[PATCH v2 0/5] rockchip: Read cpuid and generate MAC address from efuse for RK3328 and RK3399
Hi folks,
This is v2 of my "read cpuid and generate MAC address from efuse on RK3328 and RK3399 by default" series.
Changes since v1: - Also imply "CONFIG_MISC" - Add back unintentionally removed CONFIG_OF_LIBFDT_OVERLAY=y - Remove ROCKCHIP_OTP from nanopi-r4s-rk3399_defconfig as requested by Jonas
This series enables ROCKCHIP_EFUSE and MISC_INIT_R by default for RK3328 and RK3399 so that the cpuid is read from the efuse and used to generate a serial number and MAC addresses for all boards.
This stacks on top of the recent defconfig update series [1] from Jonas.
[1] https://lore.kernel.org/u-boot/20240207000301.3270722-1-jonas@kwiboo.se/
Chen-Yu Tsai (5): rockchip: rk3328: Read cpuid and generate MAC address from efuse rockchip: rk3399: Read cpuid and generate MAC address from efuse rockchip: rk3328: regenerate defconfigs rockchip: rk3399: regenerate defconfigs rockchip: nanopi-r4s: Drop ROCKCHIP_OTP
arch/arm/mach-rockchip/Kconfig | 6 ++++++ configs/chromebook_bob_defconfig | 3 --- configs/chromebook_kevin_defconfig | 3 --- configs/eaidk-610-rk3399_defconfig | 1 - configs/evb-rk3328_defconfig | 3 --- configs/evb-rk3399_defconfig | 1 - configs/firefly-rk3399_defconfig | 3 --- configs/khadas-edge-captain-rk3399_defconfig | 1 - configs/khadas-edge-rk3399_defconfig | 1 - configs/khadas-edge-v-rk3399_defconfig | 1 - configs/leez-rk3399_defconfig | 1 - configs/nanopc-t4-rk3399_defconfig | 1 - configs/nanopi-m4-2gb-rk3399_defconfig | 1 - configs/nanopi-m4-rk3399_defconfig | 1 - configs/nanopi-m4b-rk3399_defconfig | 1 - configs/nanopi-neo4-rk3399_defconfig | 1 - configs/nanopi-r2c-plus-rk3328_defconfig | 3 --- configs/nanopi-r2c-rk3328_defconfig | 3 --- configs/nanopi-r2s-rk3328_defconfig | 3 --- configs/nanopi-r4s-rk3399_defconfig | 4 ---- configs/orangepi-r1-plus-lts-rk3328_defconfig | 3 --- configs/orangepi-r1-plus-rk3328_defconfig | 3 --- configs/orangepi-rk3399_defconfig | 1 - configs/pinebook-pro-rk3399_defconfig | 3 --- configs/pinephone-pro-rk3399_defconfig | 3 --- configs/puma-rk3399_defconfig | 3 --- configs/roc-cc-rk3328_defconfig | 3 --- configs/roc-pc-mezzanine-rk3399_defconfig | 3 --- configs/roc-pc-rk3399_defconfig | 3 --- configs/rock-4c-plus-rk3399_defconfig | 3 --- configs/rock-4se-rk3399_defconfig | 3 --- configs/rock-pi-4-rk3399_defconfig | 3 --- configs/rock-pi-4c-rk3399_defconfig | 3 --- configs/rock-pi-e-rk3328_defconfig | 3 --- configs/rock-pi-n10-rk3399pro_defconfig | 2 -- configs/rock64-rk3328_defconfig | 3 --- configs/rock960-rk3399_defconfig | 2 -- configs/rockpro64-rk3399_defconfig | 3 --- 38 files changed, 6 insertions(+), 86 deletions(-)
The rockchip-efuse driver supports the efuse found on RK3328. This hardware block is part of the SoC and contains the CPUID, which can be used to generate stable serial numbers and MAC addresses.
Enable the driver and reading cpuid by default for RK3328.
Signed-off-by: Chen-Yu Tsai wens@csie.org Reviewed-by: Christopher Obbard chris.obbard@collabora.com Reviewed-by: Dragan Simic dsimic@manjaro.org --- arch/arm/mach-rockchip/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 1bc7ee904275..0553967b947f 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -189,6 +189,9 @@ config ROCKCHIP_RK3328 select ENABLE_ARM_SOC_BOOT0_HOOK select DEBUG_UART_BOARD_INIT select SYS_NS16550 + imply MISC + imply ROCKCHIP_EFUSE + imply MISC_INIT_R help The Rockchip RK3328 is a ARM-based SoC with a quad-core Cortex-A53. including NEON and GPU, 1MB L2 cache, Mali-T7 graphics, two
The rockchip-efuse driver supports the efuse found on RK3399. This hardware block is part of the SoC and contains the CPUID, which can be used to generate stable serial numbers and MAC addresses.
