[U-Boot] [PATCH 3/7] omap3630: Copy Device tree from Linux 4.9.y stable
Add device tree support to allow for CONFIG_OF_CONTROL in OMAP3630 boards. DM3730 can use this same device tree.
Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
diff --git a/arch/arm/dts/omap34xx-omap36xx-clocks.dtsi b/arch/arm/dts/omap34xx-omap36xx-clocks.dtsi new file mode 100644 index 0000000..db47f12 --- /dev/null +++ b/arch/arm/dts/omap34xx-omap36xx-clocks.dtsi @@ -0,0 +1,268 @@ +/* + * Device Tree Source for OMAP34XX/OMAP36XX clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +&cm_clocks { + security_l4_ick2: security_l4_ick2 { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + aes1_ick: aes1_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l4_ick2>; + ti,bit-shift = <3>; + reg = <0x0a14>; + }; + + rng_ick: rng_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l4_ick2>; + reg = <0x0a14>; + ti,bit-shift = <2>; + }; + + sha11_ick: sha11_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l4_ick2>; + reg = <0x0a14>; + ti,bit-shift = <1>; + }; + + des1_ick: des1_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l4_ick2>; + reg = <0x0a14>; + ti,bit-shift = <0>; + }; + + cam_mclk: cam_mclk@f00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll4_m5x2_ck>; + ti,bit-shift = <0>; + reg = <0x0f00>; + ti,set-rate-parent; + }; + + cam_ick: cam_ick@f10 { + #clock-cells = <0>; + compatible = "ti,omap3-no-wait-interface-clock"; + clocks = <&l4_ick>; + reg = <0x0f10>; + ti,bit-shift = <0>; + }; + + csi2_96m_fck: csi2_96m_fck@f00 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0f00>; + ti,bit-shift = <1>; + }; + + security_l3_ick: security_l3_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l3_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + pka_ick: pka_ick@a14 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&security_l3_ick>; + reg = <0x0a14>; + ti,bit-shift = <4>; + }; + + icr_ick: icr_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <29>; + }; + + des2_ick: des2_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <26>; + }; + + mspro_ick: mspro_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <23>; + }; + + mailboxes_ick: mailboxes_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <7>; + }; + + ssi_l4_ick: ssi_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + sr1_fck: sr1_fck@c00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&sys_ck>; + reg = <0x0c00>; + ti,bit-shift = <6>; + }; + + sr2_fck: sr2_fck@c00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&sys_ck>; + reg = <0x0c00>; + ti,bit-shift = <7>; + }; + + sr_l4_ick: sr_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + dpll2_fck: dpll2_fck@40 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&core_ck>; + ti,bit-shift = <19>; + ti,max-div = <7>; + reg = <0x0040>; + ti,index-starts-at-one; + }; + + dpll2_ck: dpll2_ck@4 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-clock"; + clocks = <&sys_ck>, <&dpll2_fck>; + reg = <0x0004>, <0x0024>, <0x0040>, <0x0034>; + ti,low-power-stop; + ti,lock; + ti,low-power-bypass; + }; + + dpll2_m2_ck: dpll2_m2_ck@44 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll2_ck>; + ti,max-div = <31>; + reg = <0x0044>; + ti,index-starts-at-one; + }; + + iva2_ck: iva2_ck@0 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&dpll2_m2_ck>; + reg = <0x0000>; + ti,bit-shift = <0>; + }; + + modem_fck: modem_fck@a00 