[U-Boot] [PATCH 6/6] 4xx: Coding style cleanup
Wrap long lines etc.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- include/configs/PLU405.h | 162 ++++++++++++++++++++++----------------------- 1 files changed, 79 insertions(+), 83 deletions(-)
diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 4d302ef..38c495e 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -57,7 +57,7 @@ #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_PHY_ADDR 0 /* PHY address */ #define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */ -#define CONFIG_RESET_PHY_R 1 /* use reset_phy() to disable phy sleep mode */ +#define CONFIG_RESET_PHY_R 1 /* use reset_phy() */
#define CONFIG_PHY_CLK_FREQ EMAC_STACR_CLK_66MHZ /* 66 MHz OPB clock*/
@@ -168,11 +168,10 @@
#define CFG_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */
-/*----------------------------------------------------------------------- +/* * NAND-FLASH stuff - *----------------------------------------------------------------------- */ -#define CFG_NAND_BASE_LIST { CFG_NAND_BASE } +#define CFG_NAND_BASE_LIST {CFG_NAND_BASE} #define NAND_MAX_CHIPS 1 #define CFG_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #define NAND_BIG_DELAY_US 25 @@ -185,9 +184,8 @@ #define CFG_NAND_SKIP_BAD_DOT_I 1 /* ".i" read skips bad blocks */ #define CFG_NAND_QUIET 1
-/*----------------------------------------------------------------------- +/* * PCI stuff - *----------------------------------------------------------------------- */ #define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ #define PCI_HOST_FORCE 1 /* configure as pci host */ @@ -212,55 +210,56 @@ #define CFG_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ #define CFG_PCI_PTM2PCI 0x08000000 /* Host: use this pci address */
-/*----------------------------------------------------------------------- +/* * IDE/ATA stuff - *----------------------------------------------------------------------- */ #undef CONFIG_IDE_8xx_DIRECT /* no pcmcia interface required */ #undef CONFIG_IDE_LED /* no led for ide supported */ #define CONFIG_IDE_RESET 1 /* reset for ide supported */
#define CFG_IDE_MAXBUS 1 /* max. 1 IDE busses */ -#define CFG_IDE_MAXDEVICE (CFG_IDE_MAXBUS*1) /* max. 1 drives per IDE bus */ +/* max. 1 drives per IDE bus */ +#define CFG_IDE_MAXDEVICE (CFG_IDE_MAXBUS*1)
#define CFG_ATA_BASE_ADDR 0xF0100000 #define CFG_ATA_IDE0_OFFSET 0x0000
-#define CFG_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ -#define CFG_ATA_REG_OFFSET 0x0000 /* Offset for normal register accesses */ -#define CFG_ATA_ALT_OFFSET 0x0000 /* Offset for alternate registers */ +#define CFG_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ +#define CFG_ATA_REG_OFFSET 0x0000 /* Offset for normal register access */ +#define CFG_ATA_ALT_OFFSET 0x0000 /* Offset for alternate registers */
/* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- +#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +/* * FLASH organization */ -#define FLASH_BASE0_PRELIM 0xFFC00000 /* FLASH bank #0 */ +#define FLASH_BASE0_PRELIM 0xFFC00000 /* FLASH bank #0 */
-#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ +#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 256 /* max number of sectors on one chip */
-#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 1000 /* Timeout for Flash Write (in ms) */ +#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CFG_FLASH_WRITE_TOUT 1000 /* Timeout for Flash Write (in ms) */
-#define CFG_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ -#define CFG_FLASH_ADDR0 0x5555 /* 1st address for flash config cycles */ -#define CFG_FLASH_ADDR1 0x2AAA /* 2nd address for flash config cycles */ +#define CFG_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ +#define CFG_FLASH_ADDR0 0x5555 /* 1st addr for flash config cycles */ +#define CFG_FLASH_ADDR1 0x2AAA /* 2nd addr for flash config cycles */ /* * The following defines are added for buggy IOP480 byte interface. * All other boards should use the standard values (CPCI405 etc.) */ -#define CFG_FLASH_READ0 0x0000 /* 0 is standard */ -#define CFG_FLASH_READ1 0x0001 /* 1 is standard */ -#define CFG_FLASH_READ2 0x0002 /* 2 is standard */ +#define CFG_FLASH_READ0 0x0000 /* 0 is standard */ +#define CFG_FLASH_READ1 0x0001 /* 1 is standard */ +#define CFG_FLASH_READ2 0x0002 /* 2 is standard */
