[U-Boot] [PATCH] cosmetic: update doc/README.scrapyard
- Add 'p1023rds' to the list since commit d0bc5140 dropped the board support but missed to update this file - Fill the Commit and Removed Date fields for boards removed by earlier commits - Move 'incaip' to keep the list sorted in reverse chronological order - Describe the soring rule in the comment block: "The list should be sorted in reverse chronological order." - Fix typos in the comment block
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- doc/README.scrapyard | 30 ++++++++++++++++-------------- 1 file changed, 16 insertions(+), 14 deletions(-)
diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 6a1d2a5..b950a41 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -5,23 +5,25 @@ by unnoticed, but often build errors will result. If nobody cares any more to resolve such problems, then the code is really dead and will be removed from the U-Boot source tree. The remainders rest in piece in the imperishable depths of the git history. This document tries to -maintain a list of such former fellows, so archeologists can check -easily if here is something they might want to dig for... +maintain a list of such former fellows, so archaeologists can check +easily if there is something they might want to dig for... +The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= -spc1920 powerpc mpc8xx - - -v37 powerpc mpc8xx - - -fads powerpc mpc8xx - - -netphone powerpc mpc8xx - - -netta2 powerpc mpc8xx - - -netta powerpc mpc8xx - - -rbc823 powerpc mpc8xx - - -quantum powerpc mpc8xx - - -RPXlite_dw powerpc mpc8xx - - -qs850 powerpc mpc8xx - - -qs860t powerpc mpc8xx - - +p1023rds powerpc mpc85xx d0bc5140 2014-07-22 Roy Zang tie-fei.zang@freescale.com +spc1920 powerpc mpc8xx 98ad54be 2014-07-07 +v37 powerpc mpc8xx b8c1438a 2014-07-07 +fads powerpc mpc8xx 03f9d7d1 2014-07-07 +netphone powerpc mpc8xx c51c1c9a 2014-07-07 +netta2 powerpc mpc8xx c51c1c9a 2014-07-07 +netta powerpc mpc8xx c51c1c9a 2014-07-07 +rbc823 powerpc mpc8xx c750b9c0 2014-07-07 +quantum powerpc mpc8xx 0657e46e 2014-07-07 +RPXlite_dw powerpc mpc8xx 0657e46e 2014-07-07 +qs850 powerpc mpc8xx dab0f762 2014-07-07 +qs860t powerpc mpc8xx dab0f762 2014-07-07 simpc8313 powerpc mpc83xx 7445207f 2014-06-05 Ron Madrid info@sheldoninst.com hidden_dragon powerpc mpc824x 3fe1a854 2014-05-30 Yusdi Santoso yusdi_santoso@adaptec.com debris powerpc mpc824x 7edb1f7b 2014-05-30 Sangmoon Kim dogoil@etinsys.com @@ -33,6 +35,7 @@ zpc1900 powerpc mpc8260 6f80bb48 2014-05-30 Yuli Barcohe mpc8260ads powerpc mpc8260 facb6725 2014-05-30 Yuli Barcohen yuli@arabellasw.com adder powerpc mpc8xx 373a9788 2014-05-30 Yuli Barcohen yuli@arabellasw.com quad100hd powerpc ppc405ep 3569571d 2014-05-30 Gary Jennejohn gljennjohn@googlemail.com +incaip mips mips32 538cf92c 2014-04-20 Wolfgang Denk wd@denx.de lubbock arm pxa 36bf57b 2014-04-18 Kyle Harris kharris@nexus-tech.net EVB64260 powerpc mpc824x bb3aef9 2014-04-18 MOUSSE powerpc mpc824x 03f2ecc 2014-04-18 @@ -149,4 +152,3 @@ MVS1 powerpc MPC823 306620b 2008-08-26 Andre Schwar adsvix ARM PXA27x 7610db1 2008-07-30 Adrian Filipi adrian.filipi@eurotech.com R5200 ColdFire - 48ead7a 2008-03-31 Zachary P. Landau zachary.landau@labxtechnologies.com CPCI440 powerpc 440GP b568fd2 2007-12-27 Matthias Fuchs matthias.fuchs@esd-electronics.com -incaip mips mips32 - 2014-04-17 Wolfgang Denk wd@denx.de
Masahiro Yamada
