[PATCH v3 0/5] rockchip: Add support for Radxa ROCK 5C
Radxa ROCK 5C is a Rockchip RK3588S2 based single board computer.
Cristian Ciocaltea (1): arm64: dts: rockchip: Add HDMI0 node to rk3588
FUKAUMI Naoki (3): arm64: dts: rockchip: enable PCIe on M.2 E key for Radxa ROCK 5A arm64: dts: rockchip: add Radxa ROCK 5C rockchip: Add support for Radxa ROCK 5C
Sam Edwards (1): arm64: dts: rockchip: Split up RK3588's PCIe pinctrls
arch/arm/dts/rk3588s-rock-5-u-boot.dtsi | 16 + arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi | 6 + arch/arm/mach-rockchip/rk3588/Kconfig | 7 + board/radxa/rock-5-rk3588s/Kconfig | 12 + board/radxa/rock-5-rk3588s/MAINTAINERS | 8 + board/radxa/rock-5-rk3588s/Makefile | 3 + board/radxa/rock-5-rk3588s/rock-5-rk3588s.c | 77 ++ configs/rock-5-rk3588s_defconfig | 94 ++ doc/board/rockchip/rockchip.rst | 1 + .../arm64/rockchip/rk3588-base-pinctrl.dtsi | 271 +++++- .../src/arm64/rockchip/rk3588-base.dtsi | 41 + .../src/arm64/rockchip/rk3588s-rock-5a.dts | 34 + .../src/arm64/rockchip/rk3588s-rock-5c.dts | 920 ++++++++++++++++++ include/configs/rock-5-rk3588s.h | 15 + 14 files changed, 1457 insertions(+), 48 deletions(-) create mode 100644 arch/arm/dts/rk3588s-rock-5-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi create mode 100644 board/radxa/rock-5-rk3588s/Kconfig create mode 100644 board/radxa/rock-5-rk3588s/MAINTAINERS create mode 100644 board/radxa/rock-5-rk3588s/Makefile create mode 100644 board/radxa/rock-5-rk3588s/rock-5-rk3588s.c create mode 100644 configs/rock-5-rk3588s_defconfig create mode 100644 dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts create mode 100644 include/configs/rock-5-rk3588s.h
Enable pcie2x1l2 and related combphy/regulator routed to M.2 E key connector on Radxa ROCK 5A.
Tested with Radxa Wireless Module A8:
$ lspci 0004:40:00.0 PCI bridge: Rockchip Electronics Co., Ltd RK3588 (rev 01) 0004:41:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8852BE PCIe 802.11ax Wireless Network Controller
$ ip l 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: end0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000 link/ether c2:58:fc:70:55:86 brd ff:ff:ff:ff:ff:ff 3: wlP4p65s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000 link/ether 2c:05:47:65:5b:ed brd ff:ff:ff:ff:ff:ff
$ lsusb Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub Bus 001 Device 003: ID 0bda:b85b Realtek Semiconductor Corp. Bluetooth Radio Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 006 Device 002: ID 0789:0336 Logitec Corp. LMD USB Device Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
$ hciconfig hci0: Type: Primary Bus: USB BD Address: 2C:05:47:65:5B:EE ACL MTU: 1021:6 SCO MTU: 255:12 UP RUNNING RX bytes:2698 acl:0 sco:0 events:329 errors:0 TX bytes:69393 acl:0 sco:0 commands:329 errors:0
Signed-off-by: FUKAUMI Naoki naoki@radxa.com Link: https://lore.kernel.org/r/20240826080456.525-1-naoki@radxa.com Signed-off-by: Heiko Stuebner heiko@sntech.de (cherry picked from commit b728d4c51f0ce9207daf502f3a85073785c46319) --- .../src/arm64/rockchip/rk3588s-rock-5a.dts | 30 +++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts index 03ed48246d36..a385e0991990 100644 --- a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts +++ b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts @@ -65,6 +65,18 @@ regulator-max-microvolt = <12000000>; };
+ vcc3v3_wf: vcc3v3-wf-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_wf"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + enable-active-high; + gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + pinctrl-0 = <&pow_en>; + pinctrl-names = "default"; + vin-supply = <&vcc5v0_sys>; + }; + vcc5v0_host: vcc5v0-host-regulator { compatible = "regulator-fixed"; regulator-name = "vcc5v0_host"; @@ -114,6 +126,10 @@ }; };
+&combphy0_ps { + status = "okay"; +}; + &combphy2_psu { status = "okay"; }; @@ -293,6 +309,14 @@ }; };
+&pcie2x1l2 { + pinctrl-0 = <&pcie20x1m0_pins>; + pinctrl-names = "default"; + reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&vcc3v3_wf>; + status = "okay"; +}; + &pinctrl { leds { io_led: io-led { @@ -300,6 +324,12 @@ }; };
+ pcie { + pow_en: pow-en { + rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + power { vcc_5v0_en: vcc-5v0-en { rockchip,pins = <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
These pinctrls manage the low-speed PCIe signals: - CLKREQ#: An output on the RK3588 (both RC or EP modes), used to request that external clock-generation circuitry provide a clock. - PERST#: An input on the RK3588 in EP mode, used to detect a reset signal from the RC. In RC mode, the hardware does not use this signal: Linux itself generates it by putting the pin in GPIO mode. - WAKE#: In EP mode, this is an output; in RC mode, this is an input.
Each of these signals serves a distinct purpose, and more importantly, PERST# should not be muxed when the RK3588 is in the RC role. Bundling them together in pinctrl groups prevents proper use: indeed, almost none of the current board-specific .dts files make any use of them. (Exception: Rock 5A recently had a patch land that misuses _pins; this patch corrects that.)
However, on some RK3588 boards, the PCIe 3 controller will indefinitely stall the boot if CLKREQ# is not muxed (details in the next patch). This patch unbundles the signals to allow them to be used.
