Dead code CONFIG_ARMADA_39X?
Hello!
I see in more U-Boot files check for ifdef CONFIG_ARMADA_39X but I do not see that CONFIG_ARMADA_39X could be defined in some header or board code.
So does it mean that all code under ifdef CONFIG_ARMADA_39X is dead? Has U-Boot support for Marvell A39X SoC?
If it is really dead code, should not be ifdef CONFIG_ARMADA_39X completely removed?
On 03.03.21 11:21, Pali Rohár wrote:
Hello!
Frankly, I don't remember the history here. Did you look into the git history to see, where this Kconfig option was introduced?
It could very well be the case, that this was introduced "by accident" by including some Marvell code without taking it out. AFAIK, we are not supporting any Armada 39x in mainline right now.
Thanks, Stefan
Hello!
There is no Kconfig option for ARMADA_39X.
Only C source files are checking if CONFIG_ARMADA_39X is defined or not. But there is no code which can define CONFIG_ARMADA_39X, neither header file nor Kconfig.
That is suspicious for me.
So it looks like that somebody introduced code #ifdef CONFIG_ARMADA_39X on more places "by accident".
For example in commit edb470253346f4a882ba9e891c8b102ce388b9cc were added some these ifdefs and commit was authorized by you. So I thought that you would know more...
So if mainline U-Boot does not support Armada 39x, does it make sense to remove all code hidden under CONFIG_ARMADA_39X? Following command could do it:
git ls-tree -r --name-only HEAD | xargs unifdef -m -UCONFIG_ARMADA_39X
Hello!
I agree. Thanks for looking into it.
Autsch. That was in 2015 - sorry my memory does not cover history that long (anymore). ;)
I agree in general. But would it make syncing with Marvell original code more difficult?
Thanks, Stefan
Hello!
Ok :)
I was synchronizing only ddr3 training code for a38x. And during synchronization I already called unifdef with tons of undef options. So adding another one does not make it more difficult.
And about synchronizing other parts of code I have no idea if it happened...
Hello!
Ok :)
The high-speed serdes code comes to my mind. But anyways, please create such a removal patch and let's review it on the list then.
Thanks, Stefan
Config option ARMADA_39X is never set so remove all dead code hidden under ifdef CONFIG_ARMADA_39X blocks.
Also remove useless checks for CONFIG_ARMADA_38X define as this macro is always defined for a38x code path.
Signed-off-by: Pali Rohár pali@kernel.org --- This patch depends on all previous a38x ddr patches. --- arch/arm/mach-mvebu/include/mach/cpu.h | 2 +- .../serdes/a38x/high_speed_env_spec.c | 46 ------------------- arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c | 24 ---------- arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h | 35 -------------- .../ddr/marvell/a38x/ddr3_training_leveling.c | 2 - drivers/ddr/marvell/a38x/mv_ddr_plat.c | 8 ---- drivers/ddr/marvell/a38x/mv_ddr_sys_env_lib.h | 7 --- scripts/config_whitelist.txt | 1 - tools/Makefile | 4 +- 9 files changed, 3 insertions(+), 126 deletions(-)
diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index c3f8ad850651..52473ade7a72 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -164,7 +164,7 @@ int serdes_phy_config(void); int ddr3_init(void);
/* Auto Voltage Scaling */ -#if defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_39X) +#if defined(CONFIG_ARMADA_38X) void mv_avs_init(void); void mv_rtc_config(void); #else diff --git a/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c b/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c index ae2a36110498..3b41c7d49b72 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c +++ b/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c @@ -14,11 +14,6 @@ #include "sys_env_lib.h" #include "ctrl_pex.h"
-#if defined(CONFIG_ARMADA_38X) -#elif defined(CONFIG_ARMADA_39X) -#else -#error "No device is defined" -#endif
/* @@ -79,11 +74,6 @@ u8 selectors_serdes_rev2_map[LAST_SERDES_TYPE][MAX_SERDES_LANES] = { { NA, 0x6, NA, NA, 0x4, NA, NA }, /* USB3_HOST0 */ { NA, NA, NA, 0x5, NA, 0x4, NA }, /* USB3_HOST1 */ { NA, NA, NA, 0x6, 0x5, 0x5, NA }, /* USB3_DEVICE */ -#ifdef CONFIG_ARMADA_39X - { NA, NA, 0x5, NA, 0x8, NA, 0x2 }, /* SGMII3 */ - { NA, NA, NA, 0x8, 0x9, 0x8, 0x4 }, /* XAUI */ - { NA, NA, NA, NA, NA, 0x8, 0x4 }, /* RXAUI */ -#endif { 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, NA } /* DEFAULT_SERDES */ };
@@ -798,11 +788,9 @@ struct op_params serdes_power_down_params[] = { */ u8 hws_ctrl_serdes_rev_get(void) { -#ifdef CONFIG_ARMADA_38X /* for A38x-Z1 */ if (sys_env_device_rev_get() == MV_88F68XX_Z1_ID) return MV_SERDES_REV_1_2; -#endif
/* for A39x-Z1, A38x-A0 */ return MV_SERDES_REV_2_1; @@ -1351,9 +1339,6 @@ enum serdes_seq serdes_type_and_speed_to_speed_seq(enum serdes_type serdes_type, case SGMII0: case SGMII1: case SGMII2: -#ifdef CONFIG_ARMADA_39X - case SGMII3: -#endif if (baud_rate == SERDES_SPEED_1_25_GBPS) seq_id = SGMII_1_25_SPEED_CONFIG_SEQ; else if (baud_rate == SERDES_SPEED_3_125_GBPS) @@ -1362,14 +1347,6 @@ enum serdes_seq serdes_type_and_speed_to_speed_seq(enum serdes_type serdes_type, case QSGMII: seq_id = QSGMII_5_SPEED_CONFIG_SEQ; break; -#ifdef CONFIG_ARMADA_39X - case XAUI: - seq_id = XAUI_3_125_SPEED_CONFIG_SEQ; - break; - case RXAUI: - seq_id = RXAUI_6_25_SPEED_CONFIG_SEQ; - break; -#endif default: return SERDES_LAST_SEQ; } @@ -2054,13 +2031,6 @@ int hws_ref_clock_set(u32 serdes_num, enum serdes_type serdes_type, (serdes_num, PEX_CONFIG_REF_CLOCK_100MHZ_SEQ)); return MV_OK; -#ifdef CONFIG_ARMADA_39X - case REF_CLOCK_40MHZ: - CHECK_STATUS(mv_seq_exec - (serdes_num, - PEX_CONFIG_REF_CLOCK_40MHZ_SEQ)); - return MV_OK; -#endif default: printf ("%s: Error: ref_clock %d for SerDes lane #%d, type %d is not supported\n", @@ -2104,22 +2074,6 @@ int hws_ref_clock_set(u32 serdes_num, enum serdes_type serdes_type, return MV_BAD_PARAM; } break; -#ifdef CONFIG_ARMADA_39X - case SGMII3: - case XAUI: - case RXAUI: - if (ref_clock == REF_CLOCK_25MHZ) { - data1 = POWER_AND_PLL_CTRL_REG_25MHZ_VAL_1; - } else if (ref_clock == REF_CLOCK_40MHZ) { - data1 = POWER_AND_PLL_CTRL_REG_40MHZ_VAL; - } else { - printf - ("hws_ref_clock_set: ref clock is not valid for serdes type %d\n", - serdes_type); - return MV_BAD_PARAM; - } - break; -#endif default: DEBUG_INIT_S("hws_ref_clock_set: not supported serdes type\n"); return MV_BAD_PARAM; diff --git a/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c b/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c index 3c4c7e01a1cd..950680a58167 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c +++ b/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c @@ -12,7 +12,6 @@ #include "seq_exec.h" #include "sys_env_lib.h"
-#ifdef CONFIG_ARMADA_38X enum unit_id sys_env_soc_unit_nums[MAX_UNITS_ID][MAX_DEV_ID_NUM] = { /* 6820 6810 6811 6828 */ /* PEX_UNIT_ID */ { 4, 3, 3, 4}, @@ -24,19 +23,6 @@ enum unit_id sys_env_soc_unit_nums[MAX_UNITS_ID][MAX_DEV_ID_NUM] = { /* XAUI_UNIT_ID */ { 0, 0, 0, 0}, /* RXAUI_UNIT_ID */ { 0, 0, 0, 0} }; -#else /* if (CONFIG_ARMADA_39X) */ -enum unit_id sys_env_soc_unit_nums[MAX_UNITS_ID][MAX_DEV_ID_NUM] = { -/* 6920 6928 */ -/* PEX_UNIT_ID */ { 4, 4}, -/* ETH_GIG_UNIT_ID */ { 3, 4}, -/* USB3H_UNIT_ID */ { 1, 2}, -/* USB3D_UNIT_ID */ { 0, 1}, -/* SATA_UNIT_ID */ { 0, 4}, -/* QSGMII_UNIT_ID */ { 0, 1}, -/* XAUI_UNIT_ID */ { 1, 1}, -/* RXAUI_UNIT_ID */ { 1, 1} -}; -#endif
u32 g_dev_id = -1;
@@ -202,11 +188,7 @@ u16 sys_env_model_get(void) return ctrl_id; default: /* Device ID Default for A38x: 6820 , for A39x: 6920 */ - #ifdef CONFIG_ARMADA_38X default_ctrl_id = MV_6820_DEV_ID; - #else - default_ctrl_id = MV_6920_DEV_ID; - #endif printf("%s: Error retrieving device ID (%x), using default ID = %x\n", __func__, ctrl_id, default_ctrl_id); return default_ctrl_id; @@ -261,9 +243,6 @@ void mv_rtc_config(void) { u32 i, val;
- if (!(IS_ENABLED(CONFIG_ARMADA_38X) || IS_ENABLED(CONFIG_ARMADA_39X))) - return; - /* Activate pipe0 for read/write transaction, and set XBAR client number #1 */ val = 0x1 << DFX_PIPE_SELECT_PIPE0_ACTIVE_OFFS | 0x1 << DFX_PIPE_SELECT_XBAR_CLIENT_SEL_OFFS; @@ -278,9 +257,6 @@ void mv_avs_init(void) { u32 sar_freq;
- if (!(IS_ENABLED(CONFIG_ARMADA_38X) || IS_ENABLED(CONFIG_ARMADA_39X))) - return; - reg_write(AVS_DEBUG_CNTR_REG, AVS_DEBUG_CNTR_DEFAULT_VALUE); reg_write(AVS_DEBUG_CNTR_REG, AVS_DEBUG_CNTR_DEFAULT_VALUE);
diff --git a/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h b/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h index 17cd811331d2..118bf56602a6 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h +++ b/arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h @@ -118,12 +118,8 @@
/* TWSI addresses */ /* starting from A38x A0, i2c address of EEPROM is 0x57 */ -#ifdef CONFIG_ARMADA_39X -#define EEPROM_I2C_ADDR 0x50 -#else #define EEPROM_I2C_ADDR (sys_env_device_rev_get() == \ MV_88F68XX_Z1_ID ? 0x50 : 0x57) -#endif #define RD_GET_MODE_ADDR 0x4c #define DB_GET_MODE_SLM1363_ADDR 0x25 #define DB_GET_MODE_SLM1364_ADDR 0x24 @@ -216,7 +212,6 @@ #define A39X_MV_MARVELL_BOARD_NUM (A39X_MV_MAX_MARVELL_BOARD_ID - \ A39X_MARVELL_BOARD_ID_BASE)
