[U-Boot] [PATCH 2/3 v5] S5PC100: Function to configure the SROMC registers.
Nand Flash, Ethernet, other features might need to configure the SROMC registers accordingly. The config_sromc() functions helps with this.
Signed-off-by: Naveen Krishna Ch ch.naveen@samsung.com --- Changes since V1:
1. Funtion config_sromc() is renamed to s5pc1xx_config_sromc(). Comments from Minkyu Kang are fixed
Changes since V2:
1.cpu_is_s5pc100() function is used instead of Macros.
Changes since V3: 1. Comments from Minkyu Kang are fixed.
Changes since V4: None
cpu/arm_cortexa8/s5pc1xx/Makefile | 1 + cpu/arm_cortexa8/s5pc1xx/sromc.c | 53 ++++++++++++++++++++++++++++++++++++ include/asm-arm/arch-s5pc1xx/smc.h | 3 ++ 3 files changed, 57 insertions(+), 0 deletions(-) create mode 100644 cpu/arm_cortexa8/s5pc1xx/sromc.c
diff --git a/cpu/arm_cortexa8/s5pc1xx/Makefile b/cpu/arm_cortexa8/s5pc1xx/Makefile index 7290c2f..01c93fe 100644 --- a/cpu/arm_cortexa8/s5pc1xx/Makefile +++ b/cpu/arm_cortexa8/s5pc1xx/Makefile @@ -34,6 +34,7 @@ SOBJS += reset.o COBJS += clock.o COBJS += cpu_info.o COBJS += gpio.o +COBJS += sromc.o COBJS += timer.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/cpu/arm_cortexa8/s5pc1xx/sromc.c b/cpu/arm_cortexa8/s5pc1xx/sromc.c new file mode 100644 index 0000000..380be81 --- /dev/null +++ b/cpu/arm_cortexa8/s5pc1xx/sromc.c @@ -0,0 +1,53 @@ +/* + * Copyright (C) 2010 Samsung Electronics + * Naveen Krishna Ch ch.naveen@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/smc.h> + +/* + * s5pc1xx_config_sromc() - select the proper SROMC Bank and configure the + * band width control and bank control registers + * srom_bank - SROM Bank 0 to 5 + * smc_bw_conf - SMC Band witdh reg configuration value + * smc_bc_conf - SMC Bank Control reg configuration value + */ +void s5pc1xx_config_sromc(u32 srom_bank, u32 smc_bw_conf, u32 smc_bc_conf) +{ + u32 tmp; + struct s5pc1xx_smc *srom; + + if (cpu_is_s5pc100()) + srom = (struct s5pc1xx_smc *)S5PC100_SROMC_BASE; + else + srom = (struct s5pc1xx_smc *)S5PC110_SROMC_BASE; + + /* Configure SMC_BW register to handle proper SROMC bank */ + tmp = srom->bw; + tmp &= ~(0xF << (srom_bank * 4)); + tmp |= smc_bw_conf; + srom->bw = tmp; + + /* Configure SMC_BC register */ + srom->bc[srom_bank] = smc_bc_conf; +} diff --git a/include/asm-arm/arch-s5pc1xx/smc.h b/include/asm-arm/arch-s5pc1xx/smc.h index e1a5399..88f4ffe 100644 --- a/include/asm-arm/arch-s5pc1xx/smc.h +++ b/include/asm-arm/arch-s5pc1xx/smc.h @@ -47,4 +47,7 @@ struct s5pc1xx_smc { }; #endif /* __ASSEMBLY__ */
+/* Configure the Band Width and Bank Control Regs for required SROMC Bank */ +void s5pc1xx_config_sromc(u32 srom_bank, u32 smc_bw_conf, u32 smc_bc_conf); + #endif /* __ASM_ARCH_SMC_H_ */
