[PATCH 1/3] ti: am43xx_evm: Switch to DISTRO_BOOT only
Remove the environment support for various legacy boot methods. With this, we will now default to booting any distribution that follows the generic distro boot framework and no longer attempt to boot various legacy (to this SoC) scripts/etc.
Signed-off-by: Tom Rini trini@konsulko.com --- configs/am43xx_evm_defconfig | 2 +- configs/am43xx_evm_qspiboot_defconfig | 2 +- configs/am43xx_evm_rtconly_defconfig | 2 +- configs/am43xx_evm_usbhost_boot_defconfig | 2 +- configs/am43xx_hs_evm_defconfig | 2 +- include/configs/am43xx_evm.h | 63 +++++++---------------- 6 files changed, 23 insertions(+), 50 deletions(-)
diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 6782695689ff..0dedd7812a0d 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_ETH_SUPPORT=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index fb8c78d11f5a..5cf4908330e2 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -13,7 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am437x-sk-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI,QSPI_BOOT" CONFIG_QSPI_BOOT=y -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_MISC_INIT_R is not set diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 7b2cb8e8d991..7287025238f7 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index a8827e667852..fd6a4ce543ae 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -11,7 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_DISTRO_DEFAULTS=y CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 8c9ba774b834..0a5411b4f248 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -21,7 +21,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y -# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_SPL_ETH_SUPPORT=y diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 6df6b49c8008..a9ec1aacf3ce 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -108,59 +108,41 @@ #define DFUARGS #endif
+#define BOOTENV_DEV_NAND(devtypeu, devtypel, instance) \ + "bootcmd_" #devtypel "=" \ + "run nandboot\0" + +#define BOOTENV_DEV_NAME_NAND(devtypeu, devtypel, instance) \ + #devtypel #instance " " + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) \ + func(NAND, nand, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + #ifndef CONFIG_SPL_BUILD #include <environment/ti/dfu.h> -#include <environment/ti/mmc.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ - DEFAULT_MMC_TI_ARGS \ - DEFAULT_FIT_TI_ARGS \ "fdtfile=undefined\0" \ - "bootpart=0:2\0" \ - "bootdir=/boot\0" \ - "bootfile=zImage\0" \ + "finduuid=part uuid mmc 0:2 uuid\0" \ "console=ttyO0,115200n8\0" \ "partitions=" \ "uuid_disk=${uuid_gpt_disk};" \ "name=rootfs,start=2MiB,size=-,uuid=${uuid_gpt_rootfs}\0" \ "optargs=\0" \ - "usbroot=/dev/sda2 rw\0" \ - "usbrootfstype=ext4 rootwait\0" \ - "usbdev=0\0" \ "ramroot=/dev/ram0 rw\0" \ "ramrootfstype=ext2\0" \ - "usbargs=setenv bootargs console=${console} " \ - "${optargs} " \ - "root=${usbroot} " \ - "rootfstype=${usbrootfstype}\0" \ "ramargs=setenv bootargs console=${console} " \ "${optargs} " \ "root=${ramroot} " \ "rootfstype=${ramrootfstype}\0" \ "loadramdisk=load ${devtype} ${devnum} ${rdaddr} ramdisk.gz\0" \ - "usbboot=" \ - "setenv devnum ${usbdev}; " \ - "setenv devtype usb; " \ - "usb start ${usbdev}; " \ - "if usb dev ${usbdev}; then " \ - "if run loadbootenv; then " \ - "echo Loaded environment from ${bootenv};" \ - "run