-#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ +#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector */
-/*----------------------------------------------------------------------- +/* * Start addresses for the final memory configuration * (Set up by the startup code) * Please note that CFG_SDRAM_BASE _must_ start at 0 @@ -268,76 +267,73 @@ #define CFG_SDRAM_BASE 0x00000000 #define CFG_FLASH_BASE 0xFFFA0000 #define CFG_MONITOR_BASE TEXT_BASE -#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 256 kB for Monitor */ -#define CFG_MALLOC_LEN (384 * 1024) /* Reserve 256 kB for malloc() */ - -#if (CFG_MONITOR_BASE < FLASH_BASE0_PRELIM) -# define CFG_RAMBOOT 1 -#else -# undef CFG_RAMBOOT -#endif +#define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384kB for Monitor */ +#define CFG_MALLOC_LEN (384 * 1024) /* Reserve 384kB for malloc() */
-/*----------------------------------------------------------------------- +/* * Environment Variable setup */ #define CFG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CFG_ENV_OFFSET 0x100 /* environment starts at the beginning of the EEPROM */ -#define CFG_ENV_SIZE 0x700 /* 2048 bytes may be used for env vars*/ - /* total size of a CAT24WC16 is 2048 bytes */ +#define CFG_ENV_OFFSET 0x100 /* reseve 0x100 bytes for strapping */ +#define CFG_ENV_SIZE 0x700
-/*----------------------------------------------------------------------- - * I2C EEPROM (CAT24WC16) for environment +/* + * I2C EEPROM (24WC16) for environment */ #define CONFIG_HARD_I2C /* I2c with hardware support */ #define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ #define CFG_I2C_SLAVE 0x7F
-#define CFG_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT24WC08 */ +#define CFG_I2C_EEPROM_ADDR 0x50 /* EEPROM 24WC16 */ #define CFG_EEPROM_WREN 1
-/* CAT24WC08/16... */ +/* 24WC16 */ #define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ +/* mask of address bits that overflow into the "EEPROM chip address" */ #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CFG_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ - /* 16 byte page write mode using*/ - /* last 4 bits of the address */ +#define CFG_EEPROM_PAGE_WRITE_BITS 4 /* The 24WC16 has */ + /* 16 byte page write mode using */ + /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ #define CFG_EEPROM_PAGE_WRITE_ENABLE
-/*----------------------------------------------------------------------- +/* * External Bus Controller (EBC) Setup */ - -#define CAN_BA 0xF0000000 /* CAN Base Address */ -#define DUART0_BA 0xF0000400 /* DUART Base Address */ -#define DUART1_BA 0xF0000408 /* DUART Base Address */ -#define RTC_BA 0xF0000500 /* RTC Base Address */ -#define VGA_BA 0xF1000000 /* Epson VGA Base Address */ -#define CFG_NAND_BASE 0xF4000000 /* NAND FLASH Base Address */ - -/* Memory Bank 0 (Flash Bank 0, NOR-FLASH) initialization */ +#define CAN_BA 0xF0000000 /* CAN Base Address */ +#define DUART0_BA 0xF0000400 /* DUART Base Address */ +#define DUART1_BA 0xF0000408 /* DUART Base Address */ +#define RTC_BA 0xF0000500 /* RTC Base Address */ +#define VGA_BA 0xF1000000 /* Epson VGA Base Address */ +#define CFG_NAND_BASE 0xF4000000 /* NAND FLASH Base Address */ + +/* Memory Bank 0 (Flash Bank 0, NOR-FLASH) initialization */ +/* TWT=16,CSN=1,OEN=1,WBN=1,WBF=1,TH=4,SOR=1 */ #define CFG_EBC_PB0AP 0x92015480 -/*#define CFG_EBC_PB0AP 0x08055880 /XXX* TWT=16,CSN=1,OEN=1,WBN=1,WBF=1,TH=4,SOR=1 */ -#define CFG_EBC_PB0CR 0xFFC5A000 /* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ +/* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ +#define CFG_EBC_PB0CR 0xFFC5A000
-/* Memory Bank 1 (Flash Bank 1, NAND-FLASH) initialization */ +/* Memory Bank 1 (Flash Bank 1, NAND-FLASH) initialization */ #define CFG_EBC_PB1AP 0x92015480 -#define CFG_EBC_PB1CR 0xF4018000 /* BAS=0xF40,BS=1MB,BU=R/W,BW=8bit */ +/* BAS=0xF40,BS=1MB,BU=R/W,BW=8bit */ +#define CFG_EBC_PB1CR 0xF4018000
-/* Memory Bank 2 (8 Bit Peripheral: CAN, UART, RTC) initialization */ -#define CFG_EBC_PB2AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CFG_EBC_PB2CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ +/* Memory Bank 2 (8 Bit Peripheral: CAN, UART, RTC) initialization */ +/* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ +#define CFG_EBC_PB2AP 0x010053C0 +/* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ +#define CFG_EBC_PB2CR 0xF0018000
-/* Memory Bank 3 (16 Bit Peripheral: FPGA internal, dig. IO) initialization */ -#define CFG_EBC_PB3AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CFG_EBC_PB3CR 0xF011A000 /* BAS=0xF01,BS=1MB,BU=R/W,BW=16bit */ +/* Memory Bank 3 (16 Bit Peripheral: FPGA internal, dig. IO) initialization */ +/* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ +#define CFG_EBC_PB3AP 0x010053C0 +/* BAS=0xF01,BS=1MB,BU=R/W,BW=16bit */ +#define CFG_EBC_PB3CR 0xF011A000
-/*----------------------------------------------------------------------- +/* * FPGA stuff */ - -#define CFG_FPGA_BASE_ADDR 0xF0100100 /* FPGA internal Base Address */ +#define CFG_FPGA_BASE_ADDR 0xF0100100 /* FPGA internal Base Address */
/* FPGA internal regs */ #define CFG_FPGA_CTRL 0x000 @@ -347,17 +343,17 @@ #define CFG_FPGA_CTRL_WDI 0x0002 #define CFG_FPGA_CTRL_PS2_RESET 0x0020
-#define CFG_FPGA_SPARTAN2 1 /* using Xilinx Spartan 2 now */ +#define CFG_FPGA_SPARTAN2 1 /* using Xilinx Spartan 2 now */ #define CFG_FPGA_MAX_SIZE 128*1024 /* 128kByte is enough for XC2S50E*/
/* FPGA program pin configuration */ #define CFG_FPGA_PRG 0x04000000 /* FPGA program pin (ppc output) */ -#define CFG_FPGA_CLK 0x02000000 /* FPGA clk pin (ppc output) */ -#define CFG_FPGA_DATA 0x01000000 /* FPGA data pin (ppc output) */ -#define CFG_FPGA_INIT 0x00010000 /* FPGA init pin (ppc input) */ -#define CFG_FPGA_DONE 0x00008000 /* FPGA done pin (ppc input) */ +#define CFG_FPGA_CLK 0x02000000 /* FPGA clk pin (ppc output) */ +#define CFG_FPGA_DATA 0x01000000 /* FPGA data pin (ppc output) */ +#define CFG_FPGA_INIT 0x00010000 /* FPGA init pin (ppc input) */ +#define CFG_FPGA_DONE 0x00008000 /* FPGA done pin (ppc input) */
-/*----------------------------------------------------------------------- +/* * Definitions for initial stack pointer and data area (in data cache) */ /* use on chip memory ( OCM ) for temperary stack until sdram is tested */ @@ -366,14 +362,14 @@ /* On Chip Memory location */ #define CFG_OCM_DATA_ADDR 0xF8000000 #define CFG_OCM_DATA_SIZE 0x1000 -#define CFG_INIT_RAM_ADDR CFG_OCM_DATA_ADDR /* inside of SDRAM */ -#define CFG_INIT_RAM_END CFG_OCM_DATA_SIZE /* End of used area in RAM */ +#define CFG_INIT_RAM_ADDR CFG_OCM_DATA_ADDR /* inside of SDRAM */ +#define CFG_INIT_RAM_END CFG_OCM_DATA_SIZE /* End of used area in RAM */
-#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ +#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ #define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) #define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
-/*----------------------------------------------------------------------- +/* * Definitions for GPIO setup (PPC405EP specific) * * GPIO0[0] - External Bus Controller BLAST output @@ -401,11 +397,11 @@ * * Boot Flags */ -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ +#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ +#define BOOTFLAG_WARM 0x02 /* Software reboot */
/* - * Default speed selection (cpu_plb_opb_ebc) in mhz. + * Default speed selection (cpu_plb_opb_ebc) in MHz. * This value will be set if iic boot eprom is disabled. */ #if 1
Matthias Fuchs
