[PATCH v3 00/12] fsl_esdhc_imx: port several patches from fsl_esdhc
This series ports some of the patches from fsl_esdhc to fsl_esdhc_imx. Because these drivers share a common lineage, many of these patches apply with minor changes. For each one, I have noted the originating commit in the style of linux stable backports. Where I have had to modify patches, I have noted the changes I have made before my SoB.
In fa33d20749 ("mmc: split fsl_esdhc driver for i.MX"), Yangbo says
For the two series processors, the eSDHCs are becoming more and more different
However, these drivers are still extremely similar; the differences between them are not major. NXP has not done a good job of porting patches which apply to both drivers. This causes the fsl_esdhc_imx driver to rot, as the fsl_esdhc gets more general fixes. For this reason, I think that the fsl_esdhc_imx driver should be removed unless NXP can commit to creating series like this which port patches which apply to both drivers.
Changes in v3: - Drop Kconfig BLK dependency - Fix build error caused by unconverted OF_PLATDATA code - Replace more #ifdefs by if
Changes in v2: - Use a switch statement instead of ifs for max_bus_width - Only default to 8 bit width when max_bus_width is not set
Sean Anderson (12): mmc: fsl_esdhc_imx: make BLK as hard requirement of DM_MMC mmc: fsl_esdhc_imx: remove redundant DM_MMC checking mmc: fsl_esdhc_imx: fix voltage validation mmc: fsl_esdhc_imx: clean up bus width configuration code mmc: fsl_esdhc_imx: drop redundant code for non-removable feature mmc: fsl_esdhc_imx: fix mmc->clock with actual clock mmc: fsl_esdhc_imx: simplify 64bit check for SDMA transfers mmc: fsl_esdhc_imx: use dma-mapping API mmc: fsl_esdhc_imx: simplify esdhc_setup_data() mmc: fsl_esdhc_imx: replace most #ifdefs by IS_ENABLED() mmc: fsl_esdhc_imx: Replace more #ifdefs by if mmc: fsl_esdhc_imx: set sysctl register for clock initialization
drivers/mmc/fsl_esdhc_imx.c | 643 ++++++++++++++---------------------- include/fsl_esdhc_imx.h | 14 +- 2 files changed, 263 insertions(+), 394 deletions(-)
[ fsl_esdhc commit 41dec2fe99512e941261594f522b2e7d485c314b ]
U-boot prefers DM_MMC + BLK for MMC. Now eSDHC driver has already support it, so let's force to use it.
- Drop non-BLK support for DM_MMC introduced by below patch. 66fa035 mmc: fsl_esdhc: fix probe issue without CONFIG_BLK enabled
- Support only DM_MMC + BLK (assuming BLK is always enabled for DM_MMC).
- Use DM_MMC instead of BLK for conditional compile.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com Signed-off-by: Sean Anderson sean.anderson@seco.com ---
drivers/mmc/fsl_esdhc_imx.c | 33 +-------------------------------- 1 file changed, 1 insertion(+), 32 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 4c06361bee..85cd72a796 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -39,10 +39,6 @@ #include <dm/ofnode.h> #include <linux/iopoll.h>
-#if !CONFIG_IS_ENABLED(BLK) -#include "mmc_private.h" -#endif - #ifndef ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE #ifdef CONFIG_FSL_USDHC #define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE 1 @@ -58,7 +54,6 @@ DECLARE_GLOBAL_DATA_PTR; IRQSTATEN_DEBE | IRQSTATEN_BRR | IRQSTATEN_BWR | \ IRQSTATEN_DINT) #define MAX_TUNING_LOOP 40 -#define ESDHC_DRIVER_STAGE_VALUE 0xffffffff
struct fsl_esdhc { uint dsaddr; /* SDMA system address register */ @@ -157,7 +152,7 @@ struct fsl_esdhc_priv { unsigned int clock; unsigned int mode; unsigned int bus_width; -#if !CONFIG_IS_ENABLED(BLK) +#if !CONFIG_IS_ENABLED(DM_MMC) struct mmc *mmc; #endif struct udevice *dev; @@ -1510,9 +1505,6 @@ static int fsl_esdhc_probe(struct udevice *dev) struct esdhc_soc_data *data = (struct esdhc_soc_data *)dev_get_driver_data(dev); struct mmc *mmc; -#if !CONFIG_IS_ENABLED(BLK) - struct blk_desc *bdesc; -#endif int ret;
#if CONFIG_IS_ENABLED(OF_PLATDATA) @@ -1611,25 +1603,6 @@ static int fsl_esdhc_probe(struct udevice *dev) mmc = &plat->mmc; mmc->cfg = &plat->cfg; mmc->dev = dev; -#if !CONFIG_IS_ENABLED(BLK) - mmc->priv = priv; - - /* Setup dsr related values */ - mmc->dsr_imp = 0; - mmc->dsr = ESDHC_DRIVER_STAGE_VALUE; - /* Setup the universal parts of the block interface just once */ - bdesc = mmc_get_blk_desc(mmc); - bdesc->if_type = IF_TYPE_MMC; - bdesc->removable = 1; - bdesc->devnum = mmc_get_next_devnum(); - bdesc->block_read = mmc_bread; - bdesc->block_write = mmc_bwrite; - bdesc->block_erase = mmc_berase; - - /* setup initial part type */ - bdesc->part_type = mmc->cfg->part_type; - mmc_list_add(mmc); -#endif
upriv->mmc = mmc;
@@ -1740,14 +1713,12 @@ static const struct udevice_id fsl_esdhc_ids[] = { { /* sentinel */ } };
-#if CONFIG_IS_ENABLED(BLK) static int fsl_esdhc_bind(struct udevice *dev) { struct fsl_esdhc_plat *plat = dev_get_plat(dev);
return mmc_bind(dev, &plat->mmc, &plat->cfg); } -#endif
U_BOOT_DRIVER(fsl_esdhc) = { .name = "fsl_esdhc", @@ -1755,9 +1726,7 @@ U_BOOT_DRIVER(fsl_esdhc) = { .of_match = fsl_esdhc_ids, .of_to_plat = fsl_esdhc_of_to_plat, .ops = &fsl_esdhc_ops, -#if CONFIG_IS_ENABLED(BLK) .bind = fsl_esdhc_bind, -#endif .probe = fsl_esdhc_probe, .plat_auto = sizeof(struct fsl_esdhc_plat), .priv_auto = sizeof(struct fsl_esdhc_priv),
[ fsl_esdhc commit 2913926f3b3dec282f8773e3c02377c9600d8267 ]
Remove redundant DM_MMC checking which is already in DM_MMC conditional compile block.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com ---
(no changes since v1)
drivers/mmc/fsl_esdhc_imx.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 85cd72a796..121f9182f6 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1609,7 +1609,6 @@ static int fsl_esdhc_probe(struct udevice *dev) return esdhc_init_common(priv, mmc); }
-#if CONFIG_IS_ENABLED(DM_MMC) static int fsl_esdhc_get_cd(struct udevice *dev) { struct fsl_esdhc_priv *priv = dev_get_priv(dev); @@ -1675,7 +1674,6 @@ static const struct dm_mmc_ops fsl_esdhc_ops = { #endif .wait_dat0 = fsl_esdhc_wait_dat0, }; -#endif
static struct esdhc_soc_data usdhc_imx7d_data = { .flags = ESDHC_FLAG_USDHC | ESDHC_FLAG_STD_TUNING
[ fsl_esdhc commit 5b05fc0310cd933acf76ee661577c6b07a95e684 ]
Voltage validation should be done by CMD8. Current comparison between mmc_cfg voltages and host voltage capabilities is meaningless. So drop current comparison and let voltage validation is through CMD8.