importbootenv;" \ - "fi;" \ - "if test -n $uenvcmd; then " \ - "echo Running uenvcmd ...;" \ - "run uenvcmd;" \ - "fi;" \ - "if run loadimage; then " \ - "run loadfdt; " \ - "echo Booting from usb ${usbdev}...; " \ - "run usbargs;" \ - "bootz ${loadaddr} - ${fdtaddr}; " \ - "fi;" \ - "fi\0" \ - "fi;" \ - "usb stop ${usbdev};\0" \ "findfdt="\ "if test $board_name = AM43EPOS; then " \ "setenv fdtfile am43x-epos-evm.dtb; fi; " \ @@ -177,16 +159,7 @@ NANDARGS \ NETARGS \ DFUARGS \ - -#define CONFIG_BOOTCOMMAND \ - "if test ${boot_fit} -eq 1; then " \ - "run update_to_fit;" \ - "fi;" \ - "run findfdt; " \ - "run envboot;" \ - "run mmcboot;" \ - "run usbboot;" \ - NANDBOOT \ + BOOTENV
#endif
This include file is only used by ti_omap5_common.h. Further, the move is towards using the generic distro boot framework and not this set of macros. Start by moving all of the contents in directly to where they are used.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/ti_omap5_common.h | 229 +++++++++++++++++++++++++++- include/environment/ti/boot.h | 243 ------------------------------ 2 files changed, 228 insertions(+), 244 deletions(-) delete mode 100644 include/environment/ti/boot.h
diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index de0a6af2fdc9..dfe69a821ed8 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -32,6 +32,8 @@
#define CONFIG_PALMAS_POWER
+#include <linux/stringify.h> + #include <asm/arch/cpu.h> #include <asm/arch/omap.h>
@@ -54,10 +56,235 @@ #define DFUARGS #endif
-#include <environment/ti/boot.h> #include <environment/ti/mmc.h> #include <environment/ti/nand.h>
+#ifndef CONSOLEDEV +#define CONSOLEDEV "ttyS2" +#endif + +#ifndef PARTS_DEFAULT +/* + * Default GPT tables for eMMC (Linux and Android). Notes: + * 1. Keep partitions aligned to erase group size (512 KiB) when possible + * 2. Keep partitions in sync with DFU_ALT_INFO_EMMC (see dfu.h) + * 3. Keep 'bootloader' partition (U-Boot proper) start address in sync with + * CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR (see common/spl/Kconfig) + */ +#define PARTS_DEFAULT \ + /* Linux partitions */ \ + "uuid_disk=${uuid_gpt_disk};" \ + "name=bootloader,start=384K,size=1792K,uuid=${uuid_gpt_bootloader};" \ + "name=rootfs,start=2688K,size=-,uuid=${uuid_gpt_rootfs}\0" \ + /* Android partitions */ \ + "partitions_android=" \ + "uuid_disk=${uuid_gpt_disk};" \ + "name=xloader,start=128K,size=256K,uuid=${uuid_gpt_xloader};" \ + "name=bootloader,size=2048K,uuid=${uuid_gpt_bootloader};" \ + "name=uboot-env,start=2432K,size=256K,uuid=${uuid_gpt_reserved};" \ + "name=misc,size=128K,uuid=${uuid_gpt_misc};" \ + "name=boot_a,size=20M,uuid=${uuid_gpt_boot_a};" \ + "name=boot_b,size=20M,uuid=${uuid_gpt_boot_b};" \ + "name=dtbo_a,size=8M,uuid=${uuid_gpt_dtbo_a};" \ + "name=dtbo_b,size=8M,uuid=${uuid_gpt_dtbo_b};" \ + "name=vbmeta_a,size=64K,uuid=${uuid_gpt_vbmeta_a};" \ + "name=vbmeta_b,size=64K,uuid=${uuid_gpt_vbmeta_b};" \ + "name=recovery,size=64M,uuid=${uuid_gpt_recovery};" \ + "name=super,size=2560M,uuid=${uuid_gpt_super};" \ + "name=metadata,size=16M,uuid=${uuid_gpt_metadata};" \ + "name=userdata,size=-,uuid=${uuid_gpt_userdata}" +#endif /* PARTS_DEFAULT */ + +#if defined(CONFIG_CMD_AVB) +#define AVB_VERIFY_CHECK "if run avb_verify; then " \ + "echo AVB verification OK.;" \ + "set bootargs $bootargs $avb_bootargs;" \ + "else " \ + "echo AVB verification failed.;" \ + "exit; fi;" +#define