[PATCH v4 0/5] imx93: Conver to OF_UPSTREAM
A few nodes were added to soc and board u-boot.dtsi(lpi2c, usbotg), those nodes could be dropped after upstream linux supports them.
To support OF_UPSTREAM, a few driver changes are included. For TMU, still use U-Boot node, I will prepare a kernel update, then back to U-Boot support.
Mathieu: please help test the boards you maintain when you have time.
Thanks, Peng.
To: Sébastien Szymanski sebastien.szymanski@armadeus.com To: Stefano Babic sbabic@denx.de To: Fabio Estevam festevam@gmail.com To: "NXP i.MX U-Boot Team" uboot-imx@nxp.com To: Mathieu Othacehe m.othacehe@gmail.com Cc: u-boot@lists.denx.de Signed-off-by: Peng Fan peng.fan@nxp.com
Changes in v4: - Convert all i.MX93 boards - Link to v3: https://lore.kernel.org/r/20240328-imx93-of-v3-0-4e7f341ed7ea@nxp.com
Changes in v3: - Update patch 5, to drop the imx8mp-evk changes which are wrongly included - Link to v2: https://lore.kernel.org/r/20240328-imx93-of-v2-0-909f5d37da87@nxp.com
Changes in v2: - Add a new patch to sync clock header to avoid breaking - Drop the Makefile change which change including order - Link to v1: https://lore.kernel.org/r/20240327-imx93-of-v1-0-afab6b31422a@nxp.com
--- Peng Fan (5): gpio: imx_rgpio2p: support one address serial: lpuart: use ipg clk for i.MX7ULP cpu: drop imx9_cpu clk: imx93: fix anatop base imx93: convert to OF_UPSTREAM
arch/arm/dts/Makefile | 5 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 119 ++++ arch/arm/dts/imx93-11x11-evk.dts | 322 --------- arch/arm/dts/imx93-phyboard-segin.dts | 117 --- arch/arm/dts/imx93-phycore-som.dtsi | 126 ---- arch/arm/dts/imx93-pinfunc.h | 623 ---------------- arch/arm/dts/imx93-u-boot.dtsi | 80 +++ arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi | 22 + arch/arm/dts/imx93-var-som-symphony.dts | 323 --------- arch/arm/dts/imx93-var-som.dtsi | 111 --- arch/arm/dts/imx93.dtsi | 906 ------------------------ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93-phyboard-segin_defconfig | 2 +- configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- configs/imx93_var_som_defconfig | 2 +- drivers/clk/imx/clk-imx93.c | 2 +- drivers/cpu/imx9_cpu.c | 224 ------ drivers/gpio/imx_rgpio2p.c | 42 +- drivers/serial/serial_lpuart.c | 9 +- include/dt-bindings/clock/imx93-clock.h | 208 ------ include/dt-bindings/power/fsl,imx93-power.h | 15 - 22 files changed, 273 insertions(+), 2990 deletions(-) --- base-commit: 280f34ba7d68bb50c0b8eaa040322c1f3b37d46e change-id: 20240328-imx93-of-v2-f879efef737d
The i.MX8ULP/93 gpio dt-schema have been updated to only have one address entry, update the driver to support it.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/gpio/imx_rgpio2p.c | 42 ++++++++++++++++++++++++++++++++++++++---- 1 file changed, 38 insertions(+), 4 deletions(-)
diff --git a/drivers/gpio/imx_rgpio2p.c b/drivers/gpio/imx_rgpio2p.c index 175e460aff5..3227a8d5b57 100644 --- a/drivers/gpio/imx_rgpio2p.c +++ b/drivers/gpio/imx_rgpio2p.c @@ -21,6 +21,12 @@ enum imx_rgpio2p_direction {
#define GPIO_PER_BANK 32
+struct imx_rgpio2p_soc_data { + bool have_dual_base; +}; + +#define IMX8ULP_GPIO_BASE_OFF 0x40 + struct imx_rgpio2p_data { struct gpio_regs *regs; }; @@ -165,6 +171,9 @@ static int imx_rgpio2p_probe(struct udevice *dev) static int imx_rgpio2p_bind(struct udevice *dev) { struct imx_rgpio2p_plat *plat = dev_get_plat(dev); + struct imx_rgpio2p_soc_data *data = + (struct imx_rgpio2p_soc_data *)dev_get_driver_data(dev); + bool dual_base = data->have_dual_base; fdt_addr_t addr;
/* @@ -176,9 +185,26 @@ static int imx_rgpio2p_bind(struct udevice *dev) if (plat) return 0;
- addr = devfdt_get_addr_index(dev, 1); - if (addr == FDT_ADDR_T_NONE) - return -EINVAL; + /* + * Handle legacy compatible combinations which used two reg values + * for the i.MX8ULP and i.MX93. + */ + if (device_is_compatible(dev, "fsl,imx7ulp-gpio") && + (device_is_compatible(dev, "fsl,imx93-gpio") || + (device_is_compatible(dev, "fsl,imx8ulp-gpio")))) + dual_base = true; + + if (dual_base) { + addr = devfdt_get_addr_index(dev, 1); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + } else { + addr = devfdt_get_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + addr += IMX8ULP_GPIO_BASE_OFF; + }
/* * TODO: @@ -202,9 +228,17 @@ static int imx_rgpio2p_bind(struct udevice *dev) return 0; }
+static struct imx_rgpio2p_soc_data imx7ulp_data = { + .have_dual_base = true, +}; + +static struct imx_rgpio2p_soc_data imx8ulp_data = { + .have_dual_base = false, +};
static const struct udevice_id imx_rgpio2p_ids[] = { - { .compatible = "fsl,imx7ulp-gpio" }, + { .compatible = "fsl,imx7ulp-gpio", .data = (ulong)&imx7ulp_data }, + { .compatible = "fsl,imx8ulp-gpio", .data = (ulong)&imx8ulp_data }, { } };
To i.MX7ULP compatible lpuart, there is only ipg clk, no per clk. So add a devtype check for i.MX7ULP.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/serial/serial_lpuart.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index ce08a6b4486..653ff99e67b 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -111,11 +111,18 @@ u32 __weak get_lpuart_clk(void) #if CONFIG_IS_ENABLED(CLK) static int get_lpuart_clk_rate(struct udevice *dev, u32 *clk) { + struct lpuart_serial_plat *plat = dev_get_plat(dev); struct clk per_clk; ulong rate; int ret; + char *name;
- ret = clk_get_by_name(dev, "per", &per_clk); + if (plat->devtype == DEV_MX7ULP) + name = "ipg"; + else + name = "per"; + + ret = clk_get_by_name(dev, name, &per_clk); if (ret) { dev_err(dev, "Failed to get per clk: %d\n", ret); return ret;
This was wrongly committed, no user, remove it.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/cpu/imx9_cpu.c | 224 ------------------------------------------------- 1 file changed, 224 deletions(-)
diff --git a/drivers/cpu/imx9_cpu.c b/drivers/cpu/imx9_cpu.c deleted file mode 100644 index 66534fe6d17..00000000000 --- a/drivers/cpu/imx9_cpu.c +++ /dev/null @@ -1,224 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2019 NXP - */ - -#include <common.h> -#include <cpu.h> -#include <dm.h> -#include <thermal.h> -#include <asm/global_data.h> -#include <asm/system.h> -#include <firmware/linux/imx/sci/sci.h> -#include <asm/arch/sys_proto.h> -#include <asm/arch-imx/cpu.h> -#include <asm/armv8/cpu.h> -#include <linux/bitops.h> - -DECLARE_GLOBAL_DATA_PTR; - -struct cpu_imx_plat { - const char *name; - const char *rev; - const char *type; - u32 cpu_rsrc; - u32 cpurev; - u32 freq_mhz; - u32 mpidr; -}; - -const char *get_imx9_type(u32 imxtype) -{ - switch (imxtype) { - case MXC_CPU_IMX93: - return "93"; - default: - return "??"; - } -} - -const char *get_imx9_rev(u32 rev) -{ - switch (rev) { - case CHIP_REV_1_0: - return "1."; - case CHIP_REV_B: - return "B"; - case CHIP_REV_C: - return "C"; - default: - return "?"; - } -} - -static void set_core_data(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - if (device_is_compatible(dev, "arm,cortex-a35")) - plat->name = "A35"; - else - plat->name = "?"; -} - -#if IS_ENABLED(CONFIG_IMX_SCU_THERMAL) -static int cpu_imx_get_temp(struct cpu_imx_plat *plat) -{ - struct udevice *thermal_dev; - int cpu_tmp, ret; - int idx = 1; /* use "cpu-thermal0" device */ - - if (plat->cpu_rsrc == SC_R_A72) - idx = 2; /* use "cpu-thermal1" device */ - - ret = uclass_get_device(UCLASS_THERMAL, idx, &thermal_dev); - if (!ret) { - ret = thermal_get_temp(thermal_dev, &cpu_tmp); - if (ret) - return 0xdeadbeef; - } else { - return 0xdeadbeef; - } - - return cpu_tmp; -} -#else -static int cpu_imx_get_temp(struct cpu_imx_plat *plat) -{ - return 0; -} -#endif - -int cpu_imx_get_desc(const struct udevice *dev, char *buf, int size) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - int ret, temp; - - if (size < 100) - return -ENOSPC; - - ret = snprintf(buf, size, "NXP i.MX8%s Rev%s %s at %u MHz", - plat->type, plat->rev, plat->name, plat->freq_mhz); - - if (IS_ENABLED(CONFIG_IMX_SCU_THERMAL)) { - temp = cpu_imx_get_temp(plat); - buf = buf + ret; - size = size - ret; - if (temp != 0xdeadbeef) - ret = snprintf(buf, size, " at %dC", temp); - else - ret = snprintf(buf, size, " - invalid sensor data"); - } - - snprintf(buf + ret, size - ret, "\n"); - - return 0; -} - -static int cpu_imx_get_info(const struct udevice *dev, struct cpu_info *info) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - info->cpu_freq = plat->freq_mhz * 1000; - info->features = BIT(CPU_FEAT_L1_CACHE) | BIT(CPU_FEAT_MMU); - return 0; -} - -static int cpu_imx_get_count(const struct udevice *dev) -{ - ofnode node; - int num = 0; - - ofnode_for_each_subnode(node, dev_ofnode(dev->parent)) { - const char *device_type; - - if (!ofnode_is_enabled(node)) - continue; - - device_type = ofnode_read_string(node, "device_type"); - if (!device_type) - continue; - - if (!strcmp(device_type, "cpu")) - num++; - } - - return num; -} - -static int cpu_imx_get_vendor(const struct udevice *dev, char *buf, int size) -{ - snprintf(buf, size, "NXP"); - return 0; -} - -static int cpu_imx_is_current(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - - if (plat->mpidr == (read_mpidr() & 0xffff)) - return 1; - - return 0; -} - -static const struct cpu_ops cpu_imx9_ops = { - .get_desc = cpu_imx_get_desc, - .get_info = cpu_imx_get_info, - .get_count = cpu_imx_get_count, - .get_vendor = cpu_imx_get_vendor, - .is_current = cpu_imx_is_current, -}; - -static const struct udevice_id cpu_imx9_ids[] = { - { .compatible = "arm,cortex-a35" }, - { .compatible = "arm,cortex-a53" }, - { .compatible = "arm,cortex-a72" }, - { } -}; - -static ulong imx9_get_cpu_rate(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - ulong rate; - int ret; - - ret = sc_pm_get_clock_rate(-1, plat->cpu_rsrc, SC_PM_CLK_CPU, - (sc_pm_clock_rate_t *)&rate); - if (ret) { - printf("Could not read CPU frequency: %d\n", ret); - return 0; - } - - return rate; -} - -static int imx9_cpu_probe(struct udevice *dev) -{ - struct cpu_imx_plat *plat = dev_get_plat(dev); - u32 cpurev; - - set_core_data(dev); - cpurev = get_cpu_rev(); - plat->cpurev = cpurev; - plat->rev = get_imx9_rev(cpurev & 0xFFF); - plat->type = get_imx9_type((cpurev & 0xFF000) >> 12); - plat->freq_mhz = imx9_get_cpu_rate(dev) / 1000000; - plat->mpidr = dev_read_addr(dev); - if (plat->mpidr == FDT_ADDR_T_NONE) { - printf("%s: Failed to get CPU reg property\n", __func__); - return -EINVAL; - } - - return 0; -} - -U_BOOT_DRIVER(cpu_imx9_drv) = { - .name = "imx9x_cpu", - .id = UCLASS_CPU, - .of_match = cpu_imx9_ids, - .ops = &cpu_imx9_ops, - .probe = imx9_cpu_probe, - .plat_auto = sizeof(struct cpu_imx_plat), - .flags = DM_FLAG_PRE_RELOC, -};
The PLL clk needs use anatop base, otherwise wrong PLL address will be used.
Fixes: 9c153e46661b ("clk: imx: add i.MX93 CCF driver") Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/clk/imx/clk-imx93.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/imx/clk-imx93.c b/drivers/clk/imx/clk-imx93.c index ce10d795316..f0cb797d975 100644 --- a/drivers/clk/imx/clk-imx93.c +++ b/drivers/clk/imx/clk-imx93.c @@ -289,7 +289,7 @@ static int imx93_clk_probe(struct udevice *dev) clk_dm(IMX93_CLK_SYS_PLL_PFD2_DIV2, imx_clk_fixed_factor("sys_pll_pfd2_div2", "sys_pll_pfd2", 1, 2));
- base = (void *)ANATOP_BASE_ADDR; + anatop_base = (void *)ANATOP_BASE_ADDR;
clk_dm(IMX93_CLK_ARM_PLL, imx_clk_fracn_gppll_integer("arm_pll", "clock-osc-24m",
Convert all i.MX93 boards to OF_UPSTREAM.
Add lpi2c2 nodes for imx93-11x11-evk-u-boot.dtsi. Add usbotg1 nodes in imx93-u-boot.dtsi and board u-boot.dtsi. The nodes could be removed after upstream linux supports them.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 5 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 119 ++++ arch/arm/dts/imx93-11x11-evk.dts | 322 --------- arch/arm/dts/imx93-phyboard-segin.dts | 117 --- arch/arm/dts/imx93-phycore-som.dtsi | 126 ---- arch/arm/dts/imx93-pinfunc.h | 623 ---------------- arch/arm/dts/imx93-u-boot.dtsi | 80 +++ arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi | 22 + arch/arm/dts/imx93-var-som-symphony.dts | 323 --------- arch/arm/dts/imx93-var-som.dtsi | 111 --- arch/arm/dts/imx93.dtsi | 906 ------------------------ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93-phyboard-segin_defconfig | 2 +- configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- configs/imx93_var_som_defconfig | 2 +- include/dt-bindings/clock/imx93-clock.h | 208 ------ include/dt-bindings/power/fsl,imx93-power.h | 15 - 18 files changed, 226 insertions(+), 2760 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d85a33055c9..75d9ee06bbf 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1114,11 +1114,6 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-kontron-pitx-imx8m.dtb \ imx8mq-librem5-r4.dtb
-dtb-$(CONFIG_ARCH_IMX9) += \ - imx93-11x11-evk.dtb \ - imx93-var-som-symphony.dtb \ - imx93-phyboard-segin.dtb - dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb \ imxrt1170-evk.dtb \ diff --git a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi index a99ba99bfb4..4a834ded44c 100644 --- a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi +++ b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi @@ -26,6 +26,112 @@ bootph-pre-ram; };
+/* The node should be removed after upstream supports it */ +&lpi2c2 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <400000>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pinctrl_lpi2c2>; + pinctrl-1 = <&pinctrl_lpi2c2>; + status = "okay"; + + pmic@25 { + compatible = "nxp,pca9451a"; + reg = <0x25>; + interrupt-parent = <&pcal6524>; + interrupts = <11 IRQ_TYPE_LEVEL_LOW>; + + regulators { + buck1: BUCK1 { + regulator-name = "BUCK1"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <2237500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck2: BUCK2 { + regulator-name = "BUCK2"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck4: BUCK4{ + regulator-name = "BUCK4"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5: BUCK5{ + regulator-name = "BUCK5"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6: BUCK6 { + regulator-name = "BUCK6"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1: LDO1 { + regulator-name = "LDO1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4: LDO4 { + regulator-name = "LDO4"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5: LDO5 { + regulator-name = "LDO5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + pcal6524: gpio@22 { + compatible = "nxp,pcal6524"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcal6524>; + reg = <0x22>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupt-parent = <&gpio3>; + interrupts = <27 IRQ_TYPE_LEVEL_LOW>; + }; + + adp5585gpio: gpio@34 { + compatible = "adp5585"; + reg = <0x34>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + &aips1 { bootph-pre-ram; bootph-all; @@ -44,6 +150,19 @@ &iomuxc { bootph-pre-ram; bootph-some-ram; + + pinctrl_lpi2c2: lpi2c2grp { + fsl,pins = < + MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e + MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e + >; + }; + + pinctrl_pcal6524: pcal6524grp { + fsl,pins = < + MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e + >; + }; };
