[U-Boot] [PATCH v4 0/8] LS1046A SMMU enabling patches
This patch series adds the required devices setup and device tree fixups for SMMU enablement on LS1046A chips. The approach taken tries to mimic the implementation of PAMU LIODN setup on booke powerpc.
First 4 patches contain some fixes and add some missing bits & pieces. Last 3 patches add the actual infrastructure for ICID setup, qman portal and fman ICID configuration.
Changes in v4: - added missing SEC ICID config - updated macro params to match arguments - supplemental comments
Changes in v3: - cleaner QMAN_BAR setup - moved SoC specific bits from generic ICID arch setup to board code
Changes in v2: - drop CONFIG_SYS_ prefix from newly introduced defines in patch [1/7]
Laurentiu Tudor (8): armv8: fsl-layerscape: add missing register blocks base address defines armv8: ls1046a: advertise QMan v3 in configuration misc: fsl_portals: setup QMAN_BAR{E} also on ARM platforms armv8: fsl-layerscape: add missing debug stream ID armv8: ls1046a: initial icid setup support armv8: ls1046a: add icid setup for qman portals armv8: ls1046a: setup fman ports ICIDs and device tree armv8: ls1046a: setup SEC ICIDs and fix up device tree
arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/icid.c | 192 ++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 90 ++++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 3 + .../include/asm/arch-fsl-layerscape/config.h | 1 + .../asm/arch-fsl-layerscape/fsl_icid.h | 114 +++++++++++ .../asm/arch-fsl-layerscape/fsl_portals.h | 24 +++ .../asm/arch-fsl-layerscape/immap_lsch2.h | 18 +- .../asm/arch-fsl-layerscape/stream_id_lsch2.h | 1 + board/freescale/ls1046aqds/ls1046aqds.c | 2 + board/freescale/ls1046ardb/ls1046ardb.c | 3 + drivers/crypto/fsl/jr.c | 2 +- drivers/misc/fsl_portals.c | 45 +++- scripts/config_whitelist.txt | 2 - 14 files changed, 480 insertions(+), 18 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/icid.c create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h
Add defines for the edma and qdma register block base addresses.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 5b4767e0fe..644a16dd30 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -88,8 +88,12 @@
#define LPUART_BASE (CONFIG_SYS_IMMR + 0x01950000)
+#define EDMA_BASE_ADDR (CONFIG_SYS_IMMR + 0x01c00000) + #define AHCI_BASE_ADDR (CONFIG_SYS_IMMR + 0x02200000)
+#define QDMA_BASE_ADDR (CONFIG_SYS_IMMR + 0x07380000) + #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x4000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x4800000000ULL #define CONFIG_SYS_PCIE3_PHYS_ADDR 0x5000000000ULL
The QMan IP block in this SoC is version 3.2 so advertise this in the SoC configuration header.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 23faffd9fc..8a05148136 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -257,6 +257,7 @@
#elif defined(CONFIG_ARCH_LS1046A) #define CONFIG_SYS_FMAN_V3 +#define CONFIG_SYS_FSL_QMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 8 #define CONFIG_SYS_NUM_FM1_10GEC 2
QMAN_BAR{E} register setup was disabled on ARM platforms, however the register does need to be set. Enable the code also on ARMs and fix the CONFIG_SYS_QMAN_MEM_PHYS define to the correct value so that the newly enabled code works.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 3 +-- drivers/misc/fsl_portals.c | 2 -- 2 files changed, 1 insertion(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index 644a16dd30..d22ec70aa5 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -57,8 +57,7 @@ #define CONFIG_SYS_BMAN_SWP_ISDR_REG 0x3E80 #define CONFIG_SYS_QMAN_NUM_PORTALS 10 #define CONFIG_SYS_QMAN_MEM_BASE 0x500000000 -#define CONFIG_SYS_QMAN_MEM_PHYS (0xf00000000ull + \ - CONFIG_SYS_QMAN_MEM_BASE) +#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE #define CONFIG_SYS_QMAN_MEM_SIZE 0x08000000 #define CONFIG_SYS_QMAN_SP_CENA_SIZE 0x10000 #define CONFIG_SYS_QMAN_SP_CINH_SIZE 0x10000 diff --git a/drivers/misc/fsl_portals.c b/drivers/misc/fsl_portals.c index 7c22b8d209..22faf16751 100644 --- a/drivers/misc/fsl_portals.c +++ b/drivers/misc/fsl_portals.c @@ -24,7 +24,6 @@ void setup_qbman_portals(void) CONFIG_SYS_BMAN_SWP_ISDR_REG; void __iomem *qpaddr = (void *)CONFIG_SYS_QMAN_CINH_BASE + CONFIG_SYS_QMAN_SWP_ISDR_REG; -#ifdef CONFIG_PPC struct ccsr_qman *qman = (void *)CONFIG_SYS_FSL_QMAN_ADDR;
