhi_writew(host, SDHI_STOP, STOP_SEC_ENABLE); + sh_sdhi_writew(host, SDHI_SECCNT, data->blocks); + } + sh_sdhi_writew(host, SDHI_SIZE, data->blocksize); + } + opc = sh_sdhi_set_cmd(host, data, opc); + + /* + * U-boot cannot use interrupt. + * So this flag may not be clear by timing + */ + sh_sdhi_writew(host, SDHI_INFO1, ~INFO1_RESP_END); + + sh_sdhi_writew(host, SDHI_INFO1_MASK, + INFO1M_RESP_END | sh_sdhi_readw(host, SDHI_INFO1_MASK)); + sh_sdhi_writew(host, SDHI_ARG0, + (unsigned short)(cmd->cmdarg & ARG0_MASK)); + sh_sdhi_writew(host, SDHI_ARG1, + (unsigned short)((cmd->cmdarg >> 16) & ARG1_MASK)); + + /* Waiting for SD Bus busy to be cleared */ + while ((sh_sdhi_readw(host, SDHI_INFO2) & 0x2000) == 0) + ; + + sh_sdhi_writew(host, SDHI_CMD, (unsigned short)(opc & CMD_MASK)); + + g_wait_int[host->ch] = 0; + sh_sdhi_writew(host, SDHI_INFO1_MASK, + ~INFO1M_RESP_END & sh_sdhi_readw(host, SDHI_INFO1_MASK)); + sh_sdhi_writew(host, SDHI_INFO2_MASK, + ~(INFO2M_CMD_ERROR | INFO2M_CRC_ERROR | + INFO2M_END_ERROR | INFO2M_TIMEOUT | + INFO2M_RESP_TIMEOUT | INFO2M_ILA) & + sh_sdhi_readw(host, SDHI_INFO2_MASK)); + + time = sh_sdhi_wait_interrupt_flag(host); + if (!time) + return sh_sdhi_error_manage(host); + + if (g_sd_error[host->ch]) { + switch (cmd->cmdidx) { + case MMC_CMD_ALL_SEND_CID: + case MMC_CMD_SELECT_CARD: + case SD_CMD_SEND_IF_COND: + case MMC_CMD_APP_CMD: + ret = TIMEOUT; + break; + default: + printf(DRIVER_NAME": Cmd(d'%d) err\n", opc); + printf(DRIVER_NAME": cmdidx = %d\n", cmd->cmdidx); + ret = sh_sdhi_error_manage(host); + break; + } + g_sd_error[host->ch] = 0; + g_wait_int[host->ch] = 0; + return ret; + } + if (sh_sdhi_readw(host, SDHI_INFO1) & INFO1_RESP_END) + return -EINVAL; + + if (g_wait_int[host->ch]) { + sh_sdhi_get_response(host, cmd); + g_wait_int[host->ch] = 0; + } + if (data) + ret = sh_sdhi_data_trans(host, data, opc); + + debug("ret = %d, resp = %08x, %08x, %08x, %08x\n", + ret, cmd->response[0], cmd->response[1], + cmd->response[2], cmd->response[3]); + return ret; +} + +static int sh_sdhi_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct sh_sdhi_host *host = mmc_priv(mmc); + int ret; + + g_sd_error[host->ch] = 0; + + ret = sh_sdhi_start_cmd(host, data, cmd); + + return ret; +} + +static void sh_sdhi_set_ios(struct mmc *mmc) +{ + struct sh_sdhi_host *host = mmc_priv(mmc); + + sh_sdhi_clock_control(host, mmc->clock); + + if (mmc->bus_width == 4) + sh_sdhi_writew(host, SDHI_OPTION, ~OPT_BUS_WIDTH_1 & + sh_sdhi_readw(host, SDHI_OPTION)); + else + sh_sdhi_writew(host, SDHI_OPTION, OPT_BUS_WIDTH_1 | + sh_sdhi_readw(host, SDHI_OPTION)); + + debug("clock = %d, buswidth = %d\n", mmc->clock, mmc->bus_width); +} + +static