Enable the driver and reading cpuid by default for RK3399.
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 0553967b947f..2c6b045c51c8 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -270,6 +270,9 @@ config ROCKCHIP_RK3399 imply SYS_BOOTCOUNT_SINGLEWORD if BOOTCOUNT_LIMIT imply BOOTSTD_FULL imply CMD_BOOTCOUNT if BOOTCOUNT_LIMIT + imply MISC + imply ROCKCHIP_EFUSE + imply MISC_INIT_R help The Rockchip RK3399 is a ARM-based SoC with a dual-core Cortex-A72 and quad-core Cortex-A53.
Regenerate RK3328 defconfigs after adding imply statements.
Signed-off-by: Chen-Yu Tsai wens@csie.org Reviewed-by: Christopher Obbard chris.obbard@collabora.com Reviewed-by: Dragan Simic dsimic@manjaro.org --- configs/evb-rk3328_defconfig | 3 --- configs/nanopi-r2c-plus-rk3328_defconfig | 3 --- configs/nanopi-r2c-rk3328_defconfig | 3 --- configs/nanopi-r2s-rk3328_defconfig | 3 --- configs/orangepi-r1-plus-lts-rk3328_defconfig | 3 --- configs/orangepi-r1-plus-rk3328_defconfig | 3 --- configs/roc-cc-rk3328_defconfig | 3 --- configs/rock-pi-e-rk3328_defconfig | 3 --- configs/rock64-rk3328_defconfig | 3 --- 9 files changed, 27 deletions(-)
diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 995bfd0558b1..c3bde3e5c457 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -30,7 +30,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-evb.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -70,8 +69,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_MOTORCOMM=y diff --git a/configs/nanopi-r2c-plus-rk3328_defconfig b/configs/nanopi-r2c-plus-rk3328_defconfig index 1cb0ed855398..1b0fa27ced16 100644 --- a/configs/nanopi-r2c-plus-rk3328_defconfig +++ b/configs/nanopi-r2c-plus-rk3328_defconfig @@ -31,7 +31,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2c-plus.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -72,8 +71,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_MOTORCOMM=y diff --git a/configs/nanopi-r2c-rk3328_defconfig b/configs/nanopi-r2c-rk3328_defconfig index 59801328deda..edf24623da2a 100644 --- a/configs/nanopi-r2c-rk3328_defconfig +++ b/configs/nanopi-r2c-rk3328_defconfig @@ -31,7 +31,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2c.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -72,8 +71,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_MOTORCOMM=y diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 61914b1650d2..32c99dfecb86 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -31,7 +31,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-nanopi-r2s.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -72,8 +71,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_MOTORCOMM=y diff --git a/configs/orangepi-r1-plus-lts-rk3328_defconfig b/configs/orangepi-r1-plus-lts-rk3328_defconfig index 968110c8cd6f..f554a284d930 100644 --- a/configs/orangepi-r1-plus-lts-rk3328_defconfig +++ b/configs/orangepi-r1-plus-lts-rk3328_defconfig @@ -34,7 +34,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-orangepi-r1-plus-lts.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -77,8 +76,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y diff --git a/configs/orangepi-r1-plus-rk3328_defconfig b/configs/orangepi-r1-plus-rk3328_defconfig index 7038f09f202c..162032460fe0 100644 --- a/configs/orangepi-r1-plus-rk3328_defconfig +++ b/configs/orangepi-r1-plus-rk3328_defconfig @@ -34,7 +34,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-orangepi-r1-plus.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -77,8 +76,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index 7d81a715ef25..02be1102697b 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -31,7 +31,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-roc-cc.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -73,8 +72,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_REALTEK=y diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index ddd482dd0195..ac6d6c5df772 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -32,7 +32,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock-pi-e.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -73,8 +72,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PHY_REALTEK=y diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index 01e447448513..718fb8f2025c 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -34,7 +34,6 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3328-rock64.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -77,8 +76,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x800800 CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_SPI_FLASH_SFDP_SUPPORT=y
Hi Chen-Yu,
Signed-off-by: Chen-Yu Tsaiwens@csie.org Reviewed-by: Christopher Obbardchris.obbard@collabora.com Reviewed-by: Dragan Simicdsimic@manjaro.org
There is no this config in the all these boards when I check the code on next,
which cause the conflict when apply this patch.
Thanks,
- Kever
On Wed, Mar 13, 2024 at 6:29 PM Kever Yang kever.yang@rock-chips.com wrote:
Hi Chen-Yu,
I can respin, but should I still base my patches on Jonas's series? I don't see them in next.