®_usdhc2_vmmc { diff --git a/arch/arm/dts/imx93-11x11-evk.dts b/arch/arm/dts/imx93-11x11-evk.dts deleted file mode 100644 index 4322cc3e11b..00000000000 --- a/arch/arm/dts/imx93-11x11-evk.dts +++ /dev/null @@ -1,322 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 NXP - */ - -/dts-v1/; - -#include "imx93.dtsi" - -/ { - model = "NXP i.MX93 11X11 EVK board"; - compatible = "fsl,imx93-11x11-evk", "fsl,imx93"; - - chosen { - stdout-path = &lpuart1; - }; - - reg_vref_1v8: regulator-adc-vref { - compatible = "regulator-fixed"; - regulator-name = "vref_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio3 7 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; -}; - -&adc1 { - vref-supply = <®_vref_1v8>; - status = "okay"; -}; - -&mu1 { - status = "okay"; -}; - -&mu2 { - status = "okay"; -}; - -&eqos { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_eqos>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy1>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <5000000>; - - ethphy1: ethernet-phy@1 { - reg = <1>; - eee-broken-1000t; - }; - }; -}; - -&fec { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy2>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <5000000>; - - ethphy2: ethernet-phy@2 { - reg = <2>; - eee-broken-1000t; - }; - }; -}; - -&lpi2c2 { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <400000>; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pinctrl_lpi2c2>; - pinctrl-1 = <&pinctrl_lpi2c2>; - status = "okay"; - - pmic@25 { - compatible = "nxp,pca9451a"; - reg = <0x25>; - interrupt-parent = <&pcal6524>; - interrupts = <11 IRQ_TYPE_LEVEL_LOW>; - - regulators { - buck1: BUCK1 { - regulator-name = "BUCK1"; - regulator-min-microvolt = <650000>; - regulator-max-microvolt = <2237500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck2: BUCK2 { - regulator-name = "BUCK2"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <2187500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck4: BUCK4{ - regulator-name = "BUCK4"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5: BUCK5{ - regulator-name = "BUCK5"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6: BUCK6 { - regulator-name = "BUCK6"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1: LDO1 { - regulator-name = "LDO1"; - regulator-min-microvolt = <1600000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4: LDO4 { - regulator-name = "LDO4"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo5: LDO5 { - regulator-name = "LDO5"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; - - pcal6524: gpio@22 { - compatible = "nxp,pcal6524"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcal6524>; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - interrupt-parent = <&gpio3>; - interrupts = <27 IRQ_TYPE_LEVEL_LOW>; - }; - - adp5585gpio: gpio@34 { - compatible = "adp5585"; - reg = <0x34>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&lpuart1 { /* console */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -&usdhc1 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc1>; - pinctrl-1 = <&pinctrl_usdhc1>; - pinctrl-2 = <&pinctrl_usdhc1>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio3 00 GPIO_ACTIVE_LOW>; - vmmc-supply = <®_usdhc2_vmmc>; - bus-width = <4>; - status = "okay"; - no-sdio; - no-mmc; -}; - -&iomuxc { - pinctrl_lpi2c2: lpi2c2grp { - fsl,pins = < - MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e - MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e - >; - }; - - pinctrl_pcal6524: pcal6524grp { - fsl,pins = < - MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e - >; - }; - - pinctrl_eqos: eqosgrp { - fsl,pins = < - MX93_PAD_ENET1_MDC__ENET_QOS_MDC 0x57e - MX93_PAD_ENET1_MDIO__ENET_QOS_MDIO 0x57e - MX93_PAD_ENET1_RD0__ENET_QOS_RGMII_RD0 0x57e - MX93_PAD_ENET1_RD1__ENET_QOS_RGMII_RD1 0x57e - MX93_PAD_ENET1_RD2__ENET_QOS_RGMII_RD2 0x57e - MX93_PAD_ENET1_RD3__ENET_QOS_RGMII_RD3 0x57e - MX93_PAD_ENET1_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x5fe - MX93_PAD_ENET1_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x57e - MX93_PAD_ENET1_TD0__ENET_QOS_RGMII_TD0 0x57e - MX93_PAD_ENET1_TD1__ENET_QOS_RGMII_TD1 0x57e - MX93_PAD_ENET1_TD2__ENET_QOS_RGMII_TD2 0x57e - MX93_PAD_ENET1_TD3__ENET_QOS_RGMII_TD3 0x57e - MX93_PAD_ENET1_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x5fe - MX93_PAD_ENET1_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_fec: fecgrp { - fsl,pins = < - MX93_PAD_ENET2_MDC__ENET1_MDC 0x57e - MX93_PAD_ENET2_MDIO__ENET1_MDIO 0x57e - MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x57e - MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x57e - MX93_PAD_ENET2_RD2__ENET1_RGMII_RD2 0x57e - MX93_PAD_ENET2_RD3__ENET1_RGMII_RD3 0x57e - MX93_PAD_ENET2_RXC__ENET1_RGMII_RXC 0x5fe - MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x57e - MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x57e - MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x57e - MX93_PAD_ENET2_TD2__ENET1_RGMII_TD2 0x57e - MX93_PAD_ENET2_TD3__ENET1_RGMII_TD3 0x57e - MX93_PAD_ENET2_TXC__ENET1_RGMII_TXC 0x5fe - MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX93_PAD_UART1_RXD__LPUART1_RX 0x31e - MX93_PAD_UART1_TXD__LPUART1_TX 0x31e - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX93_PAD_SD1_CLK__USDHC1_CLK 0x15fe - MX93_PAD_SD1_CMD__USDHC1_CMD 0x13fe - MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x13fe - MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x13fe - MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x13fe - MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x13fe - MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x13fe - MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x13fe - MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x13fe - MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x13fe - MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x15fe - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { - fsl,pins = < - MX93_PAD_SD2_RESET_B__GPIO3_IO07 0x31e - >; - }; - - pinctrl_usdhc2_gpio: usdhc2gpiogrp { - fsl,pins = < - MX93_PAD_SD2_CD_B__GPIO3_IO00 0x31e - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX93_PAD_SD2_CLK__USDHC2_CLK 0x15fe - MX93_PAD_SD2_CMD__USDHC2_CMD 0x13fe - MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x13fe - MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x13fe - MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x13fe - MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x13fe - MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e - >; - }; -}; diff --git a/arch/arm/dts/imx93-phyboard-segin.dts b/arch/arm/dts/imx93-phyboard-segin.dts deleted file mode 100644 index 85fb188b057..00000000000 --- a/arch/arm/dts/imx93-phyboard-segin.dts +++ /dev/null @@ -1,117 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2023 PHYTEC Messtechnik GmbH - * Author: Wadim Egorov w.egorov@phytec.de, Christoph Stoidner c.stoidner@phytec.de - * Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com - * - * Product homepage: - * phyBOARD-Segin carrier board is reused for the i.MX93 design. - * https://www.phytec.eu/en/produkte/single-board-computer/phyboard-segin-imx6u... - */ -/dts-v1/; - -#include "imx93-phycore-som.dtsi" - -/{ - model = "PHYTEC phyBOARD-Segin-i.MX93"; - compatible = "phytec,imx93-phyboard-segin", "phytec,imx93-phycore-som", - "fsl,imx93"; - - chosen { - stdout-path = &lpuart1; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio3 7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "VCC_SD"; - }; -}; - -/* Console */ -&lpuart1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -/* eMMC */ -&usdhc1 { - no-1-8-v; -}; - -/* SD-Card */ -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2_default>, <&pinctrl_usdhc2_cd>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_cd>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_cd>; - bus-width = <4>; - cd-gpios = <&gpio3 0 GPIO_ACTIVE_LOW>; - no-mmc; - no-sdio; - vmmc-supply = <®_usdhc2_vmmc>; - status = "okay"; -}; - -&iomuxc { - pinctrl_uart1: uart1grp { - fsl,pins = < - MX93_PAD_UART1_RXD__LPUART1_RX 0x31e - MX93_PAD_UART1_TXD__LPUART1_TX 0x30e - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { - fsl,pins = < - MX93_PAD_SD2_RESET_B__GPIO3_IO07 0x31e - >; - }; - - pinctrl_usdhc2_cd: usdhc2cdgrp { - fsl,pins = < - MX93_PAD_SD2_CD_B__GPIO3_IO00 0x31e - >; - }; - - pinctrl_usdhc2_default: usdhc2grp { - fsl,pins = < - MX93_PAD_SD2_CLK__USDHC2_CLK 0x179e - MX93_PAD_SD2_CMD__USDHC2_CMD 0x139e - MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x138e - MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x138e - MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x138e - MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x139e - MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e - >; - }; - - pinctrl_usdhc2_100mhz: usdhc2grp { - fsl,pins = < - MX93_PAD_SD2_CLK__USDHC2_CLK 0x179e - MX93_PAD_SD2_CMD__USDHC2_CMD 0x139e - MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x138e - MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x138e - MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x139e - MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x139e - MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e - >; - }; - - pinctrl_usdhc2_200mhz: usdhc2grp { - fsl,pins = < - MX93_PAD_SD2_CLK__USDHC2_CLK 0x178e - MX93_PAD_SD2_CMD__USDHC2_CMD 0x139e - MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x139e - MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x139e - MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x139e - MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x139e - MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e - >; - }; -}; diff --git a/arch/arm/dts/imx93-phycore-som.dtsi b/arch/arm/dts/imx93-phycore-som.dtsi deleted file mode 100644 index 88c2657b50e..00000000000 --- a/arch/arm/dts/imx93-phycore-som.dtsi +++ /dev/null @@ -1,126 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2023 PHYTEC Messtechnik GmbH - * Author: Wadim Egorov w.egorov@phytec.de, Christoph Stoidner c.stoidner@phytec.de - * Copyright (C) 2024 Mathieu Othacehe m.othacehe@gmail.com - * - * Product homepage: - * https://www.phytec.eu/en/produkte/system-on-modules/phycore-imx-91-93/ - */ - -#include <dt-bindings/leds/common.h> - -#include "imx93.dtsi" - -/{ - model = "PHYTEC phyCORE-i.MX93"; - compatible = "phytec,imx93-phycore-som", "fsl,imx93"; - - reserved-memory { - ranges; - #address-cells = <2>; - #size-cells = <2>; - - linux,cma { - compatible = "shared-dma-pool"; - reusable; - alloc-ranges = <0 0x80000000 0 0x40000000>; - size = <0 0x10000000>; - linux,cma-default; - }; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_leds>; - - led-0 { - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_HEARTBEAT; - gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - }; - }; -}; - -/* Ethernet */ -&fec { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; - phy-mode = "rmii"; - phy-handle = <ðphy1>; - fsl,magic-packet; - assigned-clocks = <&clk IMX93_CLK_ENET_TIMER1>, - <&clk IMX93_CLK_ENET_REF>, - <&clk IMX93_CLK_ENET_REF_PHY>; - assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>, - <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>, - <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; - assigned-clock-rates = <100000000>, <50000000>, <50000000>; - status = "okay"; - - mdio: mdio { - clock-frequency = <5000000>; - #address-cells = <1>; - #size-cells = <0>; - - ethphy1: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; - }; -}; - -/* eMMC */ -&usdhc1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usdhc1>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -/* Watchdog */ -&wdog3 { - status = "okay"; -}; - -&iomuxc { - pinctrl_fec: fecgrp { - fsl,pins = < - MX93_PAD_ENET2_MDC__ENET1_MDC 0x50e - MX93_PAD_ENET2_MDIO__ENET1_MDIO 0x502 - MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x57e - MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x57e - MX93_PAD_ENET2_RXC__ENET1_RX_ER 0x5fe - MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x57e - MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x50e - MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x50e - MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x50e - MX93_PAD_ENET2_TD2__ENET1_TX_CLK 0x4000050e - >; - }; - - pinctrl_leds: ledsgrp { - fsl,pins = < - MX93_PAD_I2C1_SDA__GPIO1_IO01 0x31e - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX93_PAD_SD1_CLK__USDHC1_CLK 0x179e - MX93_PAD_SD1_CMD__USDHC1_CMD 0x1386 - MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x138e - MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x1386 - MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x138e - MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x1386 - MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x1386 - MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x1386 - MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x1386 - MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x1386 - MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x179e - >; - }; -}; diff --git a/arch/arm/dts/imx93-pinfunc.h b/arch/arm/dts/imx93-pinfunc.h deleted file mode 100644 index 4298a145f8a..00000000000 --- a/arch/arm/dts/imx93-pinfunc.h +++ /dev/null @@ -1,623 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ -/* - * Copyright 2022 NXP - */ - -#ifndef __DTS_IMX93_PINFUNC_H -#define __DTS_IMX93_PINFUNC_H - -/* - * The pin function ID is a tuple of - * <mux_reg conf_reg input_reg mux_mode input_val> - */ -#define MX93_PAD_DAP_TDI__JTAG_MUX_TDI 0x0000 0x01B0 0x03D8 0x0 0x0 -#define MX93_PAD_DAP_TDI__MQS2_LEFT 0x0000 0x01B0 0x0000 0x1 0x0 -#define MX93_PAD_DAP_TDI__CAN2_TX 0x0000 0x01B0 0x0000 0x3 0x0 -#define MX93_PAD_DAP_TDI__FLEXIO2_FLEXIO30 0x0000 0x01B0 0x0000 0x4 0x0 -#define MX93_PAD_DAP_TDI__GPIO3_IO28 0x0000 0x01B0 0x0000 0x5 0x0 -#define MX93_PAD_DAP_TDI__LPUART5_RX 0x0000 0x01B0 0x0430 0x6 0x0 -#define MX93_PAD_DAP_TMS_SWDIO__JTAG_MUX_TMS 0x0004 0x01B4 0x03DC 0x0 0x0 -#define MX93_PAD_DAP_TMS_SWDIO__FLEXIO2_FLEXIO31 0x0004 0x01B4 0x0000 0x4 0x0 -#define MX93_PAD_DAP_TMS_SWDIO__GPIO3_IO29 0x0004 0x01B4 0x0000 0x5 0x0 -#define MX93_PAD_DAP_TMS_SWDIO__LPUART5_RTS_B 0x0004 0x01B4 0x0000 0x6 0x0 -#define MX93_PAD_DAP_TCLK_SWCLK__JTAG_MUX_TCK 0x0008 0x01B8 0x03D4 0x0 0x0 -#define MX93_PAD_DAP_TCLK_SWCLK__FLEXIO1_FLEXIO30 0x0008 0x01B8 0x0000 0x4 0x0 -#define MX93_PAD_DAP_TCLK_SWCLK__GPIO3_IO30 0x0008 0x01B8 0x0000 0x5 0x0 -#define MX93_PAD_DAP_TCLK_SWCLK__LPUART5_CTS_B 0x0008 0x01B8 0x042C 0x6 0x0 -#define MX93_PAD_DAP_TDO_TRACESWO__JTAG_MUX_TDO 0x000C 0x01BC 0x0000 0x0 0x0 -#define MX93_PAD_DAP_TDO_TRACESWO__MQS2_RIGHT 0x000C 0x01BC 0x0000 0x1 0x0 -#define MX93_PAD_DAP_TDO_TRACESWO__CAN2_RX 0x000C 0x01BC 0x0364 0x3 0x0 -#define MX93_PAD_DAP_TDO_TRACESWO__FLEXIO1_FLEXIO31 0x000C 0x01BC 0x0000 0x4 0x0 -#define MX93_PAD_DAP_TDO_TRACESWO__GPIO3_IO31 0x000C 0x01BC 0x0000 0x5 0x0 -#define MX93_PAD_DAP_TDO_TRACESWO__LPUART5_TX 0x000C 0x01BC 0x0434 0x6 0x0 -#define MX93_PAD_GPIO_IO00__GPIO2_IO00 0x0010 0x01C0 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO00__LPI2C3_SDA 0x0010 0x01C0 0x03E4 0x11 0x0 -#define MX93_PAD_GPIO_IO00__MEDIAMIX_CAM_CLK 0x0010 0x01C0 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO00__MEDIAMIX_DISP_CLK 0x0010 0x01C0 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO00__LPSPI6_PCS0 0x0010 0x01C0 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO00__LPUART5_TX 0x0010 0x01C0 0x0434 0x5 0x1 -#define MX93_PAD_GPIO_IO00__LPI2C5_SDA 0x0010 0x01C0 0x03EC 0x16 0x0 -#define MX93_PAD_GPIO_IO00__FLEXIO1_FLEXIO00 0x0010 0x01C0 0x036C 0x7 0x0 -#define MX93_PAD_GPIO_IO01__GPIO2_IO01 0x0014 0x01C4 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO01__LPI2C3_SCL 0x0014 0x01C4 0x03E0 0x11 0x0 -#define MX93_PAD_GPIO_IO01__MEDIAMIX_CAM_DATA00 0x0014 0x01C4 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO01__MEDIAMIX_DISP_DE 0x0014 0x01C4 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO01__LPSPI6_SIN 0x0014 0x01C4 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO01__LPUART5_RX 0x0014 0x01C4 0x0430 0x5 0x1 -#define MX93_PAD_GPIO_IO01__LPI2C5_SCL 0x0014 0x01C4 0x03E8 0x16 0x0 -#define MX93_PAD_GPIO_IO01__FLEXIO1_FLEXIO01 0x0014 0x01C4 0x0370 0x7 0x0 -#define MX93_PAD_GPIO_IO02__GPIO2_IO02 0x0018 0x01C8 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO02__LPI2C4_SDA 0x0018 0x01C8 0x0000 0x11 0x0 -#define MX93_PAD_GPIO_IO02__MEDIAMIX_CAM_VSYNC 0x0018 0x01C8 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO02__MEDIAMIX_DISP_VSYNC 0x0018 0x01C8 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO02__LPSPI6_SOUT 0x0018 0x01C8 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO02__LPUART5_CTS_B 0x0018 0x01C8 0x042C 0x5 0x1 -#define MX93_PAD_GPIO_IO02__LPI2C6_SDA 0x0018 0x01C8 0x03F4 0x16 0x0 -#define MX93_PAD_GPIO_IO02__FLEXIO1_FLEXIO02 0x0018 0x01C8 0x0374 0x7 0x0 -#define MX93_PAD_GPIO_IO03__GPIO2_IO03 0x001C 0x01CC 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO03__LPI2C4_SCL 0x001C 0x01CC 0x0000 0x11 0x0 -#define