-#ifdef CONFIG_ARMADA_38X #define CUTOMER_BOARD_ID_BASE A38X_CUSTOMER_BOARD_ID_BASE #define CUSTOMER_BOARD_ID0 A38X_CUSTOMER_BOARD_ID0 #define CUSTOMER_BOARD_ID1 A38X_CUSTOMER_BOARD_ID1 @@ -227,18 +222,6 @@ #define MV_MARVELL_BOARD_NUM A38X_MV_MARVELL_BOARD_NUM #define MV_DEFAULT_BOARD_ID DB_68XX_ID #define MV_DEFAULT_DEVICE_ID MV_6811 -#elif defined(CONFIG_ARMADA_39X) -#define CUTOMER_BOARD_ID_BASE A39X_CUSTOMER_BOARD_ID_BASE -#define CUSTOMER_BOARD_ID0 A39X_CUSTOMER_BOARD_ID0 -#define CUSTOMER_BOARD_ID1 A39X_CUSTOMER_BOARD_ID1 -#define MV_MAX_CUSTOMER_BOARD_ID A39X_MV_MAX_CUSTOMER_BOARD_ID -#define MV_CUSTOMER_BOARD_NUM A39X_MV_CUSTOMER_BOARD_NUM -#define MARVELL_BOARD_ID_BASE A39X_MARVELL_BOARD_ID_BASE -#define MV_MAX_MARVELL_BOARD_ID A39X_MV_MAX_MARVELL_BOARD_ID -#define MV_MARVELL_BOARD_NUM A39X_MV_MARVELL_BOARD_NUM -#define MV_DEFAULT_BOARD_ID A39X_DB_69XX_ID -#define MV_DEFAULT_DEVICE_ID MV_6920 -#endif
#define MV_INVALID_BOARD_ID 0xffffffff
@@ -295,11 +278,7 @@ enum { #define MV_6920_INDEX 0 #define MV_6928_INDEX 1
-#ifdef CONFIG_ARMADA_38X #define MAX_DEV_ID_NUM 4 -#else -#define MAX_DEV_ID_NUM 2 -#endif
#define MV_6820_INDEX 0 #define MV_6810_INDEX 1 @@ -340,21 +319,13 @@ enum suspend_wakeup_status { * If suspend to RAM is not supported set '-1' */ #ifdef CONFIG_CUSTOMER_BOARD_SUPPORT -#ifdef CONFIG_ARMADA_38X #define MV_BOARD_WAKEUP_GPIO_INFO { \ {A38X_CUSTOMER_BOARD_ID0, -1 }, \ {A38X_CUSTOMER_BOARD_ID0, -1 }, \ }; -#else -#define MV_BOARD_WAKEUP_GPIO_INFO { \ - {A39X_CUSTOMER_BOARD_ID0, -1 }, \ - {A39X_CUSTOMER_BOARD_ID0, -1 }, \ -}; -#endif /* CONFIG_ARMADA_38X */
#else
-#ifdef CONFIG_ARMADA_38X #define MV_BOARD_WAKEUP_GPIO_INFO { \ {RD_NAS_68XX_ID, -2 }, \ {DB_68XX_ID, -1 }, \ @@ -364,12 +335,6 @@ enum suspend_wakeup_status { {DB_BP_6821_ID, -2 }, \ {DB_AMC_6820_ID, -2 }, \ }; -#else -#define MV_BOARD_WAKEUP_GPIO_INFO { \ - {A39X_RD_69XX_ID, -1 }, \ - {A39X_DB_69XX_ID, -1 }, \ -}; -#endif /* CONFIG_ARMADA_38X */ #endif /* CONFIG_CUSTOMER_BOARD_SUPPORT */
u32 mv_board_tclk_get(void); diff --git a/drivers/ddr/marvell/a38x/ddr3_training_leveling.c b/drivers/ddr/marvell/a38x/ddr3_training_leveling.c index 7f7df6794a95..6523281f2b2e 100644 --- a/drivers/ddr/marvell/a38x/ddr3_training_leveling.c +++ b/drivers/ddr/marvell/a38x/ddr3_training_leveling.c @@ -915,10 +915,8 @@ int ddr3_tip_dynamic_write_leveling(u32 dev_num, int phase_remove) DEBUG_LEVELING(DEBUG_LEVEL_ERROR, ("training done failed\n")); } else { /* check for training pass */ reg_data = data_read[0]; -#if defined(CONFIG_ARMADA_38X) /* JIRA #1498 for 16 bit with ECC */ if (tm->bus_act_mask == 0xb) /* set to data to 0 to skip the check */ reg_data = 0; -#endif if (reg_data != PASS) DEBUG_LEVELING(DEBUG_LEVEL_INFO, ("training result failed\n"));
diff --git a/drivers/ddr/marvell/a38x/mv_ddr_plat.c b/drivers/ddr/marvell/a38x/mv_ddr_plat.c index da0d63d4f7a4..faafc86ea26e 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_plat.c +++ b/drivers/ddr/marvell/a38x/mv_ddr_plat.c @@ -559,11 +559,7 @@ static int ddr3_tip_a38x_get_medium_freq(int dev_num, enum mv_ddr_freq *freq)
static int ddr3_tip_a38x_get_device_info(u8 dev_num, struct ddr3_device_info *info_ptr) { -#if defined(CONFIG_ARMADA_39X) - info_ptr->device_id = 0x6900; -#else info_ptr->device_id = 0x6800; -#endif info_ptr->ck_delay = ck_delay;