Signed-off-by: Sam Edwards CFSworks@gmail.com Link: https://lore.kernel.org/r/20240912025034.180233-2-CFSworks@gmail.com Signed-off-by: Heiko Stuebner heiko@sntech.de (cherry picked from commit 4294e32111781b3de4d73b944cbd1bc1662a9a7a) --- .../arm64/rockchip/rk3588-base-pinctrl.dtsi | 271 ++++++++++++++---- .../src/arm64/rockchip/rk3588s-rock-5a.dts | 6 +- 2 files changed, 228 insertions(+), 49 deletions(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3588-base-pinctrl.dtsi b/dts/upstream/src/arm64/rockchip/rk3588-base-pinctrl.dtsi index 30db12c4fc82..b12562e9a985 100644 --- a/dts/upstream/src/arm64/rockchip/rk3588-base-pinctrl.dtsi +++ b/dts/upstream/src/arm64/rockchip/rk3588-base-pinctrl.dtsi @@ -1612,23 +1612,43 @@
pcie20x1 { /omit-if-no-ref/ - pcie20x1m0_pins: pcie20x1m0-pins { + pcie20x1m0_clkreqn: pcie20x1m0-clkreqn { rockchip,pins = /* pcie20x1_2_clkreqn_m0 */ - <3 RK_PC7 4 &pcfg_pull_none>, + <3 RK_PC7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie20x1m0_perstn: pcie20x1m0-perstn { + rockchip,pins = /* pcie20x1_2_perstn_m0 */ - <3 RK_PD1 4 &pcfg_pull_none>, + <3 RK_PD1 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie20x1m0_waken: pcie20x1m0-waken { + rockchip,pins = /* pcie20x1_2_waken_m0 */ <3 RK_PD0 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie20x1m1_pins: pcie20x1m1-pins { + pcie20x1m1_clkreqn: pcie20x1m1-clkreqn { rockchip,pins = /* pcie20x1_2_clkreqn_m1 */ - <4 RK_PB7 4 &pcfg_pull_none>, + <4 RK_PB7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie20x1m1_perstn: pcie20x1m1-perstn { + rockchip,pins = /* pcie20x1_2_perstn_m1 */ - <4 RK_PC1 4 &pcfg_pull_none>, + <4 RK_PC1 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie20x1m1_waken: pcie20x1m1-waken { + rockchip,pins = /* pcie20x1_2_waken_m1 */ <4 RK_PC0 4 &pcfg_pull_none>; }; @@ -1654,52 +1674,127 @@
pcie30x1 { /omit-if-no-ref/ - pcie30x1m0_pins: pcie30x1m0-pins { + pcie30x1m0_0_clkreqn: pcie30x1m0-0-clkreqn { rockchip,pins = /* pcie30x1_0_clkreqn_m0 */ - <0 RK_PC0 12 &pcfg_pull_none>, + <0 RK_PC0 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_0_perstn: pcie30x1m0-0-perstn { + rockchip,pins = /* pcie30x1_0_perstn_m0 */ - <0 RK_PC5 12 &pcfg_pull_none>, + <0 RK_PC5 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_0_waken: pcie30x1m0-0-waken { + rockchip,pins = /* pcie30x1_0_waken_m0 */ - <0 RK_PC4 12 &pcfg_pull_none>, + <0 RK_PC4 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_1_clkreqn: pcie30x1m0-1-clkreqn { + rockchip,pins = /* pcie30x1_1_clkreqn_m0 */ - <0 RK_PB5 12 &pcfg_pull_none>, + <0 RK_PB5 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_1_perstn: pcie30x1m0-1-perstn { + rockchip,pins = /* pcie30x1_1_perstn_m0 */ - <0 RK_PB7 12 &pcfg_pull_none>, + <0 RK_PB7 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m0_1_waken: pcie30x1m0-1-waken { + rockchip,pins = /* pcie30x1_1_waken_m0 */ <0 RK_PB6 12 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x1m1_pins: pcie30x1m1-pins { + pcie30x1m1_0_clkreqn: pcie30x1m1-0-clkreqn { rockchip,pins = /* pcie30x1_0_clkreqn_m1 */ - <4 RK_PA3 4 &pcfg_pull_none>, + <4 RK_PA3 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_0_perstn: pcie30x1m1-0-perstn { + rockchip,pins = /* pcie30x1_0_perstn_m1 */ - <4 RK_PA5 4 &pcfg_pull_none>, + <4 RK_PA5 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_0_waken: pcie30x1m1-0-waken { + rockchip,pins = /* pcie30x1_0_waken_m1 */ - <4 RK_PA4 4 &pcfg_pull_none>, + <4 RK_PA4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_1_clkreqn: pcie30x1m1-1-clkreqn { + rockchip,pins = /* pcie30x1_1_clkreqn_m1 */ - <4 RK_PA0 4 &pcfg_pull_none>, + <4 RK_PA0 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_1_perstn: pcie30x1m1-1-perstn { + rockchip,pins = /* pcie30x1_1_perstn_m1 */ - <4 RK_PA2 4 &pcfg_pull_none>, + <4 RK_PA2 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m1_1_waken: pcie30x1m1-1-waken { + rockchip,pins = /* pcie30x1_1_waken_m1 */ <4 RK_PA1 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x1m2_pins: pcie30x1m2-pins { + pcie30x1m2_0_clkreqn: pcie30x1m2-0-clkreqn { rockchip,pins = /* pcie30x1_0_clkreqn_m2 */ - <1 RK_PB5 4 &pcfg_pull_none>, + <1 RK_PB5 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_0_perstn: pcie30x1m2-0-perstn { + rockchip,pins = /* pcie30x1_0_perstn_m2 */ - <1 RK_PB4 4 &pcfg_pull_none>, + <1 RK_PB4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_0_waken: pcie30x1m2-0-waken { + rockchip,pins = /* pcie30x1_0_waken_m2 */ - <1 RK_PB3 4 &pcfg_pull_none>, + <1 RK_PB3 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_1_clkreqn: pcie30x1m2-1-clkreqn { + rockchip,pins = /* pcie30x1_1_clkreqn_m2 */ - <1 RK_PA0 4 &pcfg_pull_none>, + <1 RK_PA0 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_1_perstn: pcie30x1m2-1-perstn { + rockchip,pins = /* pcie30x1_1_perstn_m2 */ - <1 RK_PA7 4 &pcfg_pull_none>, + <1 RK_PA7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x1m2_1_waken: pcie30x1m2-1-waken { + rockchip,pins = /* pcie30x1_1_waken_m2 */ <1 RK_PA1 4 &pcfg_pull_none>; }; @@ -1721,45 +1816,85 @@
pcie30x2 { /omit-if-no-ref/ - pcie30x2m0_pins: pcie30x2m0-pins { + pcie30x2m0_clkreqn: pcie30x2m0-clkreqn { rockchip,pins = /* pcie30x2_clkreqn_m0 */ - <0 RK_PD1 12 &pcfg_pull_none>, + <0 RK_PD1 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m0_perstn: pcie30x2m0-perstn { + rockchip,pins = /* pcie30x2_perstn_m0 */ - <0 RK_PD4 12 &pcfg_pull_none>, + <0 RK_PD4 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m0_waken: pcie30x2m0-waken { + rockchip,pins = /* pcie30x2_waken_m0 */ <0 RK_PD2 12 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x2m1_pins: pcie30x2m1-pins { + pcie30x2m1_clkreqn: pcie30x2m1-clkreqn { rockchip,pins = /* pcie30x2_clkreqn_m1 */ - <4 RK_PA6 4 &pcfg_pull_none>, + <4 RK_PA6 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m1_perstn: pcie30x2m1-perstn { + rockchip,pins = /* pcie30x2_perstn_m1 */ - <4 RK_PB0 4 &pcfg_pull_none>, + <4 RK_PB0 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m1_waken: pcie30x2m1-waken { + rockchip,pins = /* pcie30x2_waken_m1 */ <4 RK_PA7 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x2m2_pins: pcie30x2m2-pins { + pcie30x2m2_clkreqn: pcie30x2m2-clkreqn { rockchip,pins = /* pcie30x2_clkreqn_m2 */ - <3 RK_PD2 4 &pcfg_pull_none>, + <3 RK_PD2 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m2_perstn: pcie30x2m2-perstn { + rockchip,pins = /* pcie30x2_perstn_m2 */ - <3 RK_PD4 4 &pcfg_pull_none>, + <3 RK_PD4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m2_waken: pcie30x2m2-waken { + rockchip,pins = /* pcie30x2_waken_m2 */ <3 RK_PD3 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x2m3_pins: pcie30x2m3-pins { + pcie30x2m3_clkreqn: pcie30x2m3-clkreqn { rockchip,pins = /* pcie30x2_clkreqn_m3 */ - <1 RK_PD7 4 &pcfg_pull_none>, + <1 RK_PD7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m3_perstn: pcie30x2m3-perstn { + rockchip,pins = /* pcie30x2_perstn_m3 */ - <1 RK_PB7 4 &pcfg_pull_none>, + <1 RK_PB7 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x2m3_waken: pcie30x2m3-waken { + rockchip,pins = /* pcie30x2_waken_m3 */ <1 RK_PB6 4 &pcfg_pull_none>; }; @@ -1774,45 +1909,85 @@
pcie30x4 { /omit-if-no-ref/ - pcie30x4m0_pins: pcie30x4m0-pins { + pcie30x4m0_clkreqn: pcie30x4m0-clkreqn { rockchip,pins = /* pcie30x4_clkreqn_m0 */ - <0 RK_PC6 12 &pcfg_pull_none>, + <0 RK_PC6 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m0_perstn: pcie30x4m0-perstn { + rockchip,pins = /* pcie30x4_perstn_m0 */ - <0 RK_PD0 12 &pcfg_pull_none>, + <0 RK_PD0 12 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m0_waken: pcie30x4m0-waken { + rockchip,pins = /* pcie30x4_waken_m0 */ <0 RK_PC7 12 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x4m1_pins: pcie30x4m1-pins { + pcie30x4m1_clkreqn: pcie30x4m1-clkreqn { rockchip,pins = /* pcie30x4_clkreqn_m1 */ - <4 RK_PB4 4 &pcfg_pull_none>, + <4 RK_PB4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m1_perstn: pcie30x4m1-perstn { + rockchip,pins = /* pcie30x4_perstn_m1 */ - <4 RK_PB6 4 &pcfg_pull_none>, + <4 RK_PB6 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m1_waken: pcie30x4m1-waken { + rockchip,pins = /* pcie30x4_waken_m1 */ <4 RK_PB5 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x4m2_pins: pcie30x4m2-pins { + pcie30x4m2_clkreqn: pcie30x4m2-clkreqn { rockchip,pins = /* pcie30x4_clkreqn_m2 */ - <3 RK_PC4 4 &pcfg_pull_none>, + <3 RK_PC4 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m2_perstn: pcie30x4m2-perstn { + rockchip,pins = /* pcie30x4_perstn_m2 */ - <3 RK_PC6 4 &pcfg_pull_none>, + <3 RK_PC6 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m2_waken: pcie30x4m2-waken { + rockchip,pins = /* pcie30x4_waken_m2 */ <3 RK_PC5 4 &pcfg_pull_none>; };