MX93_PAD_GPIO_IO03__MEDIAMIX_CAM_HSYNC 0x001C 0x01CC 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO03__MEDIAMIX_DISP_HSYNC 0x001C 0x01CC 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO03__LPSPI6_SCK 0x001C 0x01CC 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO03__LPUART5_RTS_B 0x001C 0x01CC 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO03__LPI2C6_SCL 0x001C 0x01CC 0x03F0 0x16 0x0 -#define MX93_PAD_GPIO_IO03__FLEXIO1_FLEXIO03 0x001C 0x01CC 0x0378 0x7 0x0 -#define MX93_PAD_GPIO_IO04__GPIO2_IO04 0x0020 0x01D0 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO04__TPM3_CH0 0x0020 0x01D0 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO04__PDM_CLK 0x0020 0x01D0 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO04__MEDIAMIX_DISP_DATA00 0x0020 0x01D0 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO04__LPSPI7_PCS0 0x0020 0x01D0 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO04__LPUART6_TX 0x0020 0x01D0 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO04__LPI2C6_SDA 0x0020 0x01D0 0x03F4 0x16 0x1 -#define MX93_PAD_GPIO_IO04__FLEXIO1_FLEXIO04 0x0020 0x01D0 0x037C 0x7 0x0 -#define MX93_PAD_GPIO_IO05__GPIO2_IO05 0x0024 0x01D4 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO05__TPM4_CH0 0x0024 0x01D4 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO05__PDM_BIT_STREAM00 0x0024 0x01D4 0x0438 0x2 0x0 -#define MX93_PAD_GPIO_IO05__MEDIAMIX_DISP_DATA01 0x0024 0x01D4 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO05__LPSPI7_SIN 0x0024 0x01D4 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO05__LPUART6_RX 0x0024 0x01D4 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO05__LPI2C6_SCL 0x0024 0x01D4 0x03F0 0x16 0x1 -#define MX93_PAD_GPIO_IO05__FLEXIO1_FLEXIO05 0x0024 0x01D4 0x0380 0x7 0x0 -#define MX93_PAD_GPIO_IO06__GPIO2_IO06 0x0028 0x01D8 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO06__TPM5_CH0 0x0028 0x01D8 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO06__PDM_BIT_STREAM01 0x0028 0x01D8 0x043C 0x2 0x0 -#define MX93_PAD_GPIO_IO06__MEDIAMIX_DISP_DATA02 0x0028 0x01D8 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO06__LPSPI7_SOUT 0x0028 0x01D8 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO06__LPUART6_CTS_B 0x0028 0x01D8 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO06__LPI2C7_SDA 0x0028 0x01D8 0x03FC 0x16 0x0 -#define MX93_PAD_GPIO_IO06__FLEXIO1_FLEXIO06 0x0028 0x01D8 0x0384 0x7 0x0 -#define MX93_PAD_GPIO_IO07__GPIO2_IO07 0x002C 0x01DC 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO07__LPSPI3_PCS1 0x002C 0x01DC 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO07__MEDIAMIX_CAM_DATA01 0x002C 0x01DC 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO07__MEDIAMIX_DISP_DATA03 0x002C 0x01DC 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO07__LPSPI7_SCK 0x002C 0x01DC 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO07__LPUART6_RTS_B 0x002C 0x01DC 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO07__LPI2C7_SCL 0x002C 0x01DC 0x03F8 0x16 0x0 -#define MX93_PAD_GPIO_IO07__FLEXIO1_FLEXIO07 0x002C 0x01DC 0x0388 0x7 0x0 -#define MX93_PAD_GPIO_IO08__GPIO2_IO08 0x0030 0x01E0 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO08__LPSPI3_PCS0 0x0030 0x01E0 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO08__MEDIAMIX_CAM_DATA02 0x0030 0x01E0 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO08__MEDIAMIX_DISP_DATA04 0x0030 0x01E0 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO08__TPM6_CH0 0x0030 0x01E0 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO08__LPUART7_TX 0x0030 0x01E0 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO08__LPI2C7_SDA 0x0030 0x01E0 0x03FC 0x16 0x1 -#define MX93_PAD_GPIO_IO08__FLEXIO1_FLEXIO08 0x0030 0x01E0 0x038C 0x7 0x0 -#define MX93_PAD_GPIO_IO09__GPIO2_IO09 0x0034 0x01E4 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO09__LPSPI3_SIN 0x0034 0x01E4 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO09__MEDIAMIX_CAM_DATA03 0x0034 0x01E4 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO09__MEDIAMIX_DISP_DATA05 0x0034 0x01E4 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO09__TPM3_EXTCLK 0x0034 0x01E4 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO09__LPUART7_RX 0x0034 0x01E4 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO09__LPI2C7_SCL 0x0034 0x01E4 0x03F8 0x16 0x1 -#define MX93_PAD_GPIO_IO09__FLEXIO1_FLEXIO09 0x0034 0x01E4 0x0390 0x7 0x0 -#define MX93_PAD_GPIO_IO10__GPIO2_IO10 0x0038 0x01E8 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO10__LPSPI3_SOUT 0x0038 0x01E8 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO10__MEDIAMIX_CAM_DATA04 0x0038 0x01E8 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO10__MEDIAMIX_DISP_DATA06 0x0038 0x01E8 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO10__TPM4_EXTCLK 0x0038 0x01E8 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO10__LPUART7_CTS_B 0x0038 0x01E8 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO10__LPI2C8_SDA 0x0038 0x01E8 0x0404 0x16 0x0 -#define MX93_PAD_GPIO_IO10__FLEXIO1_FLEXIO10 0x0038 0x01E8 0x0394 0x7 0x0 -#define MX93_PAD_GPIO_IO11__GPIO2_IO11 0x003C 0x01EC 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO11__LPSPI3_SCK 0x003C 0x01EC 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO11__MEDIAMIX_CAM_DATA05 0x003C 0x01EC 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO11__MEDIAMIX_DISP_DATA07 0x003C 0x01EC 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO11__TPM5_EXTCLK 0x003C 0x01EC 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO11__LPUART7_RTS_B 0x003C 0x01EC 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO11__LPI2C8_SCL 0x003C 0x01EC 0x0400 0x16 0x0 -#define MX93_PAD_GPIO_IO11__FLEXIO1_FLEXIO11 0x003C 0x01EC 0x0398 0x7 0x0 -#define MX93_PAD_GPIO_IO12__GPIO2_IO12 0x0040 0x01F0 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO12__TPM3_CH2 0x0040 0x01F0 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO12__PDM_BIT_STREAM02 0x0040 0x01F0 0x0440 0x2 0x0 -#define MX93_PAD_GPIO_IO12__MEDIAMIX_DISP_DATA08 0x0040 0x01F0 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO12__LPSPI8_PCS0 0x0040 0x01F0 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO12__LPUART8_TX 0x0040 0x01F0 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO12__LPI2C8_SDA 0x0040 0x01F0 0x0404 0x16 0x1 -#define MX93_PAD_GPIO_IO12__SAI3_RX_SYNC 0x0040 0x01F0 0x0450 0x7 0x0 -#define MX93_PAD_GPIO_IO13__GPIO2_IO13 0x0044 0x01F4 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO13__TPM4_CH2 0x0044 0x01F4 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO13__PDM_BIT_STREAM03 0x0044 0x01F4 0x0444 0x2 0x0 -#define MX93_PAD_GPIO_IO13__MEDIAMIX_DISP_DATA09 0x0044 0x01F4 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO13__LPSPI8_SIN 0x0044 0x01F4 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO13__LPUART8_RX 0x0044 0x01F4 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO13__LPI2C8_SCL 0x0044 0x01F4 0x0400 0x16 0x1 -#define MX93_PAD_GPIO_IO13__FLEXIO1_FLEXIO13 0x0044 0x01F4 0x039C 0x7 0x0 -#define MX93_PAD_GPIO_IO14__GPIO2_IO14 0x0048 0x01F8 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO14__LPUART3_TX 0x0048 0x01F8 0x041C 0x1 0x0 -#define MX93_PAD_GPIO_IO14__MEDIAMIX_CAM_DATA06 0x0048 0x01F8 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO14__MEDIAMIX_DISP_DATA10 0x0048 0x01F8 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO14__LPSPI8_SOUT 0x0048 0x01F8 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO14__LPUART8_CTS_B 0x0048 0x01F8 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO14__LPUART4_TX 0x0048 0x01F8 0x0428 0x6 0x0 -#define MX93_PAD_GPIO_IO14__FLEXIO1_FLEXIO14 0x0048 0x01F8 0x03A0 0x7 0x0 -#define MX93_PAD_GPIO_IO15__GPIO2_IO15 0x004C 0x01FC 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO15__LPUART3_RX 0x004C 0x01FC 0x0418 0x1 0x0 -#define MX93_PAD_GPIO_IO15__MEDIAMIX_CAM_DATA07 0x004C 0x01FC 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO15__MEDIAMIX_DISP_DATA11 0x004C 0x01FC 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO15__LPSPI8_SCK 0x004C 0x01FC 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO15__LPUART8_RTS_B 0x004C 0x01FC 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO15__LPUART4_RX 0x004C 0x01FC 0x0424 0x6 0x0 -#define MX93_PAD_GPIO_IO15__FLEXIO1_FLEXIO15 0x004C 0x01FC 0x03A4 0x7 0x0 -#define MX93_PAD_GPIO_IO16__GPIO2_IO16 0x0050 0x0200 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO16__SAI3_TX_BCLK 0x0050 0x0200 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO16__PDM_BIT_STREAM02 0x0050 0x0200 0x0440 0x2 0x1 -#define MX93_PAD_GPIO_IO16__MEDIAMIX_DISP_DATA12 0x0050 0x0200 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO16__LPUART3_CTS_B 0x0050 0x0200 0x0414 0x4 0x0 -#define MX93_PAD_GPIO_IO16__LPSPI4_PCS2 0x0050 0x0200 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO16__LPUART4_CTS_B 0x0050 0x0200 0x0420 0x6 0x0 -#define MX93_PAD_GPIO_IO16__FLEXIO1_FLEXIO16 0x0050 0x0200 0x03A8 0x7 0x0 -#define MX93_PAD_GPIO_IO17__GPIO2_IO17 0x0054 0x0204 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO17__SAI3_MCLK 0x0054 0x0204 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO17__MEDIAMIX_CAM_DATA08 0x0054 0x0204 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO17__MEDIAMIX_DISP_DATA13 0x0054 0x0204 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO17__LPUART3_RTS_B 0x0054 0x0204 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO17__LPSPI4_PCS1 0x0054 0x0204 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO17__LPUART4_RTS_B 0x0054 0x0204 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO17__FLEXIO1_FLEXIO17 0x0054 0x0204 0x03AC 0x7 0x0 -#define MX93_PAD_GPIO_IO18__GPIO2_IO18 0x0058 0x0208 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO18__SAI3_RX_BCLK 0x0058 0x0208 0x044C 0x1 0x0 -#define MX93_PAD_GPIO_IO18__MEDIAMIX_CAM_DATA09 0x0058 0x0208 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO18__MEDIAMIX_DISP_DATA14 0x0058 0x0208 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO18__LPSPI5_PCS0 0x0058 0x0208 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO18__LPSPI4_PCS0 0x0058 0x0208 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO18__TPM5_CH2 0x0058 0x0208 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO18__FLEXIO1_FLEXIO18 0x0058 0x0208 0x03B0 0x7 0x0 -#define MX93_PAD_GPIO_IO19__GPIO2_IO19 0x005C 0x020C 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO19__SAI3_RX_SYNC 0x005C 0x020C 0x0450 0x1 0x1 -#define MX93_PAD_GPIO_IO19__PDM_BIT_STREAM03 0x005C 0x020C 0x0444 0x2 0x1 -#define MX93_PAD_GPIO_IO19__MEDIAMIX_DISP_DATA15 0x005C 0x020C 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO19__LPSPI5_SIN 0x005C 0x020C 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO19__LPSPI4_SIN 0x005C 0x020C 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO19__TPM6_CH2 0x005C 0x020C 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO19__SAI3_TX_DATA00 0x005C 0x020C 0x0000 0x7 0x0 -#define MX93_PAD_GPIO_IO20__GPIO2_IO20 0x0060 0x0210 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO20__SAI3_RX_DATA00 0x0060 0x0210 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO20__PDM_BIT_STREAM00 0x0060 0x0210 0x0438 0x2 0x1 -#define MX93_PAD_GPIO_IO20__MEDIAMIX_DISP_DATA16 0x0060 0x0210 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO20__LPSPI5_SOUT 0x0060 0x0210 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO20__LPSPI4_SOUT 0x0060 0x0210 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO20__TPM3_CH1 0x0060 0x0210 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO20__FLEXIO1_FLEXIO20 0x0060 0x0210 0x03B4 0x7 0x0 -#define MX93_PAD_GPIO_IO21__GPIO2_IO21 0x0064 0x0214 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO21__SAI3_TX_DATA00 0x0064 0x0214 0x0000 0x1 0x0 -#define MX93_PAD_GPIO_IO21__PDM_CLK 0x0064 0x0214 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO21__MEDIAMIX_DISP_DATA17 0x0064 0x0214 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO21__LPSPI5_SCK 0x0064 0x0214 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO21__LPSPI4_SCK 0x0064 0x0214 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO21__TPM4_CH1 0x0064 0x0214 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO21__SAI3_RX_BCLK 0x0064 0x0214 0x044C 0x7 0x1 -#define MX93_PAD_GPIO_IO22__GPIO2_IO22 0x0068 0x0218 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO22__USDHC3_CLK 0x0068 0x0218 0x0458 0x1 0x0 -#define MX93_PAD_GPIO_IO22__SPDIF_IN 0x0068 0x0218 0x0454 0x2 0x0 -#define MX93_PAD_GPIO_IO22__MEDIAMIX_DISP_DATA18 0x0068 0x0218 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO22__TPM5_CH1 0x0068 0x0218 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO22__TPM6_EXTCLK 0x0068 0x0218 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO22__LPI2C5_SDA 0x0068 0x0218 0x03EC 0x16 0x1 -#define MX93_PAD_GPIO_IO22__FLEXIO1_FLEXIO22 0x0068 0x0218 0x03B8 0x7 0x0 -#define MX93_PAD_GPIO_IO23__GPIO2_IO23 0x006C 0x021C 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO23__USDHC3_CMD 0x006C 0x021C 0x045C 0x1 0x0 -#define MX93_PAD_GPIO_IO23__SPDIF_OUT 0x006C 0x021C 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO23__MEDIAMIX_DISP_DATA19 0x006C 0x021C 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO23__TPM6_CH1 0x006C 0x021C 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO23__LPI2C5_SCL 0x006C 0x021C 0x03E8 0x16 0x1 -#define MX93_PAD_GPIO_IO23__FLEXIO1_FLEXIO23 0x006C 0x021C 0x03BC 0x7 0x0 -#define MX93_PAD_GPIO_IO24__GPIO2_IO24 0x0070 0x0220 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO24__USDHC3_DATA0 0x0070 0x0220 0x0460 0x1 0x0 -#define MX93_PAD_GPIO_IO24__MEDIAMIX_DISP_DATA20 0x0070 0x0220 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO24__TPM3_CH3 0x0070 0x0220 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO24__JTAG_MUX_TDO 0x0070 0x0220 0x0000 0x5 0x0 -#define MX93_PAD_GPIO_IO24__LPSPI6_PCS1 0x0070 0x0220 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO24__FLEXIO1_FLEXIO24 0x0070 0x0220 0x03C0 0x7 0x0 -#define MX93_PAD_GPIO_IO25__GPIO2_IO25 0x0074 0x0224 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO25__USDHC3_DATA1 0x0074 0x0224 0x0464 0x1 0x0 -#define MX93_PAD_GPIO_IO25__CAN2_TX 0x0074 0x0224 0x0000 0x2 0x0 -#define MX93_PAD_GPIO_IO25__MEDIAMIX_DISP_DATA21 0x0074 0x0224 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO25__TPM4_CH3 0x0074 0x0224 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO25__JTAG_MUX_TCK 0x0074 0x0224 0x03D4 0x5 0x1 -#define MX93_PAD_GPIO_IO25__LPSPI7_PCS1 0x0074 0x0224 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO25__FLEXIO1_FLEXIO25 0x0074 0x0224 0x03C4 0x7 0x0 -#define MX93_PAD_GPIO_IO26__GPIO2_IO26 0x0078 0x0228 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO26__USDHC3_DATA2 0x0078 0x0228 0x0468 0x1 0x0 -#define MX93_PAD_GPIO_IO26__PDM_BIT_STREAM01 0x0078 0x0228 0x043C 0x2 0x1 -#define MX93_PAD_GPIO_IO26__MEDIAMIX_DISP_DATA22 0x0078 0x0228 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO26__TPM5_CH3 0x0078 0x0228 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO26__JTAG_MUX_TDI 0x0078 0x0228 0x03D8 0x5 0x1 -#define MX93_PAD_GPIO_IO26__LPSPI8_PCS1 0x0078 0x0228 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO26__SAI3_TX_SYNC 0x0078 0x0228 0x0000 0x7 0x0 -#define MX93_PAD_GPIO_IO27__GPIO2_IO27 0x007C 0x022C 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO27__USDHC3_DATA3 0x007C 0x022C 0x046C 0x1 0x0 -#define MX93_PAD_GPIO_IO27__CAN2_RX 0x007C 0x022C 0x0364 0x2 0x1 -#define MX93_PAD_GPIO_IO27__MEDIAMIX_DISP_DATA23 0x007C 0x022C 0x0000 0x3 0x0 -#define MX93_PAD_GPIO_IO27__TPM6_CH3 0x007C 0x022C 0x0000 0x4 0x0 -#define MX93_PAD_GPIO_IO27__JTAG_MUX_TMS 0x007C 0x022C 0x03DC 0x5 0x1 -#define MX93_PAD_GPIO_IO27__LPSPI5_PCS1 0x007C 0x022C 0x0000 0x6 0x0 -#define MX93_PAD_GPIO_IO27__FLEXIO1_FLEXIO27 0x007C 0x022C 0x03C8 0x7 0x0 -#define MX93_PAD_GPIO_IO28__GPIO2_IO28 0x0080 0x0230 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO28__LPI2C3_SDA 0x0080 0x0230 0x03E4 0x11 0x1 -#define MX93_PAD_GPIO_IO28__FLEXIO1_FLEXIO28 0x0080 0x0230 0x0000 0x7 0x0 -#define MX93_PAD_GPIO_IO29__GPIO2_IO29 0x0084 0x0234 0x0000 0x0 0x0 -#define MX93_PAD_GPIO_IO29__LPI2C3_SCL 0x0084 0x0234 0x03E0 0x11 0x1 -#define MX93_PAD_GPIO_IO29__FLEXIO1_FLEXIO29 0x0084 0x0234 0x0000 0x7 0x0 -#define MX93_PAD_CCM_CLKO1__CCMSRCGPCMIX_CLKO1 0x0088 0x0238 0x0000 0x0 0x0 -#define MX93_PAD_CCM_CLKO1__FLEXIO1_FLEXIO26 0x0088 0x0238 0x0000 0x4 0x0 -#define MX93_PAD_CCM_CLKO1__GPIO3_IO26 0x0088 0x0238 0x0000 0x5 0x0 -#define MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x008C 0x023C 0x0000 0x5 0x0 -#define MX93_PAD_CCM_CLKO2__CCMSRCGPCMIX_CLKO2 0x008C 0x023C 0x0000 0x0 0x0 -#define MX93_PAD_CCM_CLKO2__FLEXIO1_FLEXIO27 0x008C 0x023C 0x03C8 0x4 0x1 -#define MX93_PAD_CCM_CLKO3__CCMSRCGPCMIX_CLKO3 0x0090 0x0240 0x0000 0x0 0x0 -#define MX93_PAD_CCM_CLKO3__FLEXIO2_FLEXIO28 0x0090 0x0240 0x0000 0x4 0x0 -#define MX93_PAD_CCM_CLKO3__GPIO4_IO28 0x0090 0x0240 0x0000 0x5 0x0 -#define MX93_PAD_CCM_CLKO4__CCMSRCGPCMIX_CLKO4 0x0094 0x0244 0x0000 0x0 0x0 -#define MX93_PAD_CCM_CLKO4__FLEXIO2_FLEXIO29 0x0094 0x0244 0x0000 0x4 0x0 -#define MX93_PAD_CCM_CLKO4__GPIO4_IO29 0x0094 0x0244 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_MDC__ENET_QOS_MDC 0x0098 0x0248 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_MDC__LPUART3_DCB_B 0x0098 0x0248 0x0000 0x1 0x0 -#define MX93_PAD_ENET1_MDC__I3C2_SCL 0x0098 0x0248 0x03CC 0x2 0x0 -#define MX93_PAD_ENET1_MDC__HSIOMIX_OTG_ID1 0x0098 0x0248 0x0000 0x3 0x0 -#define MX93_PAD_ENET1_MDC__FLEXIO2_FLEXIO00 0x0098 0x0248 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_MDC__GPIO4_IO00 0x0098 0x0248 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_MDIO__ENET_QOS_MDIO 0x009C 0x024C 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_MDIO__LPUART3_RIN_B 0x009C 0x024C 0x0000 0x1 0x0 -#define MX93_PAD_ENET1_MDIO__I3C2_SDA 0x009C 0x024C 0x03D0 0x2 0x0 -#define MX93_PAD_ENET1_MDIO__HSIOMIX_OTG_PWR1 0x009C 0x024C 0x0000 0x3 0x0 -#define MX93_PAD_ENET1_MDIO__FLEXIO2_FLEXIO01 0x009C 0x024C 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_MDIO__GPIO4_IO01 0x009C 0x024C 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_TD3__ENET_QOS_RGMII_TD3 0x00A0 0x0250 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_TD3__CAN2_TX 0x00A0 0x0250 0x0000 0x2 0x0 -#define MX93_PAD_ENET1_TD3__HSIOMIX_OTG_ID2 0x00A0 0x0250 0x0000 0x3 0x0 -#define MX93_PAD_ENET1_TD3__FLEXIO2_FLEXIO02 0x00A0 0x0250 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_TD3__GPIO4_IO02 0x00A0 0x0250 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_TD2__ENET_QOS_RGMII_TD2 0x00A4 0x0254 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_TD2__CCM_ENET_QOS_CLOCK_GENERATE_REF_CLK 0x00A4 0x0254 0x0000 0x1 0x0 -#define MX93_PAD_ENET1_TD2__CAN2_RX 0x00A4 0x0254 0x0364 0x2 0x2 -#define MX93_PAD_ENET1_TD2__HSIOMIX_OTG_OC2 0x00A4 0x0254 0x0000 0x3 0x0 -#define MX93_PAD_ENET1_TD2__FLEXIO2_FLEXIO03 0x00A4 0x0254 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_TD2__GPIO4_IO03 0x00A4 0x0254 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_TD1__ENET_QOS_RGMII_TD1 0x00A8 0x0258 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_TD1__LPUART3_RTS_B 0x00A8 0x0258 0x0000 0x1 0x0 -#define MX93_PAD_ENET1_TD1__I3C2_PUR 0x00A8 0x0258 0x0000 0x2 0x0 -#define MX93_PAD_ENET1_TD1__HSIOMIX_OTG_OC1 0x00A8 0x0258 0x0000 0x3 0x0 -#define MX93_PAD_ENET1_TD1__FLEXIO2_FLEXIO04 0x00A8 0x0258 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_TD1__GPIO4_IO04 0x00A8 0x0258 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_TD1__I3C2_PUR_B 0x00A8 0x0258 0x0000 0x6 0x0 -#define MX93_PAD_ENET1_TD0__ENET_QOS_RGMII_TD0 0x00AC 0x025C 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_TD0__LPUART3_TX 0x00AC 0x025C 0x041C 0x1 0x1 -#define MX93_PAD_ENET1_TD0__FLEXIO2_FLEXIO05 0x00AC 0x025C 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_TD0__GPIO4_IO05 0x00AC 0x025C 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x00B0 0x0260 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_TX_CTL__LPUART3_DTR_B 0x00B0 0x0260 0x0000 0x1 0x0 -#define MX93_PAD_ENET1_TX_CTL__FLEXIO2_FLEXIO06 0x00B0 0x0260 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_TX_CTL__GPIO4_IO06 0x00B0 0x0260 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x00B4 0x0264 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_TXC__ENET_QOS_TX_ER 0x00B4 0x0264 0x0000 0x1 0x0 -#define MX93_PAD_ENET1_TXC__FLEXIO2_FLEXIO07 0x00B4 0x0264 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_TXC__GPIO4_IO07 0x00B4 0x0264 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x00B8 0x0268 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_RX_CTL__LPUART3_DSR_B 0x00B8 0x0268 0x0000 0x1 0x0 -#define MX93_PAD_ENET1_RX_CTL__HSIOMIX_OTG_PWR2 0x00B8 0x0268 0x0000 0x3 0x0 -#define MX93_PAD_ENET1_RX_CTL__FLEXIO2_FLEXIO08 0x00B8 0x0268 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_RX_CTL__GPIO4_IO08 0x00B8 0x0268 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x00BC 0x026C 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_RXC__ENET_QOS_RX_ER 0x00BC 0x026C 0x0000 0x1 0x0 -#define MX93_PAD_ENET1_RXC__FLEXIO2_FLEXIO09 0x00BC 0x026C 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_RXC__GPIO4_IO09 0x00BC 0x026C 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_RD0__ENET_QOS_RGMII_RD0 0x00C0 0x0270 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_RD0__LPUART3_RX 0x00C0 0x0270 0x0418 0x1 0x1 -#define MX93_PAD_ENET1_RD0__FLEXIO2_FLEXIO10 0x00C0 0x0270 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_RD0__GPIO4_IO10 0x00C0 0x0270 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_RD1__ENET_QOS_RGMII_RD1 0x00C4 0x0274 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_RD1__LPUART3_CTS_B 0x00C4 0x0274 0x0414 0x1 0x1 -#define MX93_PAD_ENET1_RD1__LPTMR2_ALT1 0x00C4 0x0274 0x0408 0x3 0x0 -#define MX93_PAD_ENET1_RD1__FLEXIO2_FLEXIO11 0x00C4 0x0274 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_RD1__GPIO4_IO11 0x00C4 0x0274 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_RD2__ENET_QOS_RGMII_RD2 0x00C8 0x0278 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_RD2__LPTMR2_ALT2 0x00C8 0x0278 0x040C 0x3 0x0 -#define MX93_PAD_ENET1_RD2__FLEXIO2_FLEXIO12 0x00C8 0x0278 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_RD2__GPIO4_IO12 0x00C8 0x0278 0x0000 0x5 0x0 -#define MX93_PAD_ENET1_RD3__ENET_QOS_RGMII_RD3 0x00CC 0x027C 0x0000 0x0 0x0 -#define MX93_PAD_ENET1_RD3__FLEXSPI1_TESTER_TRIGGER 0x00CC 0x027C 0x0000 0x2 0x0 -#define MX93_PAD_ENET1_RD3__LPTMR2_ALT3 0x00CC 0x027C 0x0410 0x3 0x0 -#define MX93_PAD_ENET1_RD3__FLEXIO2_FLEXIO13 0x00CC 0x027C 0x0000 0x4 0x0 -#define MX93_PAD_ENET1_RD3__GPIO4_IO13 0x00CC 0x027C 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_MDC__ENET1_MDC 0x00D0 0x0280 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_MDC__LPUART4_DCB_B 0x00D0 0x0280 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_MDC__SAI2_RX_SYNC 0x00D0 0x0280 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_MDC__FLEXIO2_FLEXIO14 0x00D0 0x0280 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_MDC__GPIO4_IO14 0x00D0 0x0280 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_MDIO__ENET1_MDIO 0x00D4 0x0284 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_MDIO__LPUART4_RIN_B 0x00D4 0x0284 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_MDIO__SAI2_RX_BCLK 0x00D4 0x0284 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_MDIO__FLEXIO2_FLEXIO15 0x00D4 0x0284 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_MDIO__GPIO4_IO15 0x00D4 0x0284 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_TD3__SAI2_RX_DATA00 0x00D8 0x0288 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_TD3__FLEXIO2_FLEXIO16 0x00D8 0x0288 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_TD3__GPIO4_IO16 0x00D8 0x0288 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_TD3__ENET1_RGMII_TD3 0x00D8 0x0288 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_TD2__ENET1_RGMII_TD2 0x00DC 0x028C 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_TD2__ENET1_TX_CLK 0x00DC 0x028C 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_TD2__SAI2_RX_DATA01 0x00DC 0x028C 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_TD2__FLEXIO2_FLEXIO17 0x00DC 0x028C 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_TD2__GPIO4_IO17 0x00DC 0x028C 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x00E0 0x0290 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_TD1__LPUART4_RTS_B 0x00E0 0x0290 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_TD1__SAI2_RX_DATA02 0x00E0 0x0290 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_TD1__FLEXIO2_FLEXIO18 0x00E0 0x0290 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_TD1__GPIO4_IO18 0x00E0 0x0290 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x00E4 0x0294 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_TD0__LPUART4_TX 0x00E4 0x0294 0x0428 0x1 0x1 -#define MX93_PAD_ENET2_TD0__SAI2_RX_DATA03 0x00E4 0x0294 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_TD0__FLEXIO2_FLEXIO19 0x00E4 0x0294 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_TD0__GPIO4_IO19 0x00E4 0x0294 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x00E8 0x0298 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_TX_CTL__LPUART4_DTR_B 0x00E8 0x0298 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_TX_CTL__SAI2_TX_SYNC 0x00E8 0x0298 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_TX_CTL__FLEXIO2_FLEXIO20 0x00E8 0x0298 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_TX_CTL__GPIO4_IO20 0x00E8 0x0298 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_TXC__ENET1_RGMII_TXC 0x00EC 0x029C 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_TXC__ENET1_TX_ER 0x00EC 0x029C 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_TXC__SAI2_TX_BCLK 0x00EC 0x029C 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_TXC__FLEXIO2_FLEXIO21 0x00EC 0x029C 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_TXC__GPIO4_IO21 0x00EC 0x029C 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x00F0 0x02A0 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_RX_CTL__LPUART4_DSR_B 0x00F0 0x02A0 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_RX_CTL__SAI2_TX_DATA00 0x00F0 0x02A0 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_RX_CTL__FLEXIO2_FLEXIO22 0x00F0 0x02A0 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_RX_CTL__GPIO4_IO22 0x00F0 0x02A0 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_RXC__ENET1_RGMII_RXC 0x00F4 0x02A4 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_RXC__ENET1_RX_ER 0x00F4 0x02A4 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_RXC__SAI2_TX_DATA01 0x00F4 0x02A4 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_RXC__FLEXIO2_FLEXIO23 0x00F4 0x02A4 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_RXC__GPIO4_IO23 0x00F4 0x02A4 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x00F8 0x02A8 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_RD0__LPUART4_RX 0x00F8 0x02A8 0x0424 0x1 0x1 -#define MX93_PAD_ENET2_RD0__SAI2_TX_DATA02 0x00F8 0x02A8 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_RD0__FLEXIO2_FLEXIO24 0x00F8 0x02A8 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_RD0__GPIO4_IO24 0x00F8 0x02A8 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x00FC 0x02AC 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_RD1__SPDIF_IN 0x00FC 0x02AC 0x0454 0x1 0x1 -#define MX93_PAD_ENET2_RD1__SAI2_TX_DATA03 0x00FC 0x02AC 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_RD1__FLEXIO2_FLEXIO25 0x00FC 0x02AC 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_RD1__GPIO4_IO25 0x00FC 0x02AC 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_RD2__ENET1_RGMII_RD2 0x0100 0x02B0 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_RD2__LPUART4_CTS_B 0x0100 0x02B0 0x0420 0x1 0x1 -#define MX93_PAD_ENET2_RD2__SAI2_MCLK 0x0100 0x02B0 0x0000 0x2 0x0 -#define MX93_PAD_ENET2_RD2__MQS2_RIGHT 0x0100 0x02B0 0x0000 0x3 0x0 -#define MX93_PAD_ENET2_RD2__FLEXIO2_FLEXIO26 0x0100 0x02B0 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_RD2__GPIO4_IO26 0x0100 0x02B0 0x0000 0x5 0x0 -#define MX93_PAD_ENET2_RD3__ENET1_RGMII_RD3 0x0104 0x02B4 0x0000 0x0 0x0 -#define MX93_PAD_ENET2_RD3__SPDIF_OUT 0x0104 0x02B4 0x0000 0x1 0x0 -#define MX93_PAD_ENET2_RD3__SPDIF_IN 0x0104 0x02B4 0x0454 0x2 0x2 -#define MX93_PAD_ENET2_RD3__MQS2_LEFT 0x0104 0x02B4 0x0000 0x3 0x0 -#define MX93_PAD_ENET2_RD3__FLEXIO2_FLEXIO27 0x0104 0x02B4 0x0000 0x4 0x0 -#define MX93_PAD_ENET2_RD3__GPIO4_IO27 0x0104 0x02B4 0x0000 0x5 0x0 -#define MX93_PAD_SD1_CLK__FLEXIO1_FLEXIO08 0x0108 0x02B8 0x038C 0x4 0x1 -#define MX93_PAD_SD1_CLK__GPIO3_IO08 0x0108 0x02B8 0x0000 0x5 0x0 -#define MX93_PAD_SD1_CLK__USDHC1_CLK 0x0108 0x02B8 0x0000 0x0 0x0 -#define MX93_PAD_SD1_CMD__USDHC1_CMD 0x010C 0x02BC 0x0000 0x0 0x0 -#define MX93_PAD_SD1_CMD__FLEXIO1_FLEXIO09 0x010C 0x02BC 0x0390 0x4 0x1 -#define MX93_PAD_SD1_CMD__GPIO3_IO09 0x010C 0x02BC 0x0000 0x5 0x0 -#define MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x0110 0x02C0 0x0000 0x0 0x0 -#define MX93_PAD_SD1_DATA0__FLEXIO1_FLEXIO10 0x0110 0x02C0 0x0394 0x4 0x1 -#define MX93_PAD_SD1_DATA0__GPIO3_IO10 0x0110 0x02C0 0x0000 0x5 0x0 -#define MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x0114 0x02C4 0x0000 0x0 0x0 -#define MX93_PAD_SD1_DATA1__FLEXIO1_FLEXIO11 0x0114 0x02C4 0x0398 0x4 0x1 -#define MX93_PAD_SD1_DATA1__GPIO3_IO11 0x0114 0x02C4 0x0000 0x5 0x0 -#define MX93_PAD_SD1_DATA1__CCMSRCGPCMIX_INT_BOOT 0x0114 0x02C4 0x0000 0x6 0x0 -#define MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x0118 0x02C8 0x0000 0x0 0x0 -#define MX93_PAD_SD1_DATA2__FLEXIO1_FLEXIO12 0x0118 0x02C8 0x0000 0x4 0x0 -#define MX93_PAD_SD1_DATA2__GPIO3_IO12 0x0118 0x02C8 0x0000 0x5 0x0 -#define MX93_PAD_SD1_DATA2__CCMSRCGPCMIX_PMIC_READY 0x0118 0x02C8 0x0000 0x6 0x0 -#define MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x011C 0x02CC 0x0000 0x0 0x0 -#define MX93_PAD_SD1_DATA3__FLEXSPI1_A_SS1_B 0x011C 0x02CC 0x0000 0x1 0x0 -#define MX93_PAD_SD1_DATA3__FLEXIO1_FLEXIO13 0x011C 0x02CC 0x039C 0x4 0x1 -#define MX93_PAD_SD1_DATA3__GPIO3_IO13 0x011C 0x02CC 0x0000 0x5 0x0 -#define MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x0120 0x02D0 0x0000 0x0 0x0 -#define MX93_PAD_SD1_DATA4__FLEXSPI1_A_DATA04 0x0120 0x02D0 0x0000 0x1 0x0 -#define MX93_PAD_SD1_DATA4__FLEXIO1_FLEXIO14 0x0120 0x02D0 0x03A0 0x4 0x1 -#define MX93_PAD_SD1_DATA4__GPIO3_IO14 0x0120 0x02D0 0x0000 0x5 0x0 -#define MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x0124 0x02D4 0x0000 0x0 0x0 -#define MX93_PAD_SD1_DATA5__FLEXSPI1_A_DATA05 0x0124 0x02D4 0x0000 0x1 0x0 -#define MX93_PAD_SD1_DATA5__USDHC1_RESET_B 0x0124 0x02D4 0x0000 0x2 0x0 -#define MX93_PAD_SD1_DATA5__FLEXIO1_FLEXIO15 0x0124 0x02D4 0x03A4 0x4 0x1 -#define MX93_PAD_SD1_DATA5__GPIO3_IO15 0x0124 0x02D4 0x0000 0x5 0x0 -#define MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x0128 0x02D8 0x0000 0x0 0x0 -#define MX93_PAD_SD1_DATA6__FLEXSPI1_A_DATA06 0x0128 0x02D8 0x0000 0x1 0x0 -#define MX93_PAD_SD1_DATA6__USDHC1_CD_B 0x0128 0x02D8 0x0000 0x2 0x0 -#define MX93_PAD_SD1_DATA6__FLEXIO1_FLEXIO16 0x0128 0x02D8 0x03A8 0x4 0x1 -#define MX93_PAD_SD1_DATA6__GPIO3_IO16 0x0128 0x02D8 0x0000 0x5 0x0 -#define MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x012C 0x02DC 0x0000 0x0 0x0 -#define MX93_PAD_SD1_DATA7__FLEXSPI1_A_DATA07 0x012C 0x02DC 0x0000 0x1 0x0 -#define MX93_PAD_SD1_DATA7__USDHC1_WP 0x012C 0x02DC 0x0000 0x2 0x0 -#define MX93_PAD_SD1_DATA7__FLEXIO1_FLEXIO17 0x012C 0x02DC 0x03AC 0x4 0x1 -#define MX93_PAD_SD1_DATA7__GPIO3_IO17 0x012C 0x02DC 0x0000 0x5 0x0 -#define MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x0130 0x02E0 0x0000 0x0 0x0 -#define MX93_PAD_SD1_STROBE__FLEXSPI1_A_DQS 0x0130 0x02E0 0x0000 0x1 0x0 -#define MX93_PAD_SD1_STROBE__FLEXIO1_FLEXIO18 0x0130 0x02E0 0x03B0 0x4 0x1 -#define MX93_PAD_SD1_STROBE__GPIO3_IO18 0x0130 0x02E0 0x0000 0x5 0x0 -#define MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x0134 0x02E4 0x0000 0x0 0x0 -#define MX93_PAD_SD2_VSELECT__USDHC2_WP 0x0134 0x02E4 0x0000 0x1 0x0 -#define