[U-Boot] [Question]AT91: MMC read and multiple read failed
Hello Reinhard:
I've tried your patch([PATCH] AT91: enable MMC on at91sam(9260/9g20/0xe)ek) on uboot-atmel branch on at91sam9260.The sdcard is correctly initialized,but when I test "mmc read" command, I found two issues.
1.while run command "mmc read 22000000 0 1" to read the first block,it will cause "gen_atmel_mci: CMDR 00051051 (17) ARGR 00000000 (SR: 0c400025) Data Transfer Failed". Both read and write will fail.Sd1.0 and 2.0 cards face the same problem. 2.cmd 18(multiple read) failed,that means can not run "mmc read 22000000 0 2".
Do you have faced the same problem?
To issues1: "Data Transfer Failed" is caused by transfer data lost(not read),if MCCK too high the host may not receive the data.so I try to reduce the MCCK frequency,it works. To issues2: While multiple reading ,it did not set block count . so multiple read failed because it don't know how many blocks to read.I set reg MCI_BLKR BCNT bit.It is add in gen_atmel_mci.c.
static int mci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) { ... cmdr = mci_encode_cmd(cmd, data, &error_flags);
/* Send the command */ +if ((cmd->cmdidx == MMC_CMD_READ_MULTIPLE_BLOCK) ||(cmd->cmdidx == MMC_CMD_WRITE_MULTIPLE_BLOCK)) +{ + writel(data->blocks|mmc->read_bl_len<<16,&mci->blkr); +}
writel(cmd->cmdarg, &mci->argr); writel(cmdr, &mci->cmdr); ...
MCI_BLKR should be added in mmc.h: typedef struct atmel_mci { /* reg Offset */ u32 cr; /* 0x00 */ u32 mr; /* 0x04 */ u32 dtor; /* 0x08 */ u32 sdcr; /* 0x0c */ u32 argr; /* 0x10 */ u32 cmdr; /* 0x14 */ - u32 _18; /* 0x18 */ + u32 blkr; /* 0x18 */ ...
Do you think it is correct? In that case,I will deliver a patch.
Best regards elen.song
Hello Song, Elen,
Hello Reinhard:
All worked fine when I tested the patch late last year. Since then some changes to common MMC code have been done, perhaps those affect the Atmel implementation?
No idea, the clock should be computed and set correctly in the code as is. Have you investigated why it might be set too high for the card in question? You are testing on a standard at91sam9260-ek? I can only test on a 9xe-ek, but that should be the same.
I think that multiple reading was added to common code.
static int mci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) { ... cmdr = mci_encode_cmd(cmd, data,&error_flags);
- writel(data->blocks|mmc->read_bl_len<<16,&mci->blkr);
can't we write that register for all commands (remove the if)?
writel(cmd->cmdarg,&mci->argr); writel(cmdr,&mci->cmdr); ...
atmel_mci.h, I hope...
Looks correct by the data sheet. Please verify function in both read and write modes, make sure the number of blocks read or write is correct.
How does the patch for problem 1. look like?
And please run the patch through <linux>/scripts/checkpatch.pl, I see issues in the samples you provided above.
Best Regards, Reinhard
-----Original Message----- From: Reinhard Meyer [mailto:u-boot@emk-elektronik.de] Sent: 2011年7月11日 17:06 To: Song, Elen Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [Question]AT91: MMC read and multiple read failed
Hello Song, Elen,
Hello Reinhard:
The " Data Transfer Failed" only happens in HC card, normal card does not exist the problem.I test the HC card with "mmc read" several times, fortunately read data is equal to raw data.but I'm not sure if there's any potential problems.
I just found in Atmel_mci.c MCCK is just 5000000(5M),but in mmc.c is 25000000(25M).
To issues2: While multiple reading ,it did not set block count . so multiple read failed because it don't know how many blocks to read.I set reg MCI_BLKR >BCNT bit.It is add in gen_atmel_mci.c.
I guess no. Other place ,like "sd_switch" function use it ,but it is not a real read or write.so do not need to set block count.I've tested,the code will stuck.
Yep...
Tried ,it's ok.
Just: -mmc_set_clock(mmc, 25000000); +mmc_set_clock(mmc, 20000000); Seems it is a TBD problem ,I think no need now.
in the samples you provided above. Ok!
Best Regards, Elen.song
Dear Song, Elen,
[snip]
I do not think that the code gets stuck while writing a parameter register with any value, since a command has not been issued to the chip.
It might be that the command gets stuck when an unsuitable value is in one of the parameter registers.
That itself would require to write another value to BLKR in case of such commands and not let the value be undefined or residual from a previous command.
[snip]
Another observation: it must be ensured that data->blocks is less than 65536!
-----Original Message----- From: Reinhard Meyer [mailto:u-boot@emk-elektronik.de] Sent: 2011年7月11日 18:27 To: Song, Elen Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [Question]AT91: MMC read and multiple read failed
Dear Reinhard,
[snip]
It might be that the command gets stuck when an unsuitable value is in one of >the parameter registers.
I think you are right,I printf "data->blocks",that's an unsuitable value. Anyway,I will try to fix it!
[snip]
Reinhard Meyer
Song, Elen