ChenYu
Thanks,
- Kever
Hi Kever and Chen-Yu,
Hi Chen-Yu,
The series "rockchip: rk3328: Update defconfigs, DTs and enable boot from SPI" [1] that this and some of the other patches depends on is missing in your for-next branch. Should we rebase on your for-next or will you pick that series? :-)
[1] https://patchwork.ozlabs.org/cover/1900345/
Regards, Jonas
ChenYu
Thanks,
- Kever
Hi Chen-Yu,
Sorry, forgot to pick this series, all patches apply correctly after this patch set.
Thanks,
- Kever
Regards, Jonas
ChenYu
Thanks,
Kever
Regenerate RK3399 defconfigs after adding imply statements.
Signed-off-by: Chen-Yu Tsai wens@csie.org Reviewed-by: Christopher Obbard chris.obbard@collabora.com Reviewed-by: Dragan Simic dsimic@manjaro.org Reviewed-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- configs/chromebook_bob_defconfig | 3 --- configs/chromebook_kevin_defconfig | 3 --- configs/eaidk-610-rk3399_defconfig | 1 - configs/evb-rk3399_defconfig | 1 - configs/firefly-rk3399_defconfig | 3 --- configs/khadas-edge-captain-rk3399_defconfig | 1 - configs/khadas-edge-rk3399_defconfig | 1 - configs/khadas-edge-v-rk3399_defconfig | 1 - configs/leez-rk3399_defconfig | 1 - configs/nanopc-t4-rk3399_defconfig | 1 - configs/nanopi-m4-2gb-rk3399_defconfig | 1 - configs/nanopi-m4-rk3399_defconfig | 1 - configs/nanopi-m4b-rk3399_defconfig | 1 - configs/nanopi-neo4-rk3399_defconfig | 1 - configs/nanopi-r4s-rk3399_defconfig | 3 --- configs/orangepi-rk3399_defconfig | 1 - configs/pinebook-pro-rk3399_defconfig | 3 --- configs/pinephone-pro-rk3399_defconfig | 3 --- configs/puma-rk3399_defconfig | 3 --- configs/roc-pc-mezzanine-rk3399_defconfig | 3 --- configs/roc-pc-rk3399_defconfig | 3 --- configs/rock-4c-plus-rk3399_defconfig | 3 --- configs/rock-4se-rk3399_defconfig | 3 --- configs/rock-pi-4-rk3399_defconfig | 3 --- configs/rock-pi-4c-rk3399_defconfig | 3 --- configs/rock-pi-n10-rk3399pro_defconfig | 2 -- configs/rock960-rk3399_defconfig | 2 -- configs/rockpro64-rk3399_defconfig | 3 --- 28 files changed, 58 deletions(-)
diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index b5a5ae737e52..989a8211f64d 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -27,7 +27,6 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-bob.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_MISC_INIT_R=y CONFIG_BLOBLIST=y CONFIG_BLOBLIST_ADDR=0x100000 CONFIG_BLOBLIST_SIZE=0x1000 @@ -67,8 +66,6 @@ CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_I2C_MUX=y CONFIG_CROS_EC_KEYB=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_CROS_EC=y CONFIG_CROS_EC_SPI=y CONFIG_PWRSEQ=y diff --git a/configs/chromebook_kevin_defconfig b/configs/chromebook_kevin_defconfig index 20913d2cf0fe..07a96aa18989 100644 --- a/configs/chromebook_kevin_defconfig +++ b/configs/chromebook_kevin_defconfig @@ -28,7 +28,6 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-gru-kevin.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_MISC_INIT_R=y CONFIG_BLOBLIST=y CONFIG_BLOBLIST_ADDR=0x100000 CONFIG_BLOBLIST_SIZE=0x1000 @@ -68,8 +67,6 @@ CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_I2C_MUX=y CONFIG_CROS_EC_KEYB=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_CROS_EC=y CONFIG_CROS_EC_SPI=y CONFIG_PWRSEQ=y diff --git a/configs/eaidk-610-rk3399_defconfig b/configs/eaidk-610-rk3399_defconfig index 22ad98b95ad3..0ca4cebc4d90 100644 --- a/configs/eaidk-610-rk3399_defconfig +++ b/configs/eaidk-610-rk3399_defconfig @@ -40,7 +40,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index d6140527b752..1d1e55162290 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -43,7 +43,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index b7c8e95b7b89..2fe38f81c50d 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -20,7 +20,6 @@ CONFIG_PCI=y CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-firefly.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -45,8 +44,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index 7f4e48a4e750..28a59899e1cb 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -43,7 +43,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index 9de8a53c1aea..075e28a509f4 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -42,7 +42,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index f31b8ecf6ee4..c65690ce3da7 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -43,7 +43,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/leez-rk3399_defconfig b/configs/leez-rk3399_defconfig index 76dd91911c7c..2122018e7a3e 100644 --- a/configs/leez-rk3399_defconfig +++ b/configs/leez-rk3399_defconfig @@ -39,7 +39,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index c18e7b1bd169..c1617d740112 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -43,7 +43,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/nanopi-m4-2gb-rk3399_defconfig b/configs/nanopi-m4-2gb-rk3399_defconfig index e3bdbccccbec..4d70fde6b14d 100644 --- a/configs/nanopi-m4-2gb-rk3399_defconfig +++ b/configs/nanopi-m4-2gb-rk3399_defconfig @@ -40,7 +40,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index e51e51c8cf5c..a96fe0306dad 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -40,7 +40,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/nanopi-m4b-rk3399_defconfig b/configs/nanopi-m4b-rk3399_defconfig index ca57c7f81a51..c8faccb233a5 100644 --- a/configs/nanopi-m4b-rk3399_defconfig +++ b/configs/nanopi-m4b-rk3399_defconfig @@ -40,7 +40,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 02e7f4e2ecb7..1c4ffbb44041 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -40,7 +40,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig index cacaab14d21f..f97c06412f07 100644 --- a/configs/nanopi-r4s-rk3399_defconfig +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -17,7 +17,6 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-r4s.