[U-Boot] [PATCH] mpc85xx: clean up the old deep sleep framework
All the boards that support deep sleep feature are converted to deep sleep generic board interface. The old interface which support non-generic board is not used anymore. So clean it up.
Signed-off-by: Tang Yuantian Yuantian.Tang@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 10 +--------- arch/powerpc/lib/board.c | 21 --------------------- 2 files changed, 1 insertion(+), 30 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 85d32fc..4cf8853 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -424,7 +424,6 @@ void fsl_erratum_a007212_workaround(void)
ulong cpu_init_f(void) { - ulong flag = 0; extern void m8560_cpm_reset (void); #if defined(CONFIG_SYS_DCSRBAR_PHYS) || \ (defined(CONFIG_SECURE_BOOT) && defined(CONFIG_FSL_CORENET)) @@ -499,18 +498,11 @@ ulong cpu_init_f(void) in_be32(&gur->dcsrcr); #endif
-#ifdef CONFIG_SYS_DCSRBAR_PHYS -#ifdef CONFIG_DEEP_SLEEP - /* disable the console if boot from deep sleep */ - if (in_be32(&gur->scrtsr[0]) & (1 << 3)) - flag = GD_FLG_SILENT | GD_FLG_DISABLE_CONSOLE; -#endif -#endif #ifdef CONFIG_SYS_FSL_ERRATUM_A007212 fsl_erratum_a007212_workaround(); #endif
- return flag; + return 0; }
/* Implement a dummy function for those platforms w/o SERDES */ diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index e6d5355..91645d3 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -346,13 +346,6 @@ void board_init_f(ulong bootflag) #ifdef CONFIG_PRAM ulong reg; #endif -#ifdef CONFIG_DEEP_SLEEP - const ccsr_gur_t *gur = (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct ccsr_scfg *scfg = (void *)CONFIG_SYS_MPC85xx_SCFG; - u32 start_addr; - typedef void (*func_t)(void); - func_t kernel_resume; -#endif
/* Pointer is writable since we allocated a register for it */ gd = (gd_t *) (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET); @@ -372,20 +365,6 @@ void board_init_f(ulong bootflag) if ((*init_fnc_ptr) () != 0) hang();
-#ifdef CONFIG_DEEP_SLEEP - /* Jump to kernel in deep sleep case */ - if (in_be32(&gur->scrtsr[0]) & (1 << 3)) { - l2cache_init(); -#if defined(CONFIG_RAMBOOT_PBL) - disable_cpc_sram(); -#endif - enable_cpc(); - start_addr = in_be32(&scfg->sparecr[1]); - kernel_resume = (func_t)start_addr; - kernel_resume(); - } -#endif - #ifdef CONFIG_POST post_bootmode_init(); post_run(NULL, POST_ROM | post_bootmode_get(NULL));
I know for sure we have some patches pending. It would be helpful if you list all the dependency so I won't apply this one first. It will be a good habit for all future patches.
York
Hello York,
The following 3 patches, which are independent to each other, should be applied first before this one get applied. You can apply these 4 patches in the order I sent them.
1. mpc85xx/t102xrdb: convert deep sleep to generic board interface http://patchwork.ozlabs.org/patch/422189/ 2. mpc85xx/t1040qds: convert deep sleep to generic board interface http://patchwork.ozlabs.org/patch/422451/ 3. mpc85xx/t102xqds: convert deep sleep to generic board interface http://patchwork.ozlabs.org/patch/422447/
Thanks, Yuantian
-----Original Message----- From: York Sun [mailto:yorksun@freescale.com] Sent: Thursday, December 18, 2014 10:31 AM To: Tang Yuantian-B29983 Cc: u-boot@lists.denx.de Subject: Re: [PATCH] mpc85xx: clean up the old deep sleep framework
York
On 12/17/2014 06:43 PM, Tang Yuantian-B29983 wrote:
Hello York,
- mpc85xx/t102xrdb: convert deep sleep to generic board interface
Thanks. This is what I need.
York
Applied to u-boot-mpc85xx master branch, awaiting upstream.
York
Tang Yuantian
York Sun
Yuantian Tang