AVB_VERIFY_CMD "avb_verify=avb init 1; avb verify $slot_suffix;\0" +#else +#define AVB_VERIFY_CHECK "" +#define AVB_VERIFY_CMD "" +#endif + +#define CONTROL_PARTITION "misc" + +#if defined(CONFIG_CMD_AB_SELECT) +#define AB_SELECT_SLOT \ + "if part number mmc 1 " CONTROL_PARTITION " control_part_number; " \ + "then " \ + "echo " CONTROL_PARTITION \ + " partition number:${control_part_number};" \ + "ab_select slot_name mmc ${mmcdev}:${control_part_number};" \ + "else " \ + "echo " CONTROL_PARTITION " partition not found;" \ + "exit;" \ + "fi;" \ + "setenv slot_suffix _${slot_name};" +#define AB_SELECT_ARGS \ + "setenv bootargs_ab androidboot.slot_suffix=${slot_suffix}; " \ + "echo A/B cmdline addition: ${bootargs_ab};" \ + "setenv bootargs ${bootargs} ${bootargs_ab};" +#else +#define AB_SELECT_SLOT "" +#define AB_SELECT_ARGS "" +#endif + +/* + * Prepares complete device tree blob for current board (for Android boot). + * + * Boot image or recovery image should be loaded into $loadaddr prior to running + * these commands. The logic of these commnads is next: + * + * 1. Read correct DTB for current SoC/board from boot image in $loadaddr + * to $fdtaddr + * 2. Merge all needed DTBO for current board from 'dtbo' partition into read + * DTB + * 3. User should provide $fdtaddr as 3rd argument to 'bootm' + */ +#define PREPARE_FDT \ + "echo Preparing FDT...; " \ + "if test $board_name = am57xx_evm_reva3; then " \ + "echo " Reading DTBO partition..."; " \ + "part start mmc ${mmcdev} dtbo${slot_suffix} p_dtbo_start; " \ + "part size mmc ${mmcdev} dtbo${slot_suffix} p_dtbo_size; " \ + "mmc read ${dtboaddr} ${p_dtbo_start} ${p_dtbo_size}; " \ + "echo " Reading DTB for AM57x EVM RevA3..."; " \ + "abootimg get dtb --index=0 dtb_start dtb_size; " \ + "cp.b $dtb_start $fdtaddr $dtb_size; " \ + "fdt addr $fdtaddr 0x80000; " \ + "echo " Applying DTBOs for AM57x EVM RevA3..."; " \ + "adtimg addr $dtboaddr; " \ + "adtimg get dt --index=0 dtbo0_addr dtbo0_size; " \ + "fdt apply $dtbo0_addr; " \ + "adtimg get dt --index=1 dtbo1_addr dtbo1_size; " \ + "fdt apply $dtbo1_addr; " \ + "elif test $board_name = beagle_x15_revc; then " \ + "echo " Reading DTB for Beagle X15 RevC..."; " \ + "abootimg get dtb --index=0 dtb_start dtb_size; " \ + "cp.b $dtb_start $fdtaddr $dtb_size; " \ + "fdt addr $fdtaddr 0x80000; " \ + "else " \ + "echo Error: Android boot is not supported for $board_name; " \ + "exit; " \ + "fi; " \ + +#define FASTBOOT_CMD \ + "echo Booting into fastboot ...; " \ + "fastboot " __stringify(CONFIG_FASTBOOT_USB_DEV) "; " + +#define DEFAULT_COMMON_BOOT_TI_ARGS \ + "console=" CONSOLEDEV ",115200n8\0" \ + "fdtfile=undefined\0" \ + "bootpart=0:2\0" \ + "bootdir=/boot\0" \ + "bootfile=zImage\0" \ + "usbtty=cdc_acm\0" \ + "vram=16M\0" \ + AVB_VERIFY_CMD \ + "partitions=" PARTS_DEFAULT "\0" \ + "optargs=\0" \ + "dofastboot=0\0" \ + "emmc_linux_boot=" \ + "echo Trying to boot Linux from eMMC ...; " \ + "setenv mmcdev 1; " \ + "setenv bootpart 1:2; " \ + "setenv mmcroot /dev/mmcblk0p2 rw; " \ + "run mmcboot;\0" \ + "emmc_android_boot=" \ + "setenv mmcdev 1; " \ + "mmc dev $mmcdev; " \ + "mmc rescan; " \ + AB_SELECT_SLOT \ + "if bcb load " __stringify(CONFIG_FASTBOOT_FLASH_MMC_DEV) " " \ + CONTROL_PARTITION "; then " \ + "setenv ardaddr -; " \ + "if bcb test command = bootonce-bootloader; then " \ + "echo Android: Bootloader boot...; " \ + "bcb clear command; bcb store; " \ + FASTBOOT_CMD \ + "exit; " \ + "elif bcb test command = boot-recovery; then " \ + "echo Android: Recovery boot...; " \ + "setenv ardaddr $loadaddr;" \ + "setenv apart recovery; " \ + "else " \ + "echo Android: Normal boot...; " \ + "setenv ardaddr $loadaddr; " \ + "setenv apart boot${slot_suffix}; " \ + "fi; " \ + "else " \ + "echo Warning: BCB is corrupted or does not exist; " \ + "echo Android: Normal boot...; " \ + "fi; " \ + "setenv eval_bootargs setenv bootargs $bootargs; " \ + "run eval_bootargs; " \ + "setenv machid fe6; " \ + AVB_VERIFY_CHECK \ + AB_SELECT_ARGS \ + "if part start mmc $mmcdev $apart boot_start; then " \ + "part size mmc $mmcdev $apart boot_size; " \ + "mmc read $loadaddr $boot_start $boot_size; " \ + PREPARE_FDT \ + "bootm $loadaddr $ardaddr $fdtaddr; " \ + "else " \ + "echo $apart partition not found; " \ + "exit; " \ + "fi;\0" + +#define DEFAULT_FDT_TI_ARGS \ + "findfdt="\ + "if test $board_name = omap5_uevm; then " \ + "setenv fdtfile omap5-uevm.dtb; fi; " \ + "if test $board_name = dra7xx; then " \ + "setenv fdtfile dra7-evm.dtb; fi;" \ + "if test $board_name = dra72x-revc; then " \ + "setenv fdtfile dra72-evm-revc.dtb; fi;" \ + "if test $board_name = dra72x; then " \ + "setenv fdtfile dra72-evm.dtb; fi;" \ + "if test $board_name = dra71x; then " \ + "setenv fdtfile dra71-evm.dtb; fi;" \ + "if test $board_name = dra76x_acd; then " \ + "setenv fdtfile dra76-evm.dtb; fi;" \ + "if test $board_name = beagle_x15; then " \ + "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = beagle_x15_revb1; then " \ + "setenv fdtfile am57xx-beagle-x15-revb1.dtb; fi;" \ + "if test $board_name = beagle_x15_revc; then " \ + "setenv fdtfile am57xx-beagle-x15-revc.dtb; fi;" \ + "if test $board_name = am5729_beagleboneai; then " \ + "setenv fdtfile am5729-beagleboneai.dtb; fi;" \ + "if test $board_name = am572x_idk; then " \ + "setenv fdtfile am572x-idk.dtb; fi;" \ + "if test $board_name = am574x_idk; then " \ + "setenv fdtfile am574x-idk.dtb; fi;" \ + "if test $board_name = am57xx_evm; then " \ + "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = am57xx_evm_reva3; then " \ + "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ + "if test $board_name = am571x_idk; then " \ + "setenv fdtfile am571x-idk.dtb; fi;" \ + "if test $fdtfile = undefined; then " \ + "echo WARNING: Could not determine device tree to use; fi; \0" + +#define CONFIG_BOOTCOMMAND \ + "if test ${dofastboot} -eq 1; then " \ + "echo Boot fastboot requested, resetting dofastboot ...;" \ + "setenv dofastboot 0; saveenv;" \ + FASTBOOT_CMD \ + "fi;" \ + "if test ${boot_fit} -eq 1; then " \ + "run update_to_fit;" \ + "fi;" \ + "run findfdt; " \ + "run envboot; " \ + "run mmcboot;" \ + "run emmc_linux_boot; " \ + "run emmc_android_boot; " \ + "" + + #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ DEFAULT_MMC_TI_ARGS \ diff --git a/include/environment/ti/boot.h b/include/environment/ti/boot.h deleted file mode 100644 index a9d8f28d4679..000000000000 --- a/include/environment/ti/boot.h +++ /dev/null @@ -1,243 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Boot related environment variable definitions on TI boards. - * - * (C) Copyright 2017 Linaro Ltd. - * Sam Protsenko semen.protsenko@linaro.org - */ - -#ifndef __TI_BOOT_H -#define __TI_BOOT_H - -#include <linux/stringify.h> - -#ifndef CONSOLEDEV -#define CONSOLEDEV "ttyS2" -#endif - -#ifndef PARTS_DEFAULT -/* - * Default