drivers/mmc/fsl_esdhc_imx.c | 35 +++++++++++++---------------------- include/fsl_esdhc_imx.h | 12 ++++++------ 2 files changed, 19 insertions(+), 28 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 121f9182f6..f4ccb19d9f 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1167,7 +1167,7 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, { struct mmc_config *cfg; struct fsl_esdhc *regs; - u32 caps, voltage_caps; + u32 caps; int ret;
if (!priv) @@ -1206,9 +1206,7 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, memset(cfg, '\0', sizeof(*cfg)); #endif
- voltage_caps = 0; caps = esdhc_read32(®s->hostcapblt); - #ifdef CONFIG_MCF5441x /* * MCF5441x RM declares in more points that sdhc clock speed must @@ -1219,31 +1217,24 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, #endif
#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC135 - caps = caps & ~(ESDHC_HOSTCAPBLT_SRS | - ESDHC_HOSTCAPBLT_VS18 | ESDHC_HOSTCAPBLT_VS30); + caps &= ~(HOSTCAPBLT_SRS | HOSTCAPBLT_VS18 | HOSTCAPBLT_VS30); #endif
- if (caps & ESDHC_HOSTCAPBLT_VS18) - voltage_caps |= MMC_VDD_165_195; - if (caps & ESDHC_HOSTCAPBLT_VS30) - voltage_caps |= MMC_VDD_29_30 | MMC_VDD_30_31; - if (caps & ESDHC_HOSTCAPBLT_VS33) - voltage_caps |= MMC_VDD_32_33 | MMC_VDD_33_34; +#ifdef CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 + caps |= HOSTCAPBLT_VS33; +#endif + + if (caps & HOSTCAPBLT_VS18) + cfg->voltages |= MMC_VDD_165_195; + if (caps & HOSTCAPBLT_VS30) + cfg->voltages |= MMC_VDD_29_30 | MMC_VDD_30_31; + if (caps & HOSTCAPBLT_VS33) + cfg->voltages |= MMC_VDD_32_33 | MMC_VDD_33_34;
cfg->name = "FSL_SDHC"; #if !CONFIG_IS_ENABLED(DM_MMC) cfg->ops = &esdhc_ops; #endif -#ifdef CONFIG_SYS_SD_VOLTAGE - cfg->voltages = CONFIG_SYS_SD_VOLTAGE; -#else - cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34; -#endif - if ((cfg->voltages & voltage_caps) == 0) { - printf("voltage not supported by controller\n"); - return -1; - } - if (priv->bus_width == 8) cfg->host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; else if (priv->bus_width == 4) @@ -1261,7 +1252,7 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, cfg->host_caps &= ~MMC_MODE_4BIT; }
- if (caps & ESDHC_HOSTCAPBLT_HSS) + if (caps & HOSTCAPBLT_HSS) cfg->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
#ifdef CONFIG_ESDHC_DETECT_8_BIT_QUIRK diff --git a/include/fsl_esdhc_imx.h b/include/fsl_esdhc_imx.h index 12e9163382..4ae932858e 100644 --- a/include/fsl_esdhc_imx.h +++ b/include/fsl_esdhc_imx.h @@ -164,12 +164,12 @@ #define BLKATTR_SIZE(x) (x & 0x1fff) #define MAX_BLK_CNT 0x7fff /* so malloc will have enough room with 32M */
-#define ESDHC_HOSTCAPBLT_VS18 0x04000000 -#define ESDHC_HOSTCAPBLT_VS30 0x02000000 -#define ESDHC_HOSTCAPBLT_VS33 0x01000000 -#define ESDHC_HOSTCAPBLT_SRS 0x00800000 -#define ESDHC_HOSTCAPBLT_DMAS 0x00400000 -#define ESDHC_HOSTCAPBLT_HSS 0x00200000 +#define HOSTCAPBLT_VS18 0x04000000 +#define HOSTCAPBLT_VS30 0x02000000 +#define HOSTCAPBLT_VS33 0x01000000 +#define HOSTCAPBLT_SRS 0x00800000 +#define HOSTCAPBLT_DMAS 0x00400000 +#define HOSTCAPBLT_HSS 0x00200000
#define ESDHC_VENDORSPEC_VSELECT 0x00000002 /* Use 1.8V */
[ fsl_esdhc commit 07bae1de382723b94244096953b05225572728cd ]
This patch is to clean up bus width setting code.
- For DM_MMC, remove getting "bus-width" from device tree. This has been done in mmc_of_parse().
- For non-DM_MMC, move bus width configuration from fsl_esdhc_init() to fsl_esdhc_initialize() which is non-DM_MMC specific. And fix up bus width configuration to support only 1-bit, 4-bit, or 8-bit. Keep using 8-bit if it's not set because many platforms use driver without providing max bus width.
- Remove bus_width member from fsl_esdhc_priv structure.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com [ converted if statement to switch ] Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com ---
(no changes since v2)
drivers/mmc/fsl_esdhc_imx.c | 83 ++++++++++++------------------------- 1 file changed, 26 insertions(+), 57 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index f4ccb19d9f..98b3db737b 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -126,7 +126,6 @@ struct esdhc_soc_data { * * @esdhc_regs: registers of the sdhc controller * @sdhc_clk: Current clk of the sdhc controller - * @bus_width: bus width, 1bit, 4bit or 8bit * @cfg: mmc config * @mmc: mmc * Following is used when Driver Model is enabled for MMC @@ -151,7 +150,6 @@ struct fsl_esdhc_priv { struct clk per_clk; unsigned int clock; unsigned int mode; - unsigned int bus_width; #if !CONFIG_IS_ENABLED(DM_MMC) struct mmc *mmc; #endif @@ -1235,31 +1233,13 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, #if !CONFIG_IS_ENABLED(DM_MMC) cfg->ops = &esdhc_ops; #endif - if (priv->bus_width == 8) - cfg->host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; - else if (priv->bus_width == 4) - cfg->host_caps = MMC_MODE_4BIT; - - cfg->host_caps = MMC_MODE_4BIT | MMC_MODE_8BIT; #ifdef CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE cfg->host_caps |= MMC_MODE_DDR_52MHz; #endif
- if (priv->bus_width > 0) { - if (priv->bus_width < 8) - cfg->host_caps &= ~MMC_MODE_8BIT; - if (priv->bus_width < 4) - cfg->host_caps &= ~MMC_MODE_4BIT; - } - if (caps & HOSTCAPBLT_HSS) cfg->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS;
-#ifdef CONFIG_ESDHC_DETECT_8_BIT_QUIRK - if (CONFIG_ESDHC_DETECT_8_BIT_QUIRK) - cfg->host_caps &= ~MMC_MODE_8BIT; -#endif - cfg->host_caps |= priv->caps;
cfg->f_min = 400000; @@ -1297,25 +1277,11 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, }
#if !CONFIG_IS_ENABLED(DM_MMC) -static int fsl_esdhc_cfg_to_priv(struct fsl_esdhc_cfg *cfg, - struct fsl_esdhc_priv *priv) -{ - if (!cfg || !priv) - return -EINVAL; - - priv->esdhc_regs = (struct fsl_esdhc *)(unsigned long)(cfg->esdhc_base); - priv->bus_width = cfg->max_bus_width; - priv->sdhc_clk = cfg->sdhc_clk; - priv->wp_enable = cfg->wp_enable; - priv->vs18_enable = cfg->vs18_enable; - - return 0; -}; - int fsl_esdhc_initialize(struct bd_info *bis, struct fsl_esdhc_cfg *cfg) { struct fsl_esdhc_plat *plat; struct fsl_esdhc_priv *priv; + struct mmc_config *mmc_cfg; struct mmc *mmc; int ret;
@@ -1331,14 +1297,33 @@ int fsl_esdhc_initialize(struct bd_info *bis, struct fsl_esdhc_cfg *cfg) return -ENOMEM; }
- ret = fsl_esdhc_cfg_to_priv(cfg, priv); - if (ret) { - debug("%s xlate failure\n", __func__); - free(plat); - free(priv); - return ret; + priv->esdhc_regs = (struct fsl_esdhc *)(unsigned long)(cfg->esdhc_base); + priv->sdhc_clk = cfg->sdhc_clk; + priv->wp_enable = cfg->wp_enable; + + mmc_cfg = &plat->cfg; + + switch (cfg->max_bus_width) { + case 0: /* Not set in config; assume everything is supported */ + case 8: + mmc_cfg->host_caps |= MMC_MODE_8BIT; + fallthrough; + case 4: + mmc_cfg->host_caps |= MMC_MODE_4BIT; + fallthrough; + case 1: + mmc_cfg->host_caps |= MMC_MODE_1BIT; + break; + default: + printf("invalid max bus width %u\n", cfg->max_bus_width); + return -EINVAL; }
+#ifdef CONFIG_ESDHC_DETECT_8_BIT_QUIRK + if (CONFIG_ESDHC_DETECT_8_BIT_QUIRK) + mmc_cfg->host_caps &= ~MMC_MODE_8BIT; +#endif + ret = fsl_esdhc_init(priv, plat); if (ret) { debug("%s init failure\n", __func__); @@ -1420,14 +1405,6 @@ static int fsl_esdhc_of_to_plat(struct udevice *dev) priv->dev = dev; priv->mode = -1;
- val = dev_read_u32_default(dev, "bus-width", -1); - if (val == 8) - priv->bus_width = 8; - else if (val == 4) - priv->bus_width = 4; - else - priv->bus_width = 1; - val = fdtdec_get_int(fdt, node, "fsl,tuning-step", 1); priv->tuning_step = val; val = fdtdec_get_int(fdt, node, "fsl,tuning-start-tap", @@ -1500,16 +1477,8 @@ static int fsl_esdhc_probe(struct udevice *dev)
#if CONFIG_IS_ENABLED(OF_PLATDATA) struct dtd_fsl_esdhc *dtplat = &plat->dtplat; - unsigned int val;
priv->esdhc_regs = map_sysmem(dtplat->reg[0], dtplat->reg[1]); - val = plat->dtplat.bus_width; - if (val == 8) - priv->bus_width = 8; - else if (val == 4) - priv->bus_width = 4; - else - priv->bus_width = 1;
if (dtplat->non_removable) priv->non_removable = 1;
[ fsl_esdhc commit commit 08197cb8dff7cd097ab07a325093043c39d19bbd ]
Drop redundant code for non-removable feature. "non-removable" property has been read in mmc_of_parse().