MX93_PAD_SD2_VSELECT__LPTMR2_ALT3 0x0134 0x02E4 0x0410 0x2 0x1 -#define MX93_PAD_SD2_VSELECT__FLEXIO1_FLEXIO19 0x0134 0x02E4 0x0000 0x4 0x0 -#define MX93_PAD_SD2_VSELECT__GPIO3_IO19 0x0134 0x02E4 0x0000 0x5 0x0 -#define MX93_PAD_SD2_VSELECT__CCMSRCGPCMIX_EXT_CLK1 0x0134 0x02E4 0x0368 0x6 0x0 -#define MX93_PAD_SD3_CLK__USDHC3_CLK 0x0138 0x02E8 0x0458 0x0 0x1 -#define MX93_PAD_SD3_CLK__FLEXSPI1_A_SCLK 0x0138 0x02E8 0x0000 0x1 0x0 -#define MX93_PAD_SD3_CLK__FLEXIO1_FLEXIO20 0x0138 0x02E8 0x03B4 0x4 0x1 -#define MX93_PAD_SD3_CLK__GPIO3_IO20 0x0138 0x02E8 0x0000 0x5 0x0 -#define MX93_PAD_SD3_CMD__USDHC3_CMD 0x013C 0x02EC 0x045C 0x0 0x1 -#define MX93_PAD_SD3_CMD__FLEXSPI1_A_SS0_B 0x013C 0x02EC 0x0000 0x1 0x0 -#define MX93_PAD_SD3_CMD__FLEXIO1_FLEXIO21 0x013C 0x02EC 0x0000 0x4 0x0 -#define MX93_PAD_SD3_CMD__GPIO3_IO21 0x013C 0x02EC 0x0000 0x5 0x0 -#define MX93_PAD_SD3_DATA0__USDHC3_DATA0 0x0140 0x02F0 0x0460 0x0 0x1 -#define MX93_PAD_SD3_DATA0__FLEXSPI1_A_DATA00 0x0140 0x02F0 0x0000 0x1 0x0 -#define MX93_PAD_SD3_DATA0__FLEXIO1_FLEXIO22 0x0140 0x02F0 0x03B8 0x4 0x1 -#define MX93_PAD_SD3_DATA0__GPIO3_IO22 0x0140 0x02F0 0x0000 0x5 0x0 -#define MX93_PAD_SD3_DATA1__USDHC3_DATA1 0x0144 0x02F4 0x0464 0x0 0x1 -#define MX93_PAD_SD3_DATA1__FLEXSPI1_A_DATA01 0x0144 0x02F4 0x0000 0x1 0x0 -#define MX93_PAD_SD3_DATA1__FLEXIO1_FLEXIO23 0x0144 0x02F4 0x03BC 0x4 0x1 -#define MX93_PAD_SD3_DATA1__GPIO3_IO23 0x0144 0x02F4 0x0000 0x5 0x0 -#define MX93_PAD_SD3_DATA2__USDHC3_DATA2 0x0148 0x02F8 0x0468 0x0 0x1 -#define MX93_PAD_SD3_DATA2__FLEXSPI1_A_DATA02 0x0148 0x02F8 0x0000 0x1 0x0 -#define MX93_PAD_SD3_DATA2__FLEXIO1_FLEXIO24 0x0148 0x02F8 0x03C0 0x4 0x1 -#define MX93_PAD_SD3_DATA2__GPIO3_IO24 0x0148 0x02F8 0x0000 0x5 0x0 -#define MX93_PAD_SD3_DATA3__USDHC3_DATA3 0x014C 0x02FC 0x046C 0x0 0x1 -#define MX93_PAD_SD3_DATA3__FLEXSPI1_A_DATA03 0x014C 0x02FC 0x0000 0x1 0x0 -#define MX93_PAD_SD3_DATA3__FLEXIO1_FLEXIO25 0x014C 0x02FC 0x03C4 0x4 0x1 -#define MX93_PAD_SD3_DATA3__GPIO3_IO25 0x014C 0x02FC 0x0000 0x5 0x0 -#define MX93_PAD_SD2_CD_B__USDHC2_CD_B 0x0150 0x0300 0x0000 0x0 0x0 -#define MX93_PAD_SD2_CD_B__ENET_QOS_1588_EVENT0_IN 0x0150 0x0300 0x0000 0x1 0x0 -#define MX93_PAD_SD2_CD_B__I3C2_SCL 0x0150 0x0300 0x03CC 0x2 0x1 -#define MX93_PAD_SD2_CD_B__FLEXIO1_FLEXIO00 0x0150 0x0300 0x036C 0x4 0x1 -#define MX93_PAD_SD2_CD_B__GPIO3_IO00 0x0150 0x0300 0x0000 0x5 0x0 -#define MX93_PAD_SD2_CLK__USDHC2_CLK 0x0154 0x0304 0x0000 0x0 0x0 -#define MX93_PAD_SD2_CLK__ENET_QOS_1588_EVENT0_OUT 0x0154 0x0304 0x0000 0x1 0x0 -#define MX93_PAD_SD2_CLK__I3C2_SDA 0x0154 0x0304 0x03D0 0x2 0x1 -#define MX93_PAD_SD2_CLK__FLEXIO1_FLEXIO01 0x0154 0x0304 0x0370 0x4 0x1 -#define MX93_PAD_SD2_CLK__GPIO3_IO01 0x0154 0x0304 0x0000 0x5 0x0 -#define MX93_PAD_SD2_CLK__CCMSRCGPCMIX_OBSERVE0 0x0154 0x0304 0x0000 0x6 0x0 -#define MX93_PAD_SD2_CMD__USDHC2_CMD 0x0158 0x0308 0x0000 0x0 0x0 -#define MX93_PAD_SD2_CMD__ENET1_1588_EVENT0_IN 0x0158 0x0308 0x0000 0x1 0x0 -#define MX93_PAD_SD2_CMD__I3C2_PUR 0x0158 0x0308 0x0000 0x2 0x0 -#define MX93_PAD_SD2_CMD__I3C2_PUR_B 0x0158 0x0308 0x0000 0x3 0x0 -#define MX93_PAD_SD2_CMD__FLEXIO1_FLEXIO02 0x0158 0x0308 0x0374 0x4 0x1 -#define MX93_PAD_SD2_CMD__GPIO3_IO02 0x0158 0x0308 0x0000 0x5 0x0 -#define MX93_PAD_SD2_CMD__CCMSRCGPCMIX_OBSERVE1 0x0158 0x0308 0x0000 0x6 0x0 -#define MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x015C 0x030C 0x0000 0x0 0x0 -#define MX93_PAD_SD2_DATA0__ENET1_1588_EVENT0_OUT 0x015C 0x030C 0x0000 0x1 0x0 -#define MX93_PAD_SD2_DATA0__CAN2_TX 0x015C 0x030C 0x0000 0x2 0x0 -#define MX93_PAD_SD2_DATA0__FLEXIO1_FLEXIO03 0x015C 0x030C 0x0378 0x4 0x1 -#define MX93_PAD_SD2_DATA0__GPIO3_IO03 0x015C 0x030C 0x0000 0x5 0x0 -#define MX93_PAD_SD2_DATA0__CCMSRCGPCMIX_OBSERVE2 0x015C 0x030C 0x0000 0x6 0x0 -#define MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x0160 0x0310 0x0000 0x0 0x0 -#define MX93_PAD_SD2_DATA1__ENET1_1588_EVENT1_IN 0x0160 0x0310 0x0000 0x1 0x0 -#define MX93_PAD_SD2_DATA1__CAN2_RX 0x0160 0x0310 0x0364 0x2 0x3 -#define MX93_PAD_SD2_DATA1__FLEXIO1_FLEXIO04 0x0160 0x0310 0x037C 0x4 0x1 -#define MX93_PAD_SD2_DATA1__GPIO3_IO04 0x0160 0x0310 0x0000 0x5 0x0 -#define MX93_PAD_SD2_DATA1__CCMSRCGPCMIX_WAIT 0x0160 0x0310 0x0000 0x6 0x0 -#define MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x0164 0x0314 0x0000 0x0 0x0 -#define MX93_PAD_SD2_DATA2__ENET1_1588_EVENT1_OUT 0x0164 0x0314 0x0000 0x1 0x0 -#define MX93_PAD_SD2_DATA2__MQS2_RIGHT 0x0164 0x0314 0x0000 0x2 0x0 -#define MX93_PAD_SD2_DATA2__FLEXIO1_FLEXIO05 0x0164 0x0314 0x0380 0x4 0x1 -#define MX93_PAD_SD2_DATA2__GPIO3_IO05 0x0164 0x0314 0x0000 0x5 0x0 -#define MX93_PAD_SD2_DATA2__CCMSRCGPCMIX_STOP 0x0164 0x0314 0x0000 0x6 0x0 -#define MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x0168 0x0318 0x0000 0x0 0x0 -#define MX93_PAD_SD2_DATA3__LPTMR2_ALT1 0x0168 0x0318 0x0408 0x1 0x1 -#define MX93_PAD_SD2_DATA3__MQS2_LEFT 0x0168 0x0318 0x0000 0x2 0x0 -#define MX93_PAD_SD2_DATA3__FLEXIO1_FLEXIO06 0x0168 0x0318 0x0384 0x4 0x1 -#define MX93_PAD_SD2_DATA3__GPIO3_IO06 0x0168 0x0318 0x0000 0x5 0x0 -#define MX93_PAD_SD2_DATA3__CCMSRCGPCMIX_EARLY_RESET 0x0168 0x0318 0x0000 0x6 0x0 -#define MX93_PAD_SD2_RESET_B__USDHC2_RESET_B 0x016C 0x031C 0x0000 0x0 0x0 -#define MX93_PAD_SD2_RESET_B__LPTMR2_ALT2 0x016C 0x031C 0x040C 0x1 0x1 -#define MX93_PAD_SD2_RESET_B__FLEXIO1_FLEXIO07 0x016C 0x031C 0x0388 0x4 0x1 -#define MX93_PAD_SD2_RESET_B__GPIO3_IO07 0x016C 0x031C 0x0000 0x5 0x0 -#define MX93_PAD_SD2_RESET_B__CCMSRCGPCMIX_SYSTEM_RESET 0x016C 0x031C 0x0000 0x6 0x0 -#define MX93_PAD_I2C1_SCL__LPI2C1_SCL 0x0170 0x0320 0x0000 0x10 0x0 -#define MX93_PAD_I2C1_SCL__I3C1_SCL 0x0170 0x0320 0x0000 0x1 0x0 -#define MX93_PAD_I2C1_SCL__LPUART1_DCB_B 0x0170 0x0320 0x0000 0x2 0x0 -#define MX93_PAD_I2C1_SCL__TPM2_CH0 0x0170 0x0320 0x0000 0x3 0x0 -#define MX93_PAD_I2C1_SCL__GPIO1_IO00 0x0170 0x0320 0x0000 0x5 0x0 -#define MX93_PAD_I2C1_SDA__LPI2C1_SDA 0x0174 0x0324 0x0000 0x10 0x0 -#define MX93_PAD_I2C1_SDA__I3C1_SDA 0x0174 0x0324 0x0000 0x1 0x0 -#define MX93_PAD_I2C1_SDA__LPUART1_RIN_B 0x0174 0x0324 0x0000 0x2 0x0 -#define MX93_PAD_I2C1_SDA__TPM2_CH1 0x0174 0x0324 0x0000 0x3 0x0 -#define MX93_PAD_I2C1_SDA__GPIO1_IO01 0x0174 0x0324 0x0000 0x5 0x0 -#define MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x0178 0x0328 0x0000 0x10 0x0 -#define MX93_PAD_I2C2_SCL__I3C1_PUR 0x0178 0x0328 0x0000 0x1 0x0 -#define MX93_PAD_I2C2_SCL__LPUART2_DCB_B 0x0178 0x0328 0x0000 0x2 0x0 -#define MX93_PAD_I2C2_SCL__TPM2_CH2 0x0178 0x0328 0x0000 0x3 0x0 -#define MX93_PAD_I2C2_SCL__SAI1_RX_SYNC 0x0178 0x0328 0x0000 0x4 0x0 -#define MX93_PAD_I2C2_SCL__GPIO1_IO02 0x0178 0x0328 0x0000 0x5 0x0 -#define MX93_PAD_I2C2_SCL__I3C1_PUR_B 0x0178 0x0328 0x0000 0x6 0x0 -#define MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x017C 0x032C 0x0000 0x10 0x0 -#define MX93_PAD_I2C2_SDA__LPUART2_RIN_B 0x017C 0x032C 0x0000 0x2 0x0 -#define MX93_PAD_I2C2_SDA__TPM2_CH3 0x017C 0x032C 0x0000 0x3 0x0 -#define MX93_PAD_I2C2_SDA__SAI1_RX_BCLK 0x017C 0x032C 0x0000 0x4 0x0 -#define MX93_PAD_I2C2_SDA__GPIO1_IO03 0x017C 0x032C 0x0000 0x5 0x0 -#define MX93_PAD_UART1_RXD__LPUART1_RX 0x0180 0x0330 0x0000 0x0 0x0 -#define MX93_PAD_UART1_RXD__S400_UART_RX 0x0180 0x0330 0x0000 0x1 0x0 -#define MX93_PAD_UART1_RXD__LPSPI2_SIN 0x0180 0x0330 0x0000 0x2 0x0 -#define MX93_PAD_UART1_RXD__TPM1_CH0 0x0180 0x0330 0x0000 0x3 0x0 -#define MX93_PAD_UART1_RXD__GPIO1_IO04 0x0180 0x0330 0x0000 0x5 0x0 -#define MX93_PAD_UART1_TXD__LPUART1_TX 0x0184 0x0334 0x0000 0x0 0x0 -#define MX93_PAD_UART1_TXD__S400_UART_TX 0x0184 0x0334 0x0000 0x1 0x0 -#define MX93_PAD_UART1_TXD__LPSPI2_PCS0 0x0184 0x0334 0x0000 0x2 0x0 -#define MX93_PAD_UART1_TXD__TPM1_CH1 0x0184 0x0334 0x0000 0x3 0x0 -#define MX93_PAD_UART1_TXD__GPIO1_IO05 0x0184 0x0334 0x0000 0x5 0x0 -#define MX93_PAD_UART2_RXD__LPUART2_RX 0x0188 0x0338 0x0000 0x0 0x0 -#define MX93_PAD_UART2_RXD__LPUART1_CTS_B 0x0188 0x0338 0x0000 0x1 0x0 -#define MX93_PAD_UART2_RXD__LPSPI2_SOUT 0x0188 0x0338 0x0000 0x2 0x0 -#define MX93_PAD_UART2_RXD__TPM1_CH2 0x0188 0x0338 0x0000 0x3 0x0 -#define MX93_PAD_UART2_RXD__SAI1_MCLK 0x0188 0x0338 0x0448 0x4 0x0 -#define MX93_PAD_UART2_RXD__GPIO1_IO06 0x0188 0x0338 0x0000 0x5 0x0 -#define MX93_PAD_UART2_TXD__LPUART2_TX 0x018C 0x033C 0x0000 0x0 0x0 -#define MX93_PAD_UART2_TXD__LPUART1_RTS_B 0x018C 0x033C 0x0000 0x1 0x0 -#define MX93_PAD_UART2_TXD__LPSPI2_SCK 0x018C 0x033C 0x0000 0x2 0x0 -#define MX93_PAD_UART2_TXD__TPM1_CH3 0x018C 0x033C 0x0000 0x3 0x0 -#define MX93_PAD_UART2_TXD__GPIO1_IO07 0x018C 0x033C 0x0000 0x5 0x0 -#define MX93_PAD_PDM_CLK__PDM_CLK 0x0190 0x0340 0x0000 0x0 0x0 -#define MX93_PAD_PDM_CLK__MQS1_LEFT 0x0190 0x0340 0x0000 0x1 0x0 -#define MX93_PAD_PDM_CLK__LPTMR1_ALT1 0x0190 0x0340 0x0000 0x4 0x0 -#define MX93_PAD_PDM_CLK__GPIO1_IO08 0x0190 0x0340 0x0000 0x5 0x0 -#define MX93_PAD_PDM_CLK__CAN1_TX 0x0190 0x0340 0x0000 0x6 0x0 -#define MX93_PAD_PDM_BIT_STREAM0__PDM_BIT_STREAM00 0x0194 0x0344 0x0438 0x0 0x2 -#define MX93_PAD_PDM_BIT_STREAM0__MQS1_RIGHT 0x0194 0x0344 0x0000 0x1 0x0 -#define MX93_PAD_PDM_BIT_STREAM0__LPSPI1_PCS1 0x0194 0x0344 0x0000 0x2 0x0 -#define MX93_PAD_PDM_BIT_STREAM0__TPM1_EXTCLK 0x0194 0x0344 0x0000 0x3 0x0 -#define MX93_PAD_PDM_BIT_STREAM0__LPTMR1_ALT2 0x0194 0x0344 0x0000 0x4 0x0 -#define MX93_PAD_PDM_BIT_STREAM0__GPIO1_IO09 0x0194 0x0344 0x0000 0x5 0x0 -#define MX93_PAD_PDM_BIT_STREAM0__CAN1_RX 0x0194 0x0344 0x0360 0x6 0x0 -#define MX93_PAD_PDM_BIT_STREAM1__PDM_BIT_STREAM01 0x0198 0x0348 0x043C 0x0 0x2 -#define MX93_PAD_PDM_BIT_STREAM1__NMI_GLUE_NMI 0x0198 0x0348 0x0000 0x1 0x0 -#define MX93_PAD_PDM_BIT_STREAM1__LPSPI2_PCS1 0x0198 0x0348 0x0000 0x2 0x0 -#define MX93_PAD_PDM_BIT_STREAM1__TPM2_EXTCLK 0x0198 0x0348 0x0000 0x3 0x0 -#define MX93_PAD_PDM_BIT_STREAM1__LPTMR1_ALT3 0x0198 0x0348 0x0000 0x4 0x0 -#define MX93_PAD_PDM_BIT_STREAM1__GPIO1_IO10 0x0198 0x0348 0x0000 0x5 0x0 -#define MX93_PAD_PDM_BIT_STREAM1__CCMSRCGPCMIX_EXT_CLK1 0x0198 0x0348 0x0368 0x6 0x1 -#define MX93_PAD_SAI1_TXFS__SAI1_TX_SYNC 0x019C 0x034C 0x0000 0x0 0x0 -#define MX93_PAD_SAI1_TXFS__SAI1_TX_DATA01 0x019C 0x034C 0x0000 0x1 0x0 -#define MX93_PAD_SAI1_TXFS__LPSPI1_PCS0 0x019C 0x034C 0x0000 0x2 0x0 -#define MX93_PAD_SAI1_TXFS__LPUART2_DTR_B 0x019C 0x034C 0x0000 0x3 0x0 -#define MX93_PAD_SAI1_TXFS__MQS1_LEFT 0x019C 0x034C 0x0000 0x4 0x0 -#define MX93_PAD_SAI1_TXFS__GPIO1_IO11 0x019C 0x034C 0x0000 0x5 0x0 -#define MX93_PAD_SAI1_TXC__SAI1_TX_BCLK 0x01A0 0x0350 0x0000 0x0 0x0 -#define MX93_PAD_SAI1_TXC__LPUART2_CTS_B 0x01A0 0x0350 0x0000 0x1 0x0 -#define MX93_PAD_SAI1_TXC__LPSPI1_SIN 0x01A0 0x0350 0x0000 0x2 0x0 -#define MX93_PAD_SAI1_TXC__LPUART1_DSR_B 0x01A0 0x0350 0x0000 0x3 0x0 -#define MX93_PAD_SAI1_TXC__CAN1_RX 0x01A0 0x0350 0x0360 0x4 0x1 -#define MX93_PAD_SAI1_TXC__GPIO1_IO12 0x01A0 0x0350 0x0000 0x5 0x0 -#define MX93_PAD_SAI1_TXD0__SAI1_TX_DATA00 0x01A4 0x0354 0x0000 0x0 0x0 -#define MX93_PAD_SAI1_TXD0__LPUART2_RTS_B 0x01A4 0x0354 0x0000 0x1 0x0 -#define MX93_PAD_SAI1_TXD0__LPSPI1_SCK 0x01A4 0x0354 0x0000 0x2 0x0 -#define MX93_PAD_SAI1_TXD0__LPUART1_DTR_B 0x01A4 0x0354 0x0000 0x3 0x0 -#define MX93_PAD_SAI1_TXD0__CAN1_TX 0x01A4 0x0354 0x0000 0x4 0x0 -#define MX93_PAD_SAI1_TXD0__GPIO1_IO13 0x01A4 0x0354 0x0000 0x5 0x0 -#define MX93_PAD_SAI1_RXD0__SAI1_RX_DATA00 0x01A8 0x0358 0x0000 0x0 0x0 -#define MX93_PAD_SAI1_RXD0__SAI1_MCLK 0x01A8 0x0358 0x0448 0x1 0x1 -#define MX93_PAD_SAI1_RXD0__LPSPI1_SOUT 0x01A8 0x0358 0x0000 0x2 0x0 -#define MX93_PAD_SAI1_RXD0__LPUART2_DSR_B 0x01A8 0x0358 0x0000 0x3 0x0 -#define MX93_PAD_SAI1_RXD0__MQS1_RIGHT 0x01A8 0x0358 0x0000 0x4 0x0 -#define MX93_PAD_SAI1_RXD0__GPIO1_IO14 0x01A8 0x0358 0x0000 0x5 0x0 -#define MX93_PAD_WDOG_ANY__WDOG1_WDOG_ANY 0x01AC 0x035C 0x0000 0x0 0x0 -#define MX93_PAD_WDOG_ANY__GPIO1_IO15 0x01AC 0x035C 0x0000 0x5 0x0 - -#endif /* __DTS_IMX93_PINFUNC_H */ diff --git a/arch/arm/dts/imx93-u-boot.dtsi b/arch/arm/dts/imx93-u-boot.dtsi index 40e17bbc5ae..2bd42a7f66a 100644 --- a/arch/arm/dts/imx93-u-boot.dtsi +++ b/arch/arm/dts/imx93-u-boot.dtsi @@ -86,3 +86,83 @@ }; }; }; + +&tmu { + compatible = "fsl,imx93-tmu"; + reg = <0x44482000 0x1000>; + clocks = <&clk IMX93_CLK_TMC_GATE>; + little-endian; + fsl,tmu-calibration = <0x0000000e 0x800000da + 0x00000029 0x800000e9 + 0x00000056 0x80000102 + 0x000000a2 0x8000012a + 0x00000116 0x80000166 + 0x00000195 0x800001a7 + 0x000001b2 0x800001b6>; + #thermal-sensor-cells = <1>; +}; + +/* + * The following nodes should be deleted after upstream support + */ +&{/} { + usbphynop1: usbphynop1 { + compatible = "usb-nop-xceiv"; + #phy-cells = <0>; + clocks = <&clk IMX93_CLK_USB_PHY_BURUNIN>; + clock-names = "main_clk"; + }; + + usbphynop2: usbphynop2 { + compatible = "usb-nop-xceiv"; + #phy-cells = <0>; + clocks = <&clk IMX93_CLK_USB_PHY_BURUNIN>; + clock-names = "main_clk"; + }; +}; + +&{/soc@0} { + usbotg1: usb@4c100000 { + compatible = "fsl,imx93-usb", "fsl,imx7d-usb", "fsl,imx27-usb"; + reg = <0x4c100000 0x200>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX93_CLK_USB_CONTROLLER_GATE>, + <&clk IMX93_CLK_HSIO_32K_GATE>; + clock-names = "usb_ctrl_root_clk", "usb_wakeup"; + assigned-clocks = <&clk IMX93_CLK_HSIO>; + assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; + assigned-clock-rates = <133000000>; + phys = <&usbphynop1>; + fsl,usbmisc = <&usbmisc1 0>; + status = "disabled"; + }; + + usbmisc1: usbmisc@4c100200 { + compatible = "fsl,imx8mm-usbmisc", "fsl,imx7d-usbmisc", + "fsl,imx6q-usbmisc"; + reg = <0x4c100200 0x200>; + #index-cells = <1>; + }; + + usbotg2: usb@4c200000 { + compatible = "fsl,imx93-usb", "fsl,imx7d-usb", "fsl,imx27-usb"; + reg = <0x4c200000 0x200>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clk IMX93_CLK_USB_CONTROLLER_GATE>, + <&clk IMX93_CLK_HSIO_32K_GATE>; + clock-names = "usb_ctrl_root_clk", "usb_wakeup"; + assigned-clocks = <&clk IMX93_CLK_HSIO>; + assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; + assigned-clock-rates = <133000000>; + phys = <&usbphynop2>; + fsl,usbmisc = <&usbmisc2 0>; + status = "disabled"; + }; + + usbmisc2: usbmisc@4c200200 { + compatible = "fsl,imx8mm-usbmisc", "fsl,imx7d-usbmisc", + "fsl,imx6q-usbmisc"; + reg = <0x4c200200 0x200>; + #index-cells = <1>; + }; +}; diff --git a/arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi index 1193fc0ca19..e8a5afd2131 100644 --- a/arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi @@ -148,6 +148,28 @@ bootph-pre-ram; };
