[U-Boot] [PATCH v2 2/8] armv8: Add workaround for USB erratum A-009798
The default setting for USB High Speed Squelch Threshold results in a threshold close to or lower than 100mV. This leads to Receiver Compliance test failure for a 100mV threshold.
The changes shift the threshold from ~100mV towards ~130mV resulting in passing of USB High Speed Receiver Sensitivity Compliance test
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Suresh Gupta suresh.gupta@nxp.com --- Changes in v2: None
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 6 ++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 21 +++++++++++++++++++++ .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 1 + .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 1 + 4 files changed, 29 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 666a3d1..10daaa2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -19,6 +19,7 @@ config ARCH_LS1043A select SYS_FSL_ERRATUM_A010315 select SYS_FSL_ERRATUM_A010539 select SYS_FSL_ERRATUM_A009008 + select SYS_FSL_ERRATUM_A009798 select SYS_FSL_HAS_DDR3 select SYS_FSL_HAS_DDR4
@@ -35,6 +36,7 @@ config ARCH_LS1046A select SYS_FSL_ERRATUM_A010165 select SYS_FSL_ERRATUM_A010539 select SYS_FSL_ERRATUM_A009008 + select SYS_FSL_ERRATUM_A009798 select SYS_FSL_HAS_DDR4 select SYS_FSL_SRDS_2
@@ -61,6 +63,7 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010165 select SYS_FSL_ERRATUM_A009008 + select SYS_FSL_ERRATUM_A009798
config FSL_LSCH2 bool @@ -108,6 +111,9 @@ config SYS_FSL_ERRATUM_A010539 config SYS_FSL_ERRATUM_A009008 bool "Workaround for USB PHY erratum A009008"
+config SYS_FSL_ERRATUM_A009798 + bool "Workaround for USB PHY erratum A009798" + config MAX_CPUS int "Maximum number of CPUs permitted for Layerscape" default 4 if ARCH_LS1043A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 951ccba..910f345 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -75,6 +75,25 @@ static void erratum_a009008(void) #endif /* CONFIG_SYS_FSL_ERRATUM_A009008 */ }
+static void erratum_a009798(void) +{ +#ifdef CONFIG_SYS_FSL_ERRATUM_A009798 +#if defined(CONFIG_LS1043A) || defined(CONFIG_LS1046A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB1 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB1 / 4 , val & USB_SQRXTUNE); + val = gur_in32(scfg + SCFG_USB3PRM1CR_USB2 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB2 / 4 , val & USB_SQRXTUNE); + val = scfg_in32(scfg + SCFG_USB3PRM1CR_USB3 / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR_USB3 / 4 , val & USB_SQRXTUNE); +#elif defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + u32 val = scfg_in32(scfg + SCFG_USB3PRM1CR / 4); + scfg_out32(scfg + SCFG_USB3PRM1CR / 4, val & USB_SQRXTUNE); +#endif +#endif /* CONFIG_SYS_FSL_ERRATUM_A009798 */ +} + #if defined(CONFIG_FSL_LSCH3) /* * This erratum requires setting a value to eddrtqcr1 to @@ -218,6 +237,7 @@ void fsl_lsch3_early_init_f(void) erratum_a008514(); erratum_a008336(); erratum_a009008(); + erratum_a009798(); #ifdef CONFIG_CHAIN_OF_TRUST /* In case of Secure Boot, the IBR configures the SMMU * to allow only Secure transactions. @@ -395,6 +415,7 @@ void fsl_lsch2_early_init_f(void) erratum_a009660(); erratum_a010539(); erratum_a009008(); + erratum_a009798(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index fe37bc1..ca4a31fe 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -341,6 +341,7 @@ struct ccsr_gur { #define SCFG_USB3PRM1CR_USB2 0x07C #define SCFG_USB3PRM1CR_USB3 0x088 #define USB_TXVREFTUNE 0x9 +#define USB_SQRXTUNE 0xFC7FFFFF
#define SCFG_SNPCNFGCR_SECRDSNP 0x80000000 #define SCFG_SNPCNFGCR_SECWRSNP 0x40000000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 9aad471..d726256 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -138,6 +138,7 @@ #define SCFG_USB3PRM1CR 0x000 #define SCFG_USB3PRM1CR_INIT 0x27672b2a #define USB_TXVREFTUNE 0x9 +#define USB_SQRXTUNE 0xFC7FFFFF #define SCFG_QSPICLKCTLR 0x10
#define TP_ITYP_AV 0x00000001 /* Initiator available */
Suresh Gupta