/* Set the Qman initiator BAR to match the LAW (for DQRR stashing) */ @@ -32,7 +31,6 @@ void setup_qbman_portals(void) out_be32(&qman->qcsp_bare, (u32)(CONFIG_SYS_QMAN_MEM_PHYS >> 32)); #endif out_be32(&qman->qcsp_bar, (u32)CONFIG_SYS_QMAN_MEM_PHYS); -#endif #ifdef CONFIG_FSL_CORENET int i;
Add a define with a value for the missing debug stream ID.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h index 61c6e533c6..1b02d484d9 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h @@ -50,6 +50,7 @@ #define FSL_QDMA_STREAM_ID 7 #define FSL_EDMA_STREAM_ID 8 #define FSL_ETR_STREAM_ID 9 +#define FSL_DEBUG_STREAM_ID 10
/* PCI - programmed in PEXn_LUT */ #define FSL_PEX_STREAM_ID_START 11
Add infrastructure for ICID setup and device tree fixup on ARM platforms. This include basic ICID setup for several devices.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Makefile | 1 + arch/arm/cpu/armv8/fsl-layerscape/icid.c | 110 ++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 29 +++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 3 + .../asm/arch-fsl-layerscape/fsl_icid.h | 80 +++++++++++++ board/freescale/ls1046aqds/ls1046aqds.c | 2 + board/freescale/ls1046ardb/ls1046ardb.c | 3 + 7 files changed, 228 insertions(+) create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/icid.c create mode 100644 arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 1e9e4680fe..5d6f68aad6 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -37,6 +37,7 @@ endif
ifneq ($(CONFIG_ARCH_LS1046A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1046a_serdes.o +obj-y += icid.o ls1046_ids.o endif
ifneq ($(CONFIG_ARCH_LS1088A),) diff --git a/arch/arm/cpu/armv8/fsl-layerscape/icid.c b/arch/arm/cpu/armv8/fsl-layerscape/icid.c new file mode 100644 index 0000000000..ae3b8daa95 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/icid.c @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ + +#include <common.h> +#include <linux/libfdt.h> +#include <fdt_support.h> + +#include <asm/io.h> +#include <asm/processor.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> + +static void set_icid(struct icid_id_table *tbl, int size) +{ + int i; + + for (i = 0; i < size; i++) + out_be32((u32 *)(tbl[i].reg_addr), tbl[i].reg); +} + +void set_icids(void) +{ + /* setup general icid offsets */ + set_icid(icid_tbl, icid_tbl_sz); +} + +int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids) +{ + int i, ret; + u32 prop[8]; + + /* + * Note: The "iommus" property definition mentions Stream IDs while + * this code handles ICIDs. The current implementation assumes that + * ICIDs and Stream IDs are equal. + */ + for (i = 0; i < num_ids; i++) { + prop[i * 2] = cpu_to_fdt32(smmu_ph); + prop[i * 2 + 1] = cpu_to_fdt32(ids[i]); + } + ret = fdt_setprop(blob, off, "iommus", + prop, sizeof(u32) * num_ids * 2); + if (ret) { + printf("WARNING unable to set iommus: %s\n", fdt_strerror(ret)); + return ret; + } + + return 0; +} + +int fdt_fixup_icid_tbl(void *blob, int smmu_ph, + struct icid_id_table *tbl, int size) +{ + int i, err, off; + + for (i = 0; i < size; i++) { + if (!tbl[i].compat) + continue; + + off = fdt_node_offset_by_compat_reg(blob, + tbl[i].compat, + tbl[i].compat_addr); + if (off > 0) { + err = fdt_set_iommu_prop(blob, off, smmu_ph, + &tbl[i].id, 1); + if (err) + return err; + } else { + printf("WARNING could not find node %s: %s.\n", + tbl[i].compat, fdt_strerror(off)); + } + } + + return 0; +} + +int fdt_get_smmu_phandle(void *blob) +{ + int noff, smmu_ph; + + noff = fdt_node_offset_by_compatible(blob, -1, "arm,mmu-500"); + if (noff < 0) { + printf("WARNING failed to get smmu node: %s\n", + fdt_strerror(noff)); + return noff; + } + + smmu_ph = fdt_get_phandle(blob, noff); + if (!smmu_ph) { + smmu_ph = fdt_create_phandle(blob, noff); + if (!smmu_ph) { + printf("WARNING failed to get smmu phandle\n"); + return -1; + } + } + + return smmu_ph; +} + +void fdt_fixup_icid(void *blob) +{ + int smmu_ph; + + smmu_ph = fdt_get_smmu_phandle(blob); + if (smmu_ph < 0) + return; + + fdt_fixup_icid_tbl(blob, smmu_ph, icid_tbl, icid_tbl_sz); +} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c new file mode 100644 index 0000000000..1c528ab751 --- /dev/null +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -0,0 +1,29 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ + +#include <common.h> +#include <asm/arch-fsl-layerscape/immap_lsch2.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> + +struct icid_id_table icid_tbl[] = { +#ifdef CONFIG_SYS_DPAA_QBMAN + SET_QMAN_ICID(FSL_DPAA1_STREAM_ID_START), + SET_BMAN_ICID(FSL_DPAA1_STREAM_ID_START + 1), +#endif + + SET_SDHC_ICID(FSL_SDHC_STREAM_ID), + + SET_USB_ICID(1, "snps,dwc3", FSL_USB1_STREAM_ID), + SET_USB_ICID(2, "snps,dwc3", FSL_USB2_STREAM_ID), + SET_USB_ICID(3, "snps,dwc3", FSL_USB3_STREAM_ID), + + SET_SATA_ICID("fsl,ls1046a-ahci", FSL_SATA_STREAM_ID), + SET_QDMA_ICID("fsl,ls1046a-qdma", FSL_QDMA_STREAM_ID), + SET_EDMA_ICID(FSL_EDMA_STREAM_ID), + SET_ETR_ICID(FSL_ETR_STREAM_ID), + SET_DEBUG_ICID(FSL_DEBUG_STREAM_ID), +}; + +int icid_tbl_sz = ARRAY_SIZE(icid_tbl); diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index bfd663942a..5c5df5b7ef 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -13,6 +13,7 @@ #include <asm/io.h> #include <asm/global_data.h> #include <asm/arch-fsl-layerscape/config.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> #ifdef CONFIG_LAYERSCAPE_NS_ACCESS #include <fsl_csu.h> #endif @@ -674,6 +675,8 @@ void fsl_lsch2_early_init_f(void) erratum_a009798(); erratum_a008997(); erratum_a009007(); + + set_icids(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h new file mode 100644 index 0000000000..57909392ea --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -0,0 +1,80 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#ifndef _FSL_ICID_H_ +#define _FSL_ICID_H_ + +#include <asm/types.h> +#include <fsl_qbman.h> + +struct icid_id_table { + const char *compat; + u32 id; + u32 reg; + phys_addr_t compat_addr; + phys_addr_t reg_addr; +}; + +u32 get_ppid_icid(int ppid_tbl_idx, int ppid); +int fdt_get_smmu_phandle(void *blob); +int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids); +void set_icids(void); +void fdt_fixup_icid(void *blob); + +#define SET_ICID_ENTRY(name, idA, regA, addr, compataddr) \ + { .compat = name, \ + .id = idA, \ + .reg = regA, \ + .compat_addr = compataddr, \ + .reg_addr = addr, \ + } + +#define SET_SCFG_ICID(compat, streamid, name, compataddr) \ + SET_ICID_ENTRY(compat, streamid, (((streamid) << 24) | (1 << 23)), \ + offsetof(struct ccsr_scfg, name) + CONFIG_SYS_FSL_SCFG_ADDR, \ + compataddr) + +#define SET_USB_ICID(usb_num, compat, streamid) \ + SET_SCFG_ICID(compat, streamid, usb##usb_num##_icid,\ + CONFIG_SYS_XHCI_USB##usb_num##_ADDR) + +#define SET_SATA_ICID(compat, streamid) \ + SET_SCFG_ICID(compat, streamid, sata_icid,\ + AHCI_BASE_ADDR) + +#define SET_SDHC_ICID(streamid) \ + SET_SCFG_ICID("fsl,esdhc", streamid, sdhc_icid,\ + CONFIG_SYS_FSL_ESDHC_ADDR) + +#define SET_QDMA_ICID(compat, streamid) \ + SET_SCFG_ICID(compat, streamid, dma_icid,\ + QDMA_BASE_ADDR) + +#define SET_EDMA_ICID(streamid) \ + SET_SCFG_ICID("fsl,vf610-edma", streamid, edma_icid,\ + EDMA_BASE_ADDR) + +#define SET_ETR_ICID(streamid) \ + SET_SCFG_ICID(NULL, streamid, etr_icid, 0) + +#define SET_DEBUG_ICID(streamid) \ + SET_SCFG_ICID(NULL, streamid, debug_icid, 0) + +#define SET_QMAN_ICID(streamid) \ + SET_ICID_ENTRY("fsl,qman", streamid, streamid, \ + offsetof(struct ccsr_qman, liodnr) + \ + CONFIG_SYS_FSL_QMAN_ADDR, \ + CONFIG_SYS_FSL_QMAN_ADDR) + +#define SET_BMAN_ICID(streamid) \ + SET_ICID_ENTRY("fsl,bman", streamid, streamid, \ + offsetof(struct ccsr_bman, liodnr) + \ + CONFIG_SYS_FSL_BMAN_ADDR, \ + CONFIG_SYS_FSL_BMAN_ADDR) + +extern struct icid_id_table icid_tbl[]; +extern int icid_tbl_sz; + +#endif diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c index b765f07f85..072f8c37a5 100644 --- a/board/freescale/ls1046aqds/ls1046aqds.c +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -309,6 +309,8 @@ int ft_board_setup(void *blob, bd_t *bd) fdt_fixup_board_enet(blob); #endif
+ fdt_fixup_icid(blob); + reg = QIXIS_READ(brdcfg[0]); reg = (reg & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT;
diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c index feb5c2448a..0a73fe859d 100644 --- a/board/freescale/ls1046ardb/ls1046ardb.c +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -11,6 +11,7 @@ #include <asm/arch/fsl_serdes.h> #include <asm/arch/ppa.h> #include <asm/arch/soc.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> #include <hwconfig.h> #include <ahci.h> #include <mmc.h> @@ -174,6 +175,8 @@ int ft_board_setup(void *blob, bd_t *bd) fdt_fixup_fman_ethernet(blob); #endif
+ fdt_fixup_icid(blob); + return 0; } #endif
Add support for ICID setting of qman portals and the required device tree fixups. Also fix an endiness issue in portal setup code.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 16 +++++++ .../asm/arch-fsl-layerscape/fsl_portals.h | 24 +++++++++++ drivers/misc/fsl_portals.c | 43 +++++++++++++++---- 3 files changed, 75 insertions(+), 8 deletions(-) create mode 100644 arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c index 1c528ab751..80e1ceadc0 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -6,6 +6,22 @@ #include <common.h> #include <asm/arch-fsl-layerscape/immap_lsch2.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> +#include <asm/arch-fsl-layerscape/fsl_portals.h> + +#ifdef CONFIG_SYS_DPAA_QBMAN +struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), + SET_QP_INFO(FSL_DPAA1_STREAM_ID_END, 0), +}; +#endif
struct icid_id_table icid_tbl[] = { #ifdef CONFIG_SYS_DPAA_QBMAN diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h new file mode 100644 index 0000000000..1577e935a6 --- /dev/null +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_portals.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 NXP + */ + +#ifndef _FSL_PORTALS_H_ +#define _FSL_PORTALS_H_ + +struct qportal_info { + u16 dicid; /* DQRR ICID */ + u16 ficid; /* frame data ICID */ + u16 icid; + u8 sdest; +}; + +#define SET_QP_INFO(streamid, dest) \ + { .dicid = (streamid), .ficid = (streamid), .icid = (streamid), \ + .sdest = (dest) } + +extern struct qportal_info qp_info[]; +void fdt_portal(void *blob, const char *compat, const char *container, + u64 addr, u32 size); + +#endif diff --git a/drivers/misc/fsl_portals.c b/drivers/misc/fsl_portals.c index 22faf16751..a524510707 100644 --- a/drivers/misc/fsl_portals.c +++ b/drivers/misc/fsl_portals.c @@ -13,6 +13,9 @@ #ifdef CONFIG_PPC #include <asm/fsl_portals.h> #include <asm/fsl_liodn.h> +#else +#include <asm/arch-fsl-layerscape/fsl_portals.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> #endif #include <fsl_qbman.h>