+/* + * The two nodes below won't be needed once support is added + * to the Linux kernel. + */ +&usbotg1 { + dr_mode = "otg"; + hnp-disable; + srp-disable; + adp-disable; + disable-over-current; + status = "okay"; +}; + +&usbotg2 { + dr_mode = "host"; + hnp-disable; + srp-disable; + adp-disable; + disable-over-current; + status = "okay"; +}; + /* * The two nodes below won't be needed once nxp,pca9451a * support is added to the Linux kernel. diff --git a/arch/arm/dts/imx93-var-som-symphony.dts b/arch/arm/dts/imx93-var-som-symphony.dts deleted file mode 100644 index 1bc61942716..00000000000 --- a/arch/arm/dts/imx93-var-som-symphony.dts +++ /dev/null @@ -1,323 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2021 NXP - * Copyright 2023 Variscite Ltd. - */ - -/dts-v1/; - -#include "imx93-var-som.dtsi" - -/{ - model = "Variscite VAR-SOM-MX93 on Symphony evaluation board"; - compatible = "variscite,var-som-mx93-symphony", - "variscite,var-som-mx93", "fsl,imx93"; - - aliases { - ethernet0 = &eqos; - ethernet1 = &fec; - }; - - chosen { - stdout-path = &lpuart1; - }; - - /* - * Needed only for Symphony <= v1.5 - */ - reg_fec_phy: regulator-fec-phy { - compatible = "regulator-fixed"; - regulator-name = "fec-phy"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-enable-ramp-delay = <20000>; - gpio = <&pca9534 7 GPIO_ACTIVE_HIGH>; - enable-active-high; - regulator-always-on; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio2 18 GPIO_ACTIVE_HIGH>; - off-on-delay-us = <20000>; - enable-active-high; - }; - - reg_vref_1v8: regulator-adc-vref { - compatible = "regulator-fixed"; - regulator-name = "vref_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - ethosu_mem: ethosu-region@88000000 { - compatible = "shared-dma-pool"; - reusable; - reg = <0x0 0x88000000 0x0 0x8000000>; - }; - - vdev0vring0: vdev0vring0@87ee0000 { - reg = <0 0x87ee0000 0 0x8000>; - no-map; - }; - - vdev0vring1: vdev0vring1@87ee8000 { - reg = <0 0x87ee8000 0 0x8000>; - no-map; - }; - - vdev1vring0: vdev1vring0@87ef0000 { - reg = <0 0x87ef0000 0 0x8000>; - no-map; - }; - - vdev1vring1: vdev1vring1@87ef8000 { - reg = <0 0x87ef8000 0 0x8000>; - no-map; - }; - - rsc_table: rsc-table@2021f000 { - reg = <0 0x2021f000 0 0x1000>; - no-map; - }; - - vdevbuffer: vdevbuffer@87f00000 { - compatible = "shared-dma-pool"; - reg = <0 0x87f00000 0 0x100000>; - no-map; - }; - - ele_reserved: ele-reserved@87de0000 { - compatible = "shared-dma-pool"; - reg = <0 0x87de0000 0 0x100000>; - no-map; - }; - }; -}; - -/* Use external instead of internal RTC*/ -&bbnsm_rtc { - status = "disabled"; -}; - -&eqos { - mdio { - ethphy1: ethernet-phy@5 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <5>; - qca,disable-smarteee; - eee-broken-1000t; - reset-gpios = <&pca9534 5 GPIO_ACTIVE_LOW>; - reset-assert-us = <10000>; - reset-deassert-us = <20000>; - vddio-supply = <&vddio1>; - - vddio1: vddio-regulator { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - }; - }; -}; - -&fec { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; - phy-mode = "rgmii"; - phy-handle = <ðphy1>; - phy-supply = <®_fec_phy>; - status = "okay"; -}; - -&flexcan1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexcan1>; - status = "okay"; -}; - -&iomuxc { - pinctrl_fec: fecgrp { - fsl,pins = < - MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x57e - MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x57e - MX93_PAD_ENET2_RD2__ENET1_RGMII_RD2 0x57e - MX93_PAD_ENET2_RD3__ENET1_RGMII_RD3 0x57e - MX93_PAD_ENET2_RXC__ENET1_RGMII_RXC 0x5fe - MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x57e - MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x57e - MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x57e - MX93_PAD_ENET2_TD2__ENET1_RGMII_TD2 0x57e - MX93_PAD_ENET2_TD3__ENET1_RGMII_TD3 0x57e - MX93_PAD_ENET2_TXC__ENET1_RGMII_TXC 0x5fe - MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_flexcan1: flexcan1grp { - fsl,pins = < - MX93_PAD_PDM_CLK__CAN1_TX 0x139e - MX93_PAD_PDM_BIT_STREAM0__CAN1_RX 0x139e - >; - }; - - pinctrl_lpi2c1: lpi2c1grp { - fsl,pins = < - MX93_PAD_I2C1_SCL__LPI2C1_SCL 0x40000b9e - MX93_PAD_I2C1_SDA__LPI2C1_SDA 0x40000b9e - >; - }; - - pinctrl_lpi2c1_gpio: lpi2c1gpiogrp { - fsl,pins = < - MX93_PAD_I2C1_SCL__GPIO1_IO00 0x31e - MX93_PAD_I2C1_SDA__GPIO1_IO01 0x31e - >; - }; - - pinctrl_lpi2c5: lpi2c5grp { - fsl,pins = < - MX93_PAD_GPIO_IO23__LPI2C5_SCL 0x40000b9e - MX93_PAD_GPIO_IO22__LPI2C5_SDA 0x40000b9e - >; - }; - - pinctrl_lpi2c5_gpio: lpi2c5gpiogrp { - fsl,pins = < - MX93_PAD_GPIO_IO23__GPIO2_IO23 0x31e - MX93_PAD_GPIO_IO22__GPIO2_IO22 0x31e - >; - }; - - pinctrl_pca9534: pca9534grp { - fsl,pins = < - MX93_PAD_CCM_CLKO1__GPIO3_IO26 0x31e - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX93_PAD_UART1_RXD__LPUART1_RX 0x31e - MX93_PAD_UART1_TXD__LPUART1_TX 0x31e - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { - fsl,pins = < - MX93_PAD_GPIO_IO18__GPIO2_IO18 0x31e - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX93_PAD_SD2_CLK__USDHC2_CLK 0x15fe - MX93_PAD_SD2_CMD__USDHC2_CMD 0x13fe - MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x13fe - MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x13fe - MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x13fe - MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x13fe - MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e - >; - }; - - pinctrl_usdhc2_gpio: usdhc2gpiogrp { - fsl,pins = < - MX93_PAD_SD2_CD_B__GPIO3_IO00 0x31e - >; - }; -}; - -&lpi2c1 { - clock-frequency = <400000>; - pinctrl-names = "default", "sleep", "gpio"; - pinctrl-0 = <&pinctrl_lpi2c1>; - pinctrl-1 = <&pinctrl_lpi2c1_gpio>; - pinctrl-2 = <&pinctrl_lpi2c1_gpio>; - scl-gpios = <&gpio1 0 GPIO_ACTIVE_HIGH>; - sda-gpios = <&gpio1 1 GPIO_ACTIVE_HIGH>; - status = "okay"; - - /* DS1337 RTC module */ - rtc@68 { - compatible = "dallas,ds1337"; - reg = <0x68>; - }; -}; - -&lpi2c5 { - clock-frequency = <400000>; - pinctrl-names = "default", "sleep", "gpio"; - pinctrl-0 = <&pinctrl_lpi2c5>; - pinctrl-1 = <&pinctrl_lpi2c5_gpio>; - pinctrl-2 = <&pinctrl_lpi2c5_gpio>; - scl-gpios = <&gpio2 23 GPIO_ACTIVE_HIGH>; - sda-gpios = <&gpio2 22 GPIO_ACTIVE_HIGH>; - status = "okay"; - - pca9534: gpio@20 { - compatible = "nxp,pca9534"; - reg = <0x20>; - gpio-controller; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pca9534>; - interrupt-parent = <&gpio3>; - interrupts = <26 IRQ_TYPE_EDGE_FALLING>; - #gpio-cells = <2>; - wakeup-source; - }; -}; - -/* Console */ -&lpuart1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - clocks = <&clk IMX93_CLK_LPUART1_GATE>, <&clk IMX93_CLK_LPUART1_GATE>; - clock-names = "ipg", "per"; - status = "okay"; -}; - -&usbotg1 { - dr_mode = "otg"; - hnp-disable; - srp-disable; - adp-disable; - disable-over-current; - status = "okay"; -}; - -&usbotg2 { - dr_mode = "host"; - hnp-disable; - srp-disable; - adp-disable; - disable-over-current; - status = "okay"; -}; - -/* SD */ -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio3 00 GPIO_ACTIVE_LOW>; - vmmc-supply = <®_usdhc2_vmmc>; - bus-width = <4>; - status = "okay"; - no-sdio; - no-mmc; -}; - -/* Watchdog */ -&wdog3 { - status = "okay"; -}; diff --git a/arch/arm/dts/imx93-var-som.dtsi b/arch/arm/dts/imx93-var-som.dtsi deleted file mode 100644 index 6c77b886666..00000000000 --- a/arch/arm/dts/imx93-var-som.dtsi +++ /dev/null @@ -1,111 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 NXP - * Copyright 2023 Variscite Ltd. - */ - -/dts-v1/; - -#include "imx93.dtsi" - -/{ - model = "Variscite VAR-SOM-MX93 module"; - compatible = "variscite,var-som-mx93", "fsl,imx93"; - - mmc_pwrseq: mmc-pwrseq { - compatible = "mmc-pwrseq-simple"; - post-power-on-delay-ms = <100>; - power-off-delay-us = <10000>; - reset-gpios = <&gpio4 14 GPIO_ACTIVE_LOW>, /* WIFI_RESET */ - <&gpio3 7 GPIO_ACTIVE_LOW>; /* WIFI_PWR_EN */ - }; - - reg_eqos_phy: regulator-eqos-phy { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_eqos_phy>; - regulator-name = "eth_phy_pwr"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio1 7 GPIO_ACTIVE_HIGH>; - enable-active-high; - startup-delay-us = <100000>; - regulator-always-on; - }; -}; - -&eqos { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_eqos>; - phy-mode = "rgmii"; - phy-handle = <ðphy0>; - phy-supply = <®_eqos_phy>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <1000000>; - - ethphy0: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - eee-broken-1000t; - }; - }; -}; - -&iomuxc { - pinctrl_eqos: eqosgrp { - fsl,pins = < - MX93_PAD_ENET1_MDC__ENET_QOS_MDC 0x57e - MX93_PAD_ENET1_MDIO__ENET_QOS_MDIO 0x57e - MX93_PAD_ENET1_RD0__ENET_QOS_RGMII_RD0 0x57e - MX93_PAD_ENET1_RD1__ENET_QOS_RGMII_RD1 0x57e - MX93_PAD_ENET1_RD2__ENET_QOS_RGMII_RD2 0x57e - MX93_PAD_ENET1_RD3__ENET_QOS_RGMII_RD3 0x57e - MX93_PAD_ENET1_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x5fe - MX93_PAD_ENET1_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x57e - MX93_PAD_ENET1_TD0__ENET_QOS_RGMII_TD0 0x57e - MX93_PAD_ENET1_TD1__ENET_QOS_RGMII_TD1 0x57e - MX93_PAD_ENET1_TD2__ENET_QOS_RGMII_TD2 0x57e - MX93_PAD_ENET1_TD3__ENET_QOS_RGMII_TD3 0x57e - MX93_PAD_ENET1_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x5fe - MX93_PAD_ENET1_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_reg_eqos_phy: regeqosgrp { - fsl,pins = < - MX93_PAD_UART2_TXD__GPIO1_IO07 0x51e - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX93_PAD_SD1_CLK__USDHC1_CLK 0x15fe - MX93_PAD_SD1_CMD__USDHC1_CMD 0x13fe - MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x13fe - MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x13fe - MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x13fe - MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x13fe - MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x13fe - MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x13fe - MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x13fe - MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x13fe - MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x15fe - >; - }; -}; - -/* eMMC */ -&usdhc1 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc1>; - pinctrl-1 = <&pinctrl_usdhc1>; - pinctrl-2 = <&pinctrl_usdhc1>; - bus-width = <8>; - non-removable; - status = "okay"; -}; diff --git a/arch/arm/dts/imx93.dtsi b/arch/arm/dts/imx93.dtsi deleted file mode 100644 index d6964714ea0..00000000000 --- a/arch/arm/dts/imx93.dtsi +++ /dev/null @@ -1,906 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 NXP - */ - -#include <dt-bindings/clock/imx93-clock.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/power/fsl,imx93-power.h> -#include <dt-bindings/thermal/thermal.h> - -#include "imx93-pinfunc.h" - -/ { - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - gpio0 = &gpio1; - gpio1 = &gpio2; - gpio2 = &gpio3; - gpio3 = &gpio4; - i2c0 = &lpi2c1; - i2c1 = &lpi2c2; - i2c2 = &lpi2c3; - i2c3 = &lpi2c4; - i2c4 = &lpi2c5; - i2c5 = &lpi2c6; - i2c6 = &lpi2c7; - i2c7 = &lpi2c8; - mmc0 = &usdhc1; - mmc1 = &usdhc2; - mmc2 = &usdhc3; - serial0 = &lpuart1; - serial1 = &lpuart2; - serial2 = &lpuart3; - serial3 = &lpuart4; - serial4 = &lpuart5; - serial5 = &lpuart6; - serial6 = &lpuart7; - serial7 = &lpuart8; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - A55_0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a55"; - reg = <0x0>; - enable-method = "psci"; - #cooling-cells = <2>; - }; - - A55_1: cpu@100 { - device_type = "cpu"; - compatible = "arm,cortex-a55"; - reg = <0x100>; - enable-method = "psci"; - #cooling-cells = <2>; - }; - - }; - - osc_32k: clock-osc-32k { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "osc_32k"; - }; - - osc_24m: clock-osc-24m { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24000000>; - clock-output-names = "osc_24m"; - }; - - clk_ext1: clock-ext1 { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <133000000>; - clock-output-names = "clk_ext1"; - }; - - pmu { - compatible = "arm,cortex-a55-pmu"; - interrupts = <GIC_PPI 7 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(6) | IRQ_TYPE_LEVEL_LOW)>; - clock-frequency = <24000000>; - arm,no-tick-in-suspend; - interrupt-parent = <&gic>; - }; - - gic: interrupt-controller@48000000 { - compatible = "arm,gic-v3"; - reg = <0 0x48000000 0 0x10000>, - <0 0x48040000 0 0xc0000>; - #interrupt-cells = <3>; - interrupt-controller; - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - interrupt-parent = <&gic>; - }; - - thermal-zones { - cpu-thermal { - polling-delay-passive = <250>; - polling-delay = <2000>; - - thermal-sensors = <&tmu 0>; - - trips { - cpu_alert: cpu-alert { - temperature = <80000>; - hysteresis = <2000>; - type = "passive"; - }; - - cpu_crit: cpu-crit { - temperature = <90000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&cpu_alert>; - cooling-device = - <&A55_0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&A55_1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - }; - - usbphynop1: usbphynop1 { - compatible = "usb-nop-xceiv"; - #phy-cells = <0>; - clocks = <&clk IMX93_CLK_USB_PHY_BURUNIN>; - clock-names = "main_clk"; - }; - - usbphynop2: usbphynop2 { - compatible = "usb-nop-xceiv"; - #phy-cells = <0>; - clocks = <&clk IMX93_CLK_USB_PHY_BURUNIN>; - clock-names = "main_clk"; - }; - - soc@0 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x0 0x0 0x80000000>, - <0x28000000 0x0 0x28000000 0x10000000>; - - aips1: bus@44000000 { - compatible = "fsl,aips-bus", "simple-bus"; - reg = <0x44000000 0x800000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - anomix_ns_gpr: syscon@44210000 { - compatible = "fsl,imx93-aonmix-ns-syscfg", "syscon"; - reg = <0x44210000 0x1000>; - }; - - mu1: mailbox@44230000 { - compatible = "fsl,imx93-mu", "fsl,imx8ulp-mu"; - reg = <0x44230000 0x10000>; - interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_MU1_B_GATE>; - #mbox-cells = <2>; - status = "disabled"; - }; - - system_counter: timer@44290000 { - compatible = "nxp,sysctr-timer"; - reg = <0x44290000 0x30000>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&osc_24m>; - clock-names = "per"; - nxp,no-divider; - }; - - tpm1: pwm@44310000 { - compatible = "fsl,imx7ulp-pwm"; - reg = <0x44310000 0x1000>; - clocks = <&clk IMX93_CLK_TPM1_GATE>; - #pwm-cells = <3>; - status = "disabled"; - }; - - tpm2: pwm@44320000 { - compatible = "fsl,imx7ulp-pwm"; - reg = <0x44320000 0x10000>; - clocks = <&clk IMX93_CLK_TPM2_GATE>; - #pwm-cells = <3>; - status = "disabled"; - }; - - lpi2c1: i2c@44340000 { - compatible = "fsl,imx93-lpi2c", "fsl,imx7ulp-lpi2c"; - reg = <0x44340000 0x10000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPI2C1_GATE>, - <&clk IMX93_CLK_BUS_AON>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpi2c2: i2c@44350000 { - compatible = "fsl,imx93-lpi2c", "fsl,imx7ulp-lpi2c"; - reg = <0x44350000 0x10000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPI2C2_GATE>, - <&clk IMX93_CLK_BUS_AON>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpspi1: spi@44360000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx93-spi", "fsl,imx7ulp-spi"; - reg = <0x44360000 0x10000>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPSPI1_GATE>, - <&clk IMX93_CLK_BUS_AON>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpspi2: spi@44370000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx93-spi", "fsl,imx7ulp-spi"; - reg = <0x44370000 0x10000>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPSPI2_GATE>, - <&clk IMX93_CLK_BUS_AON>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpuart1: serial@44380000 { - compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x44380000 0x1000>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART1_GATE>, <&clk IMX93_CLK_LPUART1_GATE>; - clock-names = "ipg", "per"; - status = "disabled"; - }; - - lpuart2: serial@44390000 { - compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x44390000 0x1000>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART2_GATE>; - clock-names = "ipg"; - status = "disabled"; - }; - - flexcan1: can@443a0000 { - compatible = "fsl,imx93-flexcan"; - reg = <0x443a0000 0x10000>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_BUS_AON>, - <&clk IMX93_CLK_CAN1_GATE>; - clock-names = "ipg", "per"; - assigned-clocks = <&clk IMX93_CLK_CAN1>; - assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; - assigned-clock-rates = <40000000>; - fsl,clk-source = /bits/ 8 <0>; - status = "disabled"; - }; - - iomuxc: pinctrl@443c0000 { - compatible = "fsl,imx93-iomuxc"; - reg = <0x443c0000 0x10000>; - status = "okay"; - }; - - bbnsm: bbnsm@44440000 { - compatible = "nxp,imx93-bbnsm", "syscon", "simple-mfd"; - reg = <0x44440000 0x10000>; - - bbnsm_rtc: rtc { - compatible = "nxp,imx93-bbnsm-rtc"; - interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - }; - - bbnsm_pwrkey: pwrkey { - compatible = "nxp,imx93-bbnsm-pwrkey"; - interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - linux,code = <KEY_POWER>; - }; - }; - - clk: clock-controller@44450000 { - compatible = "fsl,imx93-ccm"; - reg = <0x44450000 0x10000>; - #clock-cells = <1>; - clocks = <&osc_32k>, <&osc_24m>, <&clk_ext1>; - clock-names = "osc_32k", "osc_24m", "clk_ext1"; - status = "okay"; - }; - - src: system-controller@44460000 { - compatible = "fsl,imx93-src", "syscon"; - reg = <0x44460000 0x10000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - mediamix: power-domain@44462400 { - compatible = "fsl,imx93-src-slice"; - reg = <0x44462400 0x400>, <0x44465800 0x400>; - #power-domain-cells = <0>; - clocks = <&clk IMX93_CLK_MEDIA_AXI>, - <&clk IMX93_CLK_MEDIA_APB>; - }; - - mlmix: power-domain@44461800 { - compatible = "fsl,imx93-src-slice"; - reg = <0x44461800 0x400>, <0x44464800 0x400>; - #power-domain-cells = <0>; - clocks = <&clk IMX93_CLK_ML_APB>, - <&clk IMX93_CLK_ML>; - }; - }; - - anatop: anatop@44480000 { - compatible = "fsl,imx93-anatop", "syscon"; - reg = <0x44480000 0x10000>; - }; - - tmu: tmu@44482000 { - compatible = "fsl,imx93-tmu"; - reg = <0x44482000 0x1000>; - clocks = <&clk IMX93_CLK_TMC_GATE>; - little-endian; - fsl,tmu-calibration = <0x0000000e 0x800000da - 0x00000029 0x800000e9 - 0x00000056 0x80000102 - 0x000000a2 0x8000012a - 0x00000116 0x80000166 - 0x00000195 0x800001a7 - 0x000001b2 0x800001b6>; - #thermal-sensor-cells = <1>; - }; - - adc1: adc@44530000 { - compatible = "nxp,imx93-adc"; - reg = <0x44530000 0x10000>; - interrupts = <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_ADC1_GATE>; - clock-names = "ipg"; - #io-channel-cells = <1>; - status = "disabled"; - }; - }; - - aips2: bus@42000000 { - compatible = "fsl,aips-bus", "simple-bus"; - reg = <0x42000000 0x800000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - wakeupmix_gpr: syscon@42420000 { - compatible = "fsl,imx93-wakeupmix-syscfg", "syscon"; - reg = <0x42420000 0x1000>; - }; - - mu2: mailbox@42440000 { - compatible = "fsl,imx93-mu", "fsl,imx8ulp-mu"; - reg = <0x42440000 0x10000>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_MU2_B_GATE>; - #mbox-cells = <2>; - status = "disabled"; - }; - - wdog3: wdog@42490000 { - compatible = "fsl,imx93-wdt"; - reg = <0x42490000 0x10000>; - interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_WDOG3_GATE>; - timeout-sec = <40>; - }; - - tpm3: pwm@424e0000 { - compatible = "fsl,imx7ulp-pwm"; - reg = <0x424e0000 0x1000>; - clocks = <&clk IMX93_CLK_TPM3_GATE>; - #pwm-cells = <3>; - status = "disabled"; - }; - - tpm4: pwm@424f0000 { - compatible = "fsl,imx7ulp-pwm"; - reg = <0x424f0000 0x10000>; - clocks = <&clk IMX93_CLK_TPM4_GATE>; - #pwm-cells = <3>; - status = "disabled"; - }; - - tpm5: pwm@42500000 { - compatible = "fsl,imx7ulp-pwm"; - reg = <0x42500000 0x10000>; - clocks = <&clk IMX93_CLK_TPM5_GATE>; - #pwm-cells = <3>; - status = "disabled"; - }; - - tpm6: pwm@42510000 { - compatible = "fsl,imx7ulp-pwm"; - reg = <0x42510000 0x10000>; - clocks = <&clk IMX93_CLK_TPM6_GATE>; - #pwm-cells = <3>; - status = "disabled"; - }; - - lpi2c3: i2c@42530000 { - compatible = "fsl,imx93-lpi2c", "fsl,imx7ulp-lpi2c"; - reg = <0x42530000 0x10000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPI2C3_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpi2c4: i2c@42540000 { - compatible = "fsl,imx93-lpi2c", "fsl,imx7ulp-lpi2c"; - reg = <0x42540000 0x10000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPI2C4_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpspi3: spi@42550000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx93-spi", "fsl,imx7ulp-spi"; - reg = <0x42550000 0x10000>; - interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPSPI3_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpspi4: spi@42560000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx93-spi", "fsl,imx7ulp-spi"; - reg = <0x42560000 0x10000>; - interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPSPI4_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpuart3: serial@42570000 { - compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x42570000 0x1000>; - interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART3_GATE>; - clock-names = "ipg"; - status = "disabled"; - }; - - lpuart4: serial@42580000 { - compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x42580000 0x1000>; - interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART4_GATE>; - clock-names = "ipg"; - status = "disabled"; - }; - - lpuart5: serial@42590000 { - compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x42590000 0x1000>; - interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART5_GATE>; - clock-names = "ipg"; - status = "disabled"; - }; - - lpuart6: serial@425a0000 { - compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x425a0000 0x1000>; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART6_GATE>; - clock-names = "ipg"; - status = "disabled"; - }; - - flexcan2: can@425b0000 { - compatible = "fsl,imx93-flexcan"; - reg = <0x425b0000 0x10000>; - interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_BUS_WAKEUP>, - <&clk IMX93_CLK_CAN2_GATE>; - clock-names = "ipg", "per"; - assigned-clocks = <&clk IMX93_CLK_CAN2>; - assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; - assigned-clock-rates = <40000000>; - fsl,clk-source = /bits/ 8 <0>; - status = "disabled"; - }; - - flexspi1: spi@425e0000 { - compatible = "nxp,imx8mm-fspi"; - reg = <0x425e0000 0x10000>, <0x28000000 0x10000000>; - reg-names = "fspi_base", "fspi_mmap"; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_FLEXSPI1_GATE>, - <&clk IMX93_CLK_FLEXSPI1_GATE>; - clock-names = "fspi_en", "fspi"; - assigned-clocks = <&clk IMX93_CLK_FLEXSPI1>; - assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1>; - status = "disabled"; - }; - - lpuart7: serial@42690000 { - compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x42690000 0x1000>; - interrupts = <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART7_GATE>; - clock-names = "ipg"; - status = "disabled"; - }; - - lpuart8: serial@426a0000 { - compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; - reg = <0x426a0000 0x1000>; - interrupts = <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART8_GATE>; - clock-names = "ipg"; - status = "disabled"; - }; - - lpi2c5: i2c@426b0000 { - compatible = "fsl,imx93-lpi2c", "fsl,imx7ulp-lpi2c"; - reg = <0x426b0000 0x10000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPI2C5_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpi2c6: i2c@426c0000 { - compatible = "fsl,imx93-lpi2c", "fsl,imx7ulp-lpi2c"; - reg = <0x426c0000 0x10000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPI2C6_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpi2c7: i2c@426d0000 { - compatible = "fsl,imx93-lpi2c", "fsl,imx7ulp-lpi2c"; - reg = <0x426d0000 0x10000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPI2C7_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpi2c8: i2c@426e0000 { - compatible = "fsl,imx93-lpi2c", "fsl,imx7ulp-lpi2c"; - reg = <0x426e0000 0x10000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPI2C8_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpspi5: spi@426f0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx93-spi", "fsl,imx7ulp-spi"; - reg = <0x426f0000 0x10000>; - interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPSPI5_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpspi6: spi@42700000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx93-spi", "fsl,imx7ulp-spi"; - reg = <0x42700000 0x10000>; - interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPSPI6_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpspi7: spi@42710000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx93-spi", "fsl,imx7ulp-spi"; - reg = <0x42710000 0x10000>; - interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPSPI7_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - lpspi8: spi@42720000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx93-spi", "fsl,imx7ulp-spi"; - reg = <0x42720000 0x10000>; - interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPSPI8_GATE>, - <&clk IMX93_CLK_BUS_WAKEUP>; - clock-names = "per", "ipg"; - status = "disabled"; - }; - - }; - - aips3: bus@42800000 { - compatible = "fsl,aips-bus", "simple-bus"; - reg = <0x42800000 0x800000>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - usdhc1: mmc@42850000 { - compatible = "fsl,imx93-usdhc", "fsl,imx8mm-usdhc"; - reg = <0x42850000 0x10000>; - interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_BUS_WAKEUP>, - <&clk IMX93_CLK_WAKEUP_AXI>, - <&clk IMX93_CLK_USDHC1_GATE>; - clock-names = "ipg", "ahb", "per"; - bus-width = <8>; - fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; - status = "disabled"; - }; - - usdhc2: mmc@42860000 { - compatible = "fsl,imx93-usdhc", "fsl,imx8mm-usdhc"; - reg = <0x42860000 0x10000>; - interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_BUS_WAKEUP>, - <&clk IMX93_CLK_WAKEUP_AXI>, - <&clk IMX93_CLK_USDHC2_GATE>; - clock-names = "ipg", "ahb", "per"; - bus-width = <4>; - fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; - status = "disabled"; - }; - - eqos: ethernet@428a0000 { - compatible = "nxp,imx93-dwmac-eqos", "snps,dwmac-5.10a"; - reg = <0x428a0000 0x10000>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq", "eth_wake_irq"; - clocks = <&clk IMX93_CLK_ENET_QOS_GATE>, - <&clk IMX93_CLK_ENET_QOS_GATE>, - <&clk IMX93_CLK_ENET_TIMER2>, - <&clk IMX93_CLK_ENET>, - <&clk IMX93_CLK_ENET_QOS_GATE>; - clock-names = "stmmaceth", "pclk", "ptp_ref", "tx", "mem"; - assigned-clocks = <&clk IMX93_CLK_ENET_TIMER2>, - <&clk IMX93_CLK_ENET>; - assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>, - <&clk IMX93_CLK_SYS_PLL_PFD0_DIV2>; - assigned-clock-rates = <100000000>, <250000000>; - intf_mode = <&wakeupmix_gpr 0x28>; - snps,clk-csr = <0>; - status = "disabled"; - }; - - fec: ethernet@42890000 { - compatible = "fsl,imx93-fec", "fsl,imx8mq-fec", "fsl,imx6sx-fec"; - reg = <0x42890000 0x10000>; - interrupts = <GIC_SPI 179 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 180 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_ENET1_GATE>, - <&clk IMX93_CLK_ENET1_GATE>, - <&clk IMX93_CLK_ENET_TIMER1>, - <&clk IMX93_CLK_ENET_REF>, - <&clk IMX93_CLK_ENET_REF_PHY>; - clock-names = "ipg", "ahb", "ptp", - "enet_clk_ref", "enet_out"; - assigned-clocks = <&clk IMX93_CLK_ENET_TIMER1>, - <&clk IMX93_CLK_ENET_REF>, - <&clk IMX93_CLK_ENET_REF_PHY>; - assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>, - <&clk IMX93_CLK_SYS_PLL_PFD0_DIV2>, - <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; - assigned-clock-rates = <100000000>, <250000000>, <50000000>; - fsl,num-tx-queues = <3>; - fsl,num-rx-queues = <3>; - status = "disabled"; - }; - - usdhc3: mmc@428b0000 { - compatible = "fsl,imx93-usdhc", "fsl,imx8mm-usdhc"; - reg = <0x428b0000 0x10000>; - interrupts = <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_BUS_WAKEUP>, - <&clk IMX93_CLK_WAKEUP_AXI>, - <&clk IMX93_CLK_USDHC3_GATE>; - clock-names = "ipg", "ahb", "per"; - bus-width = <4>; - fsl,tuning-start-tap = <20>; - fsl,tuning-step= <2>; - status = "disabled"; - }; - }; - - gpio2: gpio@43810080 { - compatible = "fsl,imx93-gpio", "fsl,imx7ulp-gpio"; - reg = <0x43810080 0x1000>, <0x43810040 0x40>; - gpio-controller; - #gpio-cells = <2>; - interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&clk IMX93_CLK_GPIO2_GATE>, - <&clk IMX93_CLK_GPIO2_GATE>; - clock-names = "gpio", "port"; - gpio-ranges = <&iomuxc 0 4 30>; - }; - - gpio3: gpio@43820080 { - compatible = "fsl,imx93-gpio", "fsl,imx7ulp-gpio"; - reg = <0x43820080 0x1000>, <0x43820040 0x40>; - gpio-controller; - #gpio-cells = <2>; - interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&clk IMX93_CLK_GPIO3_GATE>, - <&clk IMX93_CLK_GPIO3_GATE>; - clock-names = "gpio", "port"; - gpio-ranges = <&iomuxc 0 84 8>, <&iomuxc 8 66 18>, - <&iomuxc 26 34 2>, <&iomuxc 28 0 4>; - }; - - gpio4: gpio@43830080 { - compatible = "fsl,imx93-gpio", "fsl,imx7ulp-gpio"; - reg = <0x43830080 0x1000>, <0x43830040 0x40>; - gpio-controller; - #gpio-cells = <2>; - interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&clk IMX93_CLK_GPIO4_GATE>, - <&clk IMX93_CLK_GPIO4_GATE>; - clock-names = "gpio", "port"; - gpio-ranges = <&iomuxc 0 38 28>, <&iomuxc 28 36 2>; - }; - - gpio1: gpio@47400080 { - compatible = "fsl,imx93-gpio", "fsl,imx7ulp-gpio"; - reg = <0x47400080 0x1000>, <0x47400040 0x40>; - gpio-controller; - #gpio-cells = <2>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&clk IMX93_CLK_GPIO1_GATE>, - <&clk IMX93_CLK_GPIO1_GATE>; - clock-names = "gpio", "port"; - gpio-ranges = <&iomuxc 0 92 16>; - }; - - s4muap: mailbox@47520000 { - compatible = "fsl,imx93-mu-s4"; - reg = <0x47520000 0x10000>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tx", "rx"; - #mbox-cells = <2>; - }; - - media_blk_ctrl: system-controller@4ac10000 { - compatible = "fsl,imx93-media-blk-ctrl", "syscon"; - reg = <0x4ac10000 0x10000>; - power-domains = <&mediamix>; - clocks = <&clk IMX93_CLK_MEDIA_APB>, - <&clk IMX93_CLK_MEDIA_AXI>, - <&clk IMX93_CLK_NIC_MEDIA_GATE>, - <&clk IMX93_CLK_MEDIA_DISP_PIX>, - <&clk IMX93_CLK_CAM_PIX>, - <&clk IMX93_CLK_PXP_GATE>, - <&clk IMX93_CLK_LCDIF_GATE>, - <&clk IMX93_CLK_ISI_GATE>, - <&clk IMX93_CLK_MIPI_CSI_GATE>, - <&clk IMX93_CLK_MIPI_DSI_GATE>; - clock-names = "apb", "axi", "nic", "disp", "cam", - "pxp", "lcdif", "isi", "csi", "dsi"; - #power-domain-cells = <1>; - status = "disabled"; - }; - - usbotg1: usb@4c100000 { - compatible = "fsl,imx93-usb", "fsl,imx7d-usb", "fsl,imx27-usb"; - reg = <0x4c100000 0x200>; - interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_USB_CONTROLLER_GATE>, - <&clk IMX93_CLK_HSIO_32K_GATE>; - clock-names = "usb_ctrl_root_clk", "usb_wakeup"; - assigned-clocks = <&clk IMX93_CLK_HSIO>; - assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; - assigned-clock-rates = <133000000>; - phys = <&usbphynop1>; - fsl,usbmisc = <&usbmisc1 0>; - status = "disabled"; - }; - - usbmisc1: usbmisc@4c100200 { - compatible = "fsl,imx8mm-usbmisc", "fsl,imx7d-usbmisc", - "fsl,imx6q-usbmisc"; - reg = <0x4c100200 0x200>; - #index-cells = <1>; - }; - - usbotg2: usb@4c200000 { - compatible = "fsl,imx93-usb", "fsl,imx7d-usb", "fsl,imx27-usb"; - reg = <0x4c200000 0x200>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_USB_CONTROLLER_GATE>, - <&clk IMX93_CLK_HSIO_32K_GATE>; - clock-names = "usb_ctrl_root_clk", "usb_wakeup"; - assigned-clocks = <&clk IMX93_CLK_HSIO>; - assigned-clock-parents = <&clk IMX93_CLK_SYS_PLL_PFD1_DIV2>; - assigned-clock-rates = <133000000>; - phys = <&usbphynop2>; - fsl,usbmisc = <&usbmisc2 0>; - status = "disabled"; - }; - - usbmisc2: usbmisc@4c200200 { - compatible = "fsl,imx8mm-usbmisc", "fsl,imx7d-usbmisc", - "fsl,imx6q-usbmisc"; - reg = <0x4c200200 0x200>; - #index-cells = <1>; - }; - }; -}; diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index b79485f1f75..ea42c4980ed 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -15,6 +15,7 @@ config IMX9 select BINMAN select HAS_CAAM select ROM_UNIFIED_SECTIONS + imply OF_UPSTREAM