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com [ set MMC_CAP_NONREMOVABLE in plat->cfg.host_caps ] Signed-off-by: Sean Anderson sean.anderson@seco.com ---
Changes in v3: - Fix build error caused by unconverted OF_PLATDATA code
drivers/mmc/fsl_esdhc_imx.c | 34 +++++++++++++--------------------- 1 file changed, 13 insertions(+), 21 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 98b3db737b..4d2d757723 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -130,7 +130,6 @@ struct esdhc_soc_data { * @mmc: mmc * Following is used when Driver Model is enabled for MMC * @dev: pointer for the device - * @non_removable: 0: removable; 1: non-removable * @broken_cd: 0: use GPIO for card detect; 1: Do not use GPIO for card detect * @wp_enable: 1: enable checking wp; 0: no check * @vs18_enable: 1: use 1.8V voltage; 0: use 3.3V @@ -154,7 +153,6 @@ struct fsl_esdhc_priv { struct mmc *mmc; #endif struct udevice *dev; - int non_removable; int broken_cd; int wp_enable; int vs18_enable; @@ -1086,9 +1084,6 @@ static int esdhc_getcd_common(struct fsl_esdhc_priv *priv) #endif
#if CONFIG_IS_ENABLED(DM_MMC) - if (priv->non_removable) - return 1; - if (priv->broken_cd) return 1; #if CONFIG_IS_ENABLED(DM_GPIO) @@ -1419,25 +1414,18 @@ static int fsl_esdhc_of_to_plat(struct udevice *dev) if (dev_read_bool(dev, "broken-cd")) priv->broken_cd = 1;
- if (dev_read_bool(dev, "non-removable")) { - priv->non_removable = 1; - } else { - priv->non_removable = 0; -#if CONFIG_IS_ENABLED(DM_GPIO) - gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, - GPIOD_IS_IN); -#endif - } - if (dev_read_prop(dev, "fsl,wp-controller", NULL)) { priv->wp_enable = 1; } else { priv->wp_enable = 0; + } + #if CONFIG_IS_ENABLED(DM_GPIO) - gpio_request_by_name(dev, "wp-gpios", 0, &priv->wp_gpio, - GPIOD_IS_IN); + gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, + GPIOD_IS_IN); + gpio_request_by_name(dev, "wp-gpios", 0, &priv->wp_gpio, + GPIOD_IS_IN); #endif - }
priv->vs18_enable = 0;
@@ -1481,11 +1469,11 @@ static int fsl_esdhc_probe(struct udevice *dev) priv->esdhc_regs = map_sysmem(dtplat->reg[0], dtplat->reg[1]);
if (dtplat->non_removable) - priv->non_removable = 1; + plat->cfg.host_caps |= MMC_CAP_NONREMOVABLE; else - priv->non_removable = 0; + plat->cfg.host_caps &= ~MMC_CAP_NONREMOVABLE;
- if (CONFIG_IS_ENABLED(DM_GPIO) && !priv->non_removable) { + if (CONFIG_IS_ENABLED(DM_GPIO) && !dtplat->non_removable) { struct udevice *gpiodev;
ret = device_get_by_ofplat_idx(dtplat->cd_gpios->idx, &gpiodev); @@ -1571,8 +1559,12 @@ static int fsl_esdhc_probe(struct udevice *dev)
static int fsl_esdhc_get_cd(struct udevice *dev) { + struct fsl_esdhc_plat *plat = dev_get_plat(dev); struct fsl_esdhc_priv *priv = dev_get_priv(dev);
+ if (plat->cfg.host_caps & MMC_CAP_NONREMOVABLE) + return 1; + return esdhc_getcd_common(priv); }
[ fsl_esdhc commit 30f6444d024a74ee48aa6969c1531aecd3c59deb ]
Fix mmc->clock with actual clock which is divided by the controller, and record it with priv->clock.
drivers/mmc/fsl_esdhc_imx.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 4d2d757723..72f3eec205 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -665,6 +665,7 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); #endif
+ mmc->clock = sdhc_clk / pre_div / div; priv->clock = clock; }
[ fsl_esdhc commit da86e8cfcb03ed5c1d8e0718bc8bc8583e60ced8 ]
SDMA can only do DMA with 32 bit addresses. This is true for all architectures (just doesn't apply to 32 bit ones). Simplify the code and remove unnecessary CONFIG_FSL_LAYERSCAPE.
Also make the error message more concise.