int sh_sdhi_initialize(struct mmc *mmc) +{ + struct sh_sdhi_host *host = mmc_priv(mmc); + + sh_sdhi_sync_reset(host); + sh_sdhi_writew(host, SDHI_PORTSEL, USE_1PORT); + +#if defined(__BIG_ENDIAN_BITFIELD) + sh_sdhi_writew(host, SDHI_EXT_SWAP, SET_SWAP); +#endif + + sh_sdhi_writew(host, SDHI_INFO1_MASK, INFO1M_RESP_END | + INFO1M_ACCESS_END | INFO1M_CARD_RE | + INFO1M_DATA3_CARD_RE | INFO1M_DATA3_CARD_IN); + + return 0; +} + +static const struct mmc_ops sh_sdhi_ops = { + .send_cmd = sh_sdhi_send_cmd, + .set_ios = sh_sdhi_set_ios, + .init = sh_sdhi_initialize, +}; + +static struct mmc_config sh_sdhi_cfg = { + .name = DRIVER_NAME, + .ops = &sh_sdhi_ops, + .f_min = CLKDEV_INIT, + .f_max = CLKDEV_HS_DATA, + .voltages = MMC_VDD_32_33 | MMC_VDD_33_34, + .host_caps = MMC_MODE_4BIT | MMC_MODE_HS, + .part_type = PART_TYPE_DOS, + .b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, +}; + +int sh_sdhi_init(unsigned long addr, int ch) +{ + int ret = 0; + struct mmc *mmc; + struct sh_sdhi_host *host = NULL; + + if (ch >= CONFIG_SYS_SH_SDHI_NR_CHANNEL) + return -ENODEV; + + host = malloc(sizeof(struct sh_sdhi_host)); + if (!host) + return -ENOMEM; + + mmc = mmc_create(&sh_sdhi_cfg, host); + if (!mmc) { + ret = -1; + goto error; + } + + host->ch = ch; + host->addr = addr; +#if defined(CONFIG_R8A7790) + if (ch < 2) + host->bus_shift = 1; + else + host->bus_shift = 0; +#elif defined(CONFIG_R8A7791) || defined(CONFIG_R8A7793) || \ + defined(CONFIG_R8A7794) + if (ch == 0) + host->bus_shift = 1; + else + host->bus_shift = 0; +#endif + return ret; +error: + if (host) + free(host); + return ret; +} +
Hi Nobuhiro,
Very good state, just a few niggles.
On Nov 12, 2014, at 06:35 , Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote:
- drivers/mmc/sh-sdhi.h
- SD/MMC driver for Reneas rmobile ARM SoCs
- Copyright (C) 2013-2014 Renesas Electronics Corporation
- Copyright (C) 2008-2009 Renesas Solutions Corp.
- SPDX-License-Identifier: GPL-2.0
(1 << 0))
+config SH_SDHI
- bool "SuperH/Renesas ARM SoCs on-chip SDHI host controller support"
- depends on RMOBILE
- help
- drivers/mmc/sh_sdhi.c
- SD/MMC driver for Renesas rmobile ARM SoCs.
- Copyright (C) 2011,2013-2014 Renesas Electronics Corporation
- Copyright (C) 2014 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
- unsigned long addr;
- int ch;
- int bus_shift;
^^^ are you sure you want these global? members in sh_sdhi_host would work right?
- writew(val, host->addr + (reg << host->bus_shift));
- return readw(host->addr + (reg << host->bus_shift));
- return (void *)mmc->priv;
^^^ do you really need a static here? Don’t you have a perfectly fine sh_sdhi_host structure to stash it?
- sh_sdhi_writew(host, SDHI_OPTION,
- detect_waiting = 0;
- struct sh_sdhi_host *host = dev_id;
- int state1 = 0, state2 = 0;
- state1 = sh_sdhi_readw(host, SDHI_INFO1);
- state2 = sh_sdhi_readw(host, SDHI_INFO2);
- debug("%s: state1 = %x, state2 = %x\n", __func__, state1, state2);
- /* CARD Insert */
- if (state1 & INFO1_CARD_IN) {
detect_waiting = 1;
return -EAGAIN;
- /* CARD Removal */
- if (state1 & INFO1_CARD_RE) {
detect_waiting = 1;
return -EAGAIN;
- if (state2 & INFO2_ALL_ERR) {
INFO2M_ALL_ERR |
- /* Respons End */
- if (state1 & INFO1_RESP_END) {
INFO1M_RESP_END |
- /* SD_BUF Read Enable */
- if (state2 & INFO2_BRE_ENABLE) {
- /* SD_BUF Write Enable */
- if (state2 & INFO2_BWE_ENABLE) {
- /* Access End */
- if (state1 & INFO1_ACCESS_END) {
INFO1_ACCESS_END |
- return -EAGAIN;
- int timeout = 10000000;
- while (1) {
timeout--;
if (timeout < 0) {
puts("timeout\n");
break;
- return 1; /* Return value: NOT 0 = complete waiting */
- u32 clkdiv, i;
- if (sh_sdhi_readw(host, SDHI_INFO2) & (1 << 14)) {
return;
- sh_sdhi_writew(host, SDHI_CLK_CTRL,
- if (clk == 0)
return;
- clkdiv = 0x80;
- i = CONFIG_SH_SDHI_FREQ >> (0x8 + 1);
- for (; clkdiv && clk >= (i << 1); (clkdiv >>= 1))
i <<= 1;
- sh_sdhi_writew(host, SDHI_CLK_CTRL, clkdiv);
- /* Waiting for SD Bus busy to be cleared */
- while ((sh_sdhi_readw(host, SDHI_INFO2) & 0x2000) == 0)
^ some kind of timeout here, or maximum time to wait? You don’t have to handle the error; a printout would be fine.
- sh_sdhi_writew(host, SDHI_SOFT_RST, SOFT_RST_ON);
- sh_sdhi_writew(host, SDHI_SOFT_RST, SOFT_RST_OFF);
- while (sh_sdhi_readw(host, SDHI_INFO2) & INFO2_CBUSY)
udelay(100);
^ same as above
- if (host->ch < 2)
- defined(CONFIG_R8A7790)
- if (host->ch == 0)
Not really fond of the configs here. Some kind of quirk would be best.
- unsigned short e_state1, e_state2;
- int ret;
- g_sd_error[host->ch] = 0;
- g_wait_int[host->ch] = 0;
- e_state1 = sh_sdhi_readw(host, SDHI_ERR_STS1);
- e_state2 = sh_sdhi_readw(host, SDHI_ERR_STS2);
- if (e_state2 & ERR_STS2_SYS_ERROR) {
ret = TIMEOUT;
else
ret = -EILSEQ;
return ret;
- if (e_state1 & ERR_STS1_CRC_ERROR || e_state1 & ERR_STS1_CMD_ERROR)
ret = -EILSEQ;
- else
ret = TIMEOUT;
- debug("%s: ERR_STS1 = %04x\n",
- sh_sdhi_sync_reset(host);
- sh_sdhi_writew(host, SDHI_INFO1_MASK,
- return ret;
- int ch = host->ch;
- long time;
- unsigned short blocksize, i;
- unsigned short *p = (unsigned short *)data->dest;
- if ((unsigned long)p & 0x00000001) {
__func__);
return -EIO;
^ That’s supposed to be a debug only thing right?
- g_wait_int[ch] = 0;
- sh_sdhi_writew(host, SDHI_INFO2_MASK,
- time = sh_sdhi_wait_interrupt_flag(host);
- if (time == 0 || g_sd_error[ch] != 0)
^ Don’t really like the globals here.
- blocksize = sh_sdhi_readw(host, SDHI_SIZE);
- for (i = 0; i < blocksize / 2; i++)
- long time;
- unsigned short blocksize, i, sec;
__func__);
return -EIO;
^ Same, debug.