GPT tables for eMMC (Linux and Android). Notes: - * 1. Keep partitions aligned to erase group size (512 KiB) when possible - * 2. Keep partitions in sync with DFU_ALT_INFO_EMMC (see dfu.h) - * 3. Keep 'bootloader' partition (U-Boot proper) start address in sync with - * CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR (see common/spl/Kconfig) - */ -#define PARTS_DEFAULT \ - /* Linux partitions */ \ - "uuid_disk=${uuid_gpt_disk};" \ - "name=bootloader,start=384K,size=1792K,uuid=${uuid_gpt_bootloader};" \ - "name=rootfs,start=2688K,size=-,uuid=${uuid_gpt_rootfs}\0" \ - /* Android partitions */ \ - "partitions_android=" \ - "uuid_disk=${uuid_gpt_disk};" \ - "name=xloader,start=128K,size=256K,uuid=${uuid_gpt_xloader};" \ - "name=bootloader,size=2048K,uuid=${uuid_gpt_bootloader};" \ - "name=uboot-env,start=2432K,size=256K,uuid=${uuid_gpt_reserved};" \ - "name=misc,size=128K,uuid=${uuid_gpt_misc};" \ - "name=boot_a,size=20M,uuid=${uuid_gpt_boot_a};" \ - "name=boot_b,size=20M,uuid=${uuid_gpt_boot_b};" \ - "name=dtbo_a,size=8M,uuid=${uuid_gpt_dtbo_a};" \ - "name=dtbo_b,size=8M,uuid=${uuid_gpt_dtbo_b};" \ - "name=vbmeta_a,size=64K,uuid=${uuid_gpt_vbmeta_a};" \ - "name=vbmeta_b,size=64K,uuid=${uuid_gpt_vbmeta_b};" \ - "name=recovery,size=64M,uuid=${uuid_gpt_recovery};" \ - "name=super,size=2560M,uuid=${uuid_gpt_super};" \ - "name=metadata,size=16M,uuid=${uuid_gpt_metadata};" \ - "name=userdata,size=-,uuid=${uuid_gpt_userdata}" -#endif /* PARTS_DEFAULT */ - -#if defined(CONFIG_CMD_AVB) -#define AVB_VERIFY_CHECK "if run avb_verify; then " \ - "echo AVB verification OK.;" \ - "set bootargs $bootargs $avb_bootargs;" \ - "else " \ - "echo AVB verification failed.;" \ - "exit; fi;" -#define AVB_VERIFY_CMD "avb_verify=avb init 1; avb verify $slot_suffix;\0" -#else -#define AVB_VERIFY_CHECK "" -#define AVB_VERIFY_CMD "" -#endif - -#define CONTROL_PARTITION "misc" - -#if defined(CONFIG_CMD_AB_SELECT) -#define AB_SELECT_SLOT \ - "if part number mmc 1 " CONTROL_PARTITION " control_part_number; " \ - "then " \ - "echo " CONTROL_PARTITION \ - " partition number:${control_part_number};" \ - "ab_select slot_name mmc ${mmcdev}:${control_part_number};" \ - "else " \ - "echo " CONTROL_PARTITION " partition not found;" \ - "exit;" \ - "fi;" \ - "setenv slot_suffix _${slot_name};" -#define AB_SELECT_ARGS \ - "setenv bootargs_ab androidboot.slot_suffix=${slot_suffix}; " \ - "echo A/B cmdline addition: ${bootargs_ab};" \ - "setenv bootargs ${bootargs} ${bootargs_ab};" -#else -#define AB_SELECT_SLOT "" -#define AB_SELECT_ARGS "" -#endif - -/* - * Prepares complete device tree blob for current board (for Android boot). - * - * Boot image or recovery image should be loaded into $loadaddr prior to running - * these commands. The logic of these commnads is next: - * - * 1. Read correct DTB for current SoC/board from boot image in $loadaddr - * to $fdtaddr - * 2. Merge all needed DTBO for current board from 'dtbo' partition into read - * DTB - * 3. User should provide $fdtaddr as 3rd argument to 'bootm' - */ -#define PREPARE_FDT \ - "echo Preparing FDT...; " \ - "if test $board_name = am57xx_evm_reva3; then " \ - "echo " Reading DTBO partition..."; " \ - "part start mmc ${mmcdev} dtbo${slot_suffix} p_dtbo_start; " \ - "part size mmc ${mmcdev} dtbo${slot_suffix} p_dtbo_size; " \ - "mmc read ${dtboaddr} ${p_dtbo_start} ${p_dtbo_size}; " \ - "echo " Reading DTB for AM57x EVM