@@ -45,6 +48,22 @@ void setup_qbman_portals(void) /* set frame liodn */ out_be32(&qman->qcsp[i].qcsp_io_cfg, (sdest << 16) | fliodn); } +#else +#ifdef CONFIG_ARM + int i; + + for (i = 0; i < CONFIG_SYS_QMAN_NUM_PORTALS; i++) { + u8 sdest = qp_info[i].sdest; + u16 ficid = qp_info[i].ficid; + u16 dicid = qp_info[i].dicid; + u16 icid = qp_info[i].icid; + + out_be32(&qman->qcsp[i].qcsp_lio_cfg, (icid << 16) | + dicid); + /* set frame icid */ + out_be32(&qman->qcsp[i].qcsp_io_cfg, (sdest << 16) | ficid); + } +#endif #endif
/* Change default state of BMan ISDR portals to all 1s */ @@ -178,6 +197,10 @@ void fdt_fixup_qportals(void *blob) char compat[64]; int compat_len;
+#ifndef CONFIG_PPC + int smmu_ph = fdt_get_smmu_phandle(blob); +#endif + maj = (rev_1 >> 8) & 0xff; min = rev_1 & 0xff; ip_cfg = rev_2 & 0xff; @@ -188,7 +211,6 @@ void fdt_fixup_qportals(void *blob)
off = fdt_node_offset_by_compatible(blob, -1, "fsl,qman-portal"); while (off != -FDT_ERR_NOTFOUND) { -#ifdef CONFIG_PPC #ifdef CONFIG_FSL_CORENET u32 liodns[2]; #endif @@ -198,12 +220,7 @@ void fdt_fixup_qportals(void *blob) if (!ci) goto err;
- i = *ci; -#ifdef CONFIG_SYS_DPAA_FMAN - int j; -#endif - -#endif /* CONFIG_PPC */ + i = fdt32_to_cpu(*ci); err = fdt_setprop(blob, off, "compatible", compat, compat_len); if (err < 0) goto err; @@ -235,7 +252,7 @@ void fdt_fixup_qportals(void *blob) #endif
#ifdef CONFIG_SYS_DPAA_FMAN - for (j = 0; j < CONFIG_SYS_NUM_FMAN; j++) { + for (int j = 0; j < CONFIG_SYS_NUM_FMAN; j++) { char name[] = "fman@0";
name[sizeof(name) - 2] = '0' + j; @@ -251,6 +268,16 @@ void fdt_fixup_qportals(void *blob) if (err < 0) goto err; #endif +#else + if (smmu_ph >= 0) { + u32 icids[3]; + + icids[0] = qp_info[i].icid; + icids[1] = qp_info[i].dicid; + icids[2] = qp_info[i].ficid; + + fdt_set_iommu_prop(blob, off, smmu_ph, icids, 3); + } #endif /* CONFIG_PPC */
err:
Add support for ICID setting of fman ports and the required device tree fixups.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/icid.c | 82 +++++++++++++++++++ .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 30 +++++++ .../asm/arch-fsl-layerscape/fsl_icid.h | 10 +++ 3 files changed, 122 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/icid.c b/arch/arm/cpu/armv8/fsl-layerscape/icid.c index ae3b8daa95..bada5040a8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/icid.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/icid.c @@ -10,6 +10,7 @@ #include <asm/io.h> #include <asm/processor.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> +#include <fsl_fman.h>
static void set_icid(struct icid_id_table *tbl, int size) { @@ -19,10 +20,27 @@ static void set_icid(struct icid_id_table *tbl, int size) out_be32((u32 *)(tbl[i].reg_addr), tbl[i].reg); }
+#ifdef CONFIG_SYS_FMAN_V3 +void set_fman_icids(struct fman_icid_id_table *tbl, int size) +{ + int i; + ccsr_fman_t *fm = (void *)CONFIG_SYS_FSL_FM1_ADDR; + + for (i = 0; i < size; i++) { + out_be32(&fm->fm_bmi_common.fmbm_ppid[tbl[i].port_id - 1], + tbl[i].icid); + } +} +#endif + void set_icids(void) { /* setup general icid offsets */ set_icid(icid_tbl, icid_tbl_sz); + +#ifdef CONFIG_SYS_FMAN_V3 + set_fman_icids(fman_icid_tbl, fman_icid_tbl_sz); +#endif }
int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids) @@ -75,6 +93,66 @@ int fdt_fixup_icid_tbl(void *blob, int smmu_ph, return 0; }
+#ifdef CONFIG_SYS_FMAN_V3 +int get_fman_port_icid(int port_id, struct fman_icid_id_table *tbl, + const int size) +{ + int i; + + for (i = 0; i < size; i++) { + if (tbl[i].port_id == port_id) + return tbl[i].icid; + } + + return -1; +} + +void fdt_fixup_fman_port_icid_by_compat(void *blob, int smmu_ph, + const char *compat) +{ + int noff, len, icid; + const u32 *prop; + + noff = fdt_node_offset_by_compatible(blob, -1, compat); + while (noff > 0) { + prop = fdt_getprop(blob, noff, "cell-index", &len); + if (!prop) { + printf("WARNING missing cell-index for fman port\n"); + continue; + } + if (len != 4) { + printf("WARNING bad cell-index size for fman port\n"); + continue; + } + + icid = get_fman_port_icid(fdt32_to_cpu(*prop), + fman_icid_tbl, fman_icid_tbl_sz); + if (icid < 0) { + printf("WARNING unknown ICID for fman port %d\n", + *prop); + continue; + } + + fdt_set_iommu_prop(blob, noff, smmu_ph, (u32 *)&icid, 1); + + noff = fdt_node_offset_by_compatible(blob, noff, compat); + } +} + +void fdt_fixup_fman_icids(void *blob, int smmu_ph) +{ + static const char * const compats[] = { + "fsl,fman-v3-port-oh", + "fsl,fman-v3-port-rx", + "fsl,fman-v3-port-tx", + }; + int i; + + for (i = 0; i < ARRAY_SIZE(compats); i++) + fdt_fixup_fman_port_icid_by_compat(blob, smmu_ph, compats[i]); +} +#endif + int fdt_get_smmu_phandle(void *blob) { int noff, smmu_ph; @@ -107,4 +185,8 @@ void fdt_fixup_icid(void *blob) return;
fdt_fixup_icid_tbl(blob, smmu_ph, icid_tbl, icid_tbl_sz); + +#ifdef CONFIG_SYS_FMAN_V3 + fdt_fixup_fman_icids(blob, smmu_ph); +#endif } diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c index 80e1ceadc0..30c7d8d28a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -43,3 +43,33 @@ struct icid_id_table icid_tbl[] = { };
int icid_tbl_sz = ARRAY_SIZE(icid_tbl); + +#ifdef CONFIG_SYS_DPAA_FMAN +struct fman_icid_id_table fman_icid_tbl[] = { + /* port id, icid */ + SET_FMAN_ICID_ENTRY(0x02, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x03, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x04, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x05, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x06, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x07, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x08, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x09, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x0a, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x0b, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x0c, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x0d, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x28, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x29, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x2a, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x2b, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x2c, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x2d, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x10, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x11, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x30, FSL_DPAA1_STREAM_ID_END), + SET_FMAN_ICID_ENTRY(0x31, FSL_DPAA1_STREAM_ID_END), +}; + +int fman_icid_tbl_sz = ARRAY_SIZE(fman_icid_tbl); +#endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index 57909392ea..5be50a17ab 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -17,6 +17,11 @@ struct icid_id_table { phys_addr_t reg_addr; };
+struct fman_icid_id_table { + u32 port_id; + u32 icid; +}; + u32 get_ppid_icid(int ppid_tbl_idx, int ppid); int fdt_get_smmu_phandle(void *blob); int fdt_set_iommu_prop(void *blob, int off, int smmu_ph, u32 *ids, int num_ids); @@ -74,7 +79,12 @@ void fdt_fixup_icid(void *blob); CONFIG_SYS_FSL_BMAN_ADDR, \ CONFIG_SYS_FSL_BMAN_ADDR)
+#define SET_FMAN_ICID_ENTRY(_port_id, streamid) \ + { .port_id = (_port_id), .icid = (streamid) } + extern struct icid_id_table icid_tbl[]; +extern struct fman_icid_id_table fman_icid_tbl[]; extern int icid_tbl_sz; +extern int fman_icid_tbl_sz;
#endif