return MV_OK; @@ -666,11 +662,7 @@ static int mv_ddr_sw_db_init(u32 dev_num, u32 board_id) ddr3_tip_dev_attr_set(dev_num, MV_ATTR_TIP_REV, MV_TIP_REV_4); ddr3_tip_dev_attr_set(dev_num, MV_ATTR_PHY_EDGE, MV_DDR_PHY_EDGE_POSITIVE); ddr3_tip_dev_attr_set(dev_num, MV_ATTR_OCTET_PER_INTERFACE, DDR_INTERFACE_OCTETS_NUM); -#ifdef CONFIG_ARMADA_39X - ddr3_tip_dev_attr_set(dev_num, MV_ATTR_INTERLEAVE_WA, 1); -#else ddr3_tip_dev_attr_set(dev_num, MV_ATTR_INTERLEAVE_WA, 0); -#endif
ca_delay = 0; delay_enable = 1; diff --git a/drivers/ddr/marvell/a38x/mv_ddr_sys_env_lib.h b/drivers/ddr/marvell/a38x/mv_ddr_sys_env_lib.h index cf5142094d31..10b0d45b35eb 100644 --- a/drivers/ddr/marvell/a38x/mv_ddr_sys_env_lib.h +++ b/drivers/ddr/marvell/a38x/mv_ddr_sys_env_lib.h @@ -79,7 +79,6 @@ enum suspend_wakeup_status { * If suspend to RAM is not supported set '-1' */
-#ifdef CONFIG_ARMADA_38X #define MV_BOARD_WAKEUP_GPIO_INFO { \ {RD_NAS_68XX_ID, -2 }, \ {DB_68XX_ID, -1 }, \ @@ -89,12 +88,6 @@ enum suspend_wakeup_status { {DB_BP_6821_ID, -2 }, \ {DB_AMC_6820_ID, -2 }, \ }; -#else -#define MV_BOARD_WAKEUP_GPIO_INFO { \ - {A39X_RD_69XX_ID, -1 }, \ - {A39X_DB_69XX_ID, -1 }, \ -}; -#endif /* CONFIG_ARMADA_38X */
enum suspend_wakeup_status mv_ddr_sys_env_suspend_wakeup_check(void); u32 mv_ddr_sys_env_get_cs_ena_from_reg(void); diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index c8c87900ce8f..877c33e27d9a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -43,7 +43,6 @@ CONFIG_ARC_MMU_VER CONFIG_ARMADA100 CONFIG_ARMADA100_FEC CONFIG_ARMADA168 -CONFIG_ARMADA_39X CONFIG_ARMV7_SECURE_BASE CONFIG_ARMV7_SECURE_MAX_SIZE CONFIG_ARMV7_SECURE_RESERVE_SIZE diff --git a/tools/Makefile b/tools/Makefile index 2d550432ba5a..62de7e6fe07d 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -150,12 +150,12 @@ ifdef CONFIG_SYS_U_BOOT_OFFS HOSTCFLAGS_kwbimage.o += -DCONFIG_SYS_U_BOOT_OFFS=$(CONFIG_SYS_U_BOOT_OFFS) endif
-ifneq ($(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X),) +ifneq ($(CONFIG_ARMADA_38X),) HOSTCFLAGS_kwbimage.o += -DCONFIG_KWB_SECURE endif
# MXSImage needs LibSSL -ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X)$(CONFIG_FIT_SIGNATURE)$(CONFIG_FIT_CIPHER),) +ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_FIT_SIGNATURE)$(CONFIG_FIT_CIPHER),) HOSTCFLAGS_kwbimage.o += \ $(shell pkg-config --cflags libssl libcrypto 2> /dev/null || echo "") HOSTLDLIBS_mkimage += \
Thanks, Stefan
- case SGMII3:
- case XAUI:
break;
- case RXAUI:
break;
(serdes_num,
return MV_OK;
- case SGMII3:
- case XAUI:
- case RXAUI:
} else {
printf
serdes_type);
break;
u32 g_dev_id = -1;
- #else
return;
return;
- If suspend to RAM is not supported set '-1'
#else
Viele Grüße, Stefan
Applied to u-boot-marvell/master
Thanks, Stefan
- case SGMII3:
- case XAUI:
break;
- case RXAUI:
break;
(serdes_num,
return MV_OK;
- case SGMII3:
- case XAUI:
- case RXAUI:
} else {
printf
serdes_type);
break;
u32 g_dev_id = -1;
- #else
return;
return;
#else
Viele Grüße, Stefan
Pali Rohár
Stefan Roese
