[U-Boot] [PATCH BUGFIX] net: fec_mxc: adjust prototype of fec_get_miibus() for DM_ETH
commit 306dd7dabd64 ("net: fec_mxc: fix PHY initialization bug with CONFIG_DM_ETH") has broken the build of the fec_mxc driver with CONFIG_DM_ETH enabled because it changed the parameters passed to *fec_get_miibus() without changing the functions prototype.
This patch fixes up the prototype of fec_get_miibus() for the DM_ETH case.
Signed-off-by: Lothar Waßmann LW@KARO-electronics.de --- drivers/net/fec_mxc.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 4ad4ddc..e42d54b 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -985,9 +985,18 @@ static void fec_free_descs(struct fec_priv *fec) free(fec->tbd_base); }
+#ifdef CONFIG_DM_ETH +struct mii_dev *fec_get_miibus(struct udevice *dev, int dev_id) +#else struct mii_dev *fec_get_miibus(uint32_t base_addr, int dev_id) +#endif { +#ifdef CONFIG_DM_ETH + struct fec_priv *priv = dev_get_priv(dev); + struct ethernet_regs *eth = priv->eth; +#else struct ethernet_regs *eth = (struct ethernet_regs *)base_addr; +#endif struct mii_dev *bus; int ret;
Is it enough ? fec_get_miibus prototype is in include/netdev.h.
- struct fec_priv *priv = dev_get_priv(dev);
- struct ethernet_regs *eth = priv->eth;
Best regards, Stefano
Sorry, I missed the include file when splitting the patch out into another working directory. I'll resend a corrected version.
Lothar Waßmann
Signed-off-by: Lothar Waßmann LW@KARO-electronics.de --- Changes vs. v1: added missing prototype change in netdev.h
drivers/net/fec_mxc.c | 9 +++++++++ include/netdev.h | 5 +++++ 2 files changed, 14 insertions(+)
diff --git a/include/netdev.h b/include/netdev.h index c06b908..b9bfeba 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -130,7 +130,12 @@ static inline int pci_eth_init(bd_t *bis) return num; }
+#ifdef CONFIG_DM_ETH +struct mii_dev *fec_get_miibus(struct udevice *dev, int dev_id); +#else struct mii_dev *fec_get_miibus(uint32_t base_addr, int dev_id); +#endif + #ifdef CONFIG_PHYLIB struct phy_device; int fec_probe(bd_t *bd, int dev_id, uint32_t base_addr,
Hi Lothar,
Applied to u-boot-imx, -master, thanks !
Best regards, Stefano Babic
Lothar Waßmann
Stefano Babic
