[PATCH 1/1] test: fix pylint warnings in test_efi_bootmgr
* Use f'' strings instead of .format(). * Correct sequence of imports. * Remove a superfluous import. * Add missing documentation. * Replace yield by return.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- test/py/tests/test_efi_bootmgr/conftest.py | 14 ++++++-------- test/py/tests/test_efi_bootmgr/test_efi_bootmgr.py | 13 ++++++++++++- 2 files changed, 18 insertions(+), 9 deletions(-)
diff --git a/test/py/tests/test_efi_bootmgr/conftest.py b/test/py/tests/test_efi_bootmgr/conftest.py index 69008fddce..a0a754afbe 100644 --- a/test/py/tests/test_efi_bootmgr/conftest.py +++ b/test/py/tests/test_efi_bootmgr/conftest.py @@ -4,9 +4,9 @@ """
import os -import pytest import shutil -from subprocess import call, check_call +from subprocess import check_call +import pytest
@pytest.fixture(scope='session') def efi_bootmgr_data(u_boot_config): @@ -14,7 +14,7 @@ def efi_bootmgr_data(u_boot_config): tests
Args: - u_boot_config: U-boot configuration. + u_boot_config -- U-boot configuration.
Return: A path to disk image to be used for testing @@ -34,9 +34,7 @@ def efi_bootmgr_data(u_boot_config): shutil.copyfile(u_boot_config.build_dir + '/lib/efi_loader/initrddump.efi', mnt_point + '/initrddump.efi')
- check_call('virt-make-fs --partition=gpt --size=+1M --type=vfat {} {}' - .format(mnt_point, image_path), shell=True) - - print(image_path) + check_call(f'virt-make-fs --partition=gpt --size=+1M --type=vfat {mnt_point} {image_path}', + shell=True)
- yield image_path + return image_path diff --git a/test/py/tests/test_efi_bootmgr/test_efi_bootmgr.py b/test/py/tests/test_efi_bootmgr/test_efi_bootmgr.py index f87e0a20b8..75a6e7c962 100644 --- a/test/py/tests/test_efi_bootmgr/test_efi_bootmgr.py +++ b/test/py/tests/test_efi_bootmgr/test_efi_bootmgr.py @@ -1,4 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+ +""" Unit test for UEFI bootmanager +"""
import pytest
@@ -6,7 +8,16 @@ import pytest @pytest.mark.buildconfigspec('cmd_efidebug') @pytest.mark.buildconfigspec('cmd_bootefi_bootmgr') def test_efi_bootmgr(u_boot_console, efi_bootmgr_data): - u_boot_console.run_command(cmd = 'host bind 0 {}'.format(efi_bootmgr_data)) + """ Unit test for UEFI bootmanager + The efidebug command is used to set up UEFI load options. + The bootefi bootmgr loads initrddump.efi as a payload. + The crc32 of the loaded initrd.img is checked + + Args: + u_boot_console -- U-Boot console + efi_bootmgr_data -- Path to the disk image used for testing. + """ + u_boot_console.run_command(cmd = f'host bind 0 {efi_bootmgr_data}')
u_boot_console.run_command(cmd = 'efidebug boot add ' \ '-b 0001 label-1 host 0:1 initrddump.efi ' \