Signed-off-by: Michael Walle michael@walle.cc Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com ---
drivers/mmc/fsl_esdhc_imx.c | 33 ++++++--------------------------- 1 file changed, 6 insertions(+), 27 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 72f3eec205..84df131c9f 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -282,10 +282,7 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, { int timeout; struct fsl_esdhc *regs = priv->esdhc_regs; -#if defined(CONFIG_S32V234) || defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) || \ - defined(CONFIG_IMX8ULP) dma_addr_t addr; -#endif uint wml_value;
wml_value = data->blocksize/4; @@ -296,16 +293,10 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc,
esdhc_clrsetbits32(®s->wml, WML_RD_WML_MASK, wml_value); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO -#if defined(CONFIG_S32V234) || defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) || \ - defined(CONFIG_IMX8ULP) addr = virt_to_phys((void *)(data->dest)); if (upper_32_bits(addr)) - printf("Error found for upper 32 bits\n"); - else - esdhc_write32(®s->dsaddr, lower_32_bits(addr)); -#else - esdhc_write32(®s->dsaddr, (u32)data->dest); -#endif + printf("Cannot use 64 bit addresses with SDMA\n"); + esdhc_write32(®s->dsaddr, lower_32_bits(addr)); #endif } else { #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO @@ -334,16 +325,10 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, esdhc_clrsetbits32(®s->wml, WML_WR_WML_MASK, wml_value << 16); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO -#if defined(CONFIG_S32V234) || defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) || \ - defined(CONFIG_IMX8ULP) addr = virt_to_phys((void *)(data->src)); if (upper_32_bits(addr)) - printf("Error found for upper 32 bits\n"); - else - esdhc_write32(®s->dsaddr, lower_32_bits(addr)); -#else - esdhc_write32(®s->dsaddr, (u32)data->src); -#endif + printf("Cannot use 64 bit addresses with SDMA\n"); + esdhc_write32(®s->dsaddr, lower_32_bits(addr)); #endif }
@@ -400,18 +385,12 @@ static void check_and_invalidate_dcache_range unsigned end = 0; unsigned size = roundup(ARCH_DMA_MINALIGN, data->blocks*data->blocksize); -#if defined(CONFIG_S32V234) || defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) || \ - defined(CONFIG_IMX8ULP) dma_addr_t addr;
addr = virt_to_phys((void *)(data->dest)); if (upper_32_bits(addr)) - printf("Error found for upper 32 bits\n"); - else - start = lower_32_bits(addr); -#else - start = (unsigned)data->dest; -#endif + printf("Cannot use 64 bit addresses with SDMA\n"); + start = lower_32_bits(addr); end = start + size; invalidate_dcache_range(start, end); }
[ fsl_esdhc commit b1ba1460a445bcc67972a617625d0349e4f22b31 ]
Use the dma_{map,unmap}_single() calls. These will take care of the flushing and invalidation of caches.
drivers/mmc/fsl_esdhc_imx.c | 50 +++++++++++-------------------------- 1 file changed, 15 insertions(+), 35 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 84df131c9f..283af35a81 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -38,6 +38,7 @@ #include <mapmem.h> #include <dm/ofnode.h> #include <linux/iopoll.h> +#include <linux/dma-mapping.h>
#ifndef ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE #ifdef CONFIG_FSL_USDHC @@ -171,6 +172,7 @@ struct fsl_esdhc_priv { struct gpio_desc cd_gpio; struct gpio_desc wp_gpio; #endif + dma_addr_t dma_addr; };
/* Return the XFERTYP flags for a given command and data packet */ @@ -281,8 +283,8 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, struct mmc_data *data) { int timeout; + uint trans_bytes = data->blocksize * data->blocks; struct fsl_esdhc *regs = priv->esdhc_regs; - dma_addr_t addr; uint wml_value;
wml_value = data->blocksize/4; @@ -293,17 +295,13 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc,
esdhc_clrsetbits32(®s->wml, WML_RD_WML_MASK, wml_value); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO - addr = virt_to_phys((void *)(data->dest)); - if (upper_32_bits(addr)) + priv->dma_addr = dma_map_single(data->dest, trans_bytes, + mmc_get_dma_dir(data)); + if (upper_32_bits(priv->dma_addr)) printf("Cannot use 64 bit addresses with SDMA\n"); - esdhc_write32(®s->dsaddr, lower_32_bits(addr)); + esdhc_write32(®s->dsaddr, lower_32_bits(priv->dma_addr)); #endif } else { -#ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO - flush_dcache_range((ulong)data->src, - (ulong)data->src+data->blocks - *data->blocksize); -#endif if (wml_value > WML_WR_WML_MAX) wml_value = WML_WR_WML_MAX_VAL; if (priv->wp_enable) { @@ -325,10 +323,11 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, esdhc_clrsetbits32(®s->wml, WML_WR_WML_MASK, wml_value << 16); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO - addr = virt_to_phys((void *)(data->src)); - if (upper_32_bits(addr)) + priv->dma_addr = dma_map_single((void *)data->src, trans_bytes, + mmc_get_dma_dir(data)); + if (upper_32_bits(priv->dma_addr)) printf("Cannot use 64 bit addresses with SDMA\n"); - esdhc_write32(®s->dsaddr, lower_32_bits(addr)); + esdhc_write32(®s->dsaddr, lower_32_bits(priv->dma_addr)); #endif }
@@ -378,23 +377,6 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, return 0; }
-static void check_and_invalidate_dcache_range - (struct mmc_cmd *cmd, - struct mmc_data *data) { - unsigned start = 0; - unsigned end = 0; - unsigned size = roundup(ARCH_DMA_MINALIGN, - data->blocks*data->blocksize); - dma_addr_t addr; - - addr = virt_to_phys((void *)(data->dest)); - if (upper_32_bits(addr)) - printf("Cannot use 64 bit addresses with SDMA\n"); - start = lower_32_bits(addr); - end = start + size; - invalidate_dcache_range(start, end); -} - #ifdef CONFIG_MCF5441x /* * Swaps 32-bit words to little-endian byte order. @@ -450,9 +432,6 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, err = esdhc_setup_data(priv, mmc, data); if(err) return err; - - if (data->flags & MMC_DATA_READ) - check_and_invalidate_dcache_range(cmd, data); }
/* Figure out the transfer arguments */ @@ -560,12 +539,13 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, * cache-fill during the DMA operations such as the * speculative pre-fetching etc. */ - if (data->flags & MMC_DATA_READ) { - check_and_invalidate_dcache_range(cmd, data); + dma_unmap_single(priv->dma_addr, + data->blocks * data->blocksize, + mmc_get_dma_dir(data)); #ifdef CONFIG_MCF5441x + if (data->flags & MMC_DATA_READ) sd_swap_dma_buff(data); #endif - } #endif }
[ fsl_esdhc commit 7e48a028a42c111ba38a90b86e5f57dace980fa0 ]
First, we need the waterlevel setting for PIO mode only. Secondy, both DMA setup code is identical for both directions, except for the data pointer. Thus, unify them.
drivers/mmc/fsl_esdhc_imx.c | 89 ++++++++++++++++++++++--------------- 1 file changed, 52 insertions(+), 37 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 283af35a81..6c25a77c79 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -279,59 +279,74 @@ static void esdhc_pio_read_write(struct fsl_esdhc_priv *priv, } #endif
-static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, - struct mmc_data *data) +#ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO +static void esdhc_setup_watermark_level(struct fsl_esdhc_priv *priv, + struct mmc_data *data) { - int timeout; - uint trans_bytes = data->blocksize * data->blocks; struct fsl_esdhc *regs = priv->esdhc_regs; - uint wml_value; - - wml_value = data->blocksize/4; + uint wml_value = data->blocksize / 4;
if (data->flags & MMC_DATA_READ) { if (wml_value > WML_RD_WML_MAX) wml_value = WML_RD_WML_MAX_VAL;
esdhc_clrsetbits32(®s->wml, WML_RD_WML_MASK, wml_value); -#ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO - priv->dma_addr = dma_map_single(data->dest, trans_bytes, - mmc_get_dma_dir(data)); - if (upper_32_bits(priv->dma_addr)) - printf("Cannot use 64 bit addresses with SDMA\n"); - esdhc_write32(®s->dsaddr, lower_32_bits(priv->dma_addr)); -#endif } else { if (wml_value > WML_WR_WML_MAX) wml_value = WML_WR_WML_MAX_VAL; - if (priv->wp_enable) { - if ((esdhc_read32(®s->prsstat) & - PRSSTAT_WPSPL) == 0) { - printf("\nThe SD card is locked. Can not write to a locked card.\n\n"); - return -ETIMEDOUT; - } - } else { -#if CONFIG_IS_ENABLED(DM_GPIO) - if (dm_gpio_is_valid(&priv->wp_gpio) && - dm_gpio_get_value(&priv->wp_gpio)) { - printf("\nThe SD card is locked. Can not write to a locked card.\n\n"); - return -ETIMEDOUT; - } -#endif - }
esdhc_clrsetbits32(®s->wml, WML_WR_WML_MASK, - wml_value << 16); -#ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO - priv->dma_addr = dma_map_single((void *)data->src, trans_bytes, - mmc_get_dma_dir(data)); - if (upper_32_bits(priv->dma_addr)) - printf("Cannot use 64 bit addresses with SDMA\n"); - esdhc_write32(®s->dsaddr, lower_32_bits(priv->dma_addr)); -#endif + wml_value << 16); } +} +#endif
+static void esdhc_setup_dma(struct fsl_esdhc_priv *priv, struct mmc_data *data) +{ + uint trans_bytes = data->blocksize * data->blocks; + struct fsl_esdhc *regs = priv->esdhc_regs; + void *buf; + + if (data->flags & MMC_DATA_WRITE) + buf = (void *)data->src; + else + buf = data->dest; + + priv->dma_addr = dma_map_single(buf, trans_bytes, + mmc_get_dma_dir(data)); + if (upper_32_bits(priv->dma_addr)) + printf("Cannot use 64 bit addresses with SDMA\n"); + esdhc_write32(®s->dsaddr, lower_32_bits(priv->dma_addr)); esdhc_write32(®s->blkattr, data->blocks << 16 | data->blocksize); +} + +static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, + struct mmc_data *data) +{ + int timeout; + bool is_write = data->flags & MMC_DATA_WRITE; + struct fsl_esdhc *regs = priv->esdhc_regs; + + if (is_write) { + if (priv->wp_enable && !(esdhc_read32(®s->prsstat) & PRSSTAT_WPSPL)) { + printf("Cannot write to locked SD card.\n"); + return -EINVAL; + } else { +#if CONFIG_IS_ENABLED(DM_GPIO) + if (dm_gpio_is_valid(&priv->wp_gpio) && + dm_gpio_get_value(&priv->wp_gpio)) { + printf("Cannot write to locked SD card.\n"); + return -EINVAL; + } +#endif + } + } + +#ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO + esdhc_setup_watermark_level(priv, data); +#else + esdhc_setup_dma(priv, data); +#endif
/* Calculate the timeout period for data transactions */ /*
[ fsl_esdhc commit 52faec31827ec1a1837977e29c067424426634c5 ]
Make the code cleaner and drop the old-style #ifdef constructs where it is possible.
