[U-Boot] [PATCH] da850/omap-l138: enable SPI flash in RMII mode
According to DA850/OMAP-L138 schematics, GP2[6] line has to be driven high for RMII mode to work. In RMII mode, SPI flash becomes un-usable. But during testing it was found out that, driving GP2[6] low also enables RMII and in this configuration SPI flash is also accessible.
Signed-off-by: Rajashekhara, Sudhakar sudhakar.raj@ti.com Signed-off-by: Lad, Prabhakar prabhakar.lad@ti.com Signed-off-by: Hadli, Manjunath manjunath.hadli@ti.com --- board/davinci/da8xxevm/da850evm.c | 6 +++--- 1 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index 004d5ad..82d707f 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -438,10 +438,10 @@ int rmii_hw_init(void) CONFIG_SYS_I2C_EXPANDER_ADDR); }
- /* Set the output as high */ - temp = REG(GPIO_BANK2_REG_SET_ADDR); + /* Set the output as low */ + temp = REG(GPIO_BANK2_REG_CLR_ADDR); temp |= (0x01 << 6); - REG(GPIO_BANK2_REG_SET_ADDR) = temp; + REG(GPIO_BANK2_REG_CLR_ADDR) = temp;
/* Set the GPIO direction as output */ temp = REG(GPIO_BANK2_REG_DIR_ADDR);
How about just removing all the code that is related to GP2[6]? There's a pull-down resistor on the board and the pin is high impedance by default.
Regards, Christian
- /* Set the output as low */
- temp = REG(GPIO_BANK2_REG_CLR_ADDR);
- REG(GPIO_BANK2_REG_CLR_ADDR) = temp;
/* Set the GPIO direction as output */ temp = REG(GPIO_BANK2_REG_DIR_ADDR); -- 1.7.4.1
Hi Christian,
Yes, this patch is not required I'll drop this patch.
Thx, --Prabhakar Lad
Regards, Christian
Christian Riesch
Lad, Prabhakar
Prabhakar Lad