/omit-if-no-ref/ - pcie30x4m3_pins: pcie30x4m3-pins { + pcie30x4m3_clkreqn: pcie30x4m3-clkreqn { rockchip,pins = /* pcie30x4_clkreqn_m3 */ - <1 RK_PB0 4 &pcfg_pull_none>, + <1 RK_PB0 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m3_perstn: pcie30x4m3-perstn { + rockchip,pins = /* pcie30x4_perstn_m3 */ - <1 RK_PB2 4 &pcfg_pull_none>, + <1 RK_PB2 4 &pcfg_pull_none>; + }; + + /omit-if-no-ref/ + pcie30x4m3_waken: pcie30x4m3-waken { + rockchip,pins = /* pcie30x4_waken_m3 */ <1 RK_PB1 4 &pcfg_pull_none>; }; diff --git a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts index a385e0991990..d6a0b559edca 100644 --- a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts +++ b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5a.dts @@ -310,7 +310,7 @@ };
&pcie2x1l2 { - pinctrl-0 = <&pcie20x1m0_pins>; + pinctrl-0 = <&pcie2_reset>, <&pcie20x1m0_clkreqn>, <&pcie20x1m0_waken>; pinctrl-names = "default"; reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; vpcie3v3-supply = <&vcc3v3_wf>; @@ -328,6 +328,10 @@ pow_en: pow-en { rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; }; + + pcie2_reset: pcie2-reset { + rockchip,pins = <3 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; };
power {
From: Cristian Ciocaltea cristian.ciocaltea@collabora.com
Add support for the HDMI0 output port found on RK3588 SoC.
Signed-off-by: Cristian Ciocaltea cristian.ciocaltea@collabora.com Link: https://lore.kernel.org/r/20241019-rk3588-hdmi0-dt-v2-1-466cd80e8ff9@collabo... Signed-off-by: Heiko Stuebner heiko@sntech.de (cherry picked from commit d7bb71e69f58c1b3665a9f926bf8d3855111bf8e) --- .../src/arm64/rockchip/rk3588-base.dtsi | 41 +++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3588-base.dtsi b/dts/upstream/src/arm64/rockchip/rk3588-base.dtsi index ee99166ebd46..3064ecf1e22a 100644 --- a/dts/upstream/src/arm64/rockchip/rk3588-base.dtsi +++ b/dts/upstream/src/arm64/rockchip/rk3588-base.dtsi @@ -1254,6 +1254,47 @@ status = "disabled"; };
+ hdmi0: hdmi@fde80000 { + compatible = "rockchip,rk3588-dw-hdmi-qp"; + reg = <0x0 0xfde80000 0x0 0x20000>; + clocks = <&cru PCLK_HDMITX0>, + <&cru CLK_HDMITX0_EARC>, + <&cru CLK_HDMITX0_REF>, + <&cru MCLK_I2S5_8CH_TX>, + <&cru CLK_HDMIHDP0>, + <&cru HCLK_VO1>; + clock-names = "pclk", "earc", "ref", "aud", "hdp", "hclk_vo1"; + interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "avp", "cec", "earc", "main", "hpd"; + phys = <&hdptxphy_hdmi0>; + pinctrl-names = "default"; + pinctrl-0 = <&hdmim0_tx0_cec &hdmim0_tx0_hpd + &hdmim0_tx0_scl &hdmim0_tx0_sda>; + power-domains = <&power RK3588_PD_VO1>; + resets = <&cru SRST_HDMITX0_REF>, <&cru SRST_HDMIHDP0>; + reset-names = "ref", "hdp"; + rockchip,grf = <&sys_grf>; + rockchip,vo-grf = <&vo1_grf>; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + hdmi0_in: port@0 { + reg = <0>; + }; + + hdmi0_out: port@1 { + reg = <1>; + }; + }; + }; + qos_gpu_m0: qos@fdf35000 { compatible = "rockchip,rk3588-qos", "syscon"; reg = <0x0 0xfdf35000 0x0 0x20>;
Radxa ROCK 5C is a 8K computer for everything[1] using the Rockchip RK3588S2 chip:
- Rockchip RK3588S2 - Quad A76 and Quad A55 CPU - 6 TOPS NPU - up to 32GB LPDDR4x RAM - eMMC / SPI flash connector - Micro SD Card slot - Gigabit ethernet port (supports PoE with add-on PoE HAT) - WiFi6 / BT5.4 - 1x USB 3.0 Type-A HOST port - 1x USB 3.0 Type-A OTG port - 2x USB 2.0 Type-A HOST port - 1x USB Type-C 5V power port
[1] https://radxa.com/products/rock5/5c
Signed-off-by: FUKAUMI Naoki naoki@radxa.com Link: https://lore.kernel.org/r/20241021090548.1052-2-naoki@radxa.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 3ddf5cdb77e6efd6fe9b70f36dec935e324a3cd2 ]
(cherry picked from commit f80689fcef4b9b07a97b629b4075cc1a4c21a68e) --- .../src/arm64/rockchip/rk3588s-rock-5c.dts | 920 ++++++++++++++++++ 1 file changed, 920 insertions(+) create mode 100644 dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts
diff --git a/dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts new file mode 100644 index 000000000000..9b14d5383cdc --- /dev/null +++ b/dts/upstream/src/arm64/rockchip/rk3588s-rock-5c.dts @@ -0,0 +1,920 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd. + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/soc/rockchip,vop2.h> +#include "rk3588s.dtsi" + +/ { + model = "Radxa ROCK 5C"; + compatible = "radxa,rock-5c", "rockchip,rk3588s"; + + aliases { + ethernet0 = &gmac1; + mmc0 = &sdhci; + mmc1 = &sdmmc; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + analog-sound { + compatible = "audio-graph-card"; + label = "rk3588-es8316"; + dais = <&i2s0_8ch_p0>; + routing = "MIC2", "Mic Jack", + "Headphones", "HPOL", + "Headphones", "HPOR"; + widgets = "Microphone", "Mic Jack", + "Headphone", "Headphones"; + }; + + hdmi0-con { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi0_con_in: endpoint { + remote-endpoint = <&hdmi0_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins>; + + led-0 { + color = <LED_COLOR_ID_GREEN>; + default-state = "on"; + function = LED_FUNCTION_POWER; + gpios = <&gpio3 RK_PC4 GPIO_ACTIVE_HIGH>; + }; + + led-1 { + color = <LED_COLOR_ID_BLUE>; + default-state = "on"; + function = LED_FUNCTION_HEARTBEAT; + gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + fan { + compatible = "pwm-fan"; + #cooling-cells = <2>; + cooling-levels = <0 64 128 192 255>; + fan-supply = <&vcc_5v0>; + pwms = <&pwm3 0 10000 0>; + }; + + pcie2x1l2_3v3: regulator-pcie2x1l2-3v3 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pow_en>; + regulator-name = "pcie2x1l2_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_sysin>; + }; + + vcc5v_dcin: regulator-vcc5v-dcin { + compatible = "regulator-fixed"; + regulator-name = "vcc5v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vcc5v0_usb_host: regulator-vcc5v0-usb-host { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PB5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_host_pwren_h>; + regulator-name = "vcc5v0_usb_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_sysin>; + }; + + vcc5v0_usb_otg0: regulator-vcc5v0-usb-otg0 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_otg_pwren_h>; + regulator-name = "vcc5v0_usb_otg0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_sysin>; + }; + + vcc_1v1_nldo_s3: regulator-vcc-1v1-nldo-s3 { + compatible = "regulator-fixed"; + regulator-name = "vcc_1v1_nldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + vin-supply = <&vcc_sysin>; + }; + + vcc_3v3_pmu: regulator-vcc-3v3-pmu { + compatible = "regulator-fixed"; + regulator-name = "vcc_3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_3v3_s3>; + }; + + vcc_3v3_s0: regulator-vcc-3v3-s0 { + compatible = "regulator-fixed"; + regulator-name = "vcc_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_1v8_s0>; + }; + + vcc_5v0: regulator-vcc-5v0 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio4 RK_PA3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc_5v0_pwren_h>; + regulator-name = "vcc_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_sysin>; + }; + + vcc_sysin: regulator-vcc-sysin { + compatible = "regulator-fixed"; + regulator-name = "vcc_sysin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v_dcin>; + }; + + vcca: regulator-vcca { + compatible = "regulator-fixed"; + regulator-name = "vcca"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <4000000>; + regulator-max-microvolt = <4000000>; + vin-supply = <&vcc_sysin>; + }; + + vdd_3v3: regulator-vdd-3v3 { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_wifi_pwr>; + regulator-name = "vdd_3v3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_3v3_s3>; + }; +}; + +&combphy0_ps { + status = "okay"; +}; + +&combphy2_psu { + status = "okay"; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_lit_s0>; +}; + +&gmac1 { + phy-handle = <&rgmii_phy1>; + phy-mode = "rgmii-id"; + phy-supply = <&vcc_3v3_s0>; + pinctrl-0 = <&gmac1_miim + &gmac1_tx_bus2 + &gmac1_rx_bus2 + &gmac1_rgmii_clk + &gmac1_rgmii_bus + &gmac1_clkinout>; + pinctrl-names = "default"; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu_s0>; + status = "okay"; +}; + +&hdmi0 { + pinctrl-names = "default"; + pinctrl-0 = <&hdmim0_tx0_cec + &hdmim1_tx0_hpd + &hdmim0_tx0_scl + &hdmim0_tx0_sda>; + status = "okay"; +}; + +&hdmi0_in { + hdmi0_in_vp0: endpoint { + remote-endpoint = <&vp0_out_hdmi0>; + }; +}; + +&hdmi0_out { + hdmi0_out_con: endpoint { + remote-endpoint = <&hdmi0_con_in>; + }; +}; + +&hdptxphy_hdmi0 { + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0m2_xfer>; + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc_sysin>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc_sysin>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + eeprom@50 { + compatible = "belling,bl24c16a", "atmel,24c16"; + reg = <0x50>; + pagesize = <16>; + vcc-supply = <&vcc_3v3_pmu>; + }; +}; + +&i2c2 { + status = "okay"; + + vdd_npu_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_npu_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc_sysin>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c5 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c5m2_xfer>; + status = "okay"; + + rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-output-names = "rtcic_32kout"; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB0 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&rtc_int_l>; + }; +}; + +&i2c7 { + status = "okay"; + + audio-codec@11 { + compatible = "everest,es8316"; + reg = <0x11>; + assigned-clocks = <&cru I2S0_8CH_MCLKOUT>; + assigned-clock-rates = <12288000>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + clock-names = "mclk"; + #sound-dai-cells = <0>; + + port { + es8316_p0_0: endpoint { + remote-endpoint = <&i2s0_8ch_p0_0>; + }; + }; + }; +}; + +&i2s0_8ch { + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; + + i2s0_8ch_p0: port { + i2s0_8ch_p0_0: endpoint { + dai-format = "i2s"; + mclk-fs = <256>; + remote-endpoint = <&es8316_p0_0>; + }; + }; +}; + +&mdio1 { + rgmii_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id001c.c916"; + reg = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac1_rstn>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + }; +}; + +&pcie2x1l2 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie20x1_2_perstn_m0>; + reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>; + vpcie3v3-supply = <&pcie2x1l2_3v3>; + status = "okay"; +}; + +&pinctrl { + leds { + led_pins: led-pins { + rockchip,pins = <3 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none>, + <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + mdio { + gmac1_rstn: gmac1-rstn { + rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pcie { + pcie20x1_2_perstn_m0: pcie20x1-2-perstn-m0 { + rockchip,pins = <3 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pow_en: pow-en { + rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + rtc { + rtc_int_l: rtc-int-l { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + usb_host_pwren_h: usb-host-pwren-h { + rockchip,pins = <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usb_otg_pwren_h: usb-otg-pwren-h { + rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + usb_wifi_pwr: usb-wifi-pwr { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + vcc_5v0_pwren_h: vcc-5v0-pwren-h { + rockchip,pins = <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pwm3m1_pins>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcca_1v8_s0>; + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + no-sdio; + no-sd; + non-removable; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + no-sdio; + no-mmc; + sd-uhs-sdr104; + vmmc-supply = <&vcc_3v3_s3>; + vqmmc-supply = <&vccio_sd_s0>; + status = "okay"; +}; + +&sfc { + pinctrl-names = "default"; + pinctrl-0 = <&fspim0_pins>; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <104000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <1>; + }; +}; + +&spi2 { + status = "okay"; + assigned-clocks = <&cru CLK_SPI2>; + assigned-clock-rates = <200000000>; + num-cs = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2m2_cs0 &spi2m2_pins>; + + pmic@0 { + compatible = "rockchip,rk806"; + reg = <0>; + gpio-controller; + #gpio-cells = <2>; + interrupt-parent = <&gpio0>; + interrupts = <7 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_pins>, <&rk806_dvs1_null>, + <&rk806_dvs2_null>, <&rk806_dvs3_null>; + spi-max-frequency = <1000000>; + system-power-controller; + + vcc1-supply = <&vcc_sysin>; + vcc2-supply = <&vcc_sysin>; + vcc3-supply = <&vcc_sysin>; + vcc4-supply = <&vcc_sysin>; + vcc5-supply = <&vcc_sysin>; + vcc6-supply = <&vcc_sysin>; + vcc7-supply = <&vcc_sysin>; + vcc8-supply = <&vcc_sysin>; + vcc9-supply = <&vcc_sysin>; + vcc10-supply = <&vcc_sysin>; + vcc11-supply = <&vcc_2v0_pldo_s3>; + vcc12-supply = <&vcc_sysin>; + vcc13-supply = <&vcc_1v1_nldo_s3>; + vcc14-supply = <&vcc_1v1_nldo_s3>; + vcca-supply = <&vcca>; + + rk806_dvs1_null: dvs1-null-pins { + pins = "gpio_pwrctrl1"; + function = "pin_fun0"; + }; + + rk806_dvs2_null: dvs2-null-pins { + pins = "gpio_pwrctrl2"; + function = "pin_fun0"; + }; + + rk806_dvs3_null: dvs3-null-pins { + pins = "gpio_pwrctrl3"; + function = "pin_fun0"; + }; + + regulators { + vdd_gpu_s0: dcdc-reg1 { + regulator-name = "vdd_gpu_s0"; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + regulator-enable-ramp-delay = <400>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_lit_s0: dcdc-reg2 { + regulator-name = "vdd_cpu_lit_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_logic_s0: dcdc-reg3 { + regulator-name = "vdd_logic_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <750000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdd_vdenc_s0: dcdc-reg4 { + regulator-name = "vdd_vdenc_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_ddr_s0: dcdc-reg5 { + regulator-name = "vdd_ddr_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <675000>; + regulator-max-microvolt = <900000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-off-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdd2_ddr_s3: dcdc-reg6 { + regulator-name = "vdd2_ddr_s3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_2v0_pldo_s3: dcdc-reg7 { + regulator-name = "vdd_2v0_pldo_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + regulator-ramp-delay = <12500>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2000000>; + }; + }; + + vcc_3v3_s3: dcdc-reg8 { + regulator-name = "vcc_3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vddq_ddr_s0: dcdc-reg9 { + regulator-name = "vddq_ddr_s0"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu_ddr_s3: dcdc-reg10 { + regulator-name = "vcc1v8_pmu_ddr_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_1v8_s0: pldo-reg1 { + regulator-name = "vcc_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca_1v8_s0: pldo-reg2 { + regulator-name = "vcca_1v8_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdda_1v2_s0: pldo-reg3 { + regulator-name = "vdda_1v2_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca_3v3_s0: pldo-reg4 { + regulator-name = "vcca_3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vccio_sd_s0: pldo-reg5 { + regulator-name = "vccio_sd_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + pldo6_s3: pldo-reg6 { + regulator-name = "pldo6_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd_0v75_s3: nldo-reg1 { + regulator-name = "vdd_0v75_s3"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <750000>; + }; + }; + + vdda_ddr_pll_s0: nldo-reg2 { + regulator-name = "vdda_ddr_pll_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <850000>; + }; + }; + + vdda_0v75_s0: nldo-reg3 { + regulator-name = "vdda_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v85_s0: nldo-reg4 { + regulator-name = "vdda_0v85_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_0v75_s0: nldo-reg5 { + regulator-name = "vdd_0v75_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&tsadc { + status = "okay"; +}; + +&u2phy0 { + status = "okay"; +}; + +&u2phy0_otg { + phy-supply = <&vcc5v0_usb_otg0>; + status = "okay"; +}; + +&u2phy2 { + status = "okay"; +}; + +&u2phy2_host { + /* connected to USB hub, which is powered by vcc_5v0 */ + phy-supply = <&vcc_5v0>; + status = "okay"; +}; + +&u2phy3 { + status = "okay"; +}; + +&u2phy3_host { + phy-supply = <&vcc5v0_usb_host>; + status = "okay"; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; + +&usbdp_phy0 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_xhci { + dr_mode = "host"; + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&usb_host2_xhci { + status = "okay"; +}; + +&vop_mmu { + status = "okay"; +}; + +&vop { + status = "okay"; +}; + +&vp0 { + vp0_out_hdmi0: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { + reg = <ROCKCHIP_VOP2_EP_HDMI0>; + remote-endpoint = <&hdmi0_in_vp0>; + }; +};
Radxa ROCK 5C[1] is a Rockchip RK3588S2 based single board computer.