Signed-off-by: Michael Walle michael@walle.cc Signed-off-by: Sean Anderson sean.anderson@seco.com ---
drivers/mmc/fsl_esdhc_imx.c | 209 +++++++++++++++++------------------- include/fsl_esdhc_imx.h | 2 - 2 files changed, 100 insertions(+), 111 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 6c25a77c79..2da70663cb 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -182,15 +182,15 @@ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data)
if (data) { xfertyp |= XFERTYP_DPSEL; -#ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO - xfertyp |= XFERTYP_DMAEN; -#endif + if (!IS_ENABLED(CONFIG_SYS_FSL_ESDHC_USE_PIO) && + cmd->cmdidx != MMC_CMD_SEND_TUNING_BLOCK && + cmd->cmdidx != MMC_CMD_SEND_TUNING_BLOCK_HS200) + xfertyp |= XFERTYP_DMAEN; if (data->blocks > 1) { xfertyp |= XFERTYP_MSBSEL; xfertyp |= XFERTYP_BCEN; -#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC111 - xfertyp |= XFERTYP_AC12EN; -#endif + if (IS_ENABLED(CONFIG_SYS_FSL_ERRATUM_ESDHC111)) + xfertyp |= XFERTYP_AC12EN; }
if (data->flags & MMC_DATA_READ) @@ -214,7 +214,6 @@ static uint esdhc_xfertyp(struct mmc_cmd *cmd, struct mmc_data *data) return XFERTYP_CMD(cmd->cmdidx) | xfertyp; }
-#ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO /* * PIO Read/Write Mode reduce the performace as DMA is not used in this mode. */ @@ -277,9 +276,7 @@ static void esdhc_pio_read_write(struct fsl_esdhc_priv *priv, } } } -#endif
-#ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO static void esdhc_setup_watermark_level(struct fsl_esdhc_priv *priv, struct mmc_data *data) { @@ -299,7 +296,6 @@ static void esdhc_setup_watermark_level(struct fsl_esdhc_priv *priv, wml_value << 16); } } -#endif
static void esdhc_setup_dma(struct fsl_esdhc_priv *priv, struct mmc_data *data) { @@ -342,11 +338,10 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, } }
-#ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO - esdhc_setup_watermark_level(priv, data); -#else - esdhc_setup_dma(priv, data); -#endif + if (IS_ENABLED(CONFIG_SYS_FSL_ESDHC_USE_PIO)) + esdhc_setup_watermark_level(priv, data); + else + esdhc_setup_dma(priv, data);
/* Calculate the timeout period for data transactions */ /* @@ -379,14 +374,13 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, if (timeout < 0) timeout = 0;
-#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC_A001 - if ((timeout == 4) || (timeout == 8) || (timeout == 12)) + if (IS_ENABLED(CONFIG_SYS_FSL_ERRATUM_ESDHC_A001) && + (timeout == 4 || timeout == 8 || timeout == 12)) timeout++; -#endif
-#ifdef ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE - timeout = 0xE; -#endif + if (IS_ENABLED(ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE)) + timeout = 0xE; + esdhc_clrsetbits32(®s->sysctl, SYSCTL_TIMEOUT_MASK, timeout << 16);
return 0; @@ -409,6 +403,11 @@ static inline void sd_swap_dma_buff(struct mmc_data *data) } } } +#else +static inline void sd_swap_dma_buff(struct mmc_data *data) +{ + return; +} #endif
/* @@ -425,10 +424,9 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, struct fsl_esdhc *regs = priv->esdhc_regs; unsigned long start;
-#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC111 - if (cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) + if (IS_ENABLED(CONFIG_SYS_FSL_ERRATUM_ESDHC111) && + cmd->cmdidx == MMC_CMD_STOP_TRANSMISSION) return 0; -#endif
esdhc_write32(®s->irqstat, -1);
@@ -526,42 +524,40 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc,
/* Wait until all of the blocks are transferred */ if (data) { -#ifdef CONFIG_SYS_FSL_ESDHC_USE_PIO - esdhc_pio_read_write(priv, data); -#else - flags = DATA_COMPLETE; - if ((cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) || - (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200)) { - flags = IRQSTAT_BRR; + if (IS_ENABLED(CONFIG_SYS_FSL_ESDHC_USE_PIO)) { + esdhc_pio_read_write(priv, data); + } else { + flags = DATA_COMPLETE; + if (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK || + cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200) + flags = IRQSTAT_BRR; + + do { + irqstat = esdhc_read32(®s->irqstat); + + if (irqstat & IRQSTAT_DTOE) { + err = -ETIMEDOUT; + goto out; + } + + if (irqstat & DATA_ERR) { + err = -ECOMM; + goto out; + } + } while ((irqstat & flags) != flags); + + /* + * Need invalidate the dcache here again to avoid any + * cache-fill during the DMA operations such as the + * speculative pre-fetching etc. + */ + dma_unmap_single(priv->dma_addr, + data->blocks * data->blocksize, + mmc_get_dma_dir(data)); + if (IS_ENABLED(CONFIG_MCF5441x) && + (data->flags & MMC_DATA_READ)) + sd_swap_dma_buff(data); } - - do { - irqstat = esdhc_read32(®s->irqstat); - - if (irqstat & IRQSTAT_DTOE) { - err = -ETIMEDOUT; - goto out; - } - - if (irqstat & DATA_ERR) { - err = -ECOMM; - goto out; - } - } while ((irqstat & flags) != flags); - - /* - * Need invalidate the dcache here again to avoid any - * cache-fill during the DMA operations such as the - * speculative pre-fetching etc. - */ - dma_unmap_single(priv->dma_addr, - data->blocks * data->blocksize, - mmc_get_dma_dir(data)); -#ifdef CONFIG_MCF5441x - if (data->flags & MMC_DATA_READ) - sd_swap_dma_buff(data); -#endif -#endif }
out: @@ -595,21 +591,22 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) struct fsl_esdhc *regs = priv->esdhc_regs; int div = 1; u32 tmp; - int ret; -#ifdef ARCH_MXC -#ifdef CONFIG_MX53 - /* For i.MX53 eSDHCv3, SYSCTL.SDCLKFS may not be set to 0. */ - int pre_div = (regs == (struct fsl_esdhc *)MMC_SDHC3_BASE_ADDR) ? 2 : 1; -#else - int pre_div = 1; -#endif -#else - int pre_div = 2; -#endif + int ret, pre_div; int ddr_pre_div = mmc->ddr_mode ? 2 : 1; int sdhc_clk = priv->sdhc_clk; uint clk;