Add support for SEC ICID configuration and apply it for ls1046a. Also add code to make the necessary device tree fixups. Also included in this patch, while adding the new required JR defines sanitize the preexisting ones by dropping the CONFIG_ prefixes.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- .../arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 15 ++++++++++++ .../asm/arch-fsl-layerscape/fsl_icid.h | 24 +++++++++++++++++++ .../asm/arch-fsl-layerscape/immap_lsch2.h | 11 ++++++--- drivers/crypto/fsl/jr.c | 2 +- scripts/config_whitelist.txt | 2 -- 5 files changed, 48 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c index 30c7d8d28a..84f7665929 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -7,6 +7,7 @@ #include <asm/arch-fsl-layerscape/immap_lsch2.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> #include <asm/arch-fsl-layerscape/fsl_portals.h> +#include <fsl_sec.h>
#ifdef CONFIG_SYS_DPAA_QBMAN struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { @@ -40,6 +41,20 @@ struct icid_id_table icid_tbl[] = { SET_EDMA_ICID(FSL_EDMA_STREAM_ID), SET_ETR_ICID(FSL_ETR_STREAM_ID), SET_DEBUG_ICID(FSL_DEBUG_STREAM_ID), +#ifdef CONFIG_FSL_CAAM + SET_SEC_QI_ICID(FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_JR_ICID_ENTRY(0, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_JR_ICID_ENTRY(1, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_JR_ICID_ENTRY(2, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_JR_ICID_ENTRY(3, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_RTIC_ICID_ENTRY(0, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_RTIC_ICID_ENTRY(1, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_RTIC_ICID_ENTRY(2, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_RTIC_ICID_ENTRY(3, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_DECO_ICID_ENTRY(0, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_DECO_ICID_ENTRY(1, FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_DECO_ICID_ENTRY(2, FSL_DPAA1_STREAM_ID_START + 2), +#endif };
int icid_tbl_sz = ARRAY_SIZE(icid_tbl); diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index 5be50a17ab..bd613219b6 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -82,6 +82,30 @@ void fdt_fixup_icid(void *blob); #define SET_FMAN_ICID_ENTRY(_port_id, streamid) \ { .port_id = (_port_id), .icid = (streamid) }
+#define SET_SEC_QI_ICID(streamid) \ + SET_ICID_ENTRY("fsl,sec-v4.0", streamid, \ + (((streamid) << 16) | (streamid)), \ + offsetof(struct ccsr_sec, qilcr_ls) + \ + CONFIG_SYS_FSL_SEC_ADDR, \ + CONFIG_SYS_FSL_SEC_ADDR) + +#define SET_SEC_JR_ICID_ENTRY(jr_num, streamid) \ + SET_ICID_ENTRY("fsl,sec-v4.0-job-ring", streamid, \ + (((streamid) << 16) | (streamid)), \ + offsetof(struct ccsr_sec, jrliodnr[jr_num].ls) + \ + CONFIG_SYS_FSL_SEC_ADDR, \ + FSL_SEC_JR##jr_num##_BASE_ADDR) + +#define SET_SEC_DECO_ICID_ENTRY(deco_num, streamid) \ + SET_ICID_ENTRY(NULL, streamid, (((streamid) << 16) | (streamid)), \ + offsetof(struct ccsr_sec, decoliodnr[deco_num].ls) + \ + CONFIG_SYS_FSL_SEC_ADDR, 0) + +#define SET_SEC_RTIC_ICID_ENTRY(rtic_num, streamid) \ + SET_ICID_ENTRY(NULL, streamid, (((streamid) << 16) | (streamid)), \ + offsetof(struct ccsr_sec, rticliodnr[rtic_num].ls) + \ + CONFIG_SYS_FSL_SEC_ADDR, 0) + extern struct icid_id_table icid_tbl[]; extern struct fman_icid_id_table fman_icid_tbl[]; extern int icid_tbl_sz; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index d22ec70aa5..0dd09a5d81 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -199,11 +199,16 @@ struct sys_info { (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_FM1_DTSEC1_OFFSET)
#define CONFIG_SYS_FSL_SEC_OFFSET 0x700000ull -#define CONFIG_SYS_FSL_JR0_OFFSET 0x710000ull +#define FSL_SEC_JR0_OFFSET 0x710000ull +#define FSL_SEC_JR1_OFFSET 0x720000ull +#define FSL_SEC_JR2_OFFSET 0x730000ull +#define FSL_SEC_JR3_OFFSET 0x740000ull #define CONFIG_SYS_FSL_SEC_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_SEC_OFFSET) -#define CONFIG_SYS_FSL_JR0_ADDR \ - (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_JR0_OFFSET) +#define FSL_SEC_JR0_BASE_ADDR (CONFIG_SYS_IMMR + FSL_SEC_JR0_OFFSET) +#define FSL_SEC_JR1_BASE_ADDR (CONFIG_SYS_IMMR + FSL_SEC_JR1_OFFSET) +#define FSL_SEC_JR2_BASE_ADDR (CONFIG_SYS_IMMR + FSL_SEC_JR2_OFFSET) +#define FSL_SEC_JR3_BASE_ADDR (CONFIG_SYS_IMMR + FSL_SEC_JR3_OFFSET)