- debug("%s: blocks = %d, blocksize = %d\n",
- for (sec = 0; sec < data->blocks; sec++) {
g_wait_int[ch] = 0;
- long time;
- const unsigned short *p = (const unsigned short *)data->src;
__func__);
return -EIO;
^ debug
- long time;
- unsigned short i, sec, blocksize;
g_wait_int[ch] = 0;
- unsigned short i, j, cnt = 1;
- volatile unsigned short resp[8];
- volatile unsigned long *p1, *p2;
I would expect a very good reason for using volatiles here.
- if (cmd->resp_type & MMC_RSP_136) {
cnt = 4;
- } else {
- p2 = (unsigned long *)cmd->response;
- for (i = 0; i < cnt; i++) {
p1--;
+#else
*p2++ = *p1--;
Err, what is the meaning of this? I would want this in a different static inline function.
- switch (opc) {
- case SD_CMD_APP_SEND_OP_COND:
- case SD_CMD_APP_SEND_SCR:
opc |= SDHI_APP;
break;
- case SD_CMD_APP_SET_BUS_WIDTH:
if (!data)
opc |= SDHI_APP;
break;
- default:
break;
- return opc;
- unsigned short ret;
- switch (opc) {
- case MMC_CMD_READ_MULTIPLE_BLOCK:
break;
- case MMC_CMD_WRITE_MULTIPLE_BLOCK:
break;
- case MMC_CMD_WRITE_SINGLE_BLOCK:
break;
- case MMC_CMD_READ_SINGLE_BLOCK:
- case SDHI_SD_APP_SEND_SCR:
- case SDHI_SD_SWITCH: /* SD_SWITCH */
break;
- default:
ret = -EINVAL;
break;
- return ret;
- long time;
- unsigned short opc = cmd->cmdidx;
- int ret = 0;
- debug("opc = %d, arg = %x, resp_type = %x\n",
- if (opc == MMC_CMD_STOP_TRANSMISSION) {
- if (data) {
- opc = sh_sdhi_set_cmd(host, data, opc);
- sh_sdhi_writew(host, SDHI_INFO1, ~INFO1_RESP_END);
- sh_sdhi_writew(host, SDHI_ARG0,
- sh_sdhi_writew(host, SDHI_ARG1,
^ Timeout
- sh_sdhi_writew(host, SDHI_CMD, (unsigned short)(opc & CMD_MASK));
- if (!time)
- if (g_sd_error[host->ch]) {
ret = TIMEOUT;
break;
default:
break;
return ret;
- if (sh_sdhi_readw(host, SDHI_INFO1) & INFO1_RESP_END)
return -EINVAL;
- if (g_wait_int[host->ch]) {
- if (data)
- debug("ret = %d, resp = %08x, %08x, %08x, %08x\n",
- return ret;
- struct sh_sdhi_host *host = mmc_priv(mmc);
- int ret;
- ret = sh_sdhi_start_cmd(host, data, cmd);
- return ret;
- sh_sdhi_clock_control(host, mmc->clock);
- if (mmc->bus_width == 4)
- else
- debug("clock = %d, buswidth = %d\n", mmc->clock, mmc->bus_width);
- sh_sdhi_writew(host, SDHI_PORTSEL, USE_1PORT);
- sh_sdhi_writew(host, SDHI_EXT_SWAP, SET_SWAP);
- sh_sdhi_writew(host, SDHI_INFO1_MASK, INFO1M_RESP_END |
- .send_cmd = sh_sdhi_send_cmd,
- .set_ios = sh_sdhi_set_ios,
- .init = sh_sdhi_initialize,
- .name = DRIVER_NAME,
- .ops = &sh_sdhi_ops,
- .f_min = CLKDEV_INIT,
- .f_max = CLKDEV_HS_DATA,
- .voltages = MMC_VDD_32_33 | MMC_VDD_33_34,
- .host_caps = MMC_MODE_4BIT | MMC_MODE_HS,
- .part_type = PART_TYPE_DOS,
- .b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT,
- int ret = 0;
- struct mmc *mmc;
- struct sh_sdhi_host *host = NULL;
- if (ch >= CONFIG_SYS_SH_SDHI_NR_CHANNEL)
return -ENODEV;
- host = malloc(sizeof(struct sh_sdhi_host));
- if (!host)
return -ENOMEM;
- mmc = mmc_create(&sh_sdhi_cfg, host);
- if (!mmc) {
ret = -1;
goto error;
- host->ch = ch;
- host->addr = addr;
- if (ch < 2)
- else
- defined(CONFIG_R8A7794)
- if (ch == 0)
- else
^ Quirks?