+ if (IS_ENABLED(ARCH_MXC)) { +#ifdef CONFIG_MX53 + /* For i.MX53 eSDHCv3, SYSCTL.SDCLKFS may not be set to 0. */ + pre_div = (regs == (struct fsl_esdhc *)MMC_SDHC3_BASE_ADDR) ? 2 : 1; +#else + pre_div = 1; +#endif + } else { + pre_div = 2; + } + while (sdhc_clk / (16 * pre_div * ddr_pre_div) > clock && pre_div < 256) pre_div *= 2;
@@ -621,11 +618,10 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock)
clk = (pre_div << 8) | (div << 4);
-#ifdef CONFIG_FSL_USDHC - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); -#else - esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); -#endif + if (IS_ENABLED(CONFIG_FSL_USDHC)) + esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); + else + esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN);
esdhc_clrsetbits32(®s->sysctl, SYSCTL_CLOCK_MASK, clk);
@@ -633,11 +629,10 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) if (ret) pr_warn("fsl_esdhc_imx: Internal clock never stabilised.\n");
-#ifdef CONFIG_FSL_USDHC - esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | VENDORSPEC_CKEN); -#else - esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); -#endif + if (IS_ENABLED(CONFIG_FSL_USDHC)) + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | VENDORSPEC_CKEN); + else + esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN);
mmc->clock = sdhc_clk / pre_div / div; priv->clock = clock; @@ -1148,22 +1143,21 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, if (ret) return ret;
-#ifdef CONFIG_MCF5441x /* ColdFire, using SDHC_DATA[3] for card detection */ - esdhc_write32(®s->proctl, PROCTL_INIT | PROCTL_D3CD); -#endif + if (IS_ENABLED(CONFIG_MCF5441x)) + esdhc_write32(®s->proctl, PROCTL_INIT | PROCTL_D3CD);
-#ifndef CONFIG_FSL_USDHC - esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_HCKEN - | SYSCTL_IPGEN | SYSCTL_CKEN); - /* Clearing tuning bits in case ROM has set it already */ - esdhc_write32(®s->mixctrl, 0); - esdhc_write32(®s->autoc12err, 0); - esdhc_write32(®s->clktunectrlstatus, 0); -#else - esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | - VENDORSPEC_HCKEN | VENDORSPEC_IPGEN | VENDORSPEC_CKEN); -#endif + if (IS_ENABLED(CONFIG_FSL_USDHC)) { + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | + VENDORSPEC_HCKEN | VENDORSPEC_IPGEN | VENDORSPEC_CKEN); + } else { + esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_HCKEN + | SYSCTL_IPGEN | SYSCTL_CKEN); + /* Clearing tuning bits in case ROM has set it already */ + esdhc_write32(®s->mixctrl, 0); + esdhc_write32(®s->autoc12err, 0); + esdhc_write32(®s->clktunectrlstatus, 0); + }
if (priv->vs18_enable) esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); @@ -1175,22 +1169,20 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, #endif
caps = esdhc_read32(®s->hostcapblt); -#ifdef CONFIG_MCF5441x + /* * MCF5441x RM declares in more points that sdhc clock speed must * never exceed 25 Mhz. From this, the HS bit needs to be disabled * from host capabilities. */ - caps &= ~ESDHC_HOSTCAPBLT_HSS; -#endif + if (IS_ENABLED(CONFIG_MCF5441x)) + caps &= ~HOSTCAPBLT_HSS;
-#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC135 - caps &= ~(HOSTCAPBLT_SRS | HOSTCAPBLT_VS18 | HOSTCAPBLT_VS30); -#endif + if (IS_ENABLED(CONFIG_SYS_FSL_ERRATUM_ESDHC135)) + caps &= ~(HOSTCAPBLT_SRS | HOSTCAPBLT_VS18 | HOSTCAPBLT_VS30);
-#ifdef CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 - caps |= HOSTCAPBLT_VS33; -#endif + if (IS_ENABLED(CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33)) + caps |= HOSTCAPBLT_VS33;
if (caps & HOSTCAPBLT_VS18) cfg->voltages |= MMC_VDD_165_195; @@ -1200,12 +1192,13 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, cfg->voltages |= MMC_VDD_32_33 | MMC_VDD_33_34;
cfg->name = "FSL_SDHC"; + #if !CONFIG_IS_ENABLED(DM_MMC) cfg->ops = &esdhc_ops; #endif -#ifdef CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE - cfg->host_caps |= MMC_MODE_DDR_52MHz; -#endif + + if (IS_ENABLED(CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE)) + cfg->host_caps |= MMC_MODE_DDR_52MHz;
if (caps & HOSTCAPBLT_HSS) cfg->host_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; @@ -1289,10 +1282,8 @@ int fsl_esdhc_initialize(struct bd_info *bis, struct fsl_esdhc_cfg *cfg) return -EINVAL; }
-#ifdef CONFIG_ESDHC_DETECT_8_BIT_QUIRK - if (CONFIG_ESDHC_DETECT_8_BIT_QUIRK) + if (IS_ENABLED(CONFIG_ESDHC_DETECT_8_BIT_QUIRK)) mmc_cfg->host_caps &= ~MMC_MODE_8BIT; -#endif
ret = fsl_esdhc_init(priv, plat); if (ret) { diff --git a/include/fsl_esdhc_imx.h b/include/fsl_esdhc_imx.h index 4ae932858e..2153f29bef 100644 --- a/include/fsl_esdhc_imx.h +++ b/include/fsl_esdhc_imx.h @@ -24,12 +24,10 @@ #define SYSCTL_INITA 0x08000000 #define SYSCTL_TIMEOUT_MASK 0x000f0000 #define SYSCTL_CLOCK_MASK 0x0000fff0 -#if !defined(CONFIG_FSL_USDHC) #define SYSCTL_CKEN 0x00000008 #define SYSCTL_PEREN 0x00000004 #define SYSCTL_HCKEN 0x00000002 #define SYSCTL_IPGEN 0x00000001 -#endif #define SYSCTL_RSTA 0x01000000 #define SYSCTL_RSTC 0x02000000 #define SYSCTL_RSTD 0x04000000
This builds on the previous patch by converting yet more preprocessor macros to C ifs. This is split off so that the changes adapted from Micheal's patch may be clearly distinguished from the ones I have authored myself.
MMC_SUPPORTS_TUNING should really get a Kconfig conversion. And DM_GPIO needs some -ENOSYS stubs when it isn't defined.
