[U-Boot] [PATCH] powerpc: Fix device tree padding associated with ramdisk
When booting with a ramdisk we bump the amount of memory reserved for the device tree by FDT_RAMDISK_OVERHEAD. However we did not increase the actual size in the device tree blob to match.
Its possible on boundary cases that we dont have enough memory according to the device tree blob and get errors like:
WARNING: could not set linux,initrd-end FDT_ERR_NOSPACE
We can easily fix this by setting the device tree size at the same time we bump the amount of memory reserved for the device tree.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/lib/bootm.c | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index e01787d..4e0cb8f 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -288,8 +288,10 @@ static int boot_body_linux(bootm_headers_t *images) return ret; of_size = ret;
- if (*initrd_start && *initrd_end) + if (*initrd_start && *initrd_end) { of_size += FDT_RAMDISK_OVERHEAD; + fdt_set_totalsize(*of_flat_tree, of_size); + } /* Create a new LMB reservation */ lmb_reserve(lmb, (ulong)*of_flat_tree, of_size);
Jerry,
Any comments on this.
- k
/* Create a new LMB reservation */ lmb_reserve(lmb, (ulong)*of_flat_tree, of_size);}
-- 1.7.3.4
Hi Kumar, Wolfgang
Signed-off-by: Kumar Galagalak@kernel.crashing.org
if (*initrd_start&& *initrd_end)
if (*initrd_start&& *initrd_end) { of_size += FDT_RAMDISK_OVERHEAD;
This looks good to me. Since it is in bootm.c and not in libfdt, I'll let Wolfgang pick it up unless I hear otherwise.
Acked-by: Gerald Van Baren vanbaren@cideas.com
Thanks, gvb
Dear Kumar Gala,
In message 1310001388-4084-1-git-send-email-galak@kernel.crashing.org you wrote:
Applied, thanks.
Jerry Van Baren
Kumar Gala