/* Device Configuration and Pin Control */ #define DCFG_DCSR_PORCR1 0x0 diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index cc8d3b02a5..f06d7a6635 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -31,7 +31,7 @@ uint32_t sec_offset[CONFIG_SYS_FSL_MAX_NUM_OF_SEC] = {
#define SEC_JR0_ADDR(idx) \ (SEC_ADDR(idx) + \ - (CONFIG_SYS_FSL_JR0_OFFSET - CONFIG_SYS_FSL_SEC_OFFSET)) + (FSL_SEC_JR0_OFFSET - CONFIG_SYS_FSL_SEC_OFFSET))
struct jobring jr0[CONFIG_SYS_FSL_MAX_NUM_OF_SEC];
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 1219dcc3be..c8e4012db0 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2865,8 +2865,6 @@ CONFIG_SYS_FSL_IFC_SIZE1 CONFIG_SYS_FSL_IFC_SIZE1_1 CONFIG_SYS_FSL_IFC_SIZE2 CONFIG_SYS_FSL_ISBC_VER -CONFIG_SYS_FSL_JR0_ADDR -CONFIG_SYS_FSL_JR0_OFFSET CONFIG_SYS_FSL_LS1_CLK_ADDR CONFIG_SYS_FSL_LSCH3_SERDES_ADDR CONFIG_SYS_FSL_MAX_NUM_OF_SEC
The header should be included where it's used, in fsl_icid.h.
- SET_SEC_QI_ICID(FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_JR_ICID_ENTRY(0, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_JR_ICID_ENTRY(1, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_JR_ICID_ENTRY(2, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_JR_ICID_ENTRY(3, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_RTIC_ICID_ENTRY(0, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_RTIC_ICID_ENTRY(1, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_RTIC_ICID_ENTRY(2, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_RTIC_ICID_ENTRY(3, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_DECO_ICID_ENTRY(0, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_DECO_ICID_ENTRY(1, FSL_DPAA1_STREAM_ID_START + 2),
- SET_SEC_DECO_ICID_ENTRY(2, FSL_DPAA1_STREAM_ID_START + 2),
+#endif };
PPA firmware running in secure world is using JR3 (what sec_firmware_used_jobring_offset() returns). I think a different ICID should be allocated for it, considering it has different security requirements.
BTW, is it clear that U-boot is responsible for ICID programming, and not PPA?
- SET_ICID_ENTRY("fsl,sec-v4.0", streamid, \
s/struct ccsr_sec/ccsr_sec_t
- SET_ICID_ENTRY("fsl,sec-v4.0-job-ring", streamid, \
- SET_ICID_ENTRY(NULL, streamid, (((streamid) << 16) | (streamid)), \
This will break all the other users of the driver (ppc, armv8 dpaa2, i.mx) since FSL_SEC_JR0_OFFSET is defined only in immap_lsch2.h.
Regards, Horia
-----Original Message----- From: Horia Geanta Sent: Wednesday, July 25, 2018 11:25 PM To: Laurentiu Tudor laurentiu.tudor@nxp.com; York Sun york.sun@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u-boot@lists.denx.de Cc: Bharat Bhushan bharat.bhushan@nxp.com Subject: Re: [PATCH v4 8/8] armv8: ls1046a: setup SEC ICIDs and fix up device tree
+#endif };
All JR interfaces should be assigned different ICID. While I am not sure DECO and RTIC are separate devices and can be used by software independently from JR interface.
We can still boot without PPA/ATF, so keeping in u-boot is good at least for now. I know about the new ATF architecture and stuff.
FSL_SEC_JR0_OFFSET)
FSL_SEC_JR1_OFFSET)
FSL_SEC_JR2_OFFSET)
FSL_SEC_JR3_OFFSET)
Regards, Horia
Hi Horia,
Thanks for having a look. Comments inline.
Ok.
+#endif };
Ok, will try.
That's how we currently setup the ICIDs / LIODNs (on ppc). Not idea if this will change in the future.
- extern struct icid_id_table icid_tbl[]; extern struct fman_icid_id_table fman_icid_tbl[]; extern int icid_tbl_sz;
Ouch. You are right. I'll think of something.
--- Best Regards, Laurentiu
Bharat Bhushan
Horia Geanta
Laurentiu Tudor
