[PATCH] efi_driver: fix duplicate efiblk#0 issue
The devnum value of the blk_desc structure starts from 0, current efi_bl_create_block_device() function creates two "efiblk#0" devices for the cases that blk_find_max_devnum() returns -ENODEV and blk_find_max_devnum() returns 0(one device found in this case).
The devnum value for the "efiblk" name needs to be incremented.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- lib/efi_driver/efi_block_device.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/lib/efi_driver/efi_block_device.c b/lib/efi_driver/efi_block_device.c index add00eeebb..e37bfe6e80 100644 --- a/lib/efi_driver/efi_block_device.c +++ b/lib/efi_driver/efi_block_device.c @@ -129,6 +129,8 @@ efi_bl_create_block_device(efi_handle_t handle, void *interface) devnum = 0; else if (devnum < 0) return EFI_OUT_OF_RESOURCES; + else + devnum++; /* device found, note that devnum starts from 0 */
name = calloc(1, 18); /* strlen("efiblk#2147483648") + 1 */ if (!name)
- else
So we can use blk_next_free_devnum() instead.
-Takahiro Akashi
name = calloc(1, 18); /* strlen("efiblk#2147483648") + 1 */ if (!name) -- 2.34.1
Hi Akashi-san,
On Mon, 3 Jul 2023 at 13:32, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
else
Yes, it is much simpler. I will revise the patch.
Thanks, Masahisa Kojima
-Takahiro Akashi
-- 2.34.1
- else
Shouldn't we simply use blk_next_free_devnum() instead of duplicating the logic here?
Best regards
Heinrich
Hi Heinrich,
else
Yes, Akashi-san also already pointed out, and I already sent v2 with blk_next_free_devnum().
Best regards
Heinrich
AKASHI Takahiro
Masahisa Kojima