RevA3..."; " \ - "abootimg get dtb --index=0 dtb_start dtb_size; " \ - "cp.b $dtb_start $fdtaddr $dtb_size; " \ - "fdt addr $fdtaddr 0x80000; " \ - "echo " Applying DTBOs for AM57x EVM RevA3..."; " \ - "adtimg addr $dtboaddr; " \ - "adtimg get dt --index=0 dtbo0_addr dtbo0_size; " \ - "fdt apply $dtbo0_addr; " \ - "adtimg get dt --index=1 dtbo1_addr dtbo1_size; " \ - "fdt apply $dtbo1_addr; " \ - "elif test $board_name = beagle_x15_revc; then " \ - "echo " Reading DTB for Beagle X15 RevC..."; " \ - "abootimg get dtb --index=0 dtb_start dtb_size; " \ - "cp.b $dtb_start $fdtaddr $dtb_size; " \ - "fdt addr $fdtaddr 0x80000; " \ - "else " \ - "echo Error: Android boot is not supported for $board_name; " \ - "exit; " \ - "fi; " \ - -#define FASTBOOT_CMD \ - "echo Booting into fastboot ...; " \ - "fastboot " __stringify(CONFIG_FASTBOOT_USB_DEV) "; " - -#define DEFAULT_COMMON_BOOT_TI_ARGS \ - "console=" CONSOLEDEV ",115200n8\0" \ - "fdtfile=undefined\0" \ - "bootpart=0:2\0" \ - "bootdir=/boot\0" \ - "bootfile=zImage\0" \ - "usbtty=cdc_acm\0" \ - "vram=16M\0" \ - AVB_VERIFY_CMD \ - "partitions=" PARTS_DEFAULT "\0" \ - "optargs=\0" \ - "dofastboot=0\0" \ - "emmc_linux_boot=" \ - "echo Trying to boot Linux from eMMC ...; " \ - "setenv mmcdev 1; " \ - "setenv bootpart 1:2; " \ - "setenv mmcroot /dev/mmcblk0p2 rw; " \ - "run mmcboot;\0" \ - "emmc_android_boot=" \ - "setenv mmcdev 1; " \ - "mmc dev $mmcdev; " \ - "mmc rescan; " \ - AB_SELECT_SLOT \ - "if bcb load " __stringify(CONFIG_FASTBOOT_FLASH_MMC_DEV) " " \ - CONTROL_PARTITION "; then " \ - "setenv ardaddr -; " \ - "if bcb test command = bootonce-bootloader; then " \ - "echo Android: Bootloader boot...; " \ - "bcb clear command; bcb store; " \ - FASTBOOT_CMD \ - "exit; " \ - "elif bcb test command = boot-recovery; then " \ - "echo Android: Recovery boot...; " \ - "setenv ardaddr $loadaddr;" \ - "setenv apart recovery; " \ - "else " \ - "echo Android: Normal boot...; " \ - "setenv ardaddr $loadaddr; " \ - "setenv apart boot${slot_suffix}; " \ - "fi; " \ - "else " \ - "echo Warning: BCB is corrupted or does not exist; " \ - "echo Android: Normal boot...; " \ - "fi; " \ - "setenv eval_bootargs setenv bootargs $bootargs; " \ - "run eval_bootargs; " \ - "setenv machid fe6; " \ - AVB_VERIFY_CHECK \ - AB_SELECT_ARGS \ - "if part start mmc $mmcdev $apart boot_start; then " \ - "part size mmc $mmcdev $apart boot_size; " \ - "mmc read $loadaddr $boot_start $boot_size; " \ - PREPARE_FDT \ - "bootm $loadaddr $ardaddr $fdtaddr; " \ - "else " \ - "echo $apart partition not found; " \ - "exit; " \ - "fi;\0" - -#ifdef CONFIG_OMAP54XX - -#define DEFAULT_FDT_TI_ARGS \ - "findfdt="\ - "if test $board_name = omap5_uevm; then " \ - "setenv fdtfile omap5-uevm.dtb; fi; " \ - "if test $board_name = dra7xx; then " \ - "setenv fdtfile dra7-evm.dtb; fi;" \ - "if test $board_name = dra72x-revc; then " \ - "setenv fdtfile dra72-evm-revc.dtb; fi;" \ - "if test $board_name = dra72x; then " \ - "setenv fdtfile dra72-evm.dtb; fi;" \ - "if test $board_name = dra71x; then " \ - "setenv fdtfile dra71-evm.dtb; fi;" \ - "if test $board_name = dra76x_acd; then " \ - "setenv fdtfile dra76-evm.dtb; fi;" \ - "if test $board_name = beagle_x15; then " \ - "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ - "if test $board_name = beagle_x15_revb1; then " \ - "setenv fdtfile am57xx-beagle-x15-revb1.dtb; fi;" \ - "if test $board_name = beagle_x15_revc; then " \ - "setenv fdtfile am57xx-beagle-x15-revc.dtb; fi;" \ - "if test $board_name = am5729_beagleboneai; then " \ - "setenv fdtfile am5729-beagleboneai.dtb; fi;" \ - "if test $board_name = am572x_idk; then " \ - "setenv fdtfile am572x-idk.dtb; fi;" \ - "if test $board_name = am574x_idk; then " \ - "setenv fdtfile am574x-idk.dtb; fi;" \ - "if test $board_name = am57xx_evm; then " \ - "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ - "if test $board_name = am57xx_evm_reva3; then " \ - "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ - "if test $board_name = am571x_idk; then " \ - "setenv fdtfile am571x-idk.dtb; fi;" \ - "if test $fdtfile = undefined; then " \ - "echo WARNING: Could not determine device tree to use; fi; \0" - -#define CONFIG_BOOTCOMMAND \ - "if test ${dofastboot} -eq 1; then " \ - "echo Boot fastboot requested, resetting dofastboot ...;" \ - "setenv dofastboot 0; saveenv;" \ - FASTBOOT_CMD \ - "fi;" \ - "if test ${boot_fit} -eq 1; then " \ - "run update_to_fit;" \ - "fi;" \ - "run findfdt; " \ - "run envboot; " \ - "run mmcboot;" \ - "run emmc_linux_boot; " \ - "run emmc_android_boot; " \ - "" - -#endif /* CONFIG_OMAP54XX */ - -#endif /* __TI_BOOT_H */
Remove the environment support for various legacy boot methods. With this, we will now default to booting any distribution that follows the generic distro boot framework and no longer attempt to boot various legacy (to this SoC) scripts/etc. Note that if we do not find anything here we will continue to try and Android methods and will start by trying fastboot.
Cc: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/ti_omap5_common.h | 23 +++++++++++------------ 1 file changed, 11 insertions(+), 12 deletions(-)
diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index dfe69a821ed8..055d108ddefe 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -177,21 +177,13 @@ #define DEFAULT_COMMON_BOOT_TI_ARGS \ "console=" CONSOLEDEV ",115200n8\0" \ "fdtfile=undefined\0" \ - "bootpart=0:2\0" \ - "bootdir=/boot\0" \ - "bootfile=zImage\0" \ + "finduuid=part uuid mmc 0:2 uuid\0" \ "usbtty=cdc_acm\0" \ "vram=16M\0" \ AVB_VERIFY_CMD \ "partitions=" PARTS_DEFAULT "\0" \ "optargs=\0" \ "dofastboot=0\0" \ - "emmc_linux_boot=" \ - "echo Trying to boot Linux from eMMC ...; " \ - "setenv mmcdev 1; " \ - "setenv bootpart 1:2; " \ - "setenv mmcroot /dev/mmcblk0p2 rw; " \ - "run mmcboot;\0" \ "emmc_android_boot=" \ "setenv mmcdev 1; " \ "mmc dev $mmcdev; " \ @@ -278,12 +270,18 @@ "run update_to_fit;" \ "fi;" \ "run findfdt; " \ - "run envboot; " \ - "run mmcboot;" \ - "run emmc_linux_boot; " \ + "run finduuid; " \ + "run distro_bootcmd;" \ "run emmc_android_boot; " \ ""
+#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ @@ -294,6 +292,7 @@ DFUARGS \ NETARGS \ NANDARGS \ + BOOTENV
/* * SPL related defines. The Public RAM memory map the ROM defines the
Applied to https://source.denx.de/u-boot/custodians/u-boot-ti.git for-rc, thanks! [1/3] ti: am43xx_evm: Switch to DISTRO_BOOT only https://source.denx.de/u-boot/custodians/u-boot-ti/-/commit/19414cfeb0 [2/3] arm: ti: environment: Move <environment/ti/boot.h> in to <configs/ti_omap5_common.h> https://source.denx.de/u-boot/custodians/u-boot-ti/-/commit/b2df6e066f [3/3] ti: omap5: Switch to generic distro boot for non-Android cases https://source.denx.de/u-boot/custodians/u-boot-ti/-/commit/b29343e471
-- Thanks and Regards, Lokesh
Lokesh Vutla
