[U-Boot] [PATCH] cmd/gpt: Support gpt command for all devices.
The gpt command was only implemented for mmc devices. There is no reason why this command should not be generalized and be applied all other storage device classes. This change both simplifies the implementation and eliminates a build failure for systems that don't support mmcs.
Signed-off-by: Egbert Eich eich@suse.com --- common/cmd_gpt.c | 43 ++++++++++++++++++------------------------- 1 files changed, 18 insertions(+), 25 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index efd7934..1a72e8e 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -23,7 +23,6 @@ #include <common.h> #include <malloc.h> #include <command.h> -#include <mmc.h> #include <part_efi.h> #include <exports.h> #include <linux/ctype.h> @@ -134,7 +133,7 @@ static int set_gpt_info(block_dev_desc_t *dev_desc, int errno = 0; uint64_t size_ll, start_ll;
- debug("%s: MMC lba num: 0x%x %d\n", __func__, + debug("%s: lba num: 0x%x %d\n", __func__, (unsigned int)dev_desc->lba, (unsigned int)dev_desc->lba);
if (str_part == NULL) @@ -247,25 +246,18 @@ err: return errno; }
-static int gpt_mmc_default(int dev, const char *str_part) +static int gpt_default(block_dev_desc_t *blk_dev_desc, const char *str_part) { int ret; char *str_disk_guid; u8 part_count = 0; disk_partition_t *partitions = NULL;
- struct mmc *mmc = find_mmc_device(dev); - - if (mmc == NULL) { - printf("%s: mmc dev %d NOT available\n", __func__, dev); - return CMD_RET_FAILURE; - } - if (!str_part) return -1;
/* fill partitions */ - ret = set_gpt_info(&mmc->block_dev, str_part, + ret = set_gpt_info(blk_dev_desc, str_part, &str_disk_guid, &partitions, &part_count); if (ret) { if (ret == -1) @@ -278,7 +270,7 @@ static int gpt_mmc_default(int dev, const char *str_part) }
/* save partitions layout to disk */ - gpt_restore(&mmc->block_dev, str_disk_guid, partitions, part_count); + gpt_restore(&blk_dev_desc, str_disk_guid, partitions, part_count); free(str_disk_guid); free(partitions);
@@ -306,20 +298,21 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* command: 'write' */ if ((strcmp(argv[1], "write") == 0) && (argc == 5)) { - /* device: 'mmc' */ - if (strcmp(argv[2], "mmc") == 0) { - /* check if 'dev' is a number */ - for (pstr = argv[3]; *pstr != '\0'; pstr++) - if (!isdigit(*pstr)) { - printf("'%s' is not a number\n", - argv[3]); - return CMD_RET_USAGE; - } - dev = (int)simple_strtoul(argv[3], NULL, 10); - /* write to mmc */ - if (gpt_mmc_default(dev, argv[4])) - return CMD_RET_FAILURE; + char *ep; + block_dev_desc_t *blk_dev_desc; + dev = (int)simple_strtoul(argv[3], NULL, 10); + if (*ep) { + printf("'%s' is not a number\n", argv[3]); + return CMD_RET_USAGE; } + blk_dev_desc = get_dev(argv[2], dev); + if (!blk_dev_desc) { + printf("%s: %s dev %d NOT available\n", __func__, argv[2], dev); + return CMD_RET_FAILURE; + } + + if (gpt_default(blk_dev_desc, argv[4])) + return CMD_RET_FAILURE; } else { return CMD_RET_USAGE; }
Dear egbert.eich@googlemail.com,
Please mark resubmits of new versions of patches as such; also, please provide a change log so we can see what you actually changed. Please see [1] for detailled instructions, and consider using patman to help you doing this.
[1] http://www.denx.de/wiki/view/U-Boot/Patches#Sending_updated_patch_versions
Note that this patch is still not checkpatch-clean:
WARNING: line over 80 characters #195: FILE: common/cmd_gpt.c:310: + printf("%s: %s dev %d NOT available\n", __func__, argv[2], dev);
Please fix!!
Signed-off-by: Egbert Eich eich@suse.com --- Changes for v2: - Coding style cleanup.
common/cmd_gpt.c | 44 +++++++++++++++++++------------------------- 1 file changed, 19 insertions(+), 25 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index efd7934..3594dca 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -23,7 +23,6 @@ #include <common.h> #include <malloc.h> #include <command.h> -#include <mmc.h> #include <part_efi.h> #include <exports.h> #include <linux/ctype.h> @@ -134,7 +133,7 @@ static int set_gpt_info(block_dev_desc_t *dev_desc, int errno = 0; uint64_t size_ll, start_ll;
@@ -306,20 +298,22 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* command: 'write' */ if ((strcmp(argv[1], "write") == 0) && (argc == 5)) { - /* device: 'mmc' */ - if (strcmp(argv[2], "mmc") == 0) { - /* check if 'dev' is a number */ - for (pstr = argv[3]; *pstr != '\0'; pstr++) - if (!isdigit(*pstr)) { - printf("'%s' is not a number\n", - argv[3]); - return CMD_RET_USAGE; - } - dev = (int)simple_strtoul(argv[3], NULL, 10); - /* write to mmc */ - if (gpt_mmc_default(dev, argv[4])) - return CMD_RET_FAILURE; + char *ep; + block_dev_desc_t *blk_dev_desc; + dev = (int)simple_strtoul(argv[3], NULL, 10); + if (*ep) { + printf("'%s' is not a number\n", argv[3]); + return CMD_RET_USAGE; } + blk_dev_desc = get_dev(argv[2], dev); + if (!blk_dev_desc) { + printf("%s: %s dev %d NOT available\n", + __func__, argv[2], dev); + return CMD_RET_FAILURE; + } + + if (gpt_default(blk_dev_desc, argv[4])) + return CMD_RET_FAILURE; } else { return CMD_RET_USAGE; }
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Reviewed-by: Tom Rini trini@ti.com
Thanks!
- -- Tom
Dear Egbert Eich,
-----Original Message----- From: Egbert Eich [mailto:egbert.eich@gmail.com] Sent: Tuesday, April 09, 2013 5:12 PM To: u-boot@lists.denx.de Cc: Piotr Wilczek; Egbert Eich Subject: [Patch v2] cmd/gpt: Support gpt command for all devices
Changes for v2:
-static int gpt_mmc_default(int dev, const char *str_part) +static int gpt_default(block_dev_desc_t *blk_dev_desc, const char +*str_part) { int ret; char *str_disk_guid; u8 part_count = 0; disk_partition_t *partitions = NULL;
if (mmc == NULL) {
- ret = set_gpt_info(blk_dev_desc, str_part, &str_disk_guid, &partitions, &part_count); if (ret) { if (ret == -1)
part_count);
- gpt_restore(&blk_dev_desc, str_disk_guid, partitions,
part_count);
'blk_dev_desc' is a pointer, no need to take its address
/* device: 'mmc' */
argv[3]);
/* write to mmc */
char *ep;
if (*ep) {
warning: 'ep' may be used uninitialized in this function shouldn't the address of 'ep' be passed to 'simple_strtoul' and then compared with argv[3]?
}return CMD_RET_USAGE;
unused 'pstr' variable can be removed
} else { return CMD_RET_USAGE; } -- 1.8.1.4
Best ragards, Piotr Wilczek
participants (5)
Egbert Eich
Piotr Wilczek