Signed-off-by: FUKAUMI Naoki naoki@radxa.com --- Changes in v3: - fix compile error Changes in v2: - arch/arm/dts/rk3588s-rock-5-u-boot.dtsi: remove unused node - include/configs/rock-5-rk3588s.h: fix include order --- arch/arm/dts/rk3588s-rock-5-u-boot.dtsi | 16 ++++ arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi | 6 ++ arch/arm/mach-rockchip/rk3588/Kconfig | 7 ++ board/radxa/rock-5-rk3588s/Kconfig | 12 +++ board/radxa/rock-5-rk3588s/MAINTAINERS | 8 ++ board/radxa/rock-5-rk3588s/Makefile | 3 + board/radxa/rock-5-rk3588s/rock-5-rk3588s.c | 77 +++++++++++++++++ configs/rock-5-rk3588s_defconfig | 94 +++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/rock-5-rk3588s.h | 15 ++++ 10 files changed, 239 insertions(+) create mode 100644 arch/arm/dts/rk3588s-rock-5-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi create mode 100644 board/radxa/rock-5-rk3588s/Kconfig create mode 100644 board/radxa/rock-5-rk3588s/MAINTAINERS create mode 100644 board/radxa/rock-5-rk3588s/Makefile create mode 100644 board/radxa/rock-5-rk3588s/rock-5-rk3588s.c create mode 100644 configs/rock-5-rk3588s_defconfig create mode 100644 include/configs/rock-5-rk3588s.h
diff --git a/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi b/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi new file mode 100644 index 000000000000..be1a2f9ae7bb --- /dev/null +++ b/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd. + */ + +#include "rk3588s-u-boot.dtsi" + +&saradc { + bootph-pre-ram; + vdd-microvolts = <1800000>; +}; + +&sdhci { + cap-mmc-highspeed; + mmc-hs200-1_8v; +}; diff --git a/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi b/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi new file mode 100644 index 000000000000..bb1cc9e4a279 --- /dev/null +++ b/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd. + */ + +#include "rk3588s-rock-5-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index b5a0e624a532..e1487ecb0464 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -260,6 +260,12 @@ config TARGET_ROCK_5_ITX_RK3588 Front-panel connectors for audio and case-power, -leds Powered by either 12V, ATX power-supply or PoE
+config TARGET_ROCK_5_RK3588S + bool "Radxa ROCK 5C RK3588S2 board" + select BOARD_LATE_INIT + help + Radxa ROCK 5C is a Rockchip RK3588S2 based single board computer. + config TARGET_SIGE7_RK3588 bool "ArmSoM Sige7 RK3588 board" select BOARD_LATE_INIT @@ -398,6 +404,7 @@ source "board/turing/turing-rk1-rk3588/Kconfig" source "board/radxa/rock5a-rk3588s/Kconfig" source "board/radxa/rock5b-rk3588/Kconfig" source "board/radxa/rock-5-itx-rk3588/Kconfig" +source "board/radxa/rock-5-rk3588s/Kconfig" source "board/rockchip/evb_rk3588/Kconfig" source "board/rockchip/toybrick_rk3588/Kconfig" source "board/theobroma-systems/jaguar_rk3588/Kconfig" diff --git a/board/radxa/rock-5-rk3588s/Kconfig b/board/radxa/rock-5-rk3588s/Kconfig new file mode 100644 index 000000000000..86830be1eeca --- /dev/null +++ b/board/radxa/rock-5-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_ROCK_5_RK3588S + +config SYS_BOARD + default "rock-5-rk3588s" + +config SYS_VENDOR + default "radxa" + +config SYS_CONFIG_NAME + default "rock-5-rk3588s" + +endif diff --git a/board/radxa/rock-5-rk3588s/MAINTAINERS b/board/radxa/rock-5-rk3588s/MAINTAINERS new file mode 100644 index 000000000000..ead6356131c1 --- /dev/null +++ b/board/radxa/rock-5-rk3588s/MAINTAINERS @@ -0,0 +1,8 @@ +ROCK-5-RK3588S +M: FUKAUMI Naoki naoki@radxa.com +S: Maintained +F: arch/arm/dts/rk3588s-rock-5-u-boot.dtsi +F: arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi +F: board/radxa/rock-5-rk3588s/ +F: configs/rock-5-rk3588s_defconfig +F: include/configs/rock-5-rk3588s.h diff --git a/board/radxa/rock-5-rk3588s/Makefile b/board/radxa/rock-5-rk3588s/Makefile new file mode 100644 index 000000000000..d9be0f42e6b9 --- /dev/null +++ b/board/radxa/rock-5-rk3588s/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += rock-5-rk3588s.o diff --git a/board/radxa/rock-5-rk3588s/rock-5-rk3588s.c b/board/radxa/rock-5-rk3588s/rock-5-rk3588s.c new file mode 100644 index 000000000000..a840ca7698d4 --- /dev/null +++ b/board/radxa/rock-5-rk3588s/rock-5-rk3588s.c @@ -0,0 +1,77 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <linux/errno.h> +#include <linux/kernel.h> +#include <adc.h> +#include <env.h> + +#define BOARD_ID 5 + +struct board_model { + unsigned int low; + unsigned int high; + const char *board; + const char *board_name; + const char *fdtfile; +}; + +static const struct board_model board_models[] = { + { + 0, + 50, + "rock-5a-rk3588s", + "Radxa ROCK 5A", + "rockchip/rk3588s-rock-5a.dtb", + }, + { + 2375, + 2425, + "rock-5c-rk3588s", + "Radxa ROCK 5C", + "rockchip/rk3588s-rock-5c.dtb" + }, +}; + +static const struct board_model *get_board_model(void) +{ + unsigned int val; + int i, ret; + + ret = adc_channel_single_shot("adc@fec10000", BOARD_ID, &val); + debug("adc_channel_single_shot ret %d val %u\n", ret, val); + if (ret) + return NULL; + + for (i = 0; i < ARRAY_SIZE(board_models); i++) { + unsigned int min = board_models[i].low; + unsigned int max = board_models[i].high; + + if (min <= val && val <= max) + return &board_models[i]; + } + + return NULL; +} + +int rk_board_late_init(void) +{ + const struct board_model *model = get_board_model(); + + if (model) { + env_set("board", model->board); + env_set("board_name", model->board_name); + env_set("fdtfile", model->fdtfile); + } + + return 0; +} + +int board_fit_config_name_match(const char *name) +{ + const struct board_model *model = get_board_model(); + + if (model && !strcmp(name, model->fdtfile)) + return 0; + + return -ENOENT; +} diff --git a/configs/rock-5-rk3588s_defconfig b/configs/rock-5-rk3588s_defconfig new file mode 100644 index 000000000000..54043264de48 --- /dev/null +++ b/configs/rock-5-rk3588s_defconfig @@ -0,0 +1,94 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-rock-5a" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_ROCK_5_RK3588S=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-rock-5a.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_ADC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_PWM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_LIST="rockchip/rk3588s-rock-5a rockchip/rk3588s-rock-5c" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_ADC=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_PWM=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 9bab86d23479..6b952654cb3d 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -141,6 +141,7 @@ List of mainline supported Rockchip boards: - Radxa ROCK 5 ITX (rock-5-itx-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) - Radxa ROCK 5B (rock5b-rk3588) + - Radxa ROCK 5C (rock-5-rk3588s) - Rockchip Toybrick TB-RK3588X (toybrick-rk3588) - Theobroma Systems RK3588-SBC Jaguar (jaguar-rk3588) - Theobroma Systems SOM-RK3588-Q7 - Tiger (tiger-rk3588) diff --git a/include/configs/rock-5-rk3588s.h b/include/configs/rock-5-rk3588s.h new file mode 100644 index 000000000000..8020177d7585 --- /dev/null +++ b/include/configs/rock-5-rk3588s.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd. + */ + +#ifndef __ROCK_5_RK3588S_H +#define __ROCK_5_RK3588S_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3588_common.h> + +#endif /* __ROCK_5_RK3588S_H */
Hi Naoki,
Changes in v3:
- fix compile error
Changes in v2:
- Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd.