Changes in v3: - New
drivers/mmc/fsl_esdhc_imx.c | 152 ++++++++++++++++-------------------- 1 file changed, 69 insertions(+), 83 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 2da70663cb..25e912ba95 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -164,10 +164,8 @@ struct fsl_esdhc_priv { u32 strobe_dll_delay_target; u32 signal_voltage; u32 signal_voltage_switch_extra_delay_ms; -#if CONFIG_IS_ENABLED(DM_REGULATOR) struct udevice *vqmmc_dev; struct udevice *vmmc_dev; -#endif #if CONFIG_IS_ENABLED(DM_GPIO) struct gpio_desc cd_gpio; struct gpio_desc wp_gpio; @@ -386,7 +384,7 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, return 0; }
-#ifdef CONFIG_MCF5441x +#if IS_ENABLED(CONFIG_MCF5441x) /* * Swaps 32-bit words to little-endian byte order. */ @@ -455,14 +453,16 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc,
/* Send the command */ esdhc_write32(®s->cmdarg, cmd->cmdarg); -#if defined(CONFIG_FSL_USDHC) - esdhc_write32(®s->mixctrl, - (esdhc_read32(®s->mixctrl) & 0xFFFFFF80) | (xfertyp & 0x7F) - | (mmc->ddr_mode ? XFERTYP_DDREN : 0)); - esdhc_write32(®s->xfertyp, xfertyp & 0xFFFF0000); -#else - esdhc_write32(®s->xfertyp, xfertyp); -#endif + if IS_ENABLED(CONFIG_FSL_USDHC) { + u32 mixctrl = esdhc_read32(®s->mixctrl); + + esdhc_write32(®s->mixctrl, + (mixctrl & 0xFFFFFF80) | (xfertyp & 0x7F) + | (mmc->ddr_mode ? XFERTYP_DDREN : 0)); + esdhc_write32(®s->xfertyp, xfertyp & 0xFFFF0000); + } else { + esdhc_write32(®s->xfertyp, xfertyp); + }
if ((cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) || (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200)) @@ -597,7 +597,7 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) uint clk;
if (IS_ENABLED(ARCH_MXC)) { -#ifdef CONFIG_MX53 +#if IS_ENABLED(CONFIG_MX53) /* For i.MX53 eSDHCv3, SYSCTL.SDCLKFS may not be set to 0. */ pre_div = (regs == (struct fsl_esdhc *)MMC_SDHC3_BASE_ADDR) ? 2 : 1; #else @@ -758,26 +758,23 @@ static int esdhc_set_voltage(struct mmc *mmc) { struct fsl_esdhc_priv *priv = dev_get_priv(mmc->dev); struct fsl_esdhc *regs = priv->esdhc_regs; -#if CONFIG_IS_ENABLED(DM_REGULATOR) int ret; -#endif
priv->signal_voltage = mmc->signal_voltage; switch (mmc->signal_voltage) { case MMC_SIGNAL_VOLTAGE_330: if (priv->vs18_enable) return -ENOTSUPP; -#if CONFIG_IS_ENABLED(DM_REGULATOR) - if (!IS_ERR_OR_NULL(priv->vqmmc_dev)) { - ret = regulator_set_value(priv->vqmmc_dev, 3300000); + if (CONFIG_IS_ENABLED(DM_REGULATOR) && + !IS_ERR_OR_NULL(priv->vqmmc_dev)) { + ret = regulator_set_value(priv->vqmmc_dev, + 3300000); if (ret) { printf("Setting to 3.3V error"); return -EIO; } - /* Wait for 5ms */ mdelay(5); } -#endif
esdhc_clrbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); if (!(esdhc_read32(®s->vendorspec) & @@ -786,15 +783,15 @@ static int esdhc_set_voltage(struct mmc *mmc)
return -EAGAIN; case MMC_SIGNAL_VOLTAGE_180: -#if CONFIG_IS_ENABLED(DM_REGULATOR) - if (!IS_ERR_OR_NULL(priv->vqmmc_dev)) { - ret = regulator_set_value(priv->vqmmc_dev, 1800000); + if (CONFIG_IS_ENABLED(DM_REGULATOR) && + !IS_ERR_OR_NULL(priv->vqmmc_dev)) { + ret = regulator_set_value(priv->vqmmc_dev, + 1800000); if (ret) { printf("Setting to 1.8V error"); return -EIO; } } -#endif esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); /* * some board like imx8mm-evk need about 18ms to switch @@ -936,18 +933,16 @@ static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) set_sysctl(priv, mmc, clock);
if (mmc->clk_disable) { -#ifdef CONFIG_FSL_USDHC - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); -#else - esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); -#endif + if (IS_ENABLED(CONFIG_FSL_USDHC)) + esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); + else + esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); } else { -#ifdef CONFIG_FSL_USDHC - esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | - VENDORSPEC_CKEN); -#else - esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); -#endif + if (IS_ENABLED(CONFIG_FSL_USDHC)) + esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | + VENDORSPEC_CKEN); + else + esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); }
#ifdef MMC_SUPPORTS_TUNING @@ -995,34 +990,34 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) return -ETIMEDOUT; }
-#if defined(CONFIG_FSL_USDHC) - /* RSTA doesn't reset MMC_BOOT register, so manually reset it */ - esdhc_write32(®s->mmcboot, 0x0); - /* Reset MIX_CTRL and CLK_TUNE_CTRL_STATUS regs to 0 */ - esdhc_write32(®s->mixctrl, 0x0); - esdhc_write32(®s->clktunectrlstatus, 0x0); + if (IS_ENABLED(CONFIG_FSL_USDHC)) { + /* RSTA doesn't reset MMC_BOOT register, so manually reset it */ + esdhc_write32(®s->mmcboot, 0x0); + /* Reset MIX_CTRL and CLK_TUNE_CTRL_STATUS regs to 0 */ + esdhc_write32(®s->mixctrl, 0x0); + esdhc_write32(®s->clktunectrlstatus, 0x0);
- /* Put VEND_SPEC to default value */ - if (priv->vs18_enable) - esdhc_write32(®s->vendorspec, (VENDORSPEC_INIT | - ESDHC_VENDORSPEC_VSELECT)); - else - esdhc_write32(®s->vendorspec, VENDORSPEC_INIT); + /* Put VEND_SPEC to default value */ + if (priv->vs18_enable) + esdhc_write32(®s->vendorspec, VENDORSPEC_INIT | + ESDHC_VENDORSPEC_VSELECT); + else + esdhc_write32(®s->vendorspec, VENDORSPEC_INIT);
- /* Disable DLL_CTRL delay line */ - esdhc_write32(®s->dllctrl, 0x0); -#endif + /* Disable DLL_CTRL delay line */ + esdhc_write32(®s->dllctrl, 0x0); + }
#ifndef ARCH_MXC /* Enable cache snooping */ esdhc_write32(®s->scr, 0x00000040); #endif
-#ifndef CONFIG_FSL_USDHC - esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN); -#else - esdhc_setbits32(®s->vendorspec, VENDORSPEC_HCKEN | VENDORSPEC_IPGEN); -#endif + if (IS_ENABLED(CONFIG_FSL_USDHC)) + esdhc_setbits32(®s->vendorspec, + VENDORSPEC_HCKEN | VENDORSPEC_IPGEN); + else + esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
/* Set the initial clock speed */ mmc_set_clock(mmc, 400000, MMC_CLK_ENABLE); @@ -1030,12 +1025,11 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) /* Disable the BRR and BWR bits in IRQSTAT */ esdhc_clrbits32(®s->irqstaten, IRQSTATEN_BRR | IRQSTATEN_BWR);
-#ifdef CONFIG_MCF5441x - esdhc_write32(®s->proctl, PROCTL_INIT | PROCTL_D3CD); -#else /* Put the PROCTL reg back to the default */ - esdhc_write32(®s->proctl, PROCTL_INIT); -#endif + if (IS_ENABLED(CONFIG_MCF5441x)) + esdhc_write32(®s->proctl, PROCTL_INIT | PROCTL_D3CD); + else + esdhc_write32(®s->proctl, PROCTL_INIT);
