[U-Boot] [PATCH] Move CONFIG_SF_DUAL_FLASH to defconfig
Move the only use of CONFIG_SF_DUAL_FLASH to defconfig. This makes the associated topic_miamiplus.h header obsolete, so remove that as well.
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl --- configs/topic_miamiplus_defconfig | 3 ++- include/configs/topic_miamiplus.h | 2 -- scripts/config_whitelist.txt | 1 - 3 files changed, 2 insertions(+), 4 deletions(-) delete mode 100644 include/configs/topic_miamiplus.h
diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 10762f8..535ce6d 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_SYS_VENDOR="topic" -CONFIG_SYS_CONFIG_NAME="topic_miamiplus" +CONFIG_SYS_CONFIG_NAME="topic_miami" CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_BOOT_INIT_FILE="board/topic/zynq/zynq-topic-miamiplus/ps7_regs.txt" @@ -28,6 +28,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_RAM=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SF_DUAL_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/include/configs/topic_miamiplus.h b/include/configs/topic_miamiplus.h deleted file mode 100644 index 46ca6bd..0000000 --- a/include/configs/topic_miamiplus.h +++ /dev/null @@ -1,2 +0,0 @@ -#include "topic_miami.h" -#define CONFIG_SF_DUAL_FLASH diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e8f49eb..642c433 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2401,7 +2401,6 @@ CONFIG_SF_DEFAULT_BUS CONFIG_SF_DEFAULT_CS CONFIG_SF_DEFAULT_MODE CONFIG_SF_DEFAULT_SPEED -CONFIG_SF_DUAL_FLASH CONFIG_SGI_IP28 CONFIG_SH4_PCI CONFIG_SH73A0
Where is that Kconfig entry change?
Thanks, Michal
Michal Simek
Mike Looijmans