+&saradc {
- bootph-pre-ram;
- vdd-microvolts = <1800000>;
+&sdhci {
- cap-mmc-highspeed;
- mmc-hs200-1_8v;
This should be TARGET_ROCK_5C_RK3588S?
- bool "Radxa ROCK 5C RK3588S2 board"
- select BOARD_LATE_INIT
- help
- config TARGET_SIGE7_RK3588 bool "ArmSoM Sige7 RK3588 board" select BOARD_LATE_INIT
Where's the c gone?
+config SYS_BOARD
- default "rock-5-rk3588s"
+config SYS_VENDOR
- default "radxa"
Why are all those files missing the c character?
+#define BOARD_ID 5
- unsigned int low;
- unsigned int high;
- const char *board;
- const char *board_name;
- const char *fdtfile;
0,
50,
"rock-5a-rk3588s",
"Radxa ROCK 5A",
We already have a config and board files for the rock-5a... There should probably something to be done to merge them together or remove this part?
2375,
2425,
"rock-5c-rk3588s",
"Radxa ROCK 5C",
- unsigned int val;
- int i, ret;
- ret = adc_channel_single_shot("adc@fec10000", BOARD_ID, &val);
- debug("adc_channel_single_shot ret %d val %u\n", ret, val);
- if (ret)
return NULL;
- for (i = 0; i < ARRAY_SIZE(board_models); i++) {
- return NULL;
- const struct board_model *model = get_board_model();
- if (model) {
- if (model && !strcmp(name, model->fdtfile))
- return -ENOENT;
And now we default to ROCK 5A DTB... This is all very confusing with this little explained in the commit log.
Cheers, Quentin
Hi Quentin,
Thank you very much for your review!
On 12/13/24 22:11, Quentin Schulz wrote:
Hi Naoki,
Changes in v3:
- fix compile error
Changes in v2:
diff --git a/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi b/arch/arm/dts/ rk3588s-rock-5-u-boot.dtsi new file mode 100644 index 000000000000..be1a2f9ae7bb --- /dev/null +++ b/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
+&sdhci { + cap-mmc-highspeed; + mmc-hs200-1_8v; +}; diff --git a/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi b/arch/arm/dts/ rk3588s-rock-5c-u-boot.dtsi new file mode 100644 index 000000000000..bb1cc9e4a279 --- /dev/null +++ b/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
+#include "rk3588s-rock-5-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach- rockchip/rk3588/Kconfig index b5a0e624a532..e1487ecb0464 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -260,6 +260,12 @@ config TARGET_ROCK_5_ITX_RK3588 Front-panel connectors for audio and case-power, -leds Powered by either 12V, ATX power-supply or PoE +config TARGET_ROCK_5_RK3588S
rock-pi-4-rk3399_defconfig uses CONFIG_TARGET_ROCKPI4_RK3399. I'm doing same thing.
Where's the c gone?
There is board/radxa/rockpi4-rk3399/.
source "board/rockchip/evb_rk3588/Kconfig" source "board/rockchip/toybrick_rk3588/Kconfig" source "board/theobroma-systems/jaguar_rk3588/Kconfig" diff --git a/board/radxa/rock-5-rk3588s/Kconfig b/board/radxa/rock-5- rk3588s/Kconfig new file mode 100644 index 000000000000..86830be1eeca --- /dev/null +++ b/board/radxa/rock-5-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_ROCK_5_RK3588S
+endif diff --git a/board/radxa/rock-5-rk3588s/MAINTAINERS b/board/radxa/ rock-5-rk3588s/MAINTAINERS new file mode 100644 index 000000000000..ead6356131c1 --- /dev/null +++ b/board/radxa/rock-5-rk3588s/MAINTAINERS @@ -0,0 +1,8 @@ +ROCK-5-RK3588S +M: FUKAUMI Naoki naoki@radxa.com +S: Maintained +F: arch/arm/dts/rk3588s-rock-5-u-boot.dtsi +F: arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi +F: board/radxa/rock-5-rk3588s/ +F: configs/rock-5-rk3588s_defconfig +F: include/configs/rock-5-rk3588s.h
Same reason as above.
diff --git a/board/radxa/rock-5-rk3588s/Makefile b/board/radxa/rock-5- rk3588s/Makefile new file mode 100644 index 000000000000..d9be0f42e6b9 --- /dev/null +++ b/board/radxa/rock-5-rk3588s/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+
+obj-y += rock-5-rk3588s.o diff --git a/board/radxa/rock-5-rk3588s/rock-5-rk3588s.c b/board/ radxa/rock-5-rk3588s/rock-5-rk3588s.c new file mode 100644 index 000000000000..a840ca7698d4 --- /dev/null +++ b/board/radxa/rock-5-rk3588s/rock-5-rk3588s.c @@ -0,0 +1,77 @@ +// SPDX-License-Identifier: GPL-2.0+
+#define BOARD_ID 5
I'll drop this part from this patch.
+ return NULL; +}
+ return 0; +}
+ return -ENOENT; +} diff --git a/configs/rock-5-rk3588s_defconfig b/configs/rock-5- rk3588s_defconfig new file mode 100644 index 000000000000..54043264de48 --- /dev/null +++ b/configs/rock-5-rk3588s_defconfig @@ -0,0 +1,94 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-rock-5a" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_ROCK_5_RK3588S=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-rock-5a.dtb"
Same as rock-pi-4-rk3399_defconfig, but I'll change them.
-- FUKAUMI Naoki Radxa Computer (Shenzhen) Co., Ltd.