config IMX93 bool diff --git a/configs/imx93-phyboard-segin_defconfig b/configs/imx93-phyboard-segin_defconfig index 54215c51c08..2db19d6f1cd 100644 --- a/configs/imx93-phyboard-segin_defconfig +++ b/configs/imx93-phyboard-segin_defconfig @@ -11,7 +11,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x700000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-phyboard-segin" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-phyboard-segin" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_AHAB_BOOT=y CONFIG_TARGET_PHYCORE_IMX93=y diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index 63613477c7f..a671de7ca40 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_TARGET_IMX93_11X11_EVK=y CONFIG_SYS_MONITOR_LEN=524288 diff --git a/configs/imx93_11x11_evk_ld_defconfig b/configs/imx93_11x11_evk_ld_defconfig index 4e3bbdd0cf5..4e1f162e35a 100644 --- a/configs/imx93_11x11_evk_ld_defconfig +++ b/configs/imx93_11x11_evk_ld_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x400000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_IMX9_LOW_DRIVE_MODE=y CONFIG_TARGET_IMX93_11X11_EVK=y diff --git a/configs/imx93_var_som_defconfig b/configs/imx93_var_som_defconfig index 996cad4854a..15896a68efe 100644 --- a/configs/imx93_var_som_defconfig +++ b/configs/imx93_var_som_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-var-som-symphony" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-var-som-symphony" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_AHAB_BOOT=y CONFIG_TARGET_IMX93_VAR_SOM=y diff --git a/include/dt-bindings/clock/imx93-clock.h b/include/dt-bindings/clock/imx93-clock.h deleted file mode 100644 index 35a1f62053a..00000000000 --- a/include/dt-bindings/clock/imx93-clock.h +++ /dev/null @@ -1,208 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ OR MIT */ -/* - * Copyright 2022 NXP - */ - -#ifndef __DT_BINDINGS_CLOCK_IMX93_CLK_H -#define __DT_BINDINGS_CLOCK_IMX93_CLK_H - -#define IMX93_CLK_DUMMY 0 -#define IMX93_CLK_24M 1 -#define IMX93_CLK_EXT1 2 -#define IMX93_CLK_SYS_PLL_PFD0 3 -#define IMX93_CLK_SYS_PLL_PFD0_DIV2 4 -#define IMX93_CLK_SYS_PLL_PFD1 5 -#define IMX93_CLK_SYS_PLL_PFD1_DIV2 6 -#define IMX93_CLK_SYS_PLL_PFD2 7 -#define IMX93_CLK_SYS_PLL_PFD2_DIV2 8 -#define IMX93_CLK_AUDIO_PLL 9 -#define IMX93_CLK_VIDEO_PLL 10 -#define IMX93_CLK_A55_PERIPH 11 -#define IMX93_CLK_A55_MTR_BUS 12 -#define IMX93_CLK_A55 13 -#define IMX93_CLK_M33 14 -#define IMX93_CLK_BUS_WAKEUP 15 -#define IMX93_CLK_BUS_AON 16 -#define IMX93_CLK_WAKEUP_AXI 17 -#define IMX93_CLK_SWO_TRACE 18 -#define IMX93_CLK_M33_SYSTICK 19 -#define IMX93_CLK_FLEXIO1 20 -#define IMX93_CLK_FLEXIO2 21 -#define IMX93_CLK_LPTMR1 24 -#define IMX93_CLK_LPTMR2 25 -#define IMX93_CLK_TPM2 27 -#define IMX93_CLK_TPM4 29 -#define IMX93_CLK_TPM5 30 -#define IMX93_CLK_TPM6 31 -#define IMX93_CLK_FLEXSPI1 32 -#define IMX93_CLK_CAN1 33 -#define IMX93_CLK_CAN2 34 -#define IMX93_CLK_LPUART1 35 -#define IMX93_CLK_LPUART2 36 -#define IMX93_CLK_LPUART3 37 -#define IMX93_CLK_LPUART4 38 -#define IMX93_CLK_LPUART5 39 -#define IMX93_CLK_LPUART6 40 -#define IMX93_CLK_LPUART7 41 -#define IMX93_CLK_LPUART8 42 -#define IMX93_CLK_LPI2C1 43 -#define IMX93_CLK_LPI2C2 44 -#define IMX93_CLK_LPI2C3 45 -#define IMX93_CLK_LPI2C4 46 -#define IMX93_CLK_LPI2C5 47 -#define IMX93_CLK_LPI2C6 48 -#define IMX93_CLK_LPI2C7 49 -#define IMX93_CLK_LPI2C8 50 -#define IMX93_CLK_LPSPI1 51 -#define IMX93_CLK_LPSPI2 52 -#define IMX93_CLK_LPSPI3 53 -#define IMX93_CLK_LPSPI4 54 -#define IMX93_CLK_LPSPI5 55 -#define IMX93_CLK_LPSPI6 56 -#define IMX93_CLK_LPSPI7 57 -#define IMX93_CLK_LPSPI8 58 -#define IMX93_CLK_I3C1 59 -#define IMX93_CLK_I3C2 60 -#define IMX93_CLK_USDHC1 61 -#define IMX93_CLK_USDHC2 62 -#define IMX93_CLK_USDHC3 63 -#define IMX93_CLK_SAI1 64 -#define IMX93_CLK_SAI2 65 -#define IMX93_CLK_SAI3 66 -#define IMX93_CLK_CCM_CKO1 67 -#define IMX93_CLK_CCM_CKO2 68 -#define IMX93_CLK_CCM_CKO3 69 -#define IMX93_CLK_CCM_CKO4 70 -#define IMX93_CLK_HSIO 71 -#define IMX93_CLK_HSIO_USB_TEST_60M 72 -#define IMX93_CLK_HSIO_ACSCAN_80M 73 -#define IMX93_CLK_HSIO_ACSCAN_480M 74 -#define IMX93_CLK_ML_APB 75 -#define IMX93_CLK_ML 76 -#define IMX93_CLK_MEDIA_AXI 77 -#define IMX93_CLK_MEDIA_APB 78 -#define IMX93_CLK_MEDIA_LDB 79 -#define IMX93_CLK_MEDIA_DISP_PIX 80 -#define IMX93_CLK_CAM_PIX 81 -#define IMX93_CLK_MIPI_TEST_BYTE 82 -#define IMX93_CLK_MIPI_PHY_CFG 83 -#define IMX93_CLK_ADC 84 -#define IMX93_CLK_PDM 85 -#define IMX93_CLK_TSTMR1 86 -#define IMX93_CLK_TSTMR2 87 -#define IMX93_CLK_MQS1 88 -#define IMX93_CLK_MQS2 89 -#define IMX93_CLK_AUDIO_XCVR 90 -#define IMX93_CLK_SPDIF 91 -#define IMX93_CLK_ENET 92 -#define IMX93_CLK_ENET_TIMER1 93 -#define IMX93_CLK_ENET_TIMER2 94 -#define IMX93_CLK_ENET_REF 95 -#define IMX93_CLK_ENET_REF_PHY 96 -#define IMX93_CLK_I3C1_SLOW 97 -#define IMX93_CLK_I3C2_SLOW 98 -#define IMX93_CLK_USB_PHY_BURUNIN 99 -#define IMX93_CLK_PAL_CAME_SCAN 100 -#define IMX93_CLK_A55_GATE 101 -#define IMX93_CLK_CM33_GATE 102 -#define IMX93_CLK_ADC1_GATE 103 -#define IMX93_CLK_WDOG1_GATE 104 -#define IMX93_CLK_WDOG2_GATE 105 -#define IMX93_CLK_WDOG3_GATE 106 -#define IMX93_CLK_WDOG4_GATE 107 -#define IMX93_CLK_WDOG5_GATE 108 -#define IMX93_CLK_SEMA1_GATE 109 -#define IMX93_CLK_SEMA2_GATE 110 -#define IMX93_CLK_MU_A_GATE 111 -#define IMX93_CLK_MU_B_GATE 112 -#define IMX93_CLK_EDMA1_GATE 113 -#define IMX93_CLK_EDMA2_GATE 114 -#define IMX93_CLK_FLEXSPI1_GATE 115 -#define IMX93_CLK_GPIO1_GATE 116 -#define IMX93_CLK_GPIO2_GATE 117 -#define IMX93_CLK_GPIO3_GATE 118 -#define IMX93_CLK_GPIO4_GATE 119 -#define IMX93_CLK_FLEXIO1_GATE 120 -#define IMX93_CLK_FLEXIO2_GATE 121 -#define IMX93_CLK_LPIT1_GATE 122 -#define IMX93_CLK_LPIT2_GATE 123 -#define IMX93_CLK_LPTMR1_GATE 124 -#define IMX93_CLK_LPTMR2_GATE 125 -#define IMX93_CLK_TPM1_GATE 126 -#define IMX93_CLK_TPM2_GATE 127 -#define IMX93_CLK_TPM3_GATE 128 -#define IMX93_CLK_TPM4_GATE 129 -#define IMX93_CLK_TPM5_GATE 130 -#define IMX93_CLK_TPM6_GATE 131 -#define IMX93_CLK_CAN1_GATE 132 -#define IMX93_CLK_CAN2_GATE 133 -#define IMX93_CLK_LPUART1_GATE 134 -#define IMX93_CLK_LPUART2_GATE 135 -#define IMX93_CLK_LPUART3_GATE 136 -#define IMX93_CLK_LPUART4_GATE 137 -#define IMX93_CLK_LPUART5_GATE 138 -#define IMX93_CLK_LPUART6_GATE 139 -#define IMX93_CLK_LPUART7_GATE 140 -#define IMX93_CLK_LPUART8_GATE 141 -#define IMX93_CLK_LPI2C1_GATE 142 -#define IMX93_CLK_LPI2C2_GATE 143 -#define IMX93_CLK_LPI2C3_GATE 144 -#define IMX93_CLK_LPI2C4_GATE 145 -#define IMX93_CLK_LPI2C5_GATE 146 -#define IMX93_CLK_LPI2C6_GATE 147 -#define IMX93_CLK_LPI2C7_GATE 148 -#define IMX93_CLK_LPI2C8_GATE 149 -#define IMX93_CLK_LPSPI1_GATE 150 -#define IMX93_CLK_LPSPI2_GATE 151 -#define IMX93_CLK_LPSPI3_GATE 152 -#define IMX93_CLK_LPSPI4_GATE 153 -#define IMX93_CLK_LPSPI5_GATE 154 -#define IMX93_CLK_LPSPI6_GATE 155 -#define IMX93_CLK_LPSPI7_GATE 156 -#define IMX93_CLK_LPSPI8_GATE 157 -#define IMX93_CLK_I3C1_GATE 158 -#define IMX93_CLK_I3C2_GATE 159 -#define IMX93_CLK_USDHC1_GATE 160 -#define IMX93_CLK_USDHC2_GATE 161 -#define IMX93_CLK_USDHC3_GATE 162 -#define IMX93_CLK_SAI1_GATE 163 -#define IMX93_CLK_SAI2_GATE 164 -#define IMX93_CLK_SAI3_GATE 165 -#define IMX93_CLK_MIPI_CSI_GATE 166 -#define IMX93_CLK_MIPI_DSI_GATE 167 -#define IMX93_CLK_LVDS_GATE 168 -#define IMX93_CLK_LCDIF_GATE 169 -#define IMX93_CLK_PXP_GATE 170 -#define IMX93_CLK_ISI_GATE 171 -#define IMX93_CLK_NIC_MEDIA_GATE 172 -#define IMX93_CLK_USB_CONTROLLER_GATE 173 -#define IMX93_CLK_USB_TEST_60M_GATE 174 -#define IMX93_CLK_HSIO_TROUT_24M_GATE 175 -#define IMX93_CLK_PDM_GATE 176 -#define IMX93_CLK_MQS1_GATE 177 -#define IMX93_CLK_MQS2_GATE 178 -#define IMX93_CLK_AUD_XCVR_GATE 179 -#define IMX93_CLK_SPDIF_GATE 180 -#define IMX93_CLK_HSIO_32K_GATE 181 -#define IMX93_CLK_ENET1_GATE 182 -#define IMX93_CLK_ENET_QOS_GATE 183 -#define IMX93_CLK_SYS_CNT_GATE 184 -#define IMX93_CLK_TSTMR1_GATE 185 -#define IMX93_CLK_TSTMR2_GATE 186 -#define IMX93_CLK_TMC_GATE 187 -#define IMX93_CLK_PMRO_GATE 188 -#define IMX93_CLK_32K 189 -#define IMX93_CLK_SAI1_IPG 190 -#define IMX93_CLK_SAI2_IPG 191 -#define IMX93_CLK_SAI3_IPG 192 -#define IMX93_CLK_MU1_A_GATE 193 -#define IMX93_CLK_MU1_B_GATE 194 -#define IMX93_CLK_MU2_A_GATE 195 -#define IMX93_CLK_MU2_B_GATE 196 -#define IMX93_CLK_NIC_AXI 197 -#define IMX93_CLK_ARM_PLL 198 -#define IMX93_CLK_A55_SEL 199 -#define IMX93_CLK_A55_CORE 200 -#define IMX93_CLK_END 201 - -#endif diff --git a/include/dt-bindings/power/fsl,imx93-power.h b/include/dt-bindings/power/fsl,imx93-power.h deleted file mode 100644 index 17f9f015bf7..00000000000 --- a/include/dt-bindings/power/fsl,imx93-power.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ -/* - * Copyright 2022 NXP - */ - -#ifndef __DT_BINDINGS_IMX93_POWER_H__ -#define __DT_BINDINGS_IMX93_POWER_H__ - -#define IMX93_MEDIABLK_PD_MIPI_DSI 0 -#define IMX93_MEDIABLK_PD_MIPI_CSI 1 -#define IMX93_MEDIABLK_PD_PXP 2 -#define IMX93_MEDIABLK_PD_LCDIF 3 -#define IMX93_MEDIABLK_PD_ISI 4 - -#endif
Hello,
Mathieu: please help test the boards you maintain when you have time.
I have tried both imx93_var_som and imx93-phyboard-segin configurations. Compilation works but I only get garbage on the UART on those two different boards.
I will try to conduct further investigations later on, but the booting test is KO here.
Thanks,
Mathieu
Any comments?
Thanks, Peng.
Subject: [PATCH v4 0/5] imx93: Conver to OF_UPSTREAM
A few nodes were added to soc and board u-boot.dtsi(lpi2c, usbotg), those nodes could be dropped after upstream linux supports them.
To support OF_UPSTREAM, a few driver changes are included. For TMU, still use U-Boot node, I will prepare a kernel update, then back to U- Boot support.
Thanks, Peng.
To: Sébastien Szymanski sebastien.szymanski@armadeus.com To: Stefano Babic sbabic@denx.de To: Fabio Estevam festevam@gmail.com To: "NXP i.MX U-Boot Team" uboot-imx@nxp.com To: Mathieu Othacehe m.othacehe@gmail.com Cc: u-boot@lists.denx.de Signed-off-by: Peng Fan peng.fan@nxp.com
Changes in v4:
- Convert all i.MX93 boards
- Link to v3: https://lore.kernel.org/r/20240328-imx93-of-v3-0-
4e7f341ed7ea@nxp.com
Changes in v3:
- Update patch 5, to drop the imx8mp-evk changes which are wrongly included
- Link to v2: https://lore.kernel.org/r/20240328-imx93-of-v2-0-
909f5d37da87@nxp.com
Changes in v2:
- Add a new patch to sync clock header to avoid breaking
- Drop the Makefile change which change including order
- Link to v1: https://lore.kernel.org/r/20240327-imx93-of-v1-0-
afab6b31422a@nxp.com
Peng Fan (5): gpio: imx_rgpio2p: support one address serial: lpuart: use ipg clk for i.MX7ULP cpu: drop imx9_cpu clk: imx93: fix anatop base imx93: convert to OF_UPSTREAM
arch/arm/dts/Makefile | 5 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 119 ++++ arch/arm/dts/imx93-11x11-evk.dts | 322 --------- arch/arm/dts/imx93-phyboard-segin.dts | 117 --- arch/arm/dts/imx93-phycore-som.dtsi | 126 ---- arch/arm/dts/imx93-pinfunc.h | 623 ---------------- arch/arm/dts/imx93-u-boot.dtsi | 80 +++ arch/arm/dts/imx93-var-som-symphony-u-boot.dtsi | 22 + arch/arm/dts/imx93-var-som-symphony.dts | 323 --------- arch/arm/dts/imx93-var-som.dtsi | 111 --- arch/arm/dts/imx93.dtsi | 906 ------------------------ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93-phyboard-segin_defconfig | 2 +- configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- configs/imx93_var_som_defconfig | 2 +- drivers/clk/imx/clk-imx93.c | 2 +- drivers/cpu/imx9_cpu.c | 224 ------ drivers/gpio/imx_rgpio2p.c | 42 +- drivers/serial/serial_lpuart.c | 9 +- include/dt-bindings/clock/imx93-clock.h | 208 ------ include/dt-bindings/power/fsl,imx93-power.h | 15 - 22 files changed, 273 insertions(+), 2990 deletions(-)
base-commit: 280f34ba7d68bb50c0b8eaa040322c1f3b37d46e change-id: 20240328-imx93-of-v2-f879efef737d
Any comments?
Yes, see: https://lists.denx.de/pipermail/u-boot/2024-March/549531.html
Thanks,
Mathieu
Hi Mathieu,
Subject: Re: [PATCH v4 0/5] imx93: Conver to OF_UPSTREAM
Any comments?
Yes, see:
Sorry, I missed your comment.
From my test just now, log below. For your uart not work proper, I think it is
the uart clk not setup
U-Boot SPL 2024.04-rc5-00388-g351988e2dce (Apr 07 2024 - 19:29:56 +0800) SOC: 0xa1009300 LC: 0x2040010 M33 prepare ok Normal Boot Trying to boot from BOOTROM Boot Stage: Primary boot image offset 0x8000, pagesize 0x200, ivt offset 0x0 Load image from 0x49800 by ROM_API NOTICE: BL31: v2.8(release):lf-6.6.3-1.0.0-10-gf12d90141 NOTICE: BL31: Built : 09:34:44, Mar 27 2024
U-Boot 2024.04-rc5-00388-g351988e2dce (Apr 07 2024 - 19:29:56 +0800)
Reset Status: POR
Could not read CPU frequency: -2 CPU: NXP i.MX93(52) Rev1.1 A55 at 0 MHz CPU: Industrial temperature grade (-40C to 105C) at 26C
Model: NXP i.MX93 11X11 EVK board DRAM: 2 GiB Core: 188 devices, 24 uclasses, devicetree: separate WDT: Started watchdog@42490000 with servicing every 1000ms (40s timeout) MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@44380000 Out: serial@44380000 Err: serial@44380000 switch to partitions #0, OK mmc1 is current device Net: Warning: ethernet@428a0000 (eth1) using random MAC address - 6a:c2:96:d2:68:a6 eth0: ethernet@42890000 [PRIME], eth1: ethernet@428a0000 Hit any key to stop autoboot: 0
I see you have: &lpuart1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; clocks = <&clk IMX93_CLK_LPUART1_GATE>, <&clk IMX93_CLK_LPUART1_GATE>; clock-names = "ipg", "per"; status = "okay"; };
Could you please help give a look on your uart settings which not work with: https://lore.kernel.org/all/20240328-imx93-of-v2-v4-2-338d15a65c36@nxp.com/
Thanks, Peng.
https://lists.d/ enx.de%2Fpipermail%2Fu-boot%2F2024- March%2F549531.html&data=05%7C02%7Cpeng.fan%40nxp.com%7C46ad4 24ef2cb4c09f8b908dc56edad0a%7C686ea1d3bc2b4c6fa92cd99c5c301635% 7C0%7C0%7C638480826025692986%7CUnknown%7CTWFpbGZsb3d8eyJWI joiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C 0%7C%7C%7C&sdata=9oXIZF8Ihp1OfaDx3C%2Bcq9nstWJVhN8u3U7xQAhX2 2o%3D&reserved=0
Thanks,
Mathieu
Hi Mathieu,
Subject: RE: [PATCH v4 0/5] imx93: Conver to OF_UPSTREAM
Hi Mathieu,
Any comments?
Yes, see:
Could you please help try this on top of this patchset? Seems this is the only point I could think of, that would impact uart.
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index 653ff99e67b..891352293f9 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -486,19 +486,22 @@ static int lpuart_serial_pending(struct udevice *dev, bool input) static int lpuart_serial_probe(struct udevice *dev) { #if CONFIG_IS_ENABLED(CLK) + struct lpuart_serial_plat *plat = dev_get_plat(dev); struct clk per_clk; struct clk ipg_clk; int ret;
- ret = clk_get_by_name(dev, "per", &per_clk); - if (!ret) { - ret = clk_enable(&per_clk); - if (ret) { - dev_err(dev, "Failed to enable per clk: %d\n", ret); - return ret; + if (plat->devtype != DEV_MX7ULP) { + ret = clk_get_by_name(dev, "per", &per_clk); + if (!ret) { + ret = clk_enable(&per_clk); + if (ret) { + dev_err(dev, "Failed to enable per clk: %d\n", ret); + return ret; + } + } else { + debug("%s: Failed to get per clk: %d\n", __func__, ret); } - } else { - debug("%s: Failed to get per clk: %d\n", __func__, ret); }
ret = clk_get_by_name(dev, "ipg", &ipg_clk);
Thanks, Peng.
From my test just now, log below. For your uart not work proper, I think it is the uart clk not setup
Reset Status: POR
Could you please help give a look on your uart settings which not work with: https://lore.kernel.org/all/20240328-imx93-of-v2-v4-2- 338d15a65c36@nxp.com/
Thanks, Peng.
2o%3D&reserved=0
Thanks,
Mathieu
Hi Peng,
Here are some comments unrelated to the UART issue.
Could you remove these three lines?
They are not very helpful and add noise to the boot log.
Reset Status: POR
Please fix this. I am sure the CPU is not running at 0 MHz :-)
Aren't the MAC address fuses programmed? Or are they not being read correctly?
Hi Peng,
Ok. But these should not be related to this patchset.
Reset Status: POR
Yes, I will fix . Also not related to this patchset.
timeout)
I will check, but I think not related to this patchset.
Thanks, Peng.
Yes, that's why my first sentence was:
"Here are some comments unrelated to the UART issue."
Thanks for taking a look at these issues.
Hello Peng,
Some minor nitpicks... s/Conver to/Convert to/ in the patch subject, and a couple more below.
s/soc/SoC/
s/linux/Linux/
To support OF_UPSTREAM, a few driver changes are included. For TMU, still use U-Boot node, I will prepare a kernel update, then back to U-Boot support.
Thanks, Peng.
Changes in v4:
- Link to v3:
https://lore.kernel.org/r/20240328-imx93-of-v3-0-4e7f341ed7ea@nxp.com
Changes in v3:
- Link to v2:
https://lore.kernel.org/r/20240328-imx93-of-v2-0-909f5d37da87@nxp.com
Changes in v2:
- Link to v1:
https://lore.kernel.org/r/20240327-imx93-of-v1-0-afab6b31422a@nxp.com
Hello Peng,
s/soc/SoC/
s/linux/Linux/
Will fix all the typos in V5.
Thanks, Peng.
Thanks, Peng.
Changes in v4:
- Link to v3:
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flore .kernel.org%2Fr%2F20240328-imx93-of-v3-0-
4e7f341ed7ea%40nxp.com&data=0
5%7C02%7Cpeng.fan%40nxp.com%7Cfb4cf5cd6eb048f7004508dc5724921f %7C686ea
1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C638481061784727166%7CU nknown%7CT
WFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLC JXVCI
6Mn0%3D%7C0%7C%7C%7C&sdata=m3eUSDFipFRBJlujTzNovsgusVTRp8lekD guNKKGlq8
%3D&reserved=0
Changes in v3:
- Link to v2:
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flore .kernel.org%2Fr%2F20240328-imx93-of-v2-0-
909f5d37da87%40nxp.com&data=0
1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C638481061784740481%7CU nknown%7CT
6Mn0%3D%7C0%7C%7C%7C&sdata=dOltsehRiqbWFgRABoeC1nUqbU5CTz2 OOt6Yq7u9sj0
%3D&reserved=0
Changes in v2:
- Link to v1:
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flore .kernel.org%2Fr%2F20240327-imx93-of-v1-0-
afab6b31422a%40nxp.com&data=0
1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C638481061784750001%7CU nknown%7CT
6Mn0%3D%7C0%7C%7C%7C&sdata=x4s291DNECLAyKaOdMRse2CLfFwaSx8Z %2BCdLZZrYV
mY%3D&reserved=0
participants (5)
Dragan Simic
Fabio Estevam
Mathieu Othacehe
Peng Fan
Peng Fan (OSS)