/* Set timout to the maximum value */ esdhc_clrsetbits32(®s->sysctl, SYSCTL_TIMEOUT_MASK, 14 << 16); @@ -1048,19 +1042,17 @@ static int esdhc_getcd_common(struct fsl_esdhc_priv *priv) struct fsl_esdhc *regs = priv->esdhc_regs; int timeout = 1000;
-#ifdef CONFIG_ESDHC_DETECT_QUIRK - if (CONFIG_ESDHC_DETECT_QUIRK) + if (IS_ENABLED(CONFIG_ESDHC_DETECT_QUIRK)) return 1; -#endif
-#if CONFIG_IS_ENABLED(DM_MMC) - if (priv->broken_cd) - return 1; + if (CONFIG_IS_ENABLED(DM_MMC)) { + if (priv->broken_cd) + return 1; #if CONFIG_IS_ENABLED(DM_GPIO) - if (dm_gpio_is_valid(&priv->cd_gpio)) - return dm_gpio_get_value(&priv->cd_gpio); -#endif + if (dm_gpio_is_valid(&priv->cd_gpio)) + return dm_gpio_get_value(&priv->cd_gpio); #endif + }
while (!(esdhc_read32(®s->prsstat) & PRSSTAT_CINS) && --timeout) udelay(1000); @@ -1164,9 +1156,8 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv,
esdhc_write32(®s->irqstaten, SDHCI_IRQ_EN_BITS); cfg = &plat->cfg; -#ifndef CONFIG_DM_MMC - memset(cfg, '\0', sizeof(*cfg)); -#endif + if (!CONFIG_IS_ENABLED(DM_MMC)) + memset(cfg, '\0', sizeof(*cfg));
@@ -1313,16 +1304,14 @@ int fsl_esdhc_mmc_init(struct bd_info *bis) } #endif
-#ifdef CONFIG_OF_LIBFDT +#if CONFIG_IS_ENABLED(OF_LIBFDT) __weak int esdhc_status_fixup(void *blob, const char *compat) { -#ifdef CONFIG_FSL_ESDHC_PIN_MUX - if (!hwconfig("esdhc")) { + if (IS_ENABLED(FSL_ESDHC_PIN_MUX) && !hwconfig("esdhc")) { do_fixup_by_compat(blob, compat, "status", "disabled", sizeof("disabled"), 1); return 1; } -#endif return 0; }
@@ -1347,10 +1336,9 @@ __weak void init_clk_usdhc(u32 index) static int fsl_esdhc_of_to_plat(struct udevice *dev) { struct fsl_esdhc_priv *priv = dev_get_priv(dev); -#if CONFIG_IS_ENABLED(DM_REGULATOR) struct udevice *vqmmc_dev; int ret; -#endif + const void *fdt = gd->fdt_blob; int node = dev_of_offset(dev); fdt_addr_t addr; @@ -1395,7 +1383,9 @@ static int fsl_esdhc_of_to_plat(struct udevice *dev)
-#if CONFIG_IS_ENABLED(DM_REGULATOR) + if (!CONFIG_IS_ENABLED(DM_REGULATOR)) + return 0; + /* * If emmc I/O has a fixed voltage at 1.8V, this must be provided, * otherwise, emmc will work abnormally. @@ -1414,8 +1404,6 @@ static int fsl_esdhc_of_to_plat(struct udevice *dev) if (regulator_get_value(vqmmc_dev) == 1800000) priv->vs18_enable = 1; } -#endif - return 0; }
@@ -1551,8 +1539,7 @@ static int fsl_esdhc_set_ios(struct udevice *dev) return esdhc_set_ios_common(priv, &plat->mmc); }
-#if CONFIG_IS_ENABLED(MMC_HS400_ES_SUPPORT) -static int fsl_esdhc_set_enhanced_strobe(struct udevice *dev) +static int __maybe_unused fsl_esdhc_set_enhanced_strobe(struct udevice *dev) { struct fsl_esdhc_priv *priv = dev_get_priv(dev); struct fsl_esdhc *regs = priv->esdhc_regs; @@ -1564,7 +1551,6 @@ static int fsl_esdhc_set_enhanced_strobe(struct udevice *dev)
return 0; } -#endif
static int fsl_esdhc_wait_dat0(struct udevice *dev, int state, int timeout_us)
[ fsl_esdhc commit 263ddfc3454ead3a988adef39b962479adce2b28 ]
The initial clock setting should be through sysctl register only, while the mmc_set_clock() will call mmc_set_ios() introduce other configurations like bus width, mode, and so on.
drivers/mmc/fsl_esdhc_imx.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 25e912ba95..9299635f50 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1020,7 +1020,7 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN);
/* Set the initial clock speed */ - mmc_set_clock(mmc, 400000, MMC_CLK_ENABLE); + set_sysctl(priv, mmc, 400000);
Dear Sean,
Sorry for too late. I had been tried to applied this series from patchwork, but i can't see [PATCH v3 01/12].
Best Regards, Jaehoon Chung
Changes in v3:
Changes in v2:
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 4c06361bee..85cd72a796 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -39,10 +39,6 @@ #include <dm/ofnode.h> #include <linux/iopoll.h> -#if !CONFIG_IS_ENABLED(BLK) -#include "mmc_private.h" -#endif - #ifndef ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE #ifdef CONFIG_FSL_USDHC #define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE 1 @@ -58,7 +54,6 @@ DECLARE_GLOBAL_DATA_PTR; IRQSTATEN_DEBE | IRQSTATEN_BRR | IRQSTATEN_BWR | \ IRQSTATEN_DINT) #define MAX_TUNING_LOOP 40 -#define ESDHC_DRIVER_STAGE_VALUE 0xffffffff struct fsl_esdhc { uint dsaddr; /* SDMA system address register */ @@ -157,7 +152,7 @@ struct fsl_esdhc_priv { unsigned int clock; unsigned int mode; unsigned int bus_width; -#if !CONFIG_IS_ENABLED(BLK) +#if !CONFIG_IS_ENABLED(DM_MMC) struct mmc *mmc; #endif struct udevice *dev; @@ -1510,9 +1505,6 @@ static int fsl_esdhc_probe(struct udevice *dev) struct esdhc_soc_data *data = (struct esdhc_soc_data *)dev_get_driver_data(dev); struct mmc *mmc; -#if !CONFIG_IS_ENABLED(BLK) - struct blk_desc *bdesc; -#endif int ret; #if CONFIG_IS_ENABLED(OF_PLATDATA) @@ -1611,25 +1603,6 @@ static int fsl_esdhc_probe(struct udevice *dev) mmc = &plat->mmc; mmc->cfg = &plat->cfg; mmc->dev = dev; -#if !CONFIG_IS_ENABLED(BLK) - mmc->priv = priv; - - /* Setup dsr related values */ - mmc->dsr_imp = 0; - mmc->dsr = ESDHC_DRIVER_STAGE_VALUE; - /* Setup the universal parts of the block interface just once */ - bdesc = mmc_get_blk_desc(mmc); - bdesc->if_type = IF_TYPE_MMC; - bdesc->removable = 1; - bdesc->devnum = mmc_get_next_devnum(); - bdesc->block_read = mmc_bread; - bdesc->block_write = mmc_bwrite; - bdesc->block_erase = mmc_berase; - - /* setup initial part type */ - bdesc->part_type = mmc->cfg->part_type; - mmc_list_add(mmc); -#endif upriv->mmc = mmc; @@ -1740,14 +1713,12 @@ static const struct udevice_id fsl_esdhc_ids[] = { { /* sentinel */ } }; -#if CONFIG_IS_ENABLED(BLK) static int fsl_esdhc_bind(struct udevice *dev) { struct fsl_esdhc_plat *plat = dev_get_plat(dev); return mmc_bind(dev, &plat->mmc, &plat->cfg); } -#endif U_BOOT_DRIVER(fsl_esdhc) = { .name = "fsl_esdhc", @@ -1755,9 +1726,7 @@ U_BOOT_DRIVER(fsl_esdhc) = { .of_match = fsl_esdhc_ids, .of_to_plat = fsl_esdhc_of_to_plat, .ops = &fsl_esdhc_ops, -#if CONFIG_IS_ENABLED(BLK) .bind = fsl_esdhc_bind, -#endif .probe = fsl_esdhc_probe, .plat_auto = sizeof(struct fsl_esdhc_plat), .priv_auto = sizeof(struct fsl_esdhc_priv),
Dear Sean,
Thanks for resend this. But it can't apply your patch from patchwork directly. https://patchwork.ozlabs.org/project/uboot/patch/17862939-c7b1-310e-d98e-ce6...
If you're ok, I will apply after modified your patch.
Changes in v3:
On 1/10/22 8:14 PM, Jaehoon Chung wrote:
Dear Sean,
That's fine; looks like it got mangled a bit by my mail client.
--Sean
Changes in v3:
Jaehoon Chung
Sean Anderson