- return ret;
+error:
- if (host)
free(host);
- return ret;
-- 2.1.1
Regards
— Pantelis
Hi, Pantelis.
Thanks for your review.
2014-12-13 3:25 GMT+09:00 Pantelis Antoniou panto@antoniou-consulting.com:
Hi Nobuhiro,
(1 << 0))
+config SH_SDHI
depends on RMOBILE
help
unsigned long addr;
int ch;
int bus_shift;
Indeed. I will move to sh_sdhi_host.
OK. Indeed. I will move to sh_sdhi_host.
detect_waiting = 0;
/* CARD Insert */
detect_waiting = 1;
return -EAGAIN;
/* CARD Removal */
detect_waiting = 1;
return -EAGAIN;
INFO2M_ALL_ERR |
/* Respons End */
INFO1M_RESP_END |
/* Access End */
INFO1_ACCESS_END |
return -EAGAIN;
while (1) {
timeout--;
if (timeout < 0) {
puts("timeout\n");
break;
u32 clkdiv, i;
return;
if (clk == 0)
return;
clkdiv = 0x80;
i <<= 1;
OK. I will add time out counter to wait.
udelay(100);
^ same as above
if (host->ch < 2)
if (host->ch == 0)
OK, I will use quirk for this.
int ret;
ret = TIMEOUT;
else
ret = -EILSEQ;
return ret;
ret = -EILSEQ;
else
ret = TIMEOUT;
return ret;
int ch = host->ch;
long time;
__func__);
return -EIO;
OK, I will change to debug.
g_wait_int[ch] = 0;
g_wait_int[ch] = 0;
Yes, I will move to sh_sdhi_host.
g_wait_int[ch] = 0;
int ch = host->ch;
long time;
__func__);
return -EIO;
^ Same, debug.
g_wait_int[ch] = 0;
g_wait_int[ch] = 0;
int ch = host->ch;
long time;
__func__);
return -EIO;
^ debug
g_wait_int[ch] = 0;
g_wait_int[ch] = 0;
g_wait_int[ch] = 0;
int ch = host->ch;
long time;
g_wait_int[ch] = 0;
g_wait_int[ch] = 0;
original code was used this as volatile. I will remove volatile form these line.
cnt = 4;
} else {
p1--;
+#else
*p2++ = *p1--;
This is word swap Yes, I know. But u-boot does not have word swap as __swahw32 in linux kenrel.
switch (opc) {
opc |= SDHI_APP;
break;
if (!data)
opc |= SDHI_APP;
break;
default:
break;
return opc;
unsigned short ret;
switch (opc) {
break;
break;
break;
break;
default:
ret = -EINVAL;
break;
return ret;
long time;
int ret = 0;
if (data) {
^ Timeout
I will add timeout control.
if (!time)
ret = TIMEOUT;
break;
default:
break;
return ret;
return -EINVAL;
if (data)
return ret;
int ret;
return ret;
else
int ret = 0;
struct mmc *mmc;
return -ENODEV;
if (!host)
return -ENOMEM;
if (!mmc) {
ret = -1;
goto error;
host->ch = ch;
host->addr = addr;
if (ch < 2)
else
if (ch == 0)
else
^ Quirks?
Yes, I will add quirk control.
return ret;
+error:
if (host)
free(host);
return ret;
-- 2.1.1
Regards
— Pantelis
Best regards, Nobuhiro
Nobuhiro Iwamatsu
Pantelis Antoniou
