[PATCH v4] disk: dos: Add all options for EFI System Partitions
The EFI spec states that the ESP can be any of FAT12/16/32 but for compatibility doesn't necssarily require the partition to be the EFI partition table ID of 0xef. A number of arm devices will not find their firmware on a FAT partition with an ID of 0xef so also allow the original FAT12/16/32 partition IDs as they are also permissable for an ESP.
Signed-off-by: Peter Robinson pbrobinson@gmail.com ---
v2: - Add 0x0c option - Make hex constants consistent - Move from if to switch statement v3: - Fix switch brain fart v4: - Drop boot_ind out of switch
disk/part_dos.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/disk/part_dos.c b/disk/part_dos.c index 567ead7511d..a35181dff4f 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -40,10 +40,21 @@ static int get_bootable(dos_partition_t *p) { int ret = 0;
- if (p->sys_ind == 0xef) + switch (p->sys_ind) { + case 0x01: + case 0x06: + case 0x0b: + case 0x0c: + case 0xef: ret |= PART_EFI_SYSTEM_PARTITION; + break; + default: + break; + } + if (p->boot_ind == 0x80) ret |= PART_BOOTABLE; + return ret; }
From: Peter Robinson pbrobinson@gmail.com Date: Sat, 2 Mar 2024 11:20:31 +0000
Reviewed-by: Mark Kettenis kettenis@openbsd.org
v2:
- Add 0x0c option
v3:
v4:
- switch (p->sys_ind) {
- case 0x01:
- case 0x06:
- case 0x0b:
- case 0x0c:
- case 0xef: ret |= PART_EFI_SYSTEM_PARTITION;
break;
- default:
break;
- if (p->boot_ind == 0x80) ret |= PART_BOOTABLE;
- return ret;
-- 2.44.0
v2:
- Add 0x0c option
v3:
v4:
case 0x01:
case 0x06:
case 0x0b:
case 0x0c:
break;
default:
break;
return ret;
-- 2.44.0
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Signed-off-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Mark Kettenis kettenis@openbsd.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
This leads to these failures in CI: https://source.denx.de/u-boot/u-boot/-/jobs/794519#L598
Ilias Apalodimas
Mark Kettenis
Peter Robinson