Cheers, Quentin
Hi Naoki,
On 12/15/24 2:37 AM, FUKAUMI Naoki wrote:
Hi Quentin,
Hi Naoki,
[1] https://eur02.safelinks.protection.outlook.com/? url=https%3A%2F%2Fradxa.com%2Fproducts%2Frock5%2F5c&data=05%7C02%7Cquentin.schulz%40cherry.de%7Cbe7d810ae88f4203af8208dd1ca921c6%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638698234938145886%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=8TcHBC2dV1LzouPSR8%2FICOBVshq9RndgMQS3m3XLwFs%3D&reserved=0
Changes in v3:
- fix compile error
Changes in v2:
config TARGET_ROCKPI4_RK3399 help Support for ROCK Pi 4 board family by Radxa.
Here you say this option is for ROCK 5C only.
While this could be a good idea, anything odd needs to be justified in the commit log so that we can follow your train of thoughts.
This patch series only adds support for the ROCK 5C so nothing hints at this being usable/used for other boards from Radxa. Which boards are you planning to support with this option? If the ROCK 5B/ROCK 5 ITX aren't going to be part of it, why and how do I know which of the ROCK 5 is supported by this option?
This could also be started with a "normal" config option which is named after the board and for the next board support you want to reuse this config option for, you rename it to something more appropriate. In any case, please document the reasons for doing that :)
Cheers, Quentin
Hi Quentin,
On 12/16/24 18:57, Quentin Schulz wrote:
Hi Naoki,
Hi Quentin,
Hi Naoki,
Changes in v3:
- fix compile error
Changes in v2:
arch/arm/dts/rk3588s-rock-5-u-boot.dtsi | 16 ++++ arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi | 6 ++ arch/arm/mach-rockchip/rk3588/Kconfig | 7 ++ board/radxa/rock-5-rk3588s/Kconfig | 12 +++ board/radxa/rock-5-rk3588s/MAINTAINERS | 8 ++ board/radxa/rock-5-rk3588s/Makefile | 3 + board/radxa/rock-5-rk3588s/rock-5-rk3588s.c | 77 +++++++++++++++++ configs/rock-5-rk3588s_defconfig | 94 +++++++++++++++++ ++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/rock-5-rk3588s.h | 15 ++++ 10 files changed, 239 insertions(+) create mode 100644 arch/arm/dts/rk3588s-rock-5-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi create mode 100644 board/radxa/rock-5-rk3588s/Kconfig create mode 100644 board/radxa/rock-5-rk3588s/MAINTAINERS create mode 100644 board/radxa/rock-5-rk3588s/Makefile create mode 100644 board/radxa/rock-5-rk3588s/rock-5-rk3588s.c create mode 100644 configs/rock-5-rk3588s_defconfig create mode 100644 include/configs/rock-5-rk3588s.h
+&sdhci { + cap-mmc-highspeed; + mmc-hs200-1_8v; +}; diff --git a/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi b/arch/arm/ dts/ rk3588s-rock-5c-u-boot.dtsi new file mode 100644 index 000000000000..bb1cc9e4a279 --- /dev/null +++ b/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
Because this is first patch which adds support for ROCK 5C.
It's possible to add support for ROCK 5A (RK3588S).
For RK3588 boards, I have another patch which adds rock-5-rk3588.
Sorry for my poor explanation...
Cheers, Quentin
Hi Naoki,
On 12/16/24 1:39 PM, FUKAUMI Naoki wrote:
Hi Quentin,
Hi Naoki,
Hi Quentin,
Hi Naoki,
Changes in v3:
- fix compile error
Changes in v2:
diff --git a/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi b/arch/arm/ dts/ rk3588s-rock-5-u-boot.dtsi new file mode 100644 index 000000000000..be1a2f9ae7bb --- /dev/null +++ b/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
That's fine, you could say something like:
Support for ROCK 5 board family by Radxa. Currently supports: ROCK 5C
And then we can extend this list whenever someone adds support for a new board of that family, which would make it easy to find with a grep if the board is supported and via which target option.
Since it seems you're planning on supporting ROCK 5A with the same target option and we already support ROCK 5A, maybe start this way instead of adding support for ROCK 5C and then migrate ROCK 5A to that?
i.e. adapt ROCK 5A so that it can be reused for ROCK 5C easily, and then add ROCK 5C using the mechanism you would introduce in the ROCK 5A adaptation commit(s)?
What do you think?
Is the ROCK 5T going to be supported by that common target, defconfig and board file as well? What are your plans :)?
Cheers, Quentin
Hi Quentin,
On 12/16/24 21:47, Quentin Schulz wrote:
Hi Naoki,
Hi Quentin,
Hi Naoki,
Hi Quentin,
Hi Naoki,
Changes in v3:
- fix compile error
Changes in v2:
+#include "rk3588s-rock-5-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/ mach- rockchip/rk3588/Kconfig index b5a0e624a532..e1487ecb0464 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -260,6 +260,12 @@ config TARGET_ROCK_5_ITX_RK3588 Front-panel connectors for audio and case-power, -leds Powered by either 12V, ATX power-supply or PoE +config TARGET_ROCK_5_RK3588S
More accurately, "RK3588S based ROCK 5" for now. I'm not sure both RK3588 and RK3588S based boards can be supported.
What do you think?
I just wanted to add ROCK 5C because dts was added in upstream. But it's okay to do "Adapt ROCK 5A then add ROCK 5C".
I'm thinking to add support for 5B+ and 5T too. But for making single target, it needs "check SoC variant" code in addition to check "Board ID". I guess following code may be used:
https://patchwork.ozlabs.org/project/uboot/patch/20241110005622.1515100-3-jo...
BTW, unfortunately, Board ID (ADC value) for ROCK 5B is not fixed...
Cheers, Quentin
Hi Naoki,
On 12/16/24 2:25 PM, FUKAUMI Naoki wrote:
Hi Quentin,
Hi Naoki,
Hi Quentin,
Hi Naoki,
Hi Quentin,
Hi Naoki,
On 12/11/24 4:39 AM, FUKAUMI Naoki wrote: > Radxa ROCK 5C[1] is a Rockchip RK3588S2 based single board computer. > > [1] https://eur02.safelinks.protection.outlook.com/? > url=https%3A%2F%2Fradxa.com%2Fproducts%2Frock5%2F5c&data=05%7C02%7Cquentin.schulz%40cherry.de%7Cbe7d810ae88f4203af8208dd1ca921c6%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638698234938145886%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=8TcHBC2dV1LzouPSR8%2FICOBVshq9RndgMQS3m3XLwFs%3D&reserved=0 > > Signed-off-by: FUKAUMI Naoki naoki@radxa.com > --- > Changes in v3: > - fix compile error > Changes in v2: > - arch/arm/dts/rk3588s-rock-5-u-boot.dtsi: remove unused node > - include/configs/rock-5-rk3588s.h: fix include order > --- > arch/arm/dts/rk3588s-rock-5-u-boot.dtsi | 16 ++++ > arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi | 6 ++ > arch/arm/mach-rockchip/rk3588/Kconfig | 7 ++ > board/radxa/rock-5-rk3588s/Kconfig | 12 +++ > board/radxa/rock-5-rk3588s/MAINTAINERS | 8 ++ > board/radxa/rock-5-rk3588s/Makefile | 3 + > board/radxa/rock-5-rk3588s/rock-5-rk3588s.c | 77 +++++++++++++++++ > configs/rock-5-rk3588s_defconfig | 94 ++++++++++++++ > + + + ++++ > doc/board/rockchip/rockchip.rst | 1 + > include/configs/rock-5-rk3588s.h | 15 ++++ > 10 files changed, 239 insertions(+) > create mode 100644 arch/arm/dts/rk3588s-rock-5-u-boot.dtsi > create mode 100644 arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi > create mode 100644 board/radxa/rock-5-rk3588s/Kconfig > create mode 100644 board/radxa/rock-5-rk3588s/MAINTAINERS > create mode 100644 board/radxa/rock-5-rk3588s/Makefile > create mode 100644 board/radxa/rock-5-rk3588s/rock-5-rk3588s.c > create mode 100644 configs/rock-5-rk3588s_defconfig > create mode 100644 include/configs/rock-5-rk3588s.h > > diff --git a/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi b/arch/arm/ > dts/ rk3588s-rock-5-u-boot.dtsi > new file mode 100644 > index 000000000000..be1a2f9ae7bb > --- /dev/null > +++ b/arch/arm/dts/rk3588s-rock-5-u-boot.dtsi > @@ -0,0 +1,16 @@ > +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) > +/* > + * Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd. > + */ > + > +#include "rk3588s-u-boot.dtsi" > + > +&saradc { > + bootph-pre-ram; > + vdd-microvolts = <1800000>; > +}; > + > +&sdhci { > + cap-mmc-highspeed; > + mmc-hs200-1_8v; > +}; > diff --git a/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi b/arch/arm/ > dts/ rk3588s-rock-5c-u-boot.dtsi > new file mode 100644 > index 000000000000..bb1cc9e4a279 > --- /dev/null > +++ b/arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi > @@ -0,0 +1,6 @@ > +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) > +/* > + * Copyright (c) 2024 Radxa Computer (Shenzhen) Co., Ltd. > + */ > + > +#include "rk3588s-rock-5-u-boot.dtsi" > diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/ > mach- rockchip/rk3588/Kconfig > index b5a0e624a532..e1487ecb0464 100644 > --- a/arch/arm/mach-rockchip/rk3588/Kconfig > +++ b/arch/arm/mach-rockchip/rk3588/Kconfig > @@ -260,6 +260,12 @@ config TARGET_ROCK_5_ITX_RK3588 > Front-panel connectors for audio and case-power, -leds > Powered by either 12V, ATX power-supply or PoE > +config TARGET_ROCK_5_RK3588S
Sounds good to me.