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -41,8 +40,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_ROCKCHIP_OTP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index 27add8a29b92..bc2c4782efbc 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -40,7 +40,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/pinebook-pro-rk3399_defconfig b/configs/pinebook-pro-rk3399_defconfig index de357415fbe4..3083d0a8bb77 100644 --- a/configs/pinebook-pro-rk3399_defconfig +++ b/configs/pinebook-pro-rk3399_defconfig @@ -26,7 +26,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-pinebook-pro.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -60,8 +59,6 @@ CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_SPL_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y diff --git a/configs/pinephone-pro-rk3399_defconfig b/configs/pinephone-pro-rk3399_defconfig index d08224fe536b..454cb7eec76b 100644 --- a/configs/pinephone-pro-rk3399_defconfig +++ b/configs/pinephone-pro-rk3399_defconfig @@ -25,7 +25,6 @@ CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-pinephone-pro.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -59,8 +58,6 @@ CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index c2aa02ec74bd..7e76ec5076f9 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -25,7 +25,6 @@ CONFIG_SYS_LOAD_ADDR=0x800800 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-puma-haikou.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -67,8 +66,6 @@ CONFIG_GPIO_HOG=y CONFIG_SPL_GPIO_HOG=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index de6539bedf48..8d4153ea5f0e 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -26,7 +26,6 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc-mezzanine.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -55,8 +54,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 7123a7a07299..3824eb22d3da 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -27,7 +27,6 @@ CONFIG_DEBUG_UART=y CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -55,8 +54,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-4c-plus-rk3399_defconfig b/configs/rock-4c-plus-rk3399_defconfig index 18525c8bf504..67ad54610a72 100644 --- a/configs/rock-4c-plus-rk3399_defconfig +++ b/configs/rock-4c-plus-rk3399_defconfig @@ -21,7 +21,6 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-4c-plus.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -52,8 +51,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-4se-rk3399_defconfig b/configs/rock-4se-rk3399_defconfig index 171de23ec8f6..b0993bb81020 100644 --- a/configs/rock-4se-rk3399_defconfig +++ b/configs/rock-4se-rk3399_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-4se.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -53,8 +52,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 83fc4ad7dabc..2df3cd41e16c 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -23,7 +23,6 @@ CONFIG_SPL_FIT_SIGNATURE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4a.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -54,8 +53,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index 089344097e0c..bac745202bc7 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -21,7 +21,6 @@ CONFIG_DEBUG_UART=y # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4c.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -52,8 +51,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DFU_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index dc4b3b40380a..e86df4b7456a 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -22,7 +22,6 @@ CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399pro-rock-pi-n10.dtb" # CONFIG_CONSOLE_MUX is not set CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -47,7 +46,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index b93dda56593b..a9cae27ccd2f 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -20,7 +20,6 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" CONFIG_SYS_PBSIZE=1052 CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x2e000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -50,7 +49,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 711541f84627..b9c885cfee55 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -28,7 +28,6 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_MISC_INIT_R=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y @@ -63,8 +62,6 @@ CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_MISC=y -CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y
The NanoPi R4S has an RK3399 SoC, which has efuse supported by ROCKCHIP_EFUSE, not ROCKCHIP_OTP.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- configs/nanopi-r4s-rk3399_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig index f97c06412f07..50dbd7a854d4 100644 --- a/configs/nanopi-r4s-rk3399_defconfig +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -40,7 +40,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y -CONFIG_ROCKCHIP_OTP=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y
Chen-Yu Tsai
Dragan Simic
Jonas Karlman
Kever Yang