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&sys_ck>; + reg = <0x0a00>; + ti,bit-shift = <31>; + }; + + sad2d_ick: sad2d_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&l3_ick>; + reg = <0x0a10>; + ti,bit-shift = <3>; + }; + + mad2d_ick: mad2d_ick@a18 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&l3_ick>; + reg = <0x0a18>; + ti,bit-shift = <3>; + }; + + mspro_fck: mspro_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <23>; + }; +}; + +&cm_clockdomains { + cam_clkdm: cam_clkdm { + compatible = "ti,clockdomain"; + clocks = <&cam_ick>, <&csi2_96m_fck>; + }; + + iva2_clkdm: iva2_clkdm { + compatible = "ti,clockdomain"; + clocks = <&iva2_ck>; + }; + + dpll2_clkdm: dpll2_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll2_ck>; + }; + + wkup_clkdm: wkup_clkdm { + compatible = "ti,clockdomain"; + clocks = <&gpio1_dbck>, <&wdt2_fck>, <&wdt2_ick>, <&wdt1_ick>, + <&gpio1_ick>, <&omap_32ksync_ick>, <&gpt12_ick>, + <&gpt1_ick>, <&sr1_fck>, <&sr2_fck>; + }; + + d2d_clkdm: d2d_clkdm { + compatible = "ti,clockdomain"; + clocks = <&modem_fck>, <&sad2d_ick>, <&mad2d_ick>; + }; + + core_l4_clkdm: core_l4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, + <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, + <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, + <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, + <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, + <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, + <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, + <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, + <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, <&icr_ick>, + <&des2_ick>, <&mspro_ick>, <&mailboxes_ick>, + <&mspro_fck>; + }; +}; diff --git a/arch/arm/dts/omap36xx-am35xx-omap3430es2plus-clocks.dtsi b/arch/arm/dts/omap36xx-am35xx-omap3430es2plus-clocks.dtsi new file mode 100644 index 0000000..572cb53 --- /dev/null +++ b/arch/arm/dts/omap36xx-am35xx-omap3430es2plus-clocks.dtsi @@ -0,0 +1,242 @@ +/* + * Device Tree Source for OMAP36xx/AM35xx/OMAP34xx clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +&prm_clocks { + corex2_d3_fck: corex2_d3_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&corex2_fck>; + clock-mult = <1>; + clock-div = <3>; + }; + + corex2_d5_fck: corex2_d5_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&corex2_fck>; + clock-mult = <1>; + clock-div = <5>; + }; +}; +&cm_clocks { + dpll5_ck: dpll5_ck@d04 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-clock"; + clocks = <&sys_ck>, <&sys_ck>; + reg = <0x0d04>, <0x0d24>, <0x0d4c>, <0x0d34>; + ti,low-power-stop; + ti,lock; + }; + + dpll5_m2_ck: dpll5_m2_ck@d50 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll5_ck>; + ti,max-div = <31>; + reg = <0x0d50>; + ti,index-starts-at-one; + }; + + sgx_gate_fck: sgx_gate_fck@b00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&core_ck>; + ti,bit-shift = <1>; + reg = <0x0b00>; + }; + + core_d3_ck: core_d3_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_ck>; + clock-mult = <1>; + clock-div = <3>; + }; + + core_d4_ck: core_d4_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + core_d6_ck: core_d6_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_ck>; + clock-mult = <1>; + clock-div = <6>; + }; + + omap_192m_alwon_fck: omap_192m_alwon_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll4_m2x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + core_d2_ck: core_d2_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&core_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + sgx_mux_fck: sgx_mux_fck@b40 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&core_d3_ck>, <&core_d4_ck>, <&core_d6_ck>, <&cm_96m_fck>, <&omap_192m_alwon_fck>, <&core_d2_ck>, <&corex2_d3_fck>, <&corex2_d5_fck>; + reg = <0x0b40>; + }; + + sgx_fck: sgx_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&sgx_gate_fck>, <&sgx_mux_fck>; + }; + + sgx_ick: sgx_ick@b10 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&l3_ick>; + reg = <0x0b10>; + ti,bit-shift = <0>; + }; + + cpefuse_fck: cpefuse_fck@a08 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_ck>; + reg = <0x0a08>; + ti,bit-shift = <0>; + }; + + ts_fck: ts_fck@a08 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&omap_32k_fck>; + reg = <0x0a08>; + ti,bit-shift = <1>; + }; + + usbtll_fck: usbtll_fck@a08 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&dpll5_m2_ck>; + reg = <0x0a08>; + ti,bit-shift = <2>; + }; + + usbtll_ick: usbtll_ick@a18 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a18>; + ti,bit-shift = <2>; + }; + + mmchs3_ick: mmchs3_ick@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&core_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <30>; + }; + + mmchs3_fck: mmchs3_fck@a00 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&core_96m_fck>; + reg = <0x0a00>; + ti,bit-shift = <30>; + }; + + dss1_alwon_fck: dss1_alwon_fck_3430es2@e00 { + #clock-cells = <0>; + compatible = "ti,dss-gate-clock"; + clocks = <&dpll4_m4x2_ck>; + ti,bit-shift = <0>; + reg = <0x0e00>; + ti,set-rate-parent; + }; + + dss_ick: dss_ick_3430es2@e10 { + #clock-cells = <0>; + compatible = "ti,omap3-dss-interface-clock"; + clocks = <&l4_ick>; + reg = <0x0e10>; + ti,bit-shift = <0>; + }; + + usbhost_120m_fck: usbhost_120m_fck@1400 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll5_m2_ck>; + reg = <0x1400>; + ti,bit-shift = <1>; + }; + + usbhost_48m_fck: usbhost_48m_fck@1400 { + #clock-cells = <0>; + compatible = "ti,dss-gate-clock"; + clocks = <&omap_48m_fck>; + reg = <0x1400>; + ti,bit-shift = <0>; + }; + + usbhost_ick: usbhost_ick@1410 { + #clock-cells = <0>; + compatible = "ti,omap3-dss-interface-clock"; + clocks = <&l4_ick>; + reg = <0x1410>; + ti,bit-shift = <0>; + }; +}; + +&cm_clockdomains { + dpll5_clkdm: dpll5_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll5_ck>; + }; + + sgx_clkdm: sgx_clkdm { + compatible = "ti,clockdomain"; + clocks = <&sgx_ick>; + }; + + dss_clkdm: dss_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dss_tv_fck>, <&dss_96m_fck>, <&dss2_alwon_fck>, + <&dss1_alwon_fck>, <&dss_ick>; + }; + + core_l4_clkdm: core_l4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, + <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, + <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, + <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, + <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, + <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, + <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, + <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, + <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, + <&cpefuse_fck>, <&ts_fck>, <&usbtll_fck>, + <&usbtll_ick>, <&mmchs3_ick>, <&mmchs3_fck>; + }; + + usbhost_clkdm: usbhost_clkdm { + compatible = "ti,clockdomain"; + clocks = <&usbhost_120m_fck>, <&usbhost_48m_fck>, + <&usbhost_ick>; + }; +}; diff --git a/arch/arm/dts/omap36xx-clocks.dtsi b/arch/arm/dts/omap36xx-clocks.dtsi new file mode 100644 index 0000000..9c7ed03 --- /dev/null +++ b/arch/arm/dts/omap36xx-clocks.dtsi @@ -0,0 +1,110 @@ +/* + * Device Tree Source for OMAP36xx clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +&cm_clocks { + dpll4_ck: dpll4_ck@d00 { + #clock-cells = <0>; + compatible = "ti,omap3-dpll-per-j-type-clock"; + clocks = <&sys_ck>, <&sys_ck>; + reg = <0x0d00>, <0x0d20>, <0x0d44>, <0x0d30>; + }; + + dpll4_m5x2_ck: dpll4_m5x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll4_m5x2_mul_ck>; + ti,bit-shift = <0x1e>; + reg = <0x0d00>; + ti,set-rate-parent; + ti,set-bit-to-disable; + }; + + dpll4_m2x2_ck: dpll4_m2x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll4_m2x2_mul_ck>; + ti,bit-shift = <0x1b>; + reg = <0x0d00>; + ti,set-bit-to-disable; + }; + + dpll3_m3x2_ck: dpll3_m3x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll3_m3x2_mul_ck>; + ti,bit-shift = <0xc>; + reg = <0x0d00>; + ti,set-bit-to-disable; + }; + + dpll4_m3x2_ck: dpll4_m3x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll4_m3x2_mul_ck>; + ti,bit-shift = <0x1c>; + reg = <0x0d00>; + ti,set-bit-to-disable; + }; + + dpll4_m6x2_ck: dpll4_m6x2_ck@d00 { + #clock-cells = <0>; + compatible = "ti,hsdiv-gate-clock"; + clocks = <&dpll4_m6x2_mul_ck>; + ti,bit-shift = <0x1f>; + reg = <0x0d00>; + ti,set-bit-to-disable; + }; + + uart4_fck: uart4_fck@1000 { + #clock-cells = <0>; + compatible = "ti,wait-gate-clock"; + clocks = <&per_48m_fck>; + reg = <0x1000>; + ti,bit-shift = <18>; + }; +}; + +&dpll4_m2x2_mul_ck { + clock-mult = <1>; +}; + +&dpll4_m3x2_mul_ck { + clock-mult = <1>; +}; + +&dpll4_m4x2_mul_ck { + ti,clock-mult = <1>; +}; + +&dpll4_m5x2_mul_ck { + ti,clock-mult = <1>; +}; + +&dpll4_m6x2_mul_ck { + clock-mult = <1>; +}; + +&cm_clockdomains { + dpll4_clkdm: dpll4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll4_ck>; + }; + + per_clkdm: per_clkdm { + compatible = "ti,clockdomain"; + clocks = <&uart3_fck>, <&gpio6_dbck>, <&gpio5_dbck>, + <&gpio4_dbck>, <&gpio3_dbck>, <&gpio2_dbck>, + <&wdt3_fck>, <&gpio6_ick>, <&gpio5_ick>, <&gpio4_ick>, + <&gpio3_ick>, <&gpio2_ick>, <&wdt3_ick>, <&uart3_ick>, + <&uart4_ick>, <&gpt9_ick>, <&gpt8_ick>, <&gpt7_ick>, + <&gpt6_ick>, <&gpt5_ick>, <&gpt4_ick>, <&gpt3_ick>, + <&gpt2_ick>, <&mcbsp2_ick>, <&mcbsp3_ick>, + <&mcbsp4_ick>, <&uart4_fck>; + }; +}; diff --git a/arch/arm/dts/omap36xx-omap3430es2plus-clocks.dtsi b/arch/arm/dts/omap36xx-omap3430es2plus-clocks.dtsi new file mode 100644 index 0000000..a9eec1b --- /dev/null +++ b/arch/arm/dts/omap36xx-omap3430es2plus-clocks.dtsi @@ -0,0 +1,198 @@ +/* + * Device Tree Source for OMAP34xx/OMAP36xx clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +&cm_clocks { + ssi_ssr_gate_fck_3430es2: ssi_ssr_gate_fck_3430es2@a00 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&corex2_fck>; + ti,bit-shift = <0>; + reg = <0x0a00>; + }; + + ssi_ssr_div_fck_3430es2: ssi_ssr_div_fck_3430es2@a40 { + #clock-cells = <0>; + compatible = "ti,composite-divider-clock"; + clocks = <&corex2_fck>; + ti,bit-shift = <8>; + reg = <0x0a40>; + ti,dividers = <0>, <1>, <2>, <3>, <4>, <0>, <6>, <0>, <8>; + }; + + ssi_ssr_fck: ssi_ssr_fck_3430es2 { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&ssi_ssr_gate_fck_3430es2>, <&ssi_ssr_div_fck_3430es2>; + }; + + ssi_sst_fck: ssi_sst_fck_3430es2 { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&ssi_ssr_fck>; + clock-mult = <1>; + clock-div = <2>; + }; + + hsotgusb_ick_3430es2: hsotgusb_ick_3430es2@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-hsotgusb-interface-clock"; + clocks = <&core_l3_ick>; + reg = <0x0a10>; + ti,bit-shift = <4>; + }; + + ssi_l4_ick: ssi_l4_ick { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l4_ick>; + clock-mult = <1>; + clock-div = <1>; + }; + + ssi_ick: ssi_ick_3430es2@a10 { + #clock-cells = <0>; + compatible = "ti,omap3-ssi-interface-clock"; + clocks = <&ssi_l4_ick>; + reg = <0x0a10>; + ti,bit-shift = <0>; + }; + + usim_gate_fck: usim_gate_fck@c00 { + #clock-cells = <0>; + compatible = "ti,composite-gate-clock"; + clocks = <&omap_96m_fck>; + ti,bit-shift = <9>; + reg = <0x0c00>; + }; + + sys_d2_ck: sys_d2_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&sys_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + omap_96m_d2_fck: omap_96m_d2_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <2>; + }; + + omap_96m_d4_fck: omap_96m_d4_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <4>; + }; + + omap_96m_d8_fck: omap_96m_d8_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <8>; + }; + + omap_96m_d10_fck: omap_96m_d10_fck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&omap_96m_fck>; + clock-mult = <1>; + clock-div = <10>; + }; + + dpll5_m2_d4_ck: dpll5_m2_d4_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll5_m2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + dpll5_m2_d8_ck: dpll5_m2_d8_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll5_m2_ck>; + clock-mult = <1>; + clock-div = <8>; + }; + + dpll5_m2_d16_ck: dpll5_m2_d16_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll5_m2_ck>; + clock-mult = <1>; + clock-div = <16>; + }; + + dpll5_m2_d20_ck: dpll5_m2_d20_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll5_m2_ck>; + clock-mult = <1>; + clock-div = <20>; + }; + + usim_mux_fck: usim_mux_fck@c40 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_ck>, <&sys_d2_ck>, <&omap_96m_d2_fck>, <&omap_96m_d4_fck>, <&omap_96m_d8_fck>, <&omap_96m_d10_fck>, <&dpll5_m2_d4_ck>, <&dpll5_m2_d8_ck>, <&dpll5_m2_d16_ck>, <&dpll5_m2_d20_ck>; + ti,bit-shift = <3>; + reg = <0x0c40>; + ti,index-starts-at-one; + }; + + usim_fck: usim_fck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&usim_gate_fck>, <&usim_mux_fck>; + }; + + usim_ick: usim_ick@c10 { + #clock-cells = <0>; + compatible = "ti,omap3-interface-clock"; + clocks = <&wkup_l4_ick>; + reg = <0x0c10>; + ti,bit-shift = <9>; + }; +}; + +&cm_clockdomains { + core_l3_clkdm: core_l3_clkdm { + compatible = "ti,clockdomain"; + clocks = <&sdrc_ick>, <&hsotgusb_ick_3430es2>; + }; + + wkup_clkdm: wkup_clkdm { + compatible = "ti,clockdomain"; + clocks = <&gpio1_dbck>, <&wdt2_fck>, <&wdt2_ick>, <&wdt1_ick>, + <&gpio1_ick>, <&omap_32ksync_ick>, <&gpt12_ick>, + <&gpt1_ick>, <&usim_ick>; + }; + + core_l4_clkdm: core_l4_clkdm { + compatible = "ti,clockdomain"; + clocks = <&cpefuse_fck>, <&ts_fck>, <&usbtll_fck>, + <&usbtll_ick>, <&mmchs3_ick>, <&mmchs3_fck>, + <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, + <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, + <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, + <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, + <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, + <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, + <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, + <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, + <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, + <&ssi_ick>; + }; +}; diff --git a/arch/arm/dts/omap36xx.dtsi b/arch/arm/dts/omap36xx.dtsi new file mode 100644 index 0000000..fc22f0d --- /dev/null +++ b/arch/arm/dts/omap36xx.dtsi @@ -0,0 +1,118 @@ +/* + * Device Tree Source for OMAP3 SoC + * + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#include <dt-bindings/media/omap3-isp.h> + +#include "omap3.dtsi" + +/ { + aliases { + serial3 = &uart4; + }; + + cpus { + /* OMAP3630/OMAP37xx 'standard device' variants OPP50 to OPP130 */ + cpu@0 { + operating-points = < + /* kHz uV */ + 300000 1012500 + 600000 1200000 + 800000 1325000 + >; + clock-latency = <300000>; /* From legacy driver */ + }; + }; + + ocp@68000000 { + uart4: serial@49042000 { + compatible = "ti,omap3-uart"; + reg = <0x49042000 0x400>; + interrupts = <80>; + dmas = <&sdma 81 &sdma 82>; + dma-names = "tx", "rx"; + ti,hwmods = "uart4"; + clock-frequency = <48000000>; + }; + + abb_mpu_iva: regulator-abb-mpu { + compatible = "ti,abb-v1"; + regulator-name = "abb_mpu_iva"; + #address-cells = <0>; + #size-cells = <0>; + reg = <0x483072f0 0x8>, <0x48306818 0x4>; + reg-names = "base-address", "int-address"; + ti,tranxdone-status-mask = <0x4000000>; + clocks = <&sys_ck>; + ti,settling-time = <30>; + ti,clock-cycles = <8>; + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 1012500 0 0 0 0 0 + 1200000 0 0 0 0 0 + 1325000 0 0 0 0 0 + 1375000 1 0 0 0 0 + >; + }; + + omap3_pmx_core2: pinmux@480025a0 { + compatible = "ti,omap3-padconf", "pinctrl-single"; + reg = <0x480025a0 0x5c>; + #address-cells = <1>; + #size-cells = <0>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0xff1f>; + }; + + isp: isp@480bc000 { + compatible = "ti,omap3-isp"; + reg = <0x480bc000 0x12fc + 0x480bd800 0x0600>; + interrupts = <24>; + iommus = <&mmu_isp>; + syscon = <&scm_conf 0x2f0>; + ti,phy-type = <OMAP3ISP_PHY_TYPE_CSIPHY>; + #clock-cells = <1>; + ports { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + bandgap@48002524 { + reg = <0x48002524 0x4>; + compatible = "ti,omap36xx-bandgap"; + #thermal-sensor-cells = <0>; + }; + }; +}; + +/* OMAP3630 needs dss_96m_fck for VENC */ +&venc { + clocks = <&dss_tv_fck>, <&dss_96m_fck>; + clock-names = "fck", "tv_dac_clk"; +}; + +&ssi { + status = "ok"; + + clocks = <&ssi_ssr_fck>, + <&ssi_sst_fck>, + <&ssi_ick>; + clock-names = "ssi_ssr_fck", + "ssi_sst_fck", + "ssi_ick"; +}; + +/include/ "omap34xx-omap36xx-clocks.dtsi" +/include/ "omap36xx-omap3430es2plus-clocks.dtsi" +/include/ "omap36xx-am35xx-omap3430es2plus-clocks.dtsi" +/include/ "omap36xx-clocks.dtsi" diff --git a/include/dt-bindings/media/omap3-isp.h b/include/dt-bindings/media/omap3-isp.h new file mode 100644 index 0000000..4e42084 --- /dev/null +++ b/include/dt-bindings/media/omap3-isp.h @@ -0,0 +1,22 @@ +/* + * include/dt-bindings/media/omap3-isp.h + * + * Copyright (C) 2015 Sakari Ailus + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + */ + +#ifndef __DT_BINDINGS_OMAP3_ISP_H__ +#define __DT_BINDINGS_OMAP3_ISP_H__ + +#define OMAP3ISP_PHY_TYPE_COMPLEX_IO 0 +#define OMAP3ISP_PHY_TYPE_CSIPHY 1 + +#endif /* __DT_BINDINGS_OMAP3_ISP_H__ */
Adam Ford