Are you planning to use TARGET_ROCK_5_RK3588S for 5B+ and 5T too?
https://eur02.safelinks.protection.outlook.com/? url=https%3A%2F%2Fpatchwork.ozlabs.org%2Fproject%2Fuboot%2Fpatch%2F20241110005622.1515100-3-jonas%40kwiboo.se%2F&data=05%7C02%7Cquentin.schulz%40cherry.de%7C204a757d4a3045d900a008dd1dd52129%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638699523428166461%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=CLTAcH08Qzmu00q9KH1PuJuUxnAuFcRKobLhnhFR3nI%3D&reserved=0
or just directly reading the OTP value you're interested in. But yes, that could be an option too. You could also have a target for all RK3588S Radxa boards that you can support with the same code, and another one for RK3588 Radxa boards that can be supported with the same code. You can have common codes in a different directory if you want, we use this for Theobroma boards for example, c.f. https://elixir.bootlin.com/u-boot/v2024.10/source/board/theobroma-systems/co.... Plenty of options :)
Does this include the ROCK 5B+ as well? It seems SARADC_VIN5_EVB_HW_ID is pulled high for that one though?
Cheers, Quentin
Hi Naoki,
Changes in v3:
- fix compile error
Changes in v2:
I have go through the discuss between you and Quentin.
First, please make it clear which boards do you want to support in this config;
Second, I would like you to use rock5/rock5c-rk3588 like all other boards instead of rock-5-rk3588.
Thanks,
- Kever
+&saradc {
- bootph-pre-ram;
+&sdhci {
- mmc-hs200-1_8v;
- help
+config SYS_BOARD
+config SYS_VENDOR
- default "radxa"
+#define BOARD_ID 5
- unsigned int low;
0,
50,
"rock-5a-rk3588s",
"Radxa ROCK 5A",
2375,
2425,
"rock-5c-rk3588s",
"Radxa ROCK 5C",
- unsigned int val;
- int i, ret;
- if (ret)
return NULL;
- return NULL;
- if (model) {
- return -ENOENT;
Hi Kever,
On 1/3/25 18:57, Kever Yang wrote:
Hi Naoki,
Changes in v3:
- fix compile error
Changes in v2:
Thanks.
Radxa ROCK 5C only. Currently updating patch.
All other Radxa ROCK boards (except ROCK 5A and ROCK 5B) use the rock- prefix (e.g. ROCK 5 ITX uses rock-5-itx), so I would like to use rock-5c.
There is a space(" ") between ROCK and 5.
Thanks,
- Kever
+#include "rk3588s-rock-5-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach- rockchip/rk3588/Kconfig index b5a0e624a532..e1487ecb0464 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -260,6 +260,12 @@ config TARGET_ROCK_5_ITX_RK3588 Front-panel connectors for audio and case-power, -leds Powered by either 12V, ATX power-supply or PoE +config TARGET_ROCK_5_RK3588S + bool "Radxa ROCK 5C RK3588S2 board" + select BOARD_LATE_INIT + help + Radxa ROCK 5C is a Rockchip RK3588S2 based single board computer.
config TARGET_SIGE7_RK3588 bool "ArmSoM Sige7 RK3588 board" select BOARD_LATE_INIT @@ -398,6 +404,7 @@ source "board/turing/turing-rk1-rk3588/Kconfig" source "board/radxa/rock5a-rk3588s/Kconfig" source "board/radxa/rock5b-rk3588/Kconfig" source "board/radxa/rock-5-itx-rk3588/Kconfig" +source "board/radxa/rock-5-rk3588s/Kconfig" source "board/rockchip/evb_rk3588/Kconfig" source "board/rockchip/toybrick_rk3588/Kconfig" source "board/theobroma-systems/jaguar_rk3588/Kconfig" diff --git a/board/radxa/rock-5-rk3588s/Kconfig b/board/radxa/rock-5- rk3588s/Kconfig new file mode 100644 index 000000000000..86830be1eeca --- /dev/null +++ b/board/radxa/rock-5-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_ROCK_5_RK3588S
+endif diff --git a/board/radxa/rock-5-rk3588s/MAINTAINERS b/board/radxa/ rock-5-rk3588s/MAINTAINERS new file mode 100644 index 000000000000..ead6356131c1 --- /dev/null +++ b/board/radxa/rock-5-rk3588s/MAINTAINERS @@ -0,0 +1,8 @@ +ROCK-5-RK3588S +M: FUKAUMI Naoki naoki@radxa.com +S: Maintained +F: arch/arm/dts/rk3588s-rock-5-u-boot.dtsi +F: arch/arm/dts/rk3588s-rock-5c-u-boot.dtsi +F: board/radxa/rock-5-rk3588s/ +F: configs/rock-5-rk3588s_defconfig +F: include/configs/rock-5-rk3588s.h diff --git a/board/radxa/rock-5-rk3588s/Makefile b/board/radxa/rock-5- rk3588s/Makefile new file mode 100644 index 000000000000..d9be0f42e6b9 --- /dev/null +++ b/board/radxa/rock-5-rk3588s/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+
+#define BOARD_ID 5
+ return NULL; +}
+ return 0; +}
+ return -ENOENT; +} diff --git a/configs/rock-5-rk3588s_defconfig b/configs/rock-5- rk3588s_defconfig new file mode 100644 index 000000000000..54043264de48 --- /dev/null +++ b/configs/rock-5-rk3588s_defconfig @@ -0,0 +1,94 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-rock-5a" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_ROCK_5_RK3588S=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-rock-5a.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_ADC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_PWM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_LIST="rockchip/rk3588s-rock-5a rockchip/rk3588s-rock-5c" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned- clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_ADC=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_PWM=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_SCSI=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_ROCKCHIP_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_PSCI=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/ rockchip.rst index 9bab86d23479..6b952654cb3d 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -141,6 +141,7 @@ List of mainline supported Rockchip boards: - Radxa ROCK 5 ITX (rock-5-itx-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) - Radxa ROCK 5B (rock5b-rk3588) + - Radxa ROCK 5C (rock-5-rk3588s) - Rockchip Toybrick TB-RK3588X (toybrick-rk3588) - Theobroma Systems RK3588-SBC Jaguar (jaguar-rk3588) - Theobroma Systems SOM-RK3588-Q7 - Tiger (tiger-rk3588) diff --git a/include/configs/rock-5-rk3588s.h b/include/configs/ rock-5-rk3588s.h new file mode 100644 index 000000000000..8020177d7585 --- /dev/null +++ b/include/configs/rock-5-rk3588s.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
FUKAUMI Naoki
Kever Yang
Quentin